Go Back   Doom9's Forum > Hardware & Software > PC Hard & Software
Old 3rd February 2006, 12:05   #21  |  Link
tareek
Goto Index (page 1) on this article . Pls Read this Before You Post . Page 02
TOSLINK Connector :
Digital (fibre Optical) . first introduced by Toshiba .
uses S/PDIF signal .
better than any copper wire type of cable & connector .
can connect your (console/player) system digitally to a Dolby Digital or DTS Receiver for Dolby Digital (AC3) or DTS surround sound .
uses Digital Optical Cable (aka : Toslink Digital Audio Cable) .
no content distortion at all .
TOSLINK audio connector TOSLINK JIS F05 (JIS C5974-1993 F05) is common .
- Tareek
tareek is offline   Reply With Quote
Old 3rd February 2006, 12:06   #22  |  Link
tareek
TRS :
Tip Ring Sleeve . extremely common Audio Jack plug / Connector .
are three(3) conductor connector (jack plugs, and corresponding sockets) .
used in audio stereophonic set/player/device .
3 size are popular . 2.5, 3.5 and 6.35 mm TRS plugs and associate matching sockets .
     TRS  Jack plug
   _____________________               5    4
  _|                    |            ||   || \_/\
_/                      |            ||   ||     \
  _                     |            ||   ||  _  /
_/ |                    |____________||___||_/ \/
   |                    |    1          2        3
   |____________________|
  1. Sleeve : usually ground .
  2. Ring : Right-side/hand channel for stereo signals, (or, negative phase for balanced mono signals, power supply for power-requiring mono signal sources) .
  3. Tip : Left-side/hand channel for stereo signals, (or, positive phase for balanced mono signals, signal line for unbalanced mono signals) .
  4. Insulating rings .
  5. Insulating rings .
In mono jacks, 2 and 5 are not present .
- Tareek
Old 3rd February 2006, 12:07   #23  |  Link
tareek
RCA connector :
RCA stands for Radio Corporation of America .
aka RCA , Phono , Cinch, AV plug/jack/connector .
2 pin connector .
               RCA  plug
            /     \________/      |
     ______/                      |______
   _|                             |      |
__/ |              ________       |      |______
   _|             /        \      |      |______)
__/ |             \________/      |      |
    |_______                      |______|
             \____________________|   2      1
  1. Central Male connector .
  2. Surrounding Ring connector . it is often segmented .
rca plug, plug-in to the rca jack .
as often, central connector comes into contact with the jack before the grounded ring connector does, it results in loud hum or buzz, in a on/powered device .
- Tareek
Old 3rd February 2006, 12:08   #24  |  Link
tareek
Cable :
look at the spec on attenuation, temperature ratings, voltage and currentcapacity, and the type of outer jacket .
traditional co-axial cable for video installations is RG-59, RG-6 . 75 ohms . RG-59 (23 awg wire) .
RG-6 (quad-shielded all-copper center conductor, 0.275 inch diameter, 18 awg wire, 2GHz) is better than RG-59 .
Triax co-axial Cable have two isolated shields to provide multiple functions through one cable . RG59 (3/8") and RG11 (1/2") . 75 Ohms . can be run upto 300-500 meters . triax cables are also referred with their thickness 14 mm, 11 mm and 8 mm .
based on attenuation, (for example) RG-59 baseband cable , RG-6 baseband cable, RG-11 basseband cable can be run upto 600 feet (200 meters), 850 feet (270 meters) and 1200 feet (400 meters), respectively . for a small length cable RG-179/U is used commonly . but have much higher attenuation than the larger cables .
to exceed those max length, use fiber optic (62.5/125 micron multimode) cable for baseband freq, or single mode fiber for broadband freq .
UTP (unshielded twisted pair) cable (CATV, CAT3, CAT, CAT6, etc) can be used for a/v signal for upto 1/4 length of RG-59's length with (almost) same attenuation . for example, upto 70 feet with balun transformer adapter, and even further, with an asymmetrical RGB video signal to symmetrical signal converter .
type of shields : Braid Shields, Foil Shields, Combination Foil/Braid Shields, French Braid Shields .
F connector . Triax connector .
- Tareek
Old 3rd February 2006, 12:08   #25  |  Link
tareek
CRT TV :
Cathode Ray Tube TV .
Based on the type of tube technology, 2 types : (Regular/General) CRT , Rear-Projection CRT .
Based on CRT screen's surface, 2 Types : General CRT , Flat-screen CRT .
also see TV
- Tareek
Old 3rd February 2006, 12:09   #26  |  Link
tareek
DLP TV :
Digital Light Processing TV .
First introduced by TI (Texas Instruments) .
720p broadcast uses 1280 x 720 px . 1080i broadcast uses 1080 x 1920 px .
Very small pixel gap .
Good black level (but, not as good as CRT, Plasma) .
Uses DMD (Digital Micromirror Device) .
Single chip (slower) DLP may have rainbow effect, but a faster DLP can get rid off that effect .
- Tareek
Old 3rd February 2006, 12:10   #27  |  Link
tareek
RP-LCD TV :
Rear Projection Liquid Crystal Display(LCD) TV .
