Go Back   Doom9's Forum > Hardware & Software > PC Hard & Software
Old 17th April 2008, 07:33   #41  |  Link
graysky
graysky's Avatar
@jay - can you give me the system specs?
graysky is offline   Reply With Quote
Old 17th April 2008, 14:16   #42  |  Link
Japhsoncross
Phenom 9750 12x200 2.40G
DDR2 800 5-5-5-18
RD780 HT 1.8G
Windows XP SP2 32bit
---------- RUN1PASS1.LOG
encoded 1442 frames, 53.38 fps, 3905.32 kb/s
---------- RUN2PASS1.LOG
encoded 1442 frames, 52.65 fps, 3905.32 kb/s
---------- RUN3PASS1.LOG
encoded 1442 frames, 53.04 fps, 3905.32 kb/s
---------- RUN4PASS1.LOG
encoded 1442 frames, 52.86 fps, 3905.32 kb/s
---------- RUN1PASS2.LOG
encoded 1442 frames, 12.86 fps, 3953.23 kb/s
---------- RUN2PASS2.LOG
---------- RUN3PASS2.LOG
---------- RUN4PASS2.LOG
encoded 1442 frames, 12.84 fps, 3953.23 kb/s
Japhsoncross is offline   Reply With Quote
Old 17th April 2008, 14:28   #43  |  Link
aicjofs
@aicjofs
same case here too bud and wat kind of rad is that ??
That's the swiftech. A thermochill is far and away better rad, but I had never tried a Swifty so I gave it a shot on this build. Allows better spacing for cable/tubing runs since it's thinner. Much dirtier then any thermochill I have had, required numerous flushings.
Gray already asked above, but what are you running there?
aicjofs is offline   Reply With Quote
Old 17th April 2008, 21:10   #44  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
encoded 1442 frames, 57.39 fps, 3904.94 kb/s
encoded 1442 frames, 58.19 fps, 3904.94 kb/s
encoded 1442 frames, 58.34 fps, 3904.94 kb/s
encoded 1442 frames, 58.22 fps, 3904.94 kb/s
encoded 1442 frames, 28.68 fps, 3974.08 kb/s
encoded 1442 frames, 28.59 fps, 3974.08 kb/s
encoded 1442 frames, 28.62 fps, 3974.08 kb/s
encoded 1442 frames, 28.65 fps, 3974.08 kb/s
On an octo-core (2x quad) Xeon X5355 2.66 GHz on Server 2003 32 bit. 2 GB FB-DIMM 667 MHz @ 4/4/4/12
Pretty zippy!
~MiSfit
Old 18th April 2008, 00:00   #45  |  Link
jay78
mobo = Asus P5E3 Deluxe wifi
CPU = Intel Core 2 Quad Q6600 2.4ghz OC at 400fsb 3.6ghz
Ram = 2x1gb patriot pc10666 1333mhz 7-7-7-20 OC at1603mhz
Ram = 2x2gb Corsair xms3 12800 1600mhz 7-7-7-20 oc at1603mhz
both ram set at 9-9-9-24 cpu-z show 800mhz
Video = Nvidia 8800GTX
Sound = Auzentech X-Fi Prelude 7.1
HDD = 150gb Raptor, 500gb Segate 7200rpm
Speakers = Logitech z5300
Monitor = Envision 22"
PS = OCZ 850watts
WC system
CPU = EK-Supreme
GPU = Danger Den
Pump = Laing D5
RES = EK-Multioption 250 Rev2
Rad = Thermochill 120.3
Fans = Silverstone FM123
Tubing = Tygon 1/2"
for more pics ck out the link
http://www.xtremesystems.org/forums/...91#post2740391
jay78 is offline   Reply With Quote
Old 18th April 2008, 00:49   #46  |  Link
Blue_MiSfit
Results for x264.exe v0.58.747
encoded 1442 frames, 57.00 fps, 3904.94 kb/s
encoded 1442 frames, 58.63 fps, 3904.94 kb/s
encoded 1442 frames, 58.41 fps, 3904.94 kb/s
encoded 1442 frames, 58.67 fps, 3904.94 kb/s
encoded 1442 frames, 28.56 fps, 3974.08 kb/s
encoded 1442 frames, 28.58 fps, 3974.08 kb/s
encoded 1442 frames, 28.50 fps, 3974.08 kb/s
Results for x264.exe v0.59.819M
encoded 1442 frames, 58.74 fps, 3895.56 kb/s
encoded 1442 frames, 59.16 fps, 3895.96 kb/s
encoded 1442 frames, 59.05 fps, 3894.82 kb/s
encoded 1442 frames, 59.16 fps, 3895.56 kb/s
encoded 1442 frames, 31.92 fps, 3981.22 kb/s
