Old 20th January 2022, 13:20   #61  |  Link
videoh
Useful n00b
Originally Posted by kedautinh12 View Post
Latest ver timecube i think avs ver don't port it
https://github.com/sekrit-twc/timecube
I'll see if there is anything we need in r3.
Old 20th January 2022, 17:36   #62  |  Link
videoh
Useful n00b
Here is a port of r3 to Avisynth. Frame properties passthrough has also been added. Please advise if this is working properly.
http://rationalqm.us/misc/vscube_13.zip
Old 20th January 2022, 21:25   #63  |  Link
Reel.Deel
http://rationalqm.us/misc/vscube_13.rar
Not sure if the file is corrupted or what but I can't open the file, the size is only 34k.
Old 20th January 2022, 21:49   #64  |  Link
videoh
Useful n00b
That's the correct size. Works fine for me. What happens when you try to open it?
Anyone else having problems?
Old 20th January 2022, 21:51   #65  |  Link
Reel.Deel
I can open other rar files just fine, I tried downloading it in a different browser and same problem .
7-Zip
Can not open file 'C:\Users\Downloads\vscube_13.rar' as archive
Edit: not sure was going on but https://extract.me/ opens the file just fine. The rar file has one binary named "vscube.dll".
Old 20th January 2022, 22:24   #66  |  Link
videoh
Useful n00b
That's correct. Is the DLL working?
I deleted the rar and put a zip instead. Is it better?
Old 20th January 2022, 22:28   #67  |  Link
Reel.Deel
Zip works just fine, thanks. I will test it and get back to you if I find any problems.
Old 20th January 2022, 22:32   #68  |  Link
videoh
Useful n00b
Thank you. Could be a RAR versus RAR4/5 thing.
Are you using WinRAR or 7zip?
Old 20th January 2022, 22:40   #69  |  Link
Reel.Deel
I'm using 7zip. I tested the DLL and used a simple LUT and it's working like it is supposed to. Have not checked frame properties.
Old 20th January 2022, 22:43   #70  |  Link
videoh
Useful n00b
OK, thank you.
Old 20th January 2022, 23:12   #71  |  Link
StvG
Thanks. It's working properly here.
StvG is offline   Reply With Quote
Old 21st January 2022, 00:58   #72  |  Link
kedautinh12
That only x86 or x64 ver? Can you support both? I remember old ver support both. Thanks
Old 21st January 2022, 11:00   #73  |  Link
RD,
I just noticed that 7zip posted update Dec 2021,
v19.00 was latest [EDIT: stable] for a long time, then updated in Nov 21 and again in Dec 21,
perhaps part reason was some RAR thingy.
7zip:- https://www.7-zip.org/
EDIT: Non beta, ie stable, v21.07 [26 Dec 2021]
Old 21st January 2022, 11:11   #74  |  Link
Reel.Deel
RD,
You're probably right. My 7-zip was super old. I went ahead and updated. Thanks for pointing that out.
Can you provide the source code please?
Old 21st January 2022, 11:36   #75  |  Link
joearmstrong
The example from Avisynth wiki seems to be wrong:
DGSource("THE GREAT WALL.dgi", fulldepth=true)
z_ConvertFormat(pixel_type="RGBP16", colorspace_op="2020ncl:st2084:2020:l=>rgb:linear:2020:f", dither_type="none")
Cube("...\test.cube")
z_ConvertFormat(pixel_type="YUV420P16", colorspace_op="rgb:linear:2020:f=>2020ncl:st2084:2020:l", dither_type="none")
Converting to linear produces errors. Maybe a bug? Without linear the reults are fine for me:
z_ConvertFormat(pixel_type="RGBP16", colorspace_op="2020ncl:st2084:2020:l=>rgb:st2084:2020:f", dither_type="none")
z_ConvertFormat(pixel_type="YV12", colorspace_op="rgb:st2084:2020:f=>709:709:709:l", dither_type="ordered")
joearmstrong is offline   Reply With Quote
Old 21st January 2022, 11:44   #76  |  Link
Reel.Deel
I copied the example that was included in avscube v1.1. I did not test it nor do I have a lot of experience with hdr. If it's indeed wrong I will update the wiki accordingly.
Old 21st January 2022, 14:17   #77  |  Link
videoh
Useful n00b
Yes, of course. When I release it there will be both versions.
Old 21st January 2022, 14:20   #78  |  Link
videoh
Useful n00b
Yes, of course, when I release it.
Old 21st January 2022, 14:21   #79  |  Link
videoh
Useful n00b
Thank you, I will update the example. Note also that DGSource() no longer takes a fulldepth parameter.
Old 21st January 2022, 14:46   #80  |  Link
videoh
Useful n00b
Released as version 1.3 (to track timecube version):
http://rationalqm.us/board/viewtopic...p=15239#p15239
3dl, cube, hdr, lut, sdr
