Go Back   Doom9's Forum > Hardware & Software > PC Hard & Software
Old 11th April 2008, 12:06   #21  |  Link
Digga
User, Registered
---------- RUN1PASS1.LOG
encoded 1442 frames, 21.10 fps, 3905.08 kb/s
---------- RUN2PASS1.LOG
encoded 1442 frames, 21.40 fps, 3905.08 kb/s
---------- RUN3PASS1.LOG
encoded 1442 frames, 21.31 fps, 3905.08 kb/s
---------- RUN4PASS1.LOG
encoded 1442 frames, 21.47 fps, 3905.08 kb/s
---------- RUN1PASS2.LOG
encoded 1442 frames, 4.90 fps, 3942.92 kb/s
---------- RUN2PASS2.LOG
encoded 1442 frames, 4.91 fps, 3942.92 kb/s
---------- RUN3PASS2.LOG
---------- RUN4PASS2.LOG
encoded 1442 frames, 4.88 fps, 3942.92 kb/s
CPU:
Athlon 64 X2 3800+ (Windsor, Socket AM2) 10x200.9
RAM:
DDR2 2x1024 (dual) 5-5-5-18 @ 200.9
MB:
NVIDIA SPP190 (C51XE)
NVIDIA nForce 570 SLI
OS:
Win XP x64 SP2
...today I like all colours, like Frans Zimmer.
Digga is offline   Reply With Quote
Old 12th April 2008, 01:40   #22  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
encoded 1442 frames, 20.44 fps, 3905.08 kb/s
encoded 1442 frames, 20.38 fps, 3905.08 kb/s
encoded 1442 frames, 20.47 fps, 3905.08 kb/s
encoded 1442 frames, 20.33 fps, 3905.08 kb/s
encoded 1442 frames, 5.09 fps, 3942.92 kb/s
Little laptop that could... Core 2 Duo (merom) 1.8 GHz - 200 MHz FSB (800 effective), 2 GB DDR2 @ 667MHz - 5/5/5/15.
Hitachi 120GB SATA HD - I think it's 5400RPM.
XP 32 bit
Not too bad!!
~MiSfit
Old 12th April 2008, 10:48   #23  |  Link
graysky
graysky's Avatar
Thanks for the new data everyone! I will update shortly.
@MiSfit - is that a T5600?
graysky is offline   Reply With Quote
Old 12th April 2008, 16:58   #24  |  Link
bond
i have avisynth installed, still your tool doesnt detect it. i have not installed avisynth in the standard folder
Ogg Theora | Ogg Vorbis
Old 12th April 2008, 17:34   #25  |  Link
graysky
graysky's Avatar
@bond - yeah, the batch file as you can see looks the avisyth in the standard folder:
%PROGRAMFILES%\AviSynth 2.5 (if using a x86 architecture)
%PROGRAMFILES(x86)%\AviSynth 2.5 (if using an x64 architecture)
Since you have it installed to a non-standard location, it'll fail the check. You can simply edit the batch file and delete both the :avisynth_check32, :avisynth_check64, and :error sections. Leave everything under the :start section alone.
The beginning of your batch file should look like this:
cls
@echo off
cd test
:start
That should work
Old 14th April 2008, 18:42   #26  |  Link
bond
here are my old fat ladies' results:
encoded 1442 frames, 2.87 fps, 3902.58 kb/s
encoded 1442 frames, 2.89 fps, 3902.58 kb/s
encoded 1442 frames, 0.73 fps, 3936.11 kb/s
encoded 1442 frames, 0.72 fps, 3936.11 kb/s
Pentium 3 EB Coppermine Brand ID 2, 6.5x133, VIA Apollo Pro Chipset, SDRAM, Timings 3-3-3-6, WinXP Pro 2002 SP2
Old 14th April 2008, 19:53   #27  |  Link
Blue_MiSfit
T7100 actually
2MB cache
Old 14th April 2008, 20:24   #28  |  Link
kurt
sidekick
kurt's Avatar
encoded 1442 frames, 18.73 fps, 3905.08 kb/s
encoded 1442 frames, 19.22 fps, 3905.08 kb/s
encoded 1442 frames, 19.19 fps, 3905.08 kb/s
encoded 1442 frames, 19.18 fps, 3905.08 kb/s
encoded 1442 frames, 4.58 fps, 3942.92 kb/s
encoded 1442 frames, 4.61 fps, 3942.92 kb/s
encoded 1442 frames, 4.60 fps, 3942.92 kb/s
Intel core duo T2500 2x2.0 GHz, 12x166, i945PM, DDR2 5x5x5x15 @ 333 MHz, XP Pro SP2
greets, kurt.
