Old 22nd August 2011, 20:16   #5001  |  Link
Superb
Originally Posted by msoltyspl View Post
In context of ogm files I had to use full name - e.g. 'Japanese' (case sensitive as well) did the thing, usual 'jpn' was not enough.
Perhaps it would be good to add extra sentence or so, that certain containers require full name instead of just the code.
Maybe it would be a better idea to make an internal (hashed?)table of all the languages and their shorter names. Automatically infer the longer name...
Superb is offline   Reply With Quote
Old 22nd August 2011, 20:21   #5002  |  Link
nevcairiel
Originally Posted by ForceX View Post
Funny, only happens with madVR 0.74. :/ However, FFDshow works ok with madVR 0.74.
Indeed.
Its really madVRs fault, it seems to keep a reference on the video decoder, so it doesn't get properly destructed. That happesn with ffdshow as well, its just that ffdshow frees the memory earlier.
I changed it now to free the memory earlier as well, so it doesn't result in catastrophic failure when this happens. In any case, you should report this to madshi.
Edit: I reported it.
Old 22nd August 2011, 20:26   #5003  |  Link
nevcairiel
Can you provide a small sample file with this problem?
Old 22nd August 2011, 20:32   #5004  |  Link
madshi
Oooopsi.
Old 22nd August 2011, 20:32   #5005  |  Link
VipZ
I found the reason it didn't work, and i fixed it (it wasn't the media type). I'll commit the change when i get home.
PS:
AR is also fixed again.
PPS:
I also fixed the problem with WMV1/2 not showing any image with the WMVideo decoder, hooray.
Awesome, thanks
Windows 11 Pro, CPU: Ryzen 9 5900X, GPU: GeForce RTX 3090 /w 512.95, Audio: HDMI to Yamaha RX-A3060 (5.1)
VipZ is offline   Reply With Quote
Old 22nd August 2011, 20:40   #5006  |  Link
nevcairiel
LAV Filters 0.33
LAV Splitter
- Improved compatibility with the MS WMVideo decoder
- Fixed the mediatype for raw PCM streams
LAV Audio
- Added support for Vorbis streams demuxed by Haali and MPC-HC Splitters
LAV Video
- VC-1 decoding is now disabled by default
- Fixed behaviour of the Stream AR option
- The maximum number of decoding threads is now 16
- Free decoding buffers when the input pin disconnects to avoid big memory leaks
Download: Installer (both x86/x64) -- Zips: 32-bit & 64-bit
Its mostly just $random bug fixes, but enough to warrant a new version, including some crash fixes.
VC-1 is now disabled by default because the decoder doesn't really offer any notable advantages over the default Windows decoder (WMVideo Decoder DMO). You can of course just re-enable it, if you want.
This does not yet include any of the performance enhancements for LAV Video, i branched those off and still working on them.
Take care.
Old 22nd August 2011, 20:48   #5007  |  Link
Thunderbolt8
thanks, the WMVideo Decoder works now (also for interlaced stuff, though still limping on 1 CPU )
Laptop Lenovo Legion 5 17IMH05: i5-10300H, 16 GB Ram, NVIDIA GTX 1650 Ti (+ Intel UHD 630), Windows 10 x64, madVR (x64), MPC-HC (x64), LAV Filter (x64), XySubfilter (x64) (K-lite codec pack)
Old 22nd August 2011, 21:13   #5008  |  Link
ForceX
Thanks for the quick fix and the new build.
ForceX is offline   Reply With Quote
Old 22nd August 2011, 21:27   #5009  |  Link
msoltyspl
Sure:
http://soltys.ziu.info/temp/a.ogm
http://soltys.ziu.info/temp/b.ogm
The first file has plain 'Japanese' and 'English' as language tags on audio track.
The second one uses 'Japanese[jpn]' and 'English[eng]' (seems more proper ?)
Of course, ogm is relatively ancient and obsoleted these days, though lots of stuff with it still around. Simple workaround is to just list the exact language tag value in the list, works as well.
msoltyspl is offline   Reply With Quote
Old 22nd August 2011, 21:36   #5010  |  Link
nevcairiel
Just "English" is better then "English[eng]". I can match full language names, i guess, but matching some construct like "English[eng]" is really alot harder.
Old 22nd August 2011, 21:40   #5011  |  Link
VipZ
Nev, I bet you gona want to add me to the ignore list with EVO
With the latest changes, VC1 within EVO doesn't work with the MS WM Decoder any more, in both Win 7 and XP. The chain all connects but playback doesn't start and is stuck at 0:00. LAV Video works as normal. There are no issues with M2TS in both Win7 or XP.
Old 22nd August 2011, 21:47   #5012  |  Link
nevcairiel
And i know why, but it'll take a few day to fix it, because it needs ffmpeg changes, not feeling like ugly hacks today.
Old 22nd August 2011, 21:50   #5013  |  Link
VipZ
Cool, we all know you don't like ugly hacks
Old 22nd August 2011, 22:06   #5014  |  Link
Midzuki
Unavailable
Midzuki's Avatar
<OT>
Please define what would be a "beautiful" hack
</OT>
Midzuki is offline   Reply With Quote
Old 22nd August 2011, 22:08   #5015  |  Link
nevcairiel
There are ugly hacks, and there are just hacks. Ugly hacks are those that you just put in, knowing that its just wrong and will be replaced in a few days.
Anyway, i actually fixed it in ffmpeg already. Its still a hack, but it does what i want it to.
The problem in this case was that apparently the EVO container does not contain key-frame infos, and ffmpeg relys on its parser to extract them from the frames. The parser is however off for EVOs, because it mangles the timestamps, so i had to introduce a new parsing mode in ffmpeg which still parses everything, but doesn't mangle the timestamps anymore -- and the WMV decoder relys on me indicating keyframes, otherwise it fails to work properly...
Old 22nd August 2011, 22:36   #5016  |  Link
VipZ
Thanks Nev, working perfectly
Old 22nd August 2011, 23:00   #5017  |  Link
Plutotype
Hi Nev,
I would like to vote for enabling your VC-1 decoder as default.
Im not sure if also by the others, but in my setup, the WMVideo Decoder DMO causes A/V sync issues, when seeking/jumping in the timeline ( lipsync issues ). With VC-1 videos I mean.
Pluto
System: Intel Core i5-6500, 16GB RAM, GTX1060, 75" Sony ZD9, Focal speakers, OS Win10 Pro, Playback: madvr/JRiver
Plutotype is offline   Reply With Quote
Old 22nd August 2011, 23:01   #5018  |  Link
nevcairiel
Originally Posted by Plutotype View Post
Hi Nev,
Pluto
So enable it again.
I had some sync issues before as well, but try again with 0.33, it might as well just have vanished.
Old 22nd August 2011, 23:40   #5019  |  Link
Thunderbolt8
actually for some strange reason it doesnt work for a VC-1 1080p 23.976 BD here -.- (BBC source)
Old 23rd August 2011, 02:48   #5020  |  Link
betaking
Fantasy Codecs writer
betaking's Avatar
To:nevcairiel,can you make lavaudio change decoder format write to Registry like it to lavvideo and lav splitters?
[HKEY_CURRENT_USER\Software\LAV\Splitter\Formats]
"4xm"=dword:00000000
"aac"=dword:00000000
or
[HKEY_CURRENT_USER\Software\LAV\Video\Formats]
"h264"=dword:00000000
"vc1"=dword:00000000
For example made ​​of this
[HKEY_CURRENT_USER\Software\LAV\Audio\Formats]
betaking is offline   Reply With Quote