encoded 1442 frames, 31.91 fps, 3981.30 kb/s
encoded 1442 frames, 31.89 fps, 3981.63 kb/s
encoded 1442 frames, 31.99 fps, 3981.30 kb/s
System Details
Name			Intel Xeon X5355
Codename		Clovertown
Codename		Clovertown
Specification		Intel(R) Xeon(R) CPU           X5355  @ 2.66GHz
Core Stepping		B3
Core Stepping		B3
Technology		65 nm
Technology		65 nm
Stock frequency		2666 MHz
Core Speed		2660.4 MHz (8.0 x 332.5 MHz)
FID range		6.0x - 8.0x
Northbridge		Intel 5000X rev. 12
Southbridge		Intel 6321ESB rev. 09
Memory Frequency	266.0 MHz (5:4)
Memory Type		FB-DDR2
Memory Size		2048 MBytes
Windows Version		Microsoft Windows Server 2003 Standard Edition   (Build 3790)
max VID			1.350 V
max VID			1.350 V
Number of processors	2
Number of threads	8
Number of threads	4 (max 4)
L2 cache		2 x 4096 KBytes, 16-way set associative, 64-byte line size
Instructions sets	MMX, SSE, SSE2, SSE3, SSSE3, EM64T
Package			Socket 771 LGA (platform ID = 6h)
Temperature sensor 0	59C (138F) [0x29] (core #0)
Temperature sensor 1	59C (138F) [0x29] (core #1)
Temperature sensor 2	57C (134F) [0x2B] (core #2)
Temperature sensor 3	56C (132F) [0x2C] (core #3)
Temperature sensor 0	67C (152F) [0x21] (core #0)
Temperature sensor 1	67C (152F) [0x21] (core #1)
Temperature sensor 2	62C (143F) [0x26] (core #2)
Temperature sensor 3	61C (141F) [0x27] (core #3)
New benchmark
Old 18th April 2008, 01:27   #47  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
That sucker runs hot!
Old 18th April 2008, 03:08   #48  |  Link
Blue_MiSfit
Yeah she does, but its a Dell system in a fat server room that's also a tad hot
Shouldn't be an issue when we move soon
~MiSfit
Old 18th April 2008, 06:57   #49  |  Link
graysky
graysky's Avatar
@jay - thanks... running Vista x64 or XP x64?
@blue_misfit - thanks... for the data dude!
To everyone else - blue_misfit ran the "new" version of the benchmark that is available publicly now!
There are two major changes:
1) CPU-Z outputs the hardware details automatically and the batch file greps out what I need so you don't have to manually provide me with details (see the report in blue's post above for a sample).
2) I included a newer version of x264 that is a bit faster than the version that was included back in the first part of March when the benchmark launched. I'll ALWAYS keep that original version so you can compare back to historical data, after all, the magnitude of the data isn't that important to see which system is faster than another, but it is kinda cool to see the speed increases as the software matures.
Quads tend to run 9-10 % faster with the new version.
Single core chips are anywhere from 5-15 % faster. I'll be sure to select some representative examples (AMD/Intel Quads, Duals, singles, etc.) and highlight them in the excel spreadsheet I've been maintaining and that is freely available at the techarp website.
Here are the comparative data for a Q6600 and Q9300 for now:
As I said, about 9-10 % faster.
Old 19th April 2008, 01:34   #50  |  Link
jay78
graysky
answer is all of em...
i am running
xp 32bit and xp64bit both.....
and
also vista ultimate 32bit
used xp 32bit to run the banchmark....
Old 19th April 2008, 14:31   #51  |  Link
Inventive Software
Turkey Machine
He means what you used to run the benchmark with.
