Go Back   Doom9's Forum > Hardware & Software > PC Hard & Software
Old 20th May 2010, 06:14   #141  |  Link
woah!
Originally Posted by prOnorama View Post
x264 HD BENCHMARK 3.0 RESULTS
Please do not compare it with older versions of the benchmark!
Please copy/paste everything below the line to to report your data
Results for x264.exe r1342
encoded 1442 frames, 69.54 fps, 3901.21 kb/s
encoded 1442 frames, 69.44 fps, 3900.93 kb/s
encoded 1442 frames, 69.23 fps, 3900.68 kb/s
encoded 1442 frames, 68.21 fps, 3900.44 kb/s
encoded 1442 frames, 21.04 fps, 3971.89 kb/s
encoded 1442 frames, 21.06 fps, 3970.63 kb/s
encoded 1442 frames, 21.09 fps, 3971.74 kb/s
encoded 1442 frames, 21.10 fps, 3971.64 kb/s
System Details
	Name			AMD Phenom II X4 955
	Codename		Deneb
	Specification		AMD Phenom(tm) II X4 955 Processor
	Core Stepping		RB-C2
	Technology		45 nm
	manufacturer		Gigabyte Technology Co., Ltd.
	vendor			Gigabyte Technology Co., Ltd.
	Core Speed		3214.6 MHz
Northbridge			AMD 790X rev. 00
Southbridge			ATI SB750 rev. 00
CAS# latency (CL)		9.0
RAS# to CAS# delay (tRCD)	9
RAS# Precharge (tRP)		9
Cycle Time (tRAS)		24
Command Rate (CR)		1T
Memory Frequency		669.7 MHz (3:10)
Memory Type			DDR3
Memory Size			4096 MBytes
Channels			Dual, (Unganged)
Windows Version			Microsoft Windows XP Home Edition  Service Pack 3 (Build 2600)
Number of processors		1
Number of threads		4
	Number of threads	4 (max 4)
	L2 cache		4 x 512 KBytes, 16-way set associative, 64-byte line size
	Instructions sets	MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64
	Package 		Socket AM2+ (940)
	Package Type		0x1
	Temperature 0	43C (109F) [0x2B] (TMPIN0)
	Temperature 1	73C (163F) [0x49] (TMPIN1)
	Temperature 2	64C (147F) [0x40] (TMPIN2)
	Temperature 0	73C (163F) [0x249] (Core #0)
	Temperature 1	73C (163F) [0x249] (Core #1)
	Temperature 3	73C (163F) [0x249] (Core #3)
	Temperature 2	73C (163F) [0x248] (Core #2)
@ woah!: Thuban gives a nice speed boost over Deneb (though it has a significant overclock, dunno how fast it is @ stock)
heres stock 1055T which runs at 2800mhz on all 6 cores %100. it clocks to 3300mhz when only 1/2/3 cores are needed...
