Old 15th October 2021, 13:09   #101  |  Link
filler56789
SuperVirus
filler56789's Avatar
Originally Posted by GMJCZP View Post
Won't there be a 32-bit version?
Built, but not tested :/
./configure --enable-shared --enable-float --enable-sse2 --enable-avx --enable-avx2 --disable-fortran --enable-threads --with-combined-threads --with-our-malloc
./configure --enable-shared --enable-long-double --disable-fortran --enable-threads --with-combined-threads --with-our-malloc
https://www.mediafire.com/file/zrrts...32DLLs.7z/file
filler56789 is offline   Reply With Quote
Old 15th October 2021, 13:51   #102  |  Link
GMJCZP
GMJCZP's Avatar
Thanks filler, it's the last version no?
EDIT1: is the last version, thanks.
EDIT2: thanks TinMan for your support.
EDIT3: It works correctly, thanks again filler56789
By law and justice!
GMJCZP's Arsenal
GMJCZP is offline   Reply With Quote
Old 15th October 2021, 14:07   #103  |  Link
yip, thanx filler56789.
Old 15th October 2021, 16:46   #104  |  Link
filler56789
SuperVirus
Great!
Old 23rd October 2021, 07:00   #105  |  Link
kedautinh12
Originally Posted by filler56789 View Post
Built, but not tested :–/
can you build x64 ver?? my fftw 3.3.10 x64 don't work correctly. Thanks
Old 23rd October 2021, 11:42   #106  |  Link
filler56789
SuperVirus
Originally Posted by kedautinh12 View Post
can you build x64 ver?? my fftw 3.3.10 x64 don,t work correctly. Thanks
https://forum.videohelp.com/threads/...ftw-3-3-7-DLLs
third post, .RAR attachment.
Old 23rd October 2021, 11:55   #107  |  Link
kedautinh12
Thanks
Old 11th March 2022, 00:52   #108  |  Link
tormento
Acid fr0g
tormento's Avatar
3.3.10 is out since a bit.
Any build for Windows?
@turment on Telegram
Old 11th March 2022, 02:35   #109  |  Link
Reel.Deel
FFTW-3.3.10-DLLs.rar
From the same thread posted by filler56789.
Old 11th March 2022, 12:26   #110  |  Link
tormento
Acid fr0g
tormento's Avatar
And think that I had also looked at it...
Old 24th December 2023, 12:58   #111  |  Link
ErazorTT
Build for AMD Ryzen owners
AMD has its own compilation of many scientifically used libraries specifically for the Zen architecture.
The official build can be downloaded here: https://www.amd.com/en/developer/aocl.html#downloads
After installation the dll can be found here: C:\Program Files\AMD\AOCL-Windows\amd-fftw\lib\shared
The relevant file is libfftw3f.dll which can be renamed to libfftw3f-3.dll and then used as usual.
ErazorTT is offline   Reply With Quote
Old 18th April 2024, 15:58   #112  |  Link
tormento
Acid fr0g
tormento's Avatar
This scares me out.
Any proof of what he is saying?
fftw, fftw3.dll
