Old 15th May 2024, 16:19   #4881  |  Link
Atlantis
Original file :
Color primaries : BT.709
Matrix coefficients : BT.709
Gamma : 2.400
encoded file :
Gamma is not passed. How to pass it?
Atlantis is offline   Reply With Quote
Old 30th May 2024, 05:41   #4882  |  Link
TDS
Formally known as .......
TDS's Avatar
Version 2.39.2 is released. (3 days ago)
https://github.com/staxrip/staxrip/releases/tag/v2.39.2
Long term RipBot264 user.
RipBot264 modded builds..
*new* x264 & x265 addon packs..
TDS is offline   Reply With Quote
Old 30th May 2024, 20:51   #4883  |  Link
Zetti
Version 2.39.3 is released.
https://github.com/staxrip/staxrip/releases/tag/v2.39.3
Zetti is offline   Reply With Quote
Old 31st May 2024, 13:45   #4884  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
QSV encoding h265, UHD-Bluray settings as below: 2.36 works, 2.38, 2.39/1/2/3 fail with GPU hang. 2.39 logs look the same.
--vbr 27000 --codec hevc --quality best --profile main10 --level 5.1 --output-depth 10 --la-quality slow --ref 5 --gop-len 24 --strict-gop --vbv-bufsize 40000 --max-bitrate 45000 --qp-max 48 --videoformat ntsc --colormatrix bt709 --colorprim bt709 --transfer bt709 --atc-sei bt709 --pic-struct --aud --bluray
------------------------- System Environment -------------------------
StaxRip : v2.38.0
Settings : v2.38
Windows : Windows 10 Pro 22H2 2009 (19041.1.amd64fre.vb_release.191206-1406)
Language : German (Germany)
CPU : 11th Gen Intel(R) Core(TM) i9-11900K @ 3.50GHz
RAM : 128GB
GPU : Intel(R) UHD Graphics 750, NVIDIA GeForce RTX 3080 Laptop GPU
Resolution : 3840 x 2160
DPI : 144
Code Page : 1252
----------------------- Media Info Source File -----------------------
D:\The Movie\BDMV\STREAM\00000.dgi_3840x2160_prob-3.mov.avi
General
Complete name : D:\The Movie\BDMV\STREAM\00000.dgi_3840x2160_prob-3.mov.avi
Format : AVI
Format/Info : Audio Video Interleave
Format profile : OpenDML
Format settings : WaveFormatExtensible
File size : 685 GiB
Duration : 1 h 29 min
Overall bit rate : 1 098 Mb/s
Frame rate : 23.976 FPS
Writing library : VirtualDub2 build 44282/release
Video
Format : M0Y0
Codec ID : M0Y0
Bit rate : 1 096 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Bits/(Pixel*Frame) : 5.512
Stream size : 684 GiB (100%)
Audio
Format : PCM
Format settings : Little / Signed
Codec ID : 00000001-0000-0010-8000-00AA00389B71
Bit rate mode : Constant
Bit rate : 1 536 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Bit depth : 16 bits
Stream size : 982 MiB (0%)
Alignment : Aligned on interleaves
Interleave, duration : 42 ms (1.00 video frame)
Interleave, preload duration : 500 ms
---------------------------- Configuration ----------------------------
Template : UHD-BD 24p QSVEnc 27Mbps 709
Video Encoder : QSVEnc
Video Encoder Profile : QSVEncC (Intel) | H.265
Container/Muxer Profile : No Muxing
Process Priority : BelowNormal
Delete Temp Files : Disabled
--------------------------- AviSynth Script ---------------------------
AddAutoloadDir("C:\_PROG_64\! Video Encoders 64\StaxRip-v2.38.0-x64\Apps\FrameServer\AviSynth\plugins")
AviSource("D:\The Movie\BDMV\STREAM\00000.dgi_3840x2160_prob-3.mov.avi", audio=false)
ConvertToYUV420()
------------------------- Source Script Info -------------------------
Width : 3840
Height : 2160
Frames : 128570
Time : 01:29:22.440
Framerate : 23.976023 (24000/1001)
Format : YUV422P10
------------------------- Target Script Info -------------------------
Width : 3840
Height : 2160
Frames : 128570
Time : 01:29:22.440
Format : YUV420P10
------------------------ Error Video encoding ------------------------
QSVEncC 7.62