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld
Inventive Software is offline   Reply With Quote
Old 20th April 2008, 16:16   #52  |  Link
Japhsoncross
x264 HD BENCHMARK RESULTS
Please copy/paste everything below the line into the forum post to report your data
encoded 1442 frames, 53.44 fps, 3905.32 kb/s
encoded 1442 frames, 53.81 fps, 3905.32 kb/s
encoded 1442 frames, 53.66 fps, 3905.32 kb/s
encoded 1442 frames, 53.47 fps, 3905.32 kb/s
encoded 1442 frames, 12.87 fps, 3953.23 kb/s
encoded 1442 frames, 12.88 fps, 3953.23 kb/s
encoded 1442 frames, 12.85 fps, 3953.23 kb/s
encoded 1442 frames, 54.38 fps, 3891.55 kb/s
encoded 1442 frames, 54.45 fps, 3888.83 kb/s
encoded 1442 frames, 54.42 fps, 3888.18 kb/s
encoded 1442 frames, 54.38 fps, 3889.26 kb/s
encoded 1442 frames, 13.83 fps, 3963.43 kb/s
encoded 1442 frames, 13.84 fps, 3963.07 kb/s
encoded 1442 frames, 13.83 fps, 3963.16 kb/s
encoded 1442 frames, 13.82 fps, 3962.51 kb/s
System Details
Name			AMD Phenom 9750
Codename		Agena
Specification		AMD Phenom(tm) 9750 Quad-Core Processor
Core Stepping		DR-B3
Technology		65 nm
Stock frequency		2400 MHz
Core Speed		2410.9 MHz (12.0 x 200.9 MHz)
FID range		5.0x - 12.0x
Northbridge		ATI RD780 rev. 00
Southbridge		ATI SB600 rev. 00
CAS#			5.0
RAS# to CAS#		5
RAS# Precharge		5
Cycle Time (tRAS)	18
Command Rate		2T
Memory Frequency	401.8 MHz (1:2)
Memory Type		DDR2
Memory Size		3328 MBytes
Channels		Dual (Ganged)
Windows Version		Microsoft Windows XP Professional  Service Pack 2 (Build 2600)
max VID			1.300 V
Voltage sensor 0	1.33 Volts [0x53] (CPU VCORE)
Number of processors	1
Number of threads	4
L2 cache		4 x 512 KBytes, 16-way set associative, 64-byte line size
Instructions sets	MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64
Package			Socket AM2+ (940)
Package Type		0x1
Temperature sensor 0	27C (80F) [0x1B] (TMPIN0)
Temperature sensor 1	52C (125F) [0x34] (TMPIN1)
Temperature sensor 2	81C (177F) [0x51] (TMPIN2)
Temperature sensor 0	64C (147F) [0x200] (core #0)
Temperature sensor 1	64C (147F) [0x200] (core #1)
Temperature sensor 3	64C (147F) [0x200] (core #3)
Temperature sensor 2	64C (147F) [0x200] (core #2)
Temperature sensor 0	33C (91F) [0x21] (GPU Core)
New benchmark.
