Old 28th March 2017, 15:46   #1  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
newer FFTW DLL's Windows?
Edit 3: Currently active links
Originally Posted by HolyWu View Post
Originally Posted by filler56789 View Post
EDIT2:
(removed dead link; see above)
EDIT:
Originally Posted by GMJCZP View Post
libfftw3f-3.dll 3.3.7 (rename it if you wish to FFTW) inside DFTTest Vapoursynth version:
Originally Posted by Overdrive80 View Post
From official mirror: ftp://ftp.fftw.org/pub/fftw/
Old:
I notice on the FFTW site that the current Windows builds are for 3.3.5.
http://fftw.org/install/windows.html
Since then, there are have been a few updates for the 'stable' 3.3.6 verison:
http://fftw.org/release-notes.html
FFTW 3.3.6-pl2
Mar 25th, 2017
Bugfix: MPI Fortran-03 headers were missing in FFTW 3.3.6-pl1.
FFTW 3.3.6-pl1 (withdrawn)
Jan 16th, 2017
Bugfix: FFTW 3.3.6 had the wrong libtool version number, and generated shared libraries of the form libfftw3.so.2.6.6 instead of libfftw3.so.3.*.
FFTW 3.3.6 (withdrawn)
Jan 15th, 2017
The fftw_make_planner_thread_safe() API introduced in 3.3.5 didn't work, and this 3.3.6 fixes it. Sorry about that.
Compilation fixes for IBM XLC.
Compilation fixes for threads on Windows.
fix SIMD autodetection on amd64 when (_MSC_VER > 1500)
media-autobuild_suite doesn't include fftw building.
and the last time I tried to compile something myself, I ended up spending 2 days trying to get everythint together and I don't even remember if I finished or not.
EDIT: Can someone please compile and upload?
The official site might update once they reach 3.3.7.
I'm pretty sure the version I have currently on my system is one of the deprecated versions.
Win10 (x64) build 19041
NTSC | DVD: R1 | BD: A
AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
Old 21st December 2017, 21:40   #2  |  Link
GMJCZP
GMJCZP's Avatar
By law and justice!
GMJCZP's Arsenal
GMJCZP is offline   Reply With Quote
Old 21st December 2017, 22:31   #3  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
FWIW, here is FFTW 3.3.7 for Win32 (SSE2 build):
fftw-3.3.7-win32.zip
Old 22nd December 2017, 22:16   #4  |  Link
Overdrive80
Anime addict
Overdrive80's Avatar
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite
Overdrive80 is offline   Reply With Quote
Old 23rd December 2017, 01:09   #5  |  Link
GMJCZP
GMJCZP's Avatar
Direct link (32 and 64 bit versions):
By law and justice!
GMJCZP's Arsenal
Old 23rd December 2017, 23:45   #6  |  Link
Groucho2004
I built libfftw3f-3.dll with gcc 4.9.3 (SSE2, x86) and was surprised to see it perform better than the ICC version that comes with dfttest.
Tested on i5 2500K @4GHz.
Script for testing:
colorbars(width = 1280, height = 720, pixel_type = "yv12").killaudio().assumefps(50, 1).trim(0, 49)
RemoveNoise()
function RemoveNoise(clip video, int "threshold")
  last = video
  sc = MSuper(hpad = 16, vpad = 16)
  backward_vector = MAnalyse(sc, isb =  true, delta = 1, blksize = 16, overlap = 4, truemotion = false, sadx264 = 4, dct = 1)
  forward_vector =  MAnalyse(sc, isb = false, delta = 1, blksize = 16, overlap = 4, truemotion = false, sadx264 = 4, dct = 1)
  MDegrain1(sc, backward_vector, forward_vector, thSAD = 300)
  return last
ICC build taken from DFTTest:
Frames processed:               50 (0 - 49)
FPS (min | max | average):      0.742 | 1.529 | 0.760
Memory usage (phys | virt):     51 | 47 MiB
Thread count:                   9
CPU usage (average):            25%
gcc 4.9.3 build:
FPS (min | max | average):      0.899 | 1.806 | 0.921 (+21%)
Memory usage (phys | virt):     49 | 45 MiB
Thread count:                   9
Groucho's Avisynth Stuff
Old 23rd December 2017, 23:48   #7  |  Link
GMJCZP
GMJCZP's Avatar
Thank you, brother Marx! Better in speed and memory usage, superb!
Edit: if I missed something, in which part of the script is called dfttest or fft3dfilter?
By law and justice!
GMJCZP's Arsenal
Old 24th December 2017, 00:03   #8  |  Link
Groucho2004
The test was with MDegrain where MAnalyse uses FFTW when dct = 1.
However, with dfttest the gcc build is quite a bit slower. So, not recommended for dfttest. With fft3dfilter it's about the same speed.
