Old 10th May 2020, 14:27   #81  |  Link
stax76
stax76's Avatar
If you use LoadLibrary() in a plugin it's considered delay-load. Loading the DLL won't happen until the function in which you attempt to load the external DLL (fftw) is called.
There is some automatic delay load using a linker flag allowing working with lib file? That would be more convenient than working with GetProcAddress if it doesn't have a versioning disadvantage.
Security tops your concerns. Just because something is hard is not a reason to throw security out of the window.
If you know where your AviSynth (etc) folder is, which you should, even in portable, then you can just dynamically build pathes, or even use SetDllDirectory (with care, it has its own problems).
But I don't have control of all the tools that read avs and vpy, most support path.
You mean move large exe and dll files around?
Old 10th May 2020, 15:07   #82  |  Link
stax76
stax76's Avatar
@HolyWu
It's working and didn't require rewriting code, thanks!
Old 10th May 2020, 15:56   #83  |  Link
almosely
Originally Posted by HolyWu View Post
I built from git commit 3a103f4, commited on 2020/4/15. I enabled SSE2, AVX, AVX2, and AVX512.
Thanks! :-)
almosely is offline   Reply With Quote
Old 10th May 2020, 18:39   #84  |  Link
Groucho2004
I actually got it backwards. Delay-load is using the MS linker flag /delayload which means that you don't have to use LoadLibrary and GetProcAddress.
I have however never seen this used in any plugin that uses the FFTW DLL, they all use LoadLibrary and GetProcAddress.
Groucho's Avisynth Stuff
Old 10th May 2020, 23:07   #85  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Delay loading is a feature of the Microsoft compiler/linker.
It will generate a "stub" function for each imported function, which – when it is called for the first time – loads the required DLL (if not loaded yet) and then resolves the actual address of the function. If anything goes wrong (e.g. the required DLL can not be loaded, or required entry point is missing), then the "stub" code will throw a structured exception – which may be caught and handled by the application code, e.g to implement optional dependencies.
Note that, under the hood, the "stub" code generated by delay loading still uses the standard LoadLibrary() and GetProcAddress() functions. The "advantage" of delay loading is that you don't have to write the DLL loading code manually.
But: You have to keep in mind that delay loading does not "magically" resolve the path to the DLL for you! It simply will invoke LoadLibrary() with the basename of the required DLL, so that the Standard Search Order for Desktop Applications applies. Consequently, if the DLL does not happen to be located in one of the directories that Windows searches by default, then delay-loading the DLL is going to fail! Consequently, even when delay loading is used, it often still is necessary to explicitly pre-load the DLL, by manually invoking LoadLibrary() with the absolute path to the DLL – before any function from that DLL is invoked for the first time. Or by setting up the DLL search path via the SetDllDirectory() function.
Old 11th May 2020, 01:21   #86  |  Link
stax76
stax76's Avatar
Thanks for the explanation.
Old 12th May 2020, 07:14   #87  |  Link
almosely
I made some new benchmarks.
- edit -
Hm, I thought I had written everything important in my previous bench-post.
I am using an Intel Core i7-3770 and Windows 10 Pro (x64) up-to-date.
Script
DGSource("test.dgi", crop_l=0, crop_r=0, crop_t=0, crop_b=0, deinterlace=0, use_top_field=true, use_pf=true)
Trim(0, 1000)
RequestLinear(rlim=100, clim=100)
neo_fft3d(sigma=1.0, beta=1.0, bw=32, bh=32, sharpen=0.040, scutoff=0.01, y=3, u=2, v=2, bt=5)
# FFT3DFilter(sigma=1.0, beta=1.0, bw=32, bh=32, sharpen=0.040, scutoff=0.01, plane=0, bt=5)
Prefetch(2) # 3, 4 and without prefetch
return last
Clip
1280 x 720 - 29.97 fps - Tennis-Training at Roland Garros
Programs and plug-ins in use (x64)
- AviSynth+ 3.5.1
- Simple x264/x265 Launcher 2.96.1198
- x264 core:160 r3000 33f9e14 (provided by Simple Launcher)
- AVSMeter 2.9.9.1
- DGDecNV 2052
- TIVTC 1.0.14 (for RequestLinear)
- neo_FFT3D r7
- FFT3DFilter 2.6
Simple Launcher (x264) parameter
"...\Simple x264 Launcher\toolset\x64\x264_x64.exe" --output-depth 8 --crf 18.0 --preset medium --tune film --trellis 2 --direct auto --me umh --partitions all --vbv-maxrate 24000 --vbv-bufsize 30000 --b-adapt 2 --bframes 5 --merange 24 --ref 5 --keyint 300 --subme 10 --aq-mode 1 --sar 1:1 --rc-lookahead 40 --output "...\test.mkv" --frames 1001 --demuxer y4m --stdin y4m -
Old 12th May 2020, 10:06   #88  |  Link
ChaosKing
@almosely Can you add the cpu model + x264 parameter to your list?
Old 12th May 2020, 15:01   #89  |  Link
almosely
@ ChaosKing
Done
Old 18th May 2020, 06:37   #90  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Only a minor mistake in terminology; dynamic and delay loading aren't far apart anyway. Delay-loading just translates static-loading in the build into dynamic-loading in the executable. I'm sure pretty much anyone understands your meaning, since true delay isn't often used.
Old 20th April 2021, 23:49   #91  |  Link
kedautinh12
Any update for 3.3.9??
Old 25th April 2021, 22:58   #92  |  Link
kedautinh12
I seen new ver 3.3.10
https://github.com/FFTW/fftw3/blob/master/NEWS
Old 6th July 2021, 00:32   #93  |  Link
GMJCZP
GMJCZP's Avatar
I don't know what version this will be but it seems to work fine, it is 32 bit:
64 bit:
By law and justice!
GMJCZP's Arsenal
GMJCZP is offline   Reply With Quote
Old 13th July 2021, 04:58   #94  |  Link
kedautinh12
this commit 1 year ago, i think it's old ver
Old 11th October 2021, 23:48   #95  |  Link
kedautinh12
3.3.10 x64 ver
https://anaconda.org/conda-forge/fft...10_101.tar.bz2
Old 14th October 2021, 02:09   #96  |  Link
TDS
Formally known as .......
TDS's Avatar
Originally Posted by kedautinh12 View Post
Excuse my noobyness, but is this the same as "libfftw3f-3.dll"
Long term RipBot264 user.
RipBot264 modded builds..
*new* x264 & x265 addon packs..
TDS is online now   Reply With Quote
Old 14th October 2021, 03:42   #97  |  Link
Yes, same file, alternate name [some plugins require one or other name, some plugins can use either name].
Old 14th October 2021, 03:53   #98  |  Link
GMJCZP
GMJCZP's Avatar
Won't there be a 32-bit version?
By law and justice!
GMJCZP's Arsenal
Old 14th October 2021, 21:19   #99  |  Link
GMJCZP
GMJCZP's Avatar
Please, does anyone know if there is a 32-bit version of this latest version of FFTW?
By law and justice!
GMJCZP's Arsenal
Old 15th October 2021, 01:29   #100  |  Link
+1 on what GMJZP said, I will not use unless both available [downloaded and deleted x64 only].
fftw, fftw3.dll
