Old 14th April 2024, 07:07   #1261  |  Link
v0lt
VirtualDub2 version 2.1 (deleted)
Changes:
Windows XP is no longer supported.
Builds for x86 are no longer planned to be released.
Fixed crash when calling RunNullVideoPass().
Updated avlib-1.vdplugin to version 0.6.1.70.
├ FFmpeg 6.1.1 is now supported.
├ Removed CineForm HD (native) codec.
├ Removed manual lazy loading of DLL for FFmpeg DLLs.
├ Removed support for systems older than Windows 7.
└ The 32-bit plugin is not implemented because there is no official build of FFmpeg 6.1.1 for x86.
v0lt is offline   Reply With Quote
Old 14th April 2024, 09:39   #1262  |  Link
nji
Thankyou for your work!
I would like to mention drawbacks of dropping 32bit:
There are several filters which are only for 32 bit.
If I remember right it is the internal logo filter for 64 bit,
that produces slight false colors ("DeShaker default color").
(shekh once had a look at it, but didn't worked on as it is confusing code).
I don't know if ffmpeg source code would allow to be build as 32 bit?
nji is offline   Reply With Quote
Old 14th April 2024, 11:29   #1263  |  Link
LigH
LigH's Avatar
What does DDL mean? Just a typo of DLL?
PS: I tried to select a video compression and it crashed:
An out-of-bounds memory access (access violation) occurred in module 'VirtualDub64'...
...reading address 00000000A9C072E0...
...while querying video codec "ffdshow Video Codec" (compchoose.cpp:420)...
...while opening video codec with FOURCC "ffds" (compchoose.cpp:528)...
...while enumerating video codecs (compchoose.cpp:515).
New German Gleitz board
Old 14th April 2024, 13:19   #1264  |  Link
v0lt
There are unofficial builds of FFmpeg. You can look for x86 shared version 6.1.1 there.
But I'm not interested.
Yes. It's a typo.
This doesn't happen to me. I don't have "ffdshow Video Codec".
Old 14th April 2024, 13:23   #1265  |  Link
LigH
LigH's Avatar
Are you interested in a crash log? Your repo doesn't seem to have an "issues" page.
It contains an error:
Thread call stack:
Incorrect VirtualDub.vdi file (build 44282) for this version of VirtualDub -- call stack unavailable.
VirtualDub2 x64 build 44282 has no issues enumerating video compressors.
The ffdshow VfW codec is part of ffdshow-tryout rev4531 by e.g. clsid2
https://sourceforge.net/projects/ffd...leases/64-bit/
https://forum.doom9.org/showthread.php?t=120465
__
P.S.: I believe this problem was introduced between VirtualDub2 x64 ffmpeg6.1.1 test 11 (contains an old EXE from 2020) and 12 (contains a new EXE).
Old 14th April 2024, 13:45   #1266  |  Link
v0lt
I installed ffdshow_rev4533_20140929_clsid_x64.exe and during installation I saw a warning about possible crashes.
I also get a crash when ffdshow VFW is installed.
PS: Perhaps the problem with ffdshow VFW appeared after replacing the Windows SDK and other things.
Old 15th April 2024, 20:01   #1267  |  Link
v0lt
I turned on the "Issues" page and created Issue #1, where I collected various information on this issue.
Old 15th April 2024, 20:14   #1268  |  Link
LigH
LigH's Avatar
I hope someone competent can find the real reason, skipping a codec is indeed not a perfect solution.
Old 19th April 2024, 04:47   #1269  |  Link
v0lt
VirtualDub2 44282 + avlib.vdplugin 0.6.1.70
I decided to re-release the old VirtualDub2 build 44282 with updated avlib.vdplugin 0.6.1.70.
Old 19th April 2024, 22:08   #1270  |  Link
LigH
LigH's Avatar
OK, nice, can handle an MP4 with AV1 video from YouTube and use ffvfw codecs.
Old 20th April 2024, 04:59   #1271  |  Link
v0lt
VirtualDub2_v2.1.0.603
Alternative link
Please check this version. Will it crash when choosing a video compressor or not?
ffdshow Video Codec (ff_vfw.dll) and Logitech Video (I420) (lvcod64.dll) are not supported.
Old 20th April 2024, 20:51   #1272  |  Link
LigH
LigH's Avatar
It does not crash but ffvfw is not listed.
Old 21st April 2024, 10:01   #1273  |  Link
jpsdr
That's odd. I've tried the 1rst version of 2.1 on my PC, which have ffdshow 1.3.4533 installed, and it doesn't crash when i choose compressor, and the ffshow codec is listed.
My github.
Old 21st April 2024, 10:17   #1274  |  Link
LigH
LigH's Avatar
For me it crashed from test12 on, because this included a new EXE built with a more modern MSVS. I guess it might be related to the set and maybe order of VfW codecs being enumerated, but we will need to trace the reason to understand what happens and find a way to avoid it. I hope a test build creating a verbose log of the enumeration loop may help...
Old 21st April 2024, 16:51   #1275  |  Link
v0lt
VirtualDub2 v2.1.0.605
64-bit "ffdshow Video Codec" (ff_vfw.dll) and "Logitech Video (I420)" (lvcod64.dll) are not supported because it crashes when opening the video compression selection window.
* FFmpeg 6.1.1 is now supported.
* Removed CineForm HD (native) codec.
* Removed manual lazy loading of DLL for FFmpeg DLLs.
* Removed support for systems older than Windows 7.
* The 32-bit plugin is not implemented because there is no official build of FFmpeg 6.1.1 for x86.
Old VirtualDub2 with updated avlib.vdplugin.
Old 21st April 2024, 17:17   #1276  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Many thanks, v0lt !
As a sidenote: As long as there are classic 32-bit AVS plugins which won't get any update
because stable (or developer had to take on other tasks) it is viable to still have 32-bit applications
like VD2 available, so again thanks if somebody caring for that still.
Old 26th April 2024, 16:28   #1277  |  Link
jpsdr
What is CineForm ? Is it a lossless codec ?
My github.
Old 26th April 2024, 16:33   #1278  |  Link
LigH
LigH's Avatar
CineForm Intermediate is the codec used in GoPro cameras, not lossless but wavelet oriented. I believe more modern camera generations moved on to HEVC and even AV1.
Old 26th April 2024, 16:56   #1279  |  Link
shekh
AFAIK it wasn`t used in cameras. It is great as intermediate
Old 26th April 2024, 17:04   #1280  |  Link
LigH
LigH's Avatar
Ah, okay... well, it's constant quality oriented, low loss, easy editing. Comparable to DNxHD/R
