Old 19th August 2011, 16:58   #4841  |  Link
Mercury_22
Thought it might be of interest to people, just tested power consumption of my PC using LAV CUVID vs LAV Video Decoder and MadVR.
In short, LAV Video Decoder dropped power consumption of my system by about 50 watts.
I suspect the reason for this is that LAV CUVID keeps my GPU in its high performance mode, whereas LAV Video Decoder lets it drop down into the low power consumption mode after 20-30s of playback.
CPU usage on playback is 5-10% with CUVID, 20-30% with LAV Video Decoder.
It'll be very interesting to know how this stands compare to MPC-HC's DXVA + EVR CP
P.S. My guess another 50 watts drop
Intel UHD Graphics 750; Win 10 22H2
Mercury_22 is offline   Reply With Quote
Old 19th August 2011, 17:06   #4842  |  Link
nevcairiel
It'll most likely increase again.
Old 19th August 2011, 18:11   #4843  |  Link
6233638
Initial power consumption with LAV CUVID + MadVR: 180W
LAV Video Decoder + MadVR: 130W
LAV Video Decoder + MadVR + Maximum Windows & BIOS Power Saving Options Enabled: 110W
EVR-CP + MPC-HC DXVA: 100W
Idle: 90W
I'm pretty happy with that, and 10W is worth it for the improvement MadVR + LAV brings.
Idle power consumption is a bit higher than I expected, but I do have five hard drives and two optical drives in there.
Old 19th August 2011, 18:23   #4844  |  Link
Mercury_22
Idle: 90W
As I was expected
But with an ( HTPC ) video card (like mine ) the gain (in %) I'll bet it's much bigger
P.S. It'll be more interesting (more accurate) a comparison using EVR for all
Old 19th August 2011, 18:32   #4845  |  Link
nevcairiel
The difference will be smaller if your video card is actually a low-powered card specifically for HTPC dutys.
Maybe its already running on a certain level just with madVR so it pushes itself into high-performance mode.
Such a high difference is quite natural when your GPU is totally overpowered for video playback. The performance mode eats more power when its clocked higher.
Old 19th August 2011, 19:18   #4846  |  Link
mindbomb
I have 2 inter-related questions about lav video:
by default, i assume hardware deinterlacing is used with evr cp since nv12 is used?
also, the high quality conversion option, that doesn't apply to outputting blurays to nv12, right?
mindbomb is offline   Reply With Quote
Old 19th August 2011, 19:31   #4847  |  Link
nevcairiel
It should work with both NV12 or YV12, but yes.
It mostly only affects RGB conversions.
Old 19th August 2011, 19:31   #4848  |  Link
pirlouy
_
You mean LAV CUVID uses more power than LAV CPU Video decoder ??? I though one reason of CUVID was the fact it uses a dedicaced GPU processor which save ressources ??!!!!
Thanks for the new Video decoder. I'm doing tests right now. I notice MPEG1 videos are not decoded by LAV Video decoder if I disable MPEG1 support in ffdshow. It's the Windows default one which is used. Is it intended (lower merit) ? Does the MS one better then the ffmpeg one ?
Also, it does not decode MP1 audio (whereas ffdshow do). Intended ?
Old 19th August 2011, 19:35   #4849  |  Link
CruNcher
CruNcher's Avatar
Btw nev did you compared (Bitstream support, eventual Software Bugs,Decoder Bugs and limits) Nvidias VP4 stability vs Intels yet also Deinterlacing Performance and Quality ?
We know that Performance through the shorter Paths is much better now but what about the SDK quality compared to Nvidias Ecosystem NVcuvid (heavily influenced from the get go by Donald Graft and Doom9),Nvcuvenc vs Intel MediaSDK 3 ?
Most reviews also not really go into details here and some HQV tests are quiet subjective after all and retests are virtually never done based on a new SDK release (UVD3 being the best example which suffered especially from this being so problematic in the beginning in bitstream support terms)
It is about Time
Old 19th August 2011, 19:37   #4850  |  Link
nevcairiel
If you use EVR-CP or something like that, Intels decoder is fine, deinterlacing quality is similar to the others. But the GPU itself is too slow for madVR.
The next generation might make it a good HTPC chip, if the GPU gets some more shader power, and the 24p bug is fixed.
Old 19th August 2011, 19:38   #4851  |  Link
nevcairiel
With which splitter? Probably the media types are different.
