Old 27th September 2016, 12:41   #21041  |  Link
nevcairiel
It works how it works. Use it or don't.
Old 27th September 2016, 18:07   #21042  |  Link
VictorLS
nevcairiel
You are quite right and I agree in this case, but hope that in case of CUVID you'll implement HEVC 10bit support if it will be possible https://devtalk.nvidia.com/default/topic/965840
It is very very important for me. You are my last hope (if nVIDIA will not object) for smooth watching 3840x2160p50 (60) HEVC 10bit channels from SATs on WinXP with my new GTX750 GM206 - all necessary for me video including 4K HEVC 8bit is perfect with 0.68.1 - Thank you very much for your filters.
PS. I agree even on LAV CUVID Decoder i.e. 0.14 with correct 4K h265 10bit support.
VictorLS is offline   Reply With Quote
Old 29th September 2016, 20:28   #21043  |  Link
amayra
Quality Checker
amayra's Avatar
is more than 4 months since last stable build how about last nightly is look stable enough for me
I love Doom9
amayra is offline   Reply With Quote
Old 1st October 2016, 20:54   #21044  |  Link
AngelGraves13
Has any progress been made on decoding the object based audio portion of Atmos and/or DTS:X?
What new features of bug fixes could we expect in the next stable version?
AngelGraves13 is offline   Reply With Quote
Old 1st October 2016, 23:12   #21045  |  Link
what's the point of decoding object based audio codecs?
you need a mixer/audio renderer that can handle this type of audio too.
Old 2nd October 2016, 04:14   #21046  |  Link
VictorLS
max_verem from https://devtalk.nvidia.com/default/topic/965840 with philipl's help can hardware play 4K HEVC 10bit (as I understand with 8bit dithering) using CUVID on Linux already.
Developers of LAV Video Decoder, tell please is it possible, theoretically, to do the same with CUVID in LAV Video Decoder?
And one more question: why CUVID not work on Win10 totally?
PS. Despite of last question I need CUVID H265 10bit hardware decoding on WinXP and Win7x64.
Old 2nd October 2016, 04:51   #21047  |  Link
CruNcher
CruNcher's Avatar
@nevcairiel
what is that ?
every scene change in the Transformer (ATME Kyrion Encoder) sample causes a massive latency spike of 15 ms ?
http://demo-uhd3d.com/fiche.php?cat=uhd&id=22
Lav Video (15 ms latency spike every scene change)
Lentoid Decoder (no issue)
I Frame decoding performance issue ?
i guess it could match with this
Lav Video CPU
Lentoid CPU
It is about Time
Old 2nd October 2016, 07:19   #21048  |  Link
AngelGraves13
The same reason we wanted to be able to decode DTS-HD MA...
To fully experience the audio track without compromises.
Old 2nd October 2016, 08:52   #21049  |  Link
even if you can decode it you can't use it.
what is the compromises of bit streaming object based audio. every hardware has to bit stream it.
even if we could decode object based audio and send this decode data to your AVR it couldn't do anything with it.
Old 2nd October 2016, 10:33   #21050  |  Link
e-t172
DTS-HD MA is a "traditional" format. It decodes to a fixed number of channels, like TrueHD or FLAC. Object-based audio is a completely different paradigm entirely, which makes things harder. If the audio decoder outputs decoded object-based audio, the next step in the chain (the audio renderer) needs to know what do to with it. In practice, that probably means someone needs to write an audio renderer that is capable of correctly mixing and rendering object audio while taking end user setup into account (how many speakers and where they're located). That's a lot of work - way more work than would be required to support a traditional format.
e-t172 is offline   Reply With Quote
Old 2nd October 2016, 19:50   #21051  |  Link
markanini
I'd love to see replaygain support.
markanini is offline   Reply With Quote
Old 3rd October 2016, 00:08   #21052  |  Link
CruNcher
CruNcher's Avatar
Hmm lav 68.1-31
causing sync issues again
sonyvegas14_best_hightier_360°.mov
https://www.sendspace.com/file/87bq1x
Something wrong on the splitter side or the decoder or both ?
tried the file with nightly MPV it plays fine
PS: Just tried MPC-BE Internal nightly filters they work also just fine with the bitstream so looks like a bug, though the scene change issues with the transformer bitstream remain untouched.
Lentoid still fails with the bitstream and mpc-be splitter combo
It is about Time
Old 3rd October 2016, 15:51   #21053  |  Link
clsid
The Frame Time Correction option in MPC-HC can 'fix' the problems with that sample.