encoded 1442 frames, 65.41 fps, 3898.70 kb/s
encoded 1442 frames, 68.26 fps, 3898.70 kb/s
encoded 1442 frames, 66.88 fps, 3898.70 kb/s
encoded 1442 frames, 65.92 fps, 3898.70 kb/s
encoded 1442 frames, 26.58 fps, 3969.57 kb/s
encoded 1442 frames, 26.82 fps, 3967.79 kb/s
encoded 1442 frames, 26.80 fps, 3970.30 kb/s
encoded 1442 frames, 26.85 fps, 3955.28 kb/s
System Details
	Name			AMD Phenom II X6 1055T
	Name			NVIDIA GeForce GTX 260
	Codename		Thuban
	Codename		GT200
	Specification		AMD Phenom(tm) II X6 1055T Processor
	Specification		PC3-12800
	Core Stepping
	Technology		45 nm
	Technology		55 nm
	Stock frequency		3300 MHz
	Core Speed		3314.9 MHz
	FID range		4.0x - 16.5x
Northbridge			AMD 890GX rev. 00
Southbridge			AMD SB850 rev. 40
	Command Rate		2T
	Command Rate		2T
Memory Type			DDR3
Windows Version			Microsoft Windows XP Professional  Service Pack 3 (Build 2600)
Number of threads		6
	Number of threads	6 (max 6)
	L2 cache		6 x 512 KBytes, 16-way set associative, 64-byte line size
	Instructions sets	MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V
	Package 		Socket AM3 (938)
	Package Type		0x1
	Temperature 0	36C (96F) [0x24] (TMPIN0)
	Temperature 1	28C (82F) [0x1C] (TMPIN1)
	Temperature 2	35C (94F) [0x23] (TMPIN2)
	Temperature 0	20C (67F) [0xA0] (Core #0)
	Temperature 1	20C (67F) [0x9D] (Core #1)
	Temperature 3	19C (66F) [0x9B] (Core #3)
	Temperature 2	20C (67F) [0x9C] (Core #2)
	Temperature 4	19C (66F) [0x9B] (Core #4)
	Temperature 5	20C (67F) [0x9D] (Core #5)
	Temperature 0	48C (118F) (GPU Core)
woah! is offline   Reply With Quote
Old 20th May 2010, 13:06   #142  |  Link
CpT
For the price that's a pretty sweet chip.
Considering what I have into this rig I could have built 2 or 3 of those rigs and setup a mini encoding/crunching farm.
When I get a minute I wanna poke around for dual socket mobos for it...
Something else worth checking out is this ramdisk software.
http://www.superspeed.com/desktop/ramdisk.php
I have a 3gb ramdisk that I run the benchmark from. It helps with initial analysis and seems to make the first pass a little faster.
Currently I'm on a 32bit os ugggggg, but this app lets me use the non accessible ram to make a ramdisk out of
CpT is offline   Reply With Quote
Old 23rd May 2010, 16:52   #143  |  Link
ChiDragon
ChiDragon's Avatar
Results for my stock Athlon 64 X2 5200+. Results are in between the 4200+ and 5600+ already listed, as you would expect...
encoded 1442 frames, 29.58 fps, 3899.26 kb/s
encoded 1442 frames, 29.59 fps, 3899.26 kb/s
encoded 1442 frames, 29.43 fps, 3899.26 kb/s
encoded 1442 frames, 6.81 fps, 3970.95 kb/s
encoded 1442 frames, 6.80 fps, 3971.19 kb/s
encoded 1442 frames, 6.81 fps, 3970.94 kb/s
encoded 1442 frames, 6.74 fps, 3971.43 kb/s
System Details
	Name			AMD Athlon 64 X2 5200+
	Codename		Brisbane
	Specification		AMD Athlon(tm) 64 X2 Dual Core Processor 5200+
	Core Stepping		BH-G2
	Technology		65 nm
	Stock frequency		2700 MHz
	Core Speed		2709.3 MHz
Northbridge			AMD 780G rev. 00
Southbridge			ATI SB700 rev. 00
CAS# latency (CL)		5.0
RAS# to CAS# delay (tRCD)	5
RAS# Precharge (tRP)		5
Cycle Time (tRAS)		15
Command Rate (CR)		2T
Memory Frequency		387.0 MHz (CPU/7)
Memory Type			DDR2
Channels			Dual
Number of threads		2
	Number of threads	2 (max 2)
	L2 cache		2 x 512 KBytes, 16-way set associative, 64-byte line size
	Instructions sets	MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
	Package 		Socket AM2 (940)
	Temperature 1	96C (204F) [0x60] (TMPIN1)
	Temperature 0	61C (141F) [0x163] (Core #0)
	Temperature 1	60C (139F) [0x160] (Core #1)
ChiDragon is offline   Reply With Quote
Old 26th May 2010, 03:42   #144  |  Link
Assassinator
Assassinator's Avatar
Phenom 9550 (yes, the old school phenom). Small overclock, cbf overvoltaging to get more.