Pioneer PDP-427 XA | Popcorn Hour NMT C-200 | Sony STR-DB 840 QS | Canton Ergo 91 DC
kurt is offline   Reply With Quote
Old 14th April 2008, 21:14   #29  |  Link
smok3
brontosaurusrex
smok3's Avatar
encoded 1442 frames, 20.32 fps, 3905.08 kb/s
encoded 1442 frames, 20.30 fps, 3905.08 kb/s
encoded 1442 frames, 20.31 fps, 3905.26 kb/s
encoded 1442 frames, 20.28 fps, 3905.08 kb/s
encoded 1442 frames, 4.78 fps, 3942.92 kb/s
encoded 1442 frames, 4.79 fps, 3942.79 kb/s
cpu - Opteron 170 (Denmark), 10x201
ram - DDR 2048 MBytes, Dual @ 167.5Mhz 4-4-7-10
chipset - nForce4
certain other member
smok3 is offline   Reply With Quote
Old 14th April 2008, 21:21   #30  |  Link
graysky
graysky's Avatar
Thanks for the data, all. Will update shortly.
@bond - is that SDRAM in your machine and what speed does it run @ (CPU-Z can tell you the answer to both questions)
@smok3 - which o/s and 32 or 64 bit?
Old 14th April 2008, 21:40   #31  |  Link
smok3
brontosaurusrex
smok3's Avatar
xp pro sp2 (32bit :P), opteron is 64 (socket 939)
Old 16th April 2008, 00:40   #32  |  Link
aicjofs
Hey long time no see...good to see the benchmark in HD...hehe. Got a new rig to test out here.
Vista x64....I believe the rest is in the screenshot(except it's the Special Edition Maximus Formula). Always a great benchmark...Cheers!!
EDIT: The 2nd result down(Yorkfield) in the master list seems to have a ridiculous 2nd pass, is it correct? which forum did that come from I'd like to see that configuration?
aicjofs is offline   Reply With Quote
Old 16th April 2008, 07:20   #33  |  Link
smok3
brontosaurusrex
smok3's Avatar
hem, and i thought my lil opteron is kinda cool,
Old 16th April 2008, 16:01   #34  |  Link
bond
yes, as i wrote its sdram. what exactly do you mean with speed? (ie which field in cpuz?), i already posted some under "timings": CL till tRAS
Old 16th April 2008, 16:05   #35  |  Link
Inventive Software
Turkey Machine
Speed I think he refers to is the clock speed the RAM's at. From the FSB you're running, I'd guess 133 MHz?
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld
Inventive Software is offline   Reply With Quote
Old 16th April 2008, 17:06   #36  |  Link
Inventive Software
Turkey Machine
Results from my trusted laptop!
encoded 1442 frames, 16.23 fps, 3905.08 kb/s
encoded 1442 frames, 16.25 fps, 3905.08 kb/s
encoded 1442 frames, 16.26 fps, 3905.08 kb/s
encoded 1442 frames, 16.27 fps, 3905.08 kb/s
encoded 1442 frames, 3.70 fps, 3942.92 kb/s
encoded 1442 frames, 3.69 fps, 3942.92 kb/s
AMD Turion64 X2 Mobile TL-50, 1.6 GHz, 90nm, Chipset: ATI Xpress 200 (RS480), 1GB DDR2 @ 266 MHz, 4-4-4-12, XP MCE 2k5 32bit. Any more info I missed?
Old 16th April 2008, 20:59   #37  |  Link
graysky
graysky's Avatar
@IS - Got it, thanks. I'll update the tables soon.
@bond - sorry I missed it in your post. Yeah, I'm just wondering what speed the memory is running at. If you look in the "Memory" tab of CPU-Z, it should tell you under the "Timings" section in a field called, "DRAM Frequency."
Old 16th April 2008, 21:12   #38  |  Link
bond
dram frequency is greyed out
Old 16th April 2008, 21:21   #39  |  Link
graysky
graysky's Avatar
@bond - ok.. it's very likely the same as your FSB. Thanks!
Old 16th April 2008, 23:55   #40  |  Link
jay78
encoded 1442 frames, 73.59 fps, 3905.42 kb/s
encoded 1442 frames, 71.82 fps, 3905.42 kb/s
encoded 1442 frames, 72.27 fps, 3905.42 kb/s
encoded 1442 frames, 71.60 fps, 3905.42 kb/s
encoded 1442 frames, 20.21 fps, 3952.85 kb/s
encoded 1442 frames, 20.14 fps, 3952.85 kb/s
encoded 1442 frames, 20.17 fps, 3952.85 kb/s
encoded 1442 frames, 20.15 fps, 3952.85 kb/s
@aicjofs
same case here too bud and wat kind of rad is that ??
jay78 is offline   Reply With Quote