The performance gain is 6.2%
Seems the bitrates which 819 produces are not stable
Old 20th April 2008, 17:40   #53  |  Link
Selur
Selur's Avatar
encoded 1442 frames, 77.95 fps, 3905.42 kb/s
encoded 1442 frames, 77.62 fps, 3905.42 kb/s
encoded 1442 frames, 77.56 fps, 3905.42 kb/s
encoded 1442 frames, 77.36 fps, 3905.42 kb/s
encoded 1442 frames, 21.45 fps, 3952.85 kb/s
encoded 1442 frames, 21.47 fps, 3952.85 kb/s
encoded 1442 frames, 21.46 fps, 3952.85 kb/s
encoded 1442 frames, 84.67 fps, 3886.58 kb/s
encoded 1442 frames, 84.51 fps, 3888.14 kb/s
encoded 1442 frames, 84.51 fps, 3889.26 kb/s
encoded 1442 frames, 84.90 fps, 3889.39 kb/s
encoded 1442 frames, 24.14 fps, 3963.78 kb/s
encoded 1442 frames, 24.15 fps, 3963.21 kb/s
encoded 1442 frames, 24.13 fps, 3962.76 kb/s
encoded 1442 frames, 24.13 fps, 3962.61 kb/s
System Details
Name			Intel Core 2 Quad Q9450
Codename		Yorkfield
Specification		Intel(R) Core(TM)2 Quad  CPU   Q9450  @ 2.66GHz
Core Stepping		C1
Technology		45 nm
Core Speed		3600.0 MHz (8.0 x 450.0 MHz)
Northbridge		Intel X38 rev. 01
Southbridge		Intel 82801IR (ICH9R) rev. 02
CAS#			7.0
RAS# to CAS#		7
RAS# Precharge		7
Cycle Time (tRAS)	20
Command Rate		2T
Memory Frequency	720.0 MHz (5:8)
Memory Type		DDR3
Channels		Dual (Symmetric)
max VID			1.238 V
Voltage sensor 0	1.25 Volts [0x9C] (CPU VCORE)
Number of threads	4
L2 cache		2 x 6144 KBytes, 24-way set associative, 64-byte line size
Instructions sets	MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T
Package			Socket 775 LGA (platform ID = 4h)
Temperature sensor 0	38C (100F) [0x26] (SYSTIN)
Temperature sensor 1	36C (96F) [0x48] (CPUTIN)
Temperature sensor 2	25C (76F) [0x31] (AUXTIN)
Temperature sensor 0	63C (145F) [0x2A] (core #0)
Temperature sensor 1	61C (141F) [0x2C] (core #1)
Temperature sensor 2	61C (141F) [0x2C] (core #2)
Temperature sensor 3	66C (150F) [0x27] (core #3)
Temperature sensor 0	49C (120F) [0x31] (GPU Core)
seeing the temperatures I should remember to switch some of the system fans from 5V to 12V when encoding during summer.
Cu Selur
Old 20th April 2008, 18:43   #54  |  Link
graysky
graysky's Avatar
@Selur and Japhsoncross - thanks for the data. Tables and xls file will be updated shortly.
Old 20th April 2008, 20:57   #55  |  Link
ditche
encoded 1442 frames, 33.62 fps, 3905.08 kb/s
encoded 1442 frames, 33.86 fps, 3905.08 kb/s
encoded 1442 frames, 33.84 fps, 3901.65 kb/s
encoded 1442 frames, 8.77 fps, 3942.92 kb/s
encoded 1442 frames, 8.79 fps, 3942.92 kb/s
encoded 1442 frames, 8.80 fps, 3942.92 kb/s
encoded 1442 frames, 8.78 fps, 3942.56 kb/s
encoded 1442 frames, 37.64 fps, 3888.04 kb/s
encoded 1442 frames, 37.67 fps, 3886.92 kb/s
encoded 1442 frames, 37.67 fps, 3888.45 kb/s
encoded 1442 frames, 37.42 fps, 3888.14 kb/s
encoded 1442 frames, 9.84 fps, 3953.02 kb/s
encoded 1442 frames, 9.83 fps, 3953.49 kb/s
encoded 1442 frames, 9.82 fps, 3953.54 kb/s
encoded 1442 frames, 9.77 fps, 3953.34 kb/s
System Details
Name			Intel Core 2 Duo E6600
Codename		Conroe
Specification		Intel(R) Core(TM)2 CPU          6600  @ 2.40GHz
Core Stepping		B2
Technology		65 nm
Core Speed		3150.2 MHz (9.0 x 350.0 MHz)
FID range		6.0x - 9.0x
Northbridge		Intel P35/G33/G31 rev. A2
CAS#			4.0
RAS# to CAS#		4
RAS# Precharge		4
Cycle Time (tRAS)	12
Command Rate		2T
Memory Frequency	350.0 MHz (1:1)
Memory Type		DDR2
max VID			1.325 V
Voltage sensor 0	1.25 Volts [0x4E] (CPU VCORE)
Number of threads	2
Number of threads	2 (max 2)
L2 cache		4096 KBytes, 16-way set associative, 64-byte line size
Package			Socket 775 LGA (platform ID = 0h)
Temperature sensor 0	39C (102F) [0x27] (TMPIN0)
Temperature sensor 1	47C (116F) [0x2F] (TMPIN1)
Temperature sensor 0	55C (130F) [0x1E] (core #0)
Temperature sensor 1	55C (130F) [0x1E] (core #1)
Temperature sensor 0	55C (130F) [0x37] (GPU Core)
ditche is offline   Reply With Quote
Old 20th April 2008, 21:23   #56  |  Link
graysky
graysky's Avatar
hey ditche - long time no see. Got your data and will place it in the next round of updates.