encoded 1442 frames, 65.88 fps, 3915.51 kb/s
encoded 1442 frames, 66.26 fps, 3915.51 kb/s
encoded 1442 frames, 65.89 fps, 3915.51 kb/s
encoded 1442 frames, 65.70 fps, 3915.51 kb/s
encoded 1442 frames, 17.83 fps, 3969.48 kb/s
encoded 1442 frames, 17.70 fps, 3969.28 kb/s
encoded 1442 frames, 17.84 fps, 3969.85 kb/s
encoded 1442 frames, 17.83 fps, 3970.09 kb/s
System Details
	Name			AMD Phenom X4 9550
	Codename		Agena
	Specification		AMD Phenom(tm) 9550 Quad-Core Processor
	Core Stepping		DR-B3
	Technology		65 nm
	Stock frequency		2200 MHz
	Core Speed		2640.1 MHz
	FID range		5.0x - 11.0x
Cycle Time (tRAS)		13
Memory Frequency		400.0 MHz (3:5)
Memory Type			DDR2
Windows Version			Microsoft Windows 7 (6.1) Ultimate Edition   (Build 7600)
Number of threads		4
	Package Type		0x1
	Temperature 1	56C (132F) [0x38] (TMPIN1)
	Temperature 2	63C (145F) [0x3F] (TMPIN2)
	Temperature 0	44C (111F) [0x160] (Core #0)
	Temperature 1	44C (111F) [0x160] (Core #1)
	Temperature 3	44C (111F) [0x160] (Core #3)
	Temperature 2	44C (111F) [0x160] (Core #2)
Originally Posted by mochevolete View Post
that's why I MUST upgrade the CPU for faster encodings ...
Time to dig that 486 out from the back of the garage, install win95, compile x264, and encode! Gonna rape you all... in the number of days it takes to finish the benchmark!
EDIT: Actually, that won't work , won't even have close to enough memory needed to pull off the HD encode.
In the meanwhile, Netbook!
encoded 1442 frames, 7.00 fps, 3899.26 kb/s
encoded 1442 frames, 7.02 fps, 3899.26 kb/s
encoded 1442 frames, 7.04 fps, 3899.26 kb/s
encoded 1442 frames, 1.59 fps, 3971.07 kb/s
encoded 1442 frames, 1.59 fps, 3970.89 kb/s
encoded 1442 frames, 1.59 fps, 3971.90 kb/s
encoded 1442 frames, 1.60 fps, 3971.85 kb/s
System Details
	Name			Intel Atom N270
	Codename		Diamondville
	Specification		Intel(R) Atom(TM) CPU N270   @ 1.60GHz
	Core Stepping		C0
	Technology		45 nm
	Stock frequency		1600 MHz
	Core Speed		1596.1 MHz
	FID range		6.0x - 12.0x
Northbridge			Intel i945GSE rev. 03
Southbridge			Intel 82801GHM (ICH7-M/U) rev. B0
CAS# latency (CL)		4.0
RAS# to CAS# delay (tRCD)	4
RAS# Precharge (tRP)		4
Cycle Time (tRAS)		12
Memory Frequency		266.0 MHz (1:2)
Memory Type			DDR2
Memory Size			1024 MBytes
Channels			Single
Number of threads		2
	L2 cache		512 KBytes, 8-way set associative, 64-byte line size
	Instructions sets	MMX, SSE, SSE2, SSE3, SSSE3
	Package (platform ID)	Socket 437 FCBGA8 (0x2)
	Temperature 0	74C (165F) [0x1F] (Core #0)
Assassinator is offline   Reply With Quote
Old 6th November 2017, 18:59   #145  |  Link
imsrk48
imsrk48's Avatar
Megui profiles please for 480p better quality
Sent from my P4 using Tapatalk
imsrk48 is offline   Reply With Quote
