Old 15th May 2020, 17:41   #1801  |  Link
almanteka
Originally Posted by Patman View Post
I can compile versions with gcc and msvc (both with avx and avx2) and you can test them.
that would be great!!! i like the M version!
almanteka is offline
Old 15th May 2020, 17:52   #1802  |  Link
stax76
stax76's Avatar
@jonrodrigos
Maybe it's because you don't have a custom path to the included portable python.
stax76 is offline
Old 15th May 2020, 18:21   #1803  |  Link
jonrodrigos
Originally Posted by stax76 View Post
@jonrodrigos
would it be this? if everything is already pointing to the internal portable
and I had uninstalled the installs
I also did it on a clean windows installation, pointing only to the portable
jonrodrigos is offline
Old 16th May 2020, 07:01   #1804  |  Link
VirulentPip
For a while now I've been using Turing Nvenc my encodes (1080p) I have just got a Ryzen 3900x and was wondering if there's any settings out there I can use that would get me the same quality output but for potentially less bitrate/file sizes?
This is what I use for 1080p Blurays
--vbrhq 4400 --codec h265 --preset quality --profile main10 --level 5.1 --output-depth 10 --max-bitrate 4400 --aq --aq-temporal --bref-mode each --bframes 5 --ref 15 --gop-len 240 --lookahead 32 --output-buf 32 --vpp-unsharp radius=2,weight=0.65,threshold=20 --vpp-edgelevel strength=6.0,threshold=16.0,black=0,white=0
And this for older Blurays with a lot of noise
--vbrhq 4400 --codec h265 --preset quality --profile main10 --level 5.1 --output-depth 10 --max-bitrate 4400 --aq --aq-temporal --bref-mode each --bframes 5 --ref 15 --gop-len 240 --lookahead 32 --output-buf 32 --vpp-knn --vpp-unsharp radius=2,weight=0.65,threshold=20 --vpp-edgelevel strength=6.0,threshold=16.0,black=0,white=0
Should I change over to x265 or continue with Nvenc and is there anything I should change?
If anyone could point me in the right direction that would be great
VirulentPip is offline
Old 16th May 2020, 19:39   #1805  |  Link
colinhunt
Could someone provide me with some pointers on how to enable FFV1 version 3 encoding (-c:v ffv1 -level 3) in Staxrip, using ffmpeg of course? I can't figure out how to add it to encoding options. Using beta 2.1.1.1, btw. Thanks.
colinhunt is offline
Old 16th May 2020, 20:02   #1806  |  Link
Patman
Patman's Avatar
updated some tools for staxrip...
Tools for StaxRip | x264 - x265
Patman is offline
Old 16th May 2020, 20:48   #1807  |  Link
Patman
Patman's Avatar
Currently this is only possible with the command line.
Patman is offline
Old 16th May 2020, 21:39   #1808  |  Link
colinhunt
Okay, thanks. No wonder I couldn't figure it out
Old 17th May 2020, 01:15   #1809  |  Link
almanteka
whats the difference between an msvc version and gcc? method of compiling? same results? thanks!
Old 17th May 2020, 09:34   #1810  |  Link
Arkana
Originally Posted by almanteka View Post
staxrip recognized the location? go to apps > manage > on the left list avisynth > KNLMeansCL > status OK? the same for vapoursynth: apps > manage > on the left list vapoursynth> KNLMeansCL > status OK? if not, then go to path > browse and locate the file manually for avisynth and vapoursynth
StaxRip folder\Apps\Plugins\Dual\KNLMeansCL\KNLMeansCL.dll
both status are OK
Arkana is offline
Old 17th May 2020, 09:49   #1811  |  Link
stax76
stax76's Avatar
@Arkana
Which GPU is in use?
stax76 is offline
Old 17th May 2020, 10:28   #1812  |  Link
colinhunt
Staxrip 2.1.1.1 beta stops processing on an error before writing a single frame when trying to output ProRes. Same job works fine in 2.0.8.0 Stable (edit: after it prompted to install Avisynth). I'll add what little information I can gather of the crash shortly.
Job: deinterlacing and IVTC'ing a music video.
TFM()
TDecimate(cycle=25,cycleR=5)
DeBlock QED (defaults)
VagueDeNoiser (defaults)
Output to ProRes normal profile.
update: Figured out why 2.1.1.1 beta throws in the towel. Avisynth+ was not installed. Odd though, I have done perhaps two dozen jobs on 2.1.1.1 and it never complained about Avisynth missing. I ran 2.0.8.0 the first time on this PC today; it told me to install Avisynth, and once I did that, 2.1.1.1 began outputting ProRes as well.
(Sidetrack: Could someone shed some light on why the CPU load remains at 4% for the job mentioned above? I get 10fps out of StaxRip with that 4%. Would be awesome to get the job done faster; where's the bottleneck?)
Old 17th May 2020, 10:53   #1813  |  Link
Patman
Patman's Avatar
MSVC (Microsoft Visual C) and GCC (GNU Compiler Collection) are different compilers. You are right with the statement that the methods of compiling are different. As a result, there are performance differences in the builds.
Patman is offline
Old 17th May 2020, 12:24   #1814  |  Link
stax76
stax76's Avatar
@colinhunt
2.1.1.3 is portable, I've not installed avisynth or fftw, tried all your configuration and it worked fine.
stax76 is offline
Old 17th May 2020, 16:00   #1815  |  Link
Khun_Doug
A lot of AVISynth filters perform really well when using PreFetch. Look through the menus and for the MT Mode stuff and you should find the option to set the number of threads (that's the prefetch). If you have 8 threads on your CPU, try setting PreFetch to 4, or 6, or even 8. You can really get a remarkable speed bump this way.
One note: I have an AMD 3950X with 16 cores / 32 threads. I found the sweet spot to be between 12 and 16 threads when using X265. Just because you have a lot of threads does not mean you will get a speed bump beyond a certain point.
Khun_Doug is offline
Old 17th May 2020, 16:03   #1816  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
The rule is simple. Always use value equal to number of physical cores not virtual ones. With higher value than number of cores you will notice choking effect. (cpu usage drops constantly)
Atak_Snajpera is offline
Old 17th May 2020, 17:36   #1817  |  Link
jlw_4049
@stax76 is there anyway to setup the program to where the video bitrate is tied to (x264/x265) preset instead of the template? Similar to how the CRF value is tied to it?
jlw_4049 is offline
Old 17th May 2020, 17:50   #1818  |  Link
stax76
stax76's Avatar
In the x265 dialog the Custom tab can be used for this, custom switches override GUI switches.
stax76 is offline
Old 17th May 2020, 17:53   #1819  |  Link
jlw_4049
Thank you for this information!
@stax76 - I know you are busy with tons of stuff. IDK if you would want to do this, but could you add a way to setup more then just 2 audio tracks. For those rare films/etc where there is 3 or 4 of them?
Also is there anyway you could add a DTS down mix to core option for the audio section? You can do this with ffmpeg via a command like this "-c:v copy -bsf:a dca_core -c:a copy" and I know there is a way to do it with mkv.
Thanks!
jlw_4049 is offline
Old 17th May 2020, 19:12   #1820  |  Link
stax76
stax76's Avatar
If you are not batch processing you can add more audio tracks in the Container Options, it has an audio Tab.
For that I would need more info, ideally on the issue tracker, mediainfo for the input file, command line and mediainfo for the output file.
stax76 is offline
aac, hdr, hevc, nvenc, staxrip, x264, x265
