Old 8th July 2011, 08:42   #4041  |  Link
nevcairiel
The MPC-HC/Gabest MKV Splitter does not do any stream switching at all.
Old 8th July 2011, 08:58   #4042  |  Link
somy
Hi nevcairiel,
Thanks for the reply, maybe I misunderstood how it works. I just followed the configuration by Sebastiii to make audio switching work in MP:
http://forum.team-mediaportal.com/co...85/#post593924
Anyway, I'd very much like to try LAVF, is it compatible with 64bits Windows 7? Thanks!
somy is offline   Reply With Quote
Old 8th July 2011, 17:50   #4043  |  Link
APorter819
Navigate -> Audio Language, all tracks are there.
Thanks, was use to looking under Play -> Audio.
APorter819 is offline   Reply With Quote
Old 8th July 2011, 17:52   #4044  |  Link
nevcairiel
Yeah i hate how MPC-HC is so inconsistent there and has two menus with completely different contents.
Old 8th July 2011, 17:52   #4045  |  Link
Underground78
Underground78's Avatar
I don't really understand why it is not there any more. Is that by design or is it a bug on MPC-HC side ?
Edit:
So it is a bug in MPC-HC ?
Underground78 is offline   Reply With Quote
Old 8th July 2011, 18:15   #4046  |  Link
clsid
Navigate -> Audio language shows the streams selectable in the splitter (if it has internal stream switching). This happens with LAV and Haali.
Play -> Audio shows all connected incoming streams to the stream switcher. That is just one with Haali and LAV. The MPC splitters create a pin for each audio stream.
Perhaps the behavior can be change so that Play->Audio shows the contents of the Navigate list when the audio stream switcher has only 1 input stream.
MPC-HC 2.3.0
Old 8th July 2011, 18:17   #4047  |  Link
Underground78
Yeah those two menus probably need to be somehow merged I guess.
Old 9th July 2011, 06:50   #4048  |  Link
nevcairiel
Here is a new test build for anyone brave enough:
http://files.1f0.de/lavf/LAVFilters-...0-g66b84fa.zip
And i'm off for the weekend, have fun.
Old 9th July 2011, 11:06   #4049  |  Link
Gleb Egorych
nevcairiel, thanks!
DTS no_sound/low_volume bug is fixed and Zoom Player compatibility is improved by adding "Remove Audio Decoder on Audio Stream Switch" option.
Gleb Egorych is offline   Reply With Quote
Old 9th July 2011, 16:15   #4050  |  Link
mark0077
nev, I have tried you're latest splitter again today on some mkv files, and I'm not sure if they were badly made or not (made about 6 months ago using MakeMKV), but with lav splitter I can't seek to any point in them again. With haali I can. If you need a sample let me know or maybe you already know if this is something that can be improved or not?
For the moment I have to use haali for mkv, although I'd rather have your filters / decoders 100%
mark0077 is offline   Reply With Quote
Old 10th July 2011, 07:05   #4051  |  Link
ney2x
FYI. Someone made a media foundation FLAC codec http://free-codecs.com/download/Medi...FLAC_Codec.htm . It's good news, cause if someone starts to make media foundation codec, I think this will be the "go signal" for other developers to migrate other codec into MF.
ney2x is offline   Reply With Quote
Old 10th July 2011, 09:01   #4052  |  Link
Superb
lol, how exactly is it a "go signal" for developers?
Superb is offline   Reply With Quote
Old 10th July 2011, 11:07   #4053  |  Link
ney2x
That's why I said, " I think" --- there's a possibility, maybe or possible.
Old 11th July 2011, 12:55   #4054  |  Link
nevcairiel
Decoders are easy, i could probably add MF support to LAV Audio in a days work (not that i will). Source Filters is where all the hard work is at.
Old 11th July 2011, 22:12   #4055  |  Link
Po
!Complain
Here a TS sample to improve LAV Splitter.
http://www.mediafire.com/?dkxrsbk79kkkbys
Vista x86, ATI HD5850
Po is offline   Reply With Quote
Old 13th July 2011, 21:40   #4056  |  Link
hoborg
@nevcairiel:
Will be possible to use LAV audio decoder with MS demultiplexer for eac3?
FFDshow audio decoder is working, but LAV refuse connection.
Here is an eac3 .ts sample
Working machine: Win10x64 + Intel Skull Canyon
My HTPC.
How to start with Bitcoin
hoborg is offline   Reply With Quote
Old 13th July 2011, 22:50   #4057  |  Link
nevcairiel
Originally Posted by hoborg View Post
@nevcairiel:
The MS MPEG-2 Demultiplexer does not open that file here.
Old 14th July 2011, 18:59   #4058  |  Link
hoborg
You can try to play it in NPVR (or other PVR software based on MS demultiplexer).
I did some research, and it looks like it can be subtype problem.
LAV splitter and MediaPortal TS reader output EAC3 as {A7FB87AF-2D02-42FB-A4D4-05CD93843BDD} (both are working) but Ms demultiplexer use {71CFA727-37E4-404A-AEC0-34842532EFF7} (LAV audio decoder refuse connection).
My HTPC.
Old 14th July 2011, 19:02   #4059  |  Link
nevcairiel
Thats the ArcSoft DDPlus type. I added it on output of E-AC3 to LAV Splitter, but not on input in LAV Audio. I can add it, i guess.
Not feeling installing that silly player again, it installs some weird background thingy.
Edit:
Try this: http://files.1f0.de/lavf/LAVFilters-...0-g60871ec.zip
Old 14th July 2011, 19:16   #4060  |  Link
hoborg
@nevcairiel:
Working. As always
So now only HE/LATM AAC remain
My HTPC.
