Old 18th August 2020, 08:32   #24001  |  Link
NikosD
Originally Posted by NikosD View Post
Haswell's and probably onwards Intel's HW H.264 is the fastest (even from Turing) and I have already tested 4K H.264 L5.2 Ref 16 with huge bandwidth (1Gbps) and with success
And I have to correct myself, as 4K H.264 L5.2 samples of my test, had Ref 5 and 1080p H.264 L5.2 samples had Ref 16.
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
Old 18th August 2020, 08:47   #24002  |  Link
alleway
hi i would like to know is there a way lav is able to decode dts:x. if i set atmos to bitstream my avr will indicate atmos is playing but for dts:x when i set it to bitstream my avr doesnt indicate it is playing dts:x. my avr is atmos and dts:x capable.
alleway is offline   Reply With Quote
Old 18th August 2020, 08:53   #24003  |  Link
nevcairiel
Thats the big limit there, more then 5 ref frames at 4K is going over the L5.2 limit and likely causing these issues.
Old 18th August 2020, 09:13   #24004  |  Link
nevcairiel
No, LAV does not decode DTS:X, but if its present in the bitstream then the full bitstream is being send untouched to your receiver. LAV does not modify it at all.
Old 18th August 2020, 09:33   #24005  |  Link
alleway
thanks nev for the info. so dts:x audio will still be present if i set it to bitstream right?
Old 18th August 2020, 10:37   #24006  |  Link
nevcairiel
It should be. LAV does not modify it at all.
Old 18th August 2020, 10:57   #24007  |  Link
alleway
got it. thanks nev👍👍
Old 18th August 2020, 11:31   #24008  |  Link
NikosD
The first HW decoders of H.264 could properly decode 1080p up to L4.1 with maximum number of ReF 4, which was the level used by Blu-ray.
It took years for HW decoders to support properly H.264 1080p L5.1 Ref 16, due to very limited commercial support.
I still remember that 1080p H.264 L5.1 Ref 16 Samsung demo clip with something like an aquarium, which was a nightmare to decode for HW H.264 decoders of that time.
Likewise, due to very limited commercial support of beyond UHD use of H.264 codec, I don't expect companies to revise their HW H.264 decoder soon (or ever) in order to support L6.x
Old 20th August 2020, 12:22   #24009  |  Link
clsid
HEVC sample that decodes wrong with DXVA2. Playback is ok with software decoding or CUVID.
Problem seems to be that main10 dxva2 decoder is used, while this video is 8bit. MediaInfo indicates profile "Main 10@L4.1@Main".
Old 20th August 2020, 23:11   #24010  |  Link
VBB
VBB's Avatar
Nev, just wanted to let you know that the cert to 1f0.de has expired again, which you probably already know
Henry | LG OLED65C7P | Denon AVR-X3500H | ELAC Uni-Fi x7 | ELAC Debut 2.0 SUB3030 x2 | NVIDIA SHIELD TV Pro 2019 | Plex
VBB is offline   Reply With Quote
Old 21st August 2020, 06:58   #24011  |  Link
nevcairiel
It was supposed to have moved to a new server by now, but I haven't had the time to finish the move... But i updated the old certificates in the meantime.
Old 27th August 2020, 14:57   #24012  |  Link
chainik_svp
nevcairiel
Could you please give a small hint regarding DirectShow magic?
https://forum.doom9.org/showthread.php?t=180424 - a DS transform filter running Avisynth script. We want to pass-through HDR meta-data from LAV to madVR. What could be the easiest way to do this?
AFAIU IMediaSideData must be attached to the media sample. But when I simply trying to QueryInterface() on the received IMediaSample - it doesn't work. What am I doing wrong? o_O
Probably there's another way to simply copy that "attached" data block from the input sample to output, w/o "parsing" it?
SVPflow motion interpolation
chainik_svp is offline   Reply With Quote
Old 27th August 2020, 16:18   #24013  |  Link
nevcairiel
If you are implementing your own sample allocator, you need to make sure that it implements IMediaSideData on the samples, otherwise it wouldn't come from anywhere. I don't think LAV actually implements it on a normal sample allocator, since in practically every normal case its provided by the renderer. So if you want to sit between LAV and madVR, you would either pass the madVR allocator to LAV, or implement IMediaSideData on a new one.
Old 27th August 2020, 16:48   #24014  |  Link
chainik_svp
Ah! indeed the IMediaSideData interface is available for the output samples. The picture begins to take shape...
Old 28th August 2020, 08:14   #24015  |  Link
vosya
In the PotPlayer's settings of the built-in video decoder there is an option "Use output queue". Activating it seems to result a more stable FPS on heavy videos. Is there something similar in LAV Video Decoder and is such functionality generally useful?
vosya is offline   Reply With Quote
Old 28th August 2020, 09:55   #24016  |  Link
it's in the lav splitter part but except for streaming or in slow local networks this shouldn't help you. render queue like in madVR or EVR should do what you ask for but that's not lav filters job.
Old 28th August 2020, 15:42   #24017  |  Link
vosya
Don't you think that the video decoder and the video renderer are different entities, and the queues in them are also different, independently controlled? This is obviously observed in the mentioned PotPlayer.
Old 28th August 2020, 20:09   #24018  |  Link
no because it was possible to break hardware decoding with to big queue in madVR.
Old 28th August 2020, 23:20   #24019  |  Link
nevcairiel
There is no functional difference on which side the queue is.
Old 29th August 2020, 04:43   #24020  |  Link
vosya
The video renderer I use, Overlay Mixer - it seems to me has no queue at all. Therefore, there is no alternative to a queue in a video decoder.