Old 20th April 2008, 21:25   #57  |  Link
graysky
graysky's Avatar
Could just be a function of quads. Here are several examples of other quads:
encoded 1442 frames, 55.20 fps, 3905.42 kb/s
encoded 1442 frames, 55.59 fps, 3905.42 kb/s
encoded 1442 frames, 55.50 fps, 3905.42 kb/s
encoded 1442 frames, 15.02 fps, 3952.85 kb/s
encoded 1442 frames, 14.96 fps, 3952.85 kb/s
encoded 1442 frames, 14.98 fps, 3952.85 kb/s
encoded 1442 frames, 15.01 fps, 3952.85 kb/s
encoded 1442 frames, 59.70 fps, 3889.39 kb/s
encoded 1442 frames, 59.39 fps, 3889.10 kb/s
encoded 1442 frames, 59.54 fps, 3889.31 kb/s
encoded 1442 frames, 59.05 fps, 3888.34 kb/s
encoded 1442 frames, 16.77 fps, 3963.56 kb/s
encoded 1442 frames, 16.81 fps, 3962.87 kb/s
encoded 1442 frames, 16.79 fps, 3962.92 kb/s
encoded 1442 frames, 16.80 fps, 3963.34 kb/s
System Details
Name			Intel Core 2 Quad Q6600
Codename		Kentsfield
Specification		Intel(R) Core(TM)2 Quad CPU           @ 2.40GHz
Core Stepping		B3
Technology		65 nm
Core Speed		2666.7 MHz (8.0 x 333.3 MHz)
Northbridge		Intel P965/G965 rev. C2
Southbridge		Intel 82801HB/HR (ICH8/R) rev. 02
CAS#			4.0
RAS# to CAS#		4
RAS# Precharge		4
Cycle Time (tRAS)	10
Command Rate		2T
Memory Frequency	333.3 MHz (1:1)
Memory Type		DDR2
Memory Size		4096 MBytes
Windows Version		Microsoft Windows XP x64 Professional  Service Pack 2 (Build 3790)
max VID			1.288 V
Voltage sensor 0	1.12 Volts [0x8C] (CPU VCORE)
Number of threads	4
Temperature sensor 0	42C (107F) [0x2A] (SYSTIN)
Temperature sensor 1	42C (106F) [0x53] (CPUTIN)
Temperature sensor 2	127C (260F) [0xFE] (AUXTIN)
Temperature sensor 0	51C (123F) [0x31] (core #0)
Temperature sensor 1	54C (129F) [0x2E] (core #1)
Temperature sensor 2	48C (118F) [0x34] (core #2)
Temperature sensor 3	49C (120F) [0x33] (core #3)
Temperature sensor 0	52C (125F) [0x34] (GPU Core)
encoded 1442 frames, 61.09 fps, 3905.42 kb/s
encoded 1442 frames, 59.83 fps, 3905.42 kb/s
encoded 1442 frames, 61.18 fps, 3905.42 kb/s
encoded 1442 frames, 61.30 fps, 3905.42 kb/s
encoded 1442 frames, 17.57 fps, 3952.85 kb/s
encoded 1442 frames, 17.49 fps, 3952.85 kb/s
encoded 1442 frames, 17.61 fps, 3952.85 kb/s
encoded 1442 frames, 17.50 fps, 3952.85 kb/s
encoded 1442 frames, 65.61 fps, 3891.55 kb/s
encoded 1442 frames, 65.42 fps, 3891.55 kb/s
encoded 1442 frames, 66.07 fps, 3889.35 kb/s
encoded 1442 frames, 65.65 fps, 3889.35 kb/s
encoded 1442 frames, 19.74 fps, 3963.43 kb/s
encoded 1442 frames, 19.76 fps, 3963.43 kb/s
encoded 1442 frames, 19.67 fps, 3963.51 kb/s
encoded 1442 frames, 19.70 fps, 3962.47 kb/s
System Details
Name Intel Core 2 Extreme QX9650
Codename Yorkfield
Specification Intel(R) Core(TM)2 Extreme CPU X9650 @ 3.00GHz (Engineering Sample)
Core Stepping C0
Technology 45 nm
Stock frequency 3000 MHz
Core Speed 3000.4 MHz (9.0 x 333.4 MHz)
CAS# 5.0
RAS# to CAS# 6
RAS# Precharge 6
Cycle Time (tRAS) 15