"C:\_PROG_64\! Video Encoders 64\StaxRip-v2.38.0-x64\Apps\Encoders\QSVEncC\QSVEncC64.exe" --avsdll "C:\_PROG_64\! Video Encoders 64\StaxRip-v2.38.0-x64\Apps\FrameServer\AviSynth\AviSynth.dll" --vbr 27000 --codec hevc --quality best --profile main10 --level 5.1 --output-depth 10 --la-quality slow --ref 5 --gop-len 24 --strict-gop --vbv-bufsize 40000 --max-bitrate 45000 --qp-max 48 --videoformat ntsc --colormatrix bt709 --colorprim bt709 --transfer bt709 --atc-sei bt709 --pic-struct --aud --bluray -i "D:\The Movie\BDMV\STREAM\00000.dgi_3840x2160_prob-3.mov_temp\00000.dgi_3840x2160_prob-3.mov_qsv38.avs" -o "D:\The Movie\BDMV\STREAM\00000.dgi_3840x2160_prob-3.mov_qsv38.hevc"
videoPrm.mfx.CodecLevel value changed 4.1 -> unknown by driver
cop.VuiVclHrdParameters value changed on -> auto by driver
cop.ResetRefList value changed on -> auto by driver
cop.MaxDecFrameBuffering value changed 5 -> 0 by driver
cop.SingleSeiNalUnit value changed off -> auto by driver
QSVEncC (x64) 7.62 (r3298) by rigaya, Mar 17 2024 12:04:53 (VC 1938/Win)
OS Windows 10 x64 (19045) [UTF-8]
CPU Info 11th Gen Intel Core i9-11900K @ 3.50GHz [TB: 4.89GHz] (8C/16T) <Tigerlake>
GPU Info Intel UHD Graphics 750 (32EU) 350-1300MHz [125W] (31.0.101.4575)
Media SDK QuickSyncVideo (hardware encoder) FF, 1st GPU(i), API v2.09
Async Depth 3 frames
Hyper Mode off
Buffer Memory d3d11, 13 work buffer
Input Info AviSynth+ 3.7.3 r4003(yv12(10bit))->p010 [AVX2], 3840x2160, 24000/1001 fps
AVSync auto
Output H.265/HEVC(yuv420 10bit) main10 @ Level 5 (high tier)
3840x2160p 1:1 23.976fps (24000/1001fps)
Target usage 1 - best
Encode Mode Bitrate Mode - VBR
Bitrate 27000 kbps
Max Bitrate 40000 kbps
VBV Bufsize 22000 kb
QP Limit min: 22, max: 48
Ref frames 5 frames
Bframes 3 frames, B-pyramid: on
Max GOP Length 24 frames
Slices 4
VUI matrix:bt709,colorprim:bt709,transfer:bt709,videoformat:ntsc
atcsei bt709
Ext. Features WeightP WeightB GPB aud pic_struct tskip ctu:64 sao:all
bitstream: Failed to get frame ID for pts -1, using 2.
MFXENCODE: device kept on busy for 30s, unknown error occurred.
Break in task MFXENCODE: gpu hang..
encoded 7 frames, 0.35 fps, 79.63 kbps, 0.00 MB
encode time 0:00:20, CPULoad: 5.2
frame type IDR 1
frame type I 2, total size 0.00 MB
frame type P 3, total size 0.00 MB
frame type B 3, total size 0.00 MB
QSVEncC.exe finished with error!
Video encoding returned exit code: -21 (0xFFFFFFEB)
Start: 14:38:26
End: 14:38:49
Duration: 00:00:22
Old 1st June 2024, 09:01   #4885  |  Link
Joekiwi
Hi Anyone using the latest Nvidia driver and NVEnc will need to download rigaya's latest version and copy it in, as encodes at a wrong bitrate, will naturally be fixed if you download a later version of staxrip with Nvenc colder updated
Joekiwi is offline   Reply With Quote
Old 7th June 2024, 01:38   #4886  |  Link
Emulgator
Emulgator's Avatar
And regarding IntelQSV:
QSVEncC64.exe 7.62 brings the incompatibility.
QSVEncC64.exe 7.61 works in SR2.39.3
P.S. SR 2.40: the same problem with QSVEncC64.exe encoding .h265:
QSVEncC64.exe 7.65 can encode .h264, .MPEG-2, .vp9
(.av1 I can not test, not supported on my platform.)
P.P.S. I have just reported that to rigaya.
https://github.com/rigaya/QSVEnc/issues/202
Got rigaya's answer: add
--function-mode PG
to commandline and it works again.
BTW, huge options list in QSVEncC...
Old 8th June 2024, 10:06   #4887  |  Link
Zetti
Version 2.40.0 is released.
https://github.com/staxrip/staxrip/releases/tag/v2.40.0
Old 8th June 2024, 21:11   #4888  |  Link
DMD
DMD's Avatar
I restored the Auto Crop after opening setting to Dolby Vision Only as in previous versions.
To avoid the long analysis on HDR10 files.
my PC with Ryzen 7950X
DMD is offline   Reply With Quote
Old Today, 20:21   #4889  |  Link
Zetti
Version 2.41.0 is released.
https://github.com/staxrip/staxrip/releases/tag/v2.41.0