Old 19th August 2011, 19:58   #4852  |  Link
pirlouy
_
I try to use only LAV stuff (except madVR decoders), and I confirm it's the LAV splitter. It's for all MPEG1 videos !
As you guess, these are poor quality videos.
Here is an example, with MPEG1 videos and MP1 audio:
http://dl.free.fr/vpgBXGDfH (5Mo)
Old 19th August 2011, 20:29   #4853  |  Link
6233638
Yes, but it makes my GPU (which is a gaming-class GPU rather than HTPC) go into its high power mode rather than staying in its low power mode which means the system ends up using considerably more power.
It probably doesn't need to be in the high power state, but there doesn't seem to be a way to force it to stay in the low power mode, it's automatic.
The CPU does the same thing when running LAV Video Decoder, clocking up to the full speed, but you can create a power management profile to keep it downclocked rather than going up to full speed to keep power consumption down. (as CPU usage isn't going over 30% it's fine in the low power state)
DXVA shaves off 10W compared to the CPU decoding, but I can't use MadVR with DXVA.
Old 19th August 2011, 20:43   #4854  |  Link
pirlouy
_
Yeah... I'm not really convinced. Maybe someone with a GT430 could tell his results.
The use of a special dedicaced processor should not interfere with GPU processor.
It seems to me it's better to use CPU decoder (LAV Video or MadVR -actual- decoders) than CUDA solution. CUDA is like DXVA: untrustworthy.
Old 19th August 2011, 20:45   #4855  |  Link
nevcairiel
The real advantage is the deinterlacing with lav cuvid.
Old 19th August 2011, 21:10   #4856  |  Link
Plutotype
Hi Nev,
tested 0.32, so far no issues with video. I have couple of general questions:
- LAVvideo - what would speak for your LAVvideo decoder to be used instead of internal madVR or even ffdshow video decoder?+/-
- LAVvideo - number of threads is the number of physical cores or inclusive virtual ones?
- LAVsplitter - is File Source ( Async. ) still needed in the preffered list of external decoders?
- LAVsplitter - does "remove audio decoder before audio stream switch" work properly with MPC-HC? In what exactly does it help?
- should I use exe installer instead of .bat files?
Thanks
Pluto
System: Intel Core i5-6500, 16GB RAM, GTX1060, 75" Sony ZD9, Focal speakers, OS Win10 Pro, Playback: madvr/JRiver
Plutotype is offline   Reply With Quote
Old 19th August 2011, 21:35   #4857  |  Link
madshi
Compared to the current version of the madVR internal decoders:
+ LAV fully supports Reclock
+ LAV allows you to use post processing, e.g. DirectVobSub
+ LAV supports more video codecs
o performance should be identical
- LAV doesn't support VC-1 interlaced, but doesn't reject it
Compared to ffdshow:
+ newer version of ffmpeg/libav library, I think
+ full support for 9bit & 10bit decoding, 4:2:0, 4:2:2 and 4:4:4
+ capable of outputting decoded video untouched to madVR
+ dedicated and active developer -> quick bugfixes etc
Old 19th August 2011, 21:37   #4858  |  Link
nevcairiel
If you tell me how.
I tried, but the only method i could come up with was checking the interlaced flag in the header.
However, that flag is also set on 60i coded EVOs with forced pulldown, which decode just fine.
In the end, i decided to not block it.
Old 19th August 2011, 21:42   #4859  |  Link
madshi
If you tell me how.
However, that flag is also set on 60i coded EVOs with forced pulldown.
Well, it's a pity that ffmpeg/libav doesn't support interlaced decoding yet. I don't think there's anything you can do to fix the problem. madVR can work around it by simply switching to the Intel VC-1 decoder for interlaced content.
But truth be told, I consider the MS decoder to be superior to both the ffmpeg/libav and Intel VC-1 decoders, anyway. Consequently I've disabled the internal VC-1 decoder(s) in madVR by default. Maybe it would be worth a thought disabling the VC-1 decoder by default in LAV Video, too? I don't really see why anybody would want to use the ffmpeg/libav VC-1 decoder. It's slower than the MS VC-1 decoder, without having any advantages that I'm aware of. But maybe I'm missing something?
Old 19th August 2011, 21:46   #4860  |  Link
nevcairiel
The MS decoder doesn't work with EVO streams, don't ask me why not.
But i guess cannot make it right for everyone.