Command Rate 2T
Memory Frequency 333.4 MHz (1:1)
Memory Type DDR2
Memory Size 3008 MBytes
Windows Version Microsoft Windows Vista (6.0) Ultimate Edition (Build 6000)
max VID 1.250 V
Voltage sensor 0 1.22 Volts [0x99] (CPU VCORE)
Number of threads 4
Temperature sensor 0 35C (94F) [0x23] (SYSTIN)
Temperature sensor 1 57C (134F) [0x72] (CPUTIN)
Temperature sensor 2 119C (246F) [0xEE] (AUXTIN)
Temperature sensor 0 65C (148F) [0x28] (core #0)
Temperature sensor 1 62C (143F) [0x2B] (core #1)
Temperature sensor 2 60C (139F) [0x2D] (core #2)
Temperature sensor 3 59C (138F) [0x2E] (core #3)
Temperature sensor 0 63C (145F) [0x3F] (GPU Core)
Now some single core systems:
encoded 1442 frames, 9.42 fps, 3902.58 kb/s
encoded 1442 frames, 9.40 fps, 3902.58 kb/s
encoded 1442 frames, 9.48 fps, 3902.58 kb/s
encoded 1442 frames, 9.47 fps, 3902.58 kb/s
encoded 1442 frames, 2.26 fps, 3936.11 kb/s
encoded 1442 frames, 2.28 fps, 3936.11 kb/s
encoded 1442 frames, 9.96 fps, 3882.40 kb/s
encoded 1442 frames, 9.84 fps, 3882.40 kb/s
encoded 1442 frames, 2.39 fps, 3947.86 kb/s
encoded 1442 frames, 2.38 fps, 3947.86 kb/s
System Details
Name			AMD Athlon XP
Codename		Barton
Specification		AMD Athlon(tm) XP 3200+
Core Stepping
Technology		0.13 um
Core Speed		2205.1 MHz (11.0 x 200.5 MHz)
Northbridge		NVIDIA nForce2 Ultra 400 rev. C1
Southbridge		NVIDIA nForce2 MCP-T rev. A4
CAS#			2.0
RAS# to CAS#		2
RAS# Precharge		2
Cycle Time (tRAS)	6
Memory Frequency	200.5 MHz (1:1)
Memory Type		DDR
Memory Size		1024 MBytes
Channels		Dual
Number of threads	1
Number of threads	1 (max 1)
L2 cache		512 KBytes, 16-way set associative, 64-byte line size
Package			Socket A (462)
encoded 721 frames, 8.24 fps, 3857.71 kb/s
encoded 721 frames, 8.28 fps, 3857.71 kb/s
encoded 721 frames, 8.34 fps, 3857.71 kb/s
encoded 721 frames, 8.29 fps, 3857.71 kb/s
encoded 721 frames, 2.00 fps, 3912.28 kb/s
encoded 721 frames, 9.01 fps, 3847.95 kb/s
encoded 721 frames, 9.03 fps, 3847.95 kb/s
encoded 721 frames, 9.02 fps, 3847.95 kb/s
encoded 721 frames, 2.16 fps, 3927.47 kb/s
System Details
Name			Intel Pentium M 740
Codename		Dothan
Specification		Intel(R) Pentium(R) M processor 1.73GHz
Core Stepping		C0
Technology		90 nm
Stock frequency		1733 MHz
Core Speed		1729.3 MHz (13.0 x 133.0 MHz)
FID range		6.0x - 13.0x
Northbridge		Intel i915GMS/i910GML rev. 03
Southbridge		Intel 82801FBM (ICH6-M) rev. 03
CAS#			4.0
RAS# to CAS#		4
RAS# Precharge		4
Memory Frequency	266.0 MHz (1:2)
Memory Type		DDR2
Memory Size		1016 MBytes
Channels		Dual
max VID			1.308 V
Number of threads	1
L2 cache		2048 KBytes, 8-way set associative, 64-byte line size
Package			Socket 479 mPGA (platform ID = 5h)
Old 20th April 2008, 23:14   #58  |  Link
Inventive Software
Turkey Machine
Could be something to report to the x264 devs. I think it has something to do with threading and determinancy.
