Old 5th October 2022, 17:30   #24881  |  Link
Thunderbolt8
so the (side) Ls/Rs setup is the common one nowadays? and so the track is not a rather a-typical one? would it sound strange if your setup is rather rear/behind when you play this "side" track or would it sound as it is supposed to be?
Laptop Lenovo Legion 5 17IMH05: i5-10300H, 16 GB Ram, NVIDIA GTX 1650 Ti (+ Intel UHD 630), Windows 10 x64, madVR (x64), MPC-HC (x64), LAV Filter (x64), XySubfilter (x64) (K-lite codec pack)
Old 5th October 2022, 18:48   #24882  |  Link
if you want it to sound as it is intended you theoretical need to change the speaker setup in that case.
with bit streaming your AVR my even be remixing to move them ever so slightly if it knows your speaker position.
i suggest you to just ignore it. it's a spec that is hard to follow.
maybe there are now audio renderer where you can specify your setup but i don't know that.
even if your setup is "incorrect" it will not sound terrible.
Old 6th October 2022, 12:09   #24883  |  Link
tebasuna51
tebasuna51's Avatar
Standard channel layouts:
5.1            FL+FR+FC+LFE+BL+BR  standard in XX Century (decoded from Ls-Rs in AC3,DTS,...)
5.1(side)      FL+FR+FC+LFE+SL+SR  standard in XXI Century (decoded from Ls-Rs in AC3,DTS,...)
Read also https://mediaarea.net/AudioChannelLayout to understand different names for channels
An AVR 5.1 send to Surround speakers (Ls-Rs 110-120) both channels SL-SR 90 (Lss-Rss) and BL-BR 150 (Lb-Rb)
Old 23rd October 2022, 19:48   #24884  |  Link
flossy_cake
In LAV Video if I set Deinterlacing Mode to Auto, does this mean my selected Software deinterlacer will only be activated if the stream has interlace flags? And is this 100% reliable in terms of avoiding false positives -- i.e could some progressive sources be accidentally detected as interlaced and therefore have software deinterlacing applied to them which would needlessly degrade the progressive image?
Old 24th October 2022, 13:10   #24885  |  Link
el Filou
el Filou's Avatar
Yes; and no.
As the tooltip says, 'Auto' uses frame flags to decide.
If a progressive stream is incorrectly flagged as interlaced frames, it will be passed through the chosen software deinterlacer.
Old 1st November 2022, 09:34   #24886  |  Link
flossy_cake
Sorry if this is a silly question but is there an arg I can pass to LAV Splitter to tell it to select a particular subtitle track? I know I can pass it eg. "eng" to select the English track, but I have multiple English tracks, eg. track 2 is an English commentary track. Is there some arg I can pass to tell it "track 2"?
I have read the readme here but it doesn't seem to cover such a scenario.
In case you're wondering why don't I just use MPC-HC's built in subtitle selector or LAV Splitter's tray icon...the answer is that I'm calling LAV Splitter from Avisynth via DSS2() and I am trying to pass it arguments for subtitle track selection so that I don't have to manually set it every time I open the .avs file.
edit: code sample
video = dss2(sourcefile, subsm=2, lavs="l3 vc2 sm3 sl[] sa[eng] es0 ti1", lavf_path="C:\Program Files (x86)\K-Lite Codec Pack\Filters\LAV64")
audio = directshowsource(sourcefile, video=false, audio=true)
AudioDub(video, audio)
Old 2nd November 2022, 04:24   #24887  |  Link
Sunspark
The only way I know of is via using the @ operator.
eng@SDH eng@ass both work.. I don't have commentary tracks so I can't see how they're labelled on your side, but eng@commentary or whatever is in the square brackets should work.
Old 2nd November 2022, 11:35   #24888  |  Link
flossy_cake
Thank you, it works:
Old 6th November 2022, 01:13   #24889  |  Link
flossy_cake
I was wondering about how LAV Video handles the "repeat flags" for "soft telecined" NTSC DVD MPEG2 streams.
From what I can tell the MPEG2 stream on the disc is stored as 24p but contains some "repeat flags" to tell the player when to repeat frames/fields to make it come out as 60hz 3:2 pattern.
This makes sense but how does LAV handle it exactly -- is it creating repeat FIELDS or FRAMES? Does it assume 60hz in its calculation for repeating these fields/frames?
I noticed when playing such material on 120hz display, I still have 3:2 judder even though 24 goes 5:5 into 120. From this I'm inferring that LAV Decoder must be assuming the repeat flags are intended for 60hz display -- is that codified in the MPEG2 spec or does LAV make the decision about the timing of the repeat flags?
edit: after some more testing it seems LAV uses the repeat flags to convert it to 60p. The LAV settings GUI doesn't seem to offer an option to not perform this conversion and just output it as 24p.
edit: a 60i option would be nice too as there are some edge cases where that can be beneficial.
Old 6th November 2022, 10:29   #24890  |  Link
nevcairiel
LAV does not repeat fields on its own. It forwards the metadata to the renderer, which can decide to repeat frames, or not to.
Old 7th November 2022, 08:14   #24891  |  Link
as far as i know the Microsoft decoder is outputting soft telecine as hard telecine and the lav is not so you have to disable the Microsoft decoder to get soft telecine.
and if i remember correctly the microsoft decoder is used by default when a normal dvd is loaded to make menus work.
Old 10th November 2022, 17:29   #24892  |  Link
nevcairiel
LAV Filters 0.77
LAV Splitter
- Fixed: Improved handling of multichannel PCM channel assignments
- Fixed: MP4 Keyframe information could be wrong
LAV Audio
- NEW: Support for audio with more then 8 channel, including automatic downmixing if required
Download: Installer (both x86/x64) -- Zips: 32-bit & 64-bit
Nothing much to say for this one. Lots of under-the-hood changes in FFmpeg, bugfixes, speedups, etc. dav1d was updated for faster AV1 decoding.
Thats it. Short and sweet.
Old 10th November 2022, 18:26   #24893  |  Link
Manni
Thanks for all your work
Win11 Pro x64 b23H2
Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 546.65
JRVR/LAV/jRiver/MyMovies/CMC
Denon X8500HA>HD Fury VRRoom>Samsung 77S90C
Old 10th November 2022, 20:05   #24894  |  Link
ryrynz
ryrynz's Avatar
Stellar as always.
Old 10th November 2022, 21:13   #24895  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
I wonder if someone can help...
I've managed to configure LAV Filters to parse every audio format with MPC-BE 1.6.4. except LPCM.wav files!
What do I need to do?
Old 11th November 2022, 11:40   #24896  |  Link
chros
chros's Avatar
Thanks Nev!
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config
Old 11th November 2022, 11:57   #24897  |  Link
tebasuna51
tebasuna51's Avatar
LAV Filters 0.77
[CODE]
LAV Splitter
Many thanks!
Old 14th November 2022, 03:34   #24898  |  Link
AYColumbia
AYColumbia's Avatar
Thanks very much.
AYColumbia is offline   Reply With Quote
Old 11th December 2022, 23:08   #24899  |  Link
Mercury_22
@Nev
Strange thing happens when playing a YouTube clip: audio ends 20s - 60s before video ends, which doesn't happen when using MPC-BE's internal splitter
Intel UHD Graphics 750; Win 10 22H2
Mercury_22 is offline   Reply With Quote
Old 11th December 2022, 23:41   #24900  |  Link
clsid
Working fine here. So if it happens with all files/streams, the problem is at your end.
If problem only happens with certain files/stream, you need to give a link to an example.
MPC-HC 2.3.0