Old 2nd January 2018, 13:37   #9  |  Link
Groucho2004
Interesting. I had compiled FFTW with GCC 7.2.0 as well but only done tests with FFTW's benchmark program (benchf.exe) and DFTTest since I didn't use DCT mode in MVTools. After investigation I find out that MVTools dislike ICC's O3 optimization for unknown reason, change to O2 optimization gives better performance. I also discover that FFTW by default only generate efficient codelets of size 8 in DCT/IDCT transforms. I especially generate codelets of typical sizes 4, 16, 32 and 64 so now it's at least 50% faster than before when blksize is one of them. DFTTest and FFT3DFilter are unaffected since they use real DFT transforms. The 7z file on GitHub is updated.
Nice, the new fftw DLL is almost twice as fast with the script I posted above.
Old 2nd May 2018, 09:31   #10  |  Link
tormento
Acid fr0g
tormento's Avatar
Direct link (32 and 64 bit versions)]
The link has expired. Could someone please post a link with a windows working x64 build of 3.3.7?
@turment on Telegram
Old 2nd May 2018, 19:31   #11  |  Link
Midzuki
Unavailable
Midzuki's Avatar
https://forum.videohelp.com/threads/...Ls-for-Windows
Midzuki is offline   Reply With Quote
Old 21st October 2018, 13:35   #12  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
@Wolfberry... Nice, but if you don't mind, could you build the SSE2 with v141_XP and AVX/AVX2 with the normal v141?
Thank you in advance.
Old 22nd October 2018, 09:13   #13  |  Link
ChaosKing
THX for the builds.
o2 is always faster on my Ryzen 1700 (like 0.5 fps faster ). And for some reason the avx build is the slowest. Tested with dfttest.
Old 25th October 2018, 22:45   #14  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
I tested it, it works fine on WinXP, but I had to include LIBGCC_S_DW2-1.DLL myself in system32 as it was missing.
Thanks. ^_^
Old 5th November 2018, 09:12   #15  |  Link
ErazorTT
@Wolfberry:
I tested the performance of your x64 compilations with dfttest on a mobile i5 Haswell. The one named „simd128+256“ was around 10% faster than the official 3.3.5 Build, all others were 5% slower.
However using fft3dfilter with „simd128+256“ produces an access violation. As far as I know, the instruction set of haswells should be complete up to AVX-256. Did someone manage to get fft3dfilter working with this build, if yes on what system?
ErazorTT is offline   Reply With Quote
Old 8th November 2018, 11:24   #16  |  Link
Wolfberry
Helenium(Easter)
Wolfberry's Avatar
@ErazorTT
Confirmed.
It seems that fft3dfilter dislike generic (gcc) 256-bit SIMD optimizations.
Updated original post.
Monochrome Anomaly
Wolfberry is offline   Reply With Quote
Old 8th November 2018, 11:39   #17  |  Link
ErazorTT
Great, I will test the performance with your new builds when I’m back home.
For me this sounds like some kind of an alignment error.
Can you show the differences of the flags you use for your compilations and the old 128+256?
Old 9th November 2018, 09:05   #18  |  Link
ErazorTT
Ok so all builds apart of simd256 work with fft3dfilter. However the old build simd128+256 appears to have been a wee bit faster than all new builds with dfttest.
Out of curiosity: what do you actually mean by simd 128 or 256 in contrast to sse2/avx/avx2? After all sse2 is a 128 simd and avx/avx2 have additional 256 simd instructions on top of sse2.
Old 9th November 2018, 13:08   #19  |  Link
Wolfberry
Helenium(Easter)
Wolfberry's Avatar
  --enable-sse2             enable SSE/SSE2 optimizations
  --enable-avx              enable AVX optimizations
  --enable-avx2             enable AVX2 optimizations
  --enable-avx512           enable AVX512 optimizations
  --enable-avx-128-fma      enable AVX128/FMA optimizations
  --enable-kcvi             enable Knights Corner vector instructions optimizations
  --enable-altivec          enable Altivec optimizations
  --enable-vsx              enable IBM VSX optimizations
  --enable-neon             enable ARM NEON optimizations
  --enable-generic-simd128  enable generic (gcc) 128-bit SIMD optimizations
  --enable-generic-simd256  enable generic (gcc) 256-bit SIMD optimizations
Above is some flags that you can use during configuration.
The SIMD builds also enabled SSE2/AVX/AVX2, but I am not sure if it is worth it.
AFAIK, the generic-simd128/256 is some kind of generic AVX(2), not sure how generic they are.
The fftw release note says:
enabling them all at the same time is a bad idea, because it increases the planning time for minimal gain
And the more path you enabled, the more fat the dlls will be.
The future builds will have these codelets generated as well.
Monochrome Anomaly
Old 9th November 2018, 18:46   #20  |  Link
ErazorTT
So the generic options are based on the compiler vectorization and optimization.
Have you tried to increase the alignment using --with-incoming-stack-boundary? Like suggested here: https://forum.doom9.org/showthread.p...80#post1857180
fftw, fftw3.dll