Old 21st April 2008, 10:48   #59  |  Link
smok3
brontosaurusrex
smok3's Avatar
this post was edited;
alternative avisynth checker, using practical example (ok, i'am sure there must be simpler way, but here you go):
:: check if avisynth is operational using practical test
@echo off
:: make temporary version.avs in current folder
echo filename = ^"avstest.txt^" > version.avs
echo Version^(^) >> version.avs
echo trim^(1,5^) >> version.avs
echo converttoyv12^(^) >> version.avs
echo WriteFile^(filename, ^"current_frame^"^) >> version.avs
::run version.avs with avs2avi or x264 in null mode to get the avisynth log
::avs2avi version.avs null.avi -o n -c null >nul 2>&1
x264 --pass 1 --bitrate 1000 --stats "temp.stats" --output NUL "version.avs" >nul 2>&1
echo.
:: check if there was something written
if exist avstest.txt (
echo avisynth seems operational!
) else (
echo avisynth test did NOT pass!
echo.
::delete some
del version.avs
del avstest.txt
if exist temp.stats (
del temp.stats
requirements: x264.exe or avs2avi.exe http://www.moitah.net/
certain other member
smok3 is offline   Reply With Quote
Old 21st April 2008, 11:42   #60  |  Link
smok3
brontosaurusrex
smok3's Avatar
same opteron, new bech;
encoded 1442 frames, 20.24 fps, 3905.08 kb/s
encoded 1442 frames, 20.29 fps, 3905.08 kb/s
encoded 1442 frames, 20.27 fps, 3905.08 kb/s
encoded 1442 frames, 20.23 fps, 3905.08 kb/s
encoded 1442 frames, 4.80 fps, 3942.92 kb/s
encoded 1442 frames, 4.78 fps, 3942.92 kb/s
encoded 1442 frames, 4.77 fps, 3942.92 kb/s
encoded 1442 frames, 21.10 fps, 3886.14 kb/s
encoded 1442 frames, 21.15 fps, 3889.96 kb/s
encoded 1442 frames, 21.12 fps, 3887.89 kb/s
encoded 1442 frames, 21.13 fps, 3886.90 kb/s
encoded 1442 frames, 5.04 fps, 3954.05 kb/s
encoded 1442 frames, 5.04 fps, 3953.35 kb/s
encoded 1442 frames, 5.04 fps, 3953.36 kb/s
encoded 1442 frames, 5.02 fps, 3953.48 kb/s
System Details
Name			AMD Opteron 170 (UP)
Codename		Denmark
Specification		Dual Core AMD Opteron(tm) Processor 170
Core Stepping		JH9-E6
Technology		90 nm
Stock frequency		2000 MHz
Core Speed		2010.3 MHz (10.0 x 201.0 MHz)
Northbridge		NVIDIA nForce4 rev. A3
Southbridge		NVIDIA nForce4 MCP rev. F3
CAS#			2.5
RAS# to CAS#		4
RAS# Precharge		4
Cycle Time (tRAS)	7
Command Rate		2T
Memory Frequency	167.5 MHz (CPU/12)
Memory Type		DDR
Channels		Dual
max VID			1.400 V
Voltage sensor 0	1.36 Volts [0x55] (CPU VCORE)
Number of threads	2
L2 cache		2 x 1024 KBytes, 16-way set associative, 64-byte line size
Instructions sets	MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
Package			Socket 939
Temperature sensor 0	75C (166F) [0x4B] (TMPIN0)
Temperature sensor 1	36C (96F) [0x24] (TMPIN1)
Temperature sensor 2	46C (114F) [0x2E] (TMPIN2)
Temperature sensor 0	83C (181F) [0x84] (core #0)
Temperature sensor 1	78C (172F) [0x7F] (core #1)