Old 3rd October 2016, 18:21   #21054  |  Link
CruNcher
CruNcher's Avatar
right just pushing c with lav video and the problem is gone
aiks what is the right/wrong behavior now ?
should it always only playback with the FTC correctly on EVR with 25 fps or should it playback from itself like in MPV (ogl) and MPC-BE without FTC @25 fps on EVR ?
FTC has also impact on the Transformer Sample instead of 3 or 4 consective dropouts after a scene change you only get 1 bigger one though im not really sure which behavior is to prefer both is bad in its own way
with ftc
without ftc
Though if i think about it maybe it was done on purpose to get this stop hard cut effect ?
but that makes no sense at all as scene blends that got detected as sencechanges are also affected so most probably it really is a overflow situation on Atemes encoder side @ that time
It is about Time
Old 8th October 2016, 22:22   #21055  |  Link
fxv300
DXVA corruption
This issue also happens with AMD Polaris range.
It could be a LAV filter issue.
Blog here
video
Originally Posted by Clemens View Post
Hello,
I have heavy artifacts if I use dxva2 (native) with my GTX 960 4gb, with Software decoding or QSV it's no problem.
The content is of a TV channel, some of the times its just fine on that channel sometimes I get the artifacts.
Here you can download the sample (is SD and I think H.264): https://www.dropbox.com/s/2zxhgqx2dh...ia_bug.ts?dl=0
Is this a known bug? Is there a workaround? Have others also problems with Nvidia graphics playing this short sample?
If needed I want to make screen record of the artifact...
Thanks and kind regards,
Clemens
AMD PhenomII 6core T1100 3.3Ghz W10_64_16G Ram Sapphire RX 480 8G SoundsOKOK QAcoustic 2020i, ROKU4
AzureWave AD-SP400 DVB-S2 BlackGold BGT3620 DVB-T2 Monitor LG 27MU67 SONY STR-DN8600
fxv300 is offline   Reply With Quote
Old 9th October 2016, 08:24   #21056  |  Link
nevcairiel
All these issues happen with other decoder as well, sometimes at slightly different circumstances, but still happens. Polaris decoders are just broken, if its in drivers or in the hardware only AMD can tell you.
The sample you quoted for example is also broken with Microsofts decoder, so its very likely a driver or hardware issue.
People really shouldn't jump to conclusions without proper information. H264 DXVA2 decoding in particular has been well tested over various generations of hardware, so if suddenly a specific piece of hardware shows issues, its far more likely to be that hardware (or its drivers), rather than a fundamental issue in the software. Even more so if other decoders show the same problems.
Old 14th October 2016, 00:39   #21057  |  Link
CruNcher
CruNcher's Avatar
As i said wouldn't really surprise seeing how catastrophically UVDs Parser behavior was especially at the beginning with Broadcast and Resilience Playback Nvidia had only very minor issues that got really fast fixed 1 after another via Firmware updates early on through lot of developer and community feedback with problematic bitstreams (not bios firmware but the VPX Firmware on the Driver side) mostly.
So this is something AMD still has to go through to get their Hardware more stable in the future lot of bad decision in the past where made and Nvidia ran so fast away with their more open ecosystem approach initiated by Roy Taylor back then, until Intel arrived and hell did they pressured.
We already see some some really great things from him now being the Corporate Vice President of Alliances for practically the whole AMD Ecosystem which even became so much more open then we just could have dreamed for on Nvidias side now feedback will be the key to domination the faster this process runs now the better.
And i really see that Doom9 once again could become the major aggregation point for this feedback and enhancing process for AMDs UVD and Media SDKs
It is about Time
Old 15th October 2016, 08:17   #21058  |  Link
Joniii
Is there any way to to make LAV Filters prefer AC3 core from TrueHD?
My receiver doesn't support TrueHD and LAV Filters always plays TrueHD if available and I have to manually change to AC3 core from MPC-HC.
Windows 10 Pro 2004 with Media Center, 2 x DVB-C with cable cards
MPC-HC (madVR, LAV Filters, XySubFilter)
Sony Bravia 85X950H/85XH95
Yamaha RX-V685
Yamaha Piano Black NS-777/555/C444/YST-SW315
Joniii is offline   Reply With Quote
Old 15th October 2016, 11:02   #21059  |  Link
ryrynz
ryrynz's Avatar
Just untick 'Dolby TrueHD' under 'Bitstreaming (S/PDIF, HDMI)' options in LAV Audio.
Old 15th October 2016, 14:10   #21060  |  Link
Joniii
That's how I've always set it up, but LAV Audio selects TrueHD as default and I have to manually select AC3 core.
Yamaha RX-V685