- Tareek
Old 3rd February 2006, 12:11   #28  |  Link
tareek
Plasma TV :
uses 3 color phosphor, which will fade out over time . 30 k ~ 60 k hours (5 Hours / Day, for 16.5 years) .
screen size above 50 inches is HDTV . 42 inchs EDTV and HDTV both are found . lower inch TVs are actually EDTV .
15 ms pixel response (4 ms refresh) .
High power usage .
Better picture quality (in fast moving/changing picture) than LCD .
still picture can cause bad Burn-in effect .
High frame rate, so no jitter .
160 degree viewing angle .
- Tareek
Old 3rd February 2006, 12:12   #29  |  Link
tareek
LCD Flat Panel TV :
LCD (Liquid Crystal Display) .
No Display Burn-in effect .
Better picture quality (in slow moving or still picture) than Plasma .
But pixel response time is not as fast as Plasma pixels .
1920 x 1080p px .
16 ms pixel response time . 16 ms refresh .
- Tareek
Old 3rd February 2006, 13:40   #30  |  Link
tareek
Sed Tv :
- Tareek
Old 3rd February 2006, 13:45   #31  |  Link
tareek
LCoS TV:
Two type : S-XRD from Sony , D-ILA from JVC .
first introduced by Intel .
S-XRD is better than D-ILA .
- Tareek
Old 3rd February 2006, 14:17   #32  |  Link
tareek
EDTV :
Enhanced Definition Television .
NTSC 480p .
- Tareek
Old 6th February 2006, 03:08   #33  |  Link
tareek
DTV :
Digital Television .
- Tareek
Old 6th February 2006, 03:50   #34  |  Link
tareek
other TV
- Tareek
Old 6th February 2006, 04:25   #35  |  Link
tareek
RJ connector :
RJ is Registered Jack . electrical connector .
RJ-11 : 6P2C, for one telephone line, 2 conductor/1 pair, .
RJ-11 : 6P4C, for one telephone line with power on second pair, 4 conductor/2 pair, .
RJ-14 : 6P4C, for two telephone lines, 4 conductor/2 pair, .
RJ-12 : 6P6C, for three telephone lines, 6 conductor/3 pair, .
RJ-25 : 6P6C, for three telephone lines, 6 conductor/3 pair, .
RJ-45 : 8P8C, for Ethernet LAN lines, 8 conductor/4 pair, .
       RJ-45 (EIA/TIA-568B) :
    ______________________________
    |   1  2  3  4  5  6  7  8   |
    |______  Face of Jack  ______|
          |____        ____|
              |________|
Pin : Pair : Pair : Wire : Color Pins
    : 568B : 568A :      :
1   : 2    : 3    : tip  : white/orange
2   : 2    : 3    : ring : orange
3   : 3    : 2    : tip  : white/green
4   : 1    : 1    : ring : blue
5   : 1    : 1    : tip  : white/blue
6   : 3    : 2    : ring : green
7   : 4    : 4    : tip  : white/brown
8   : 4    : 4    : ring : brown
pairs 2 and 3 (orange and green) are
swapped, in between TIA/EIA 568 B & A
- Tareek
Old 6th February 2006, 06:36   #36  |  Link
tareek
S/PDIF :
Sony/Philips Digital Interface Format . aka IEC 958 type II . part of IEC-60958 .
(aka S/P-DIF, aka SP-DIF, aka SPDIF) .
collection of hardware and low-level protocol specifications .
can use XLR, RCA jack, etc electrical connector, or, optical TOSLINK connector .
signal contains 20 bit audio data streams plus other related info . uses Biphase Mark Code modulation signal .
can connect your (console/player) system digitally to a Dolby Digital or DTS Receiver for Dolby Digital (AC3) or DTS surround sound . uses digital PCM audio signal .
- Tareek
Old 6th February 2006, 07:26   #37  |  Link
tareek
HDMI :
High-Definition Multi-media Interface .
it is industry-supported, uncompressed, all-digital audio/video interface .
The standard Type A HDMI connector has 19 pins . Type B has 29 pins .
Type A HDMI is backward compatible with the single-link DVI used on computer monitors and graphics cards . Type B HDMI is similarly backward-compatible with dual-link DVI .
to prevent end users, from viewing / copying legally protected content,
without the support for HDCP, the video quality and resolution can be downgraded by the signal source .
uses TMDS, DDC, CEC channels/signals .
            Type A (Receptacle) HDMI
    ______________________________________________
  |   ,-19--17--15--13--11--09--07--05--03--01-,   |
  |    \--18--16--14--12--10--08--06--04--02--/    |
Type A Connector Pin Assignment (Pin : Signal Assignment) :
  • Pin 1 : TMDS Data2+ , . . . . • Pin 2 : TMDS Data2 Shield
  • Pin 3 : TMDS Data2– , . . . . • Pin 4 : TMDS Data1+
  • Pin 5 : TMDS Data1 Shield , • Pin 6 : TMDS Data1–
  • Pin 7 : TMDS Data0+ , . . . . • Pin 8 : TMDS Data0 Shield
  • Pin 9 : TMDS Data0– , . . . . • Pin 10 : TMDS Clock+
  • Pin 11 : TMDS Clock Shield , • Pin 12 : TMDS Clock–
  • Pin 13 : CEC , . . . . . . . . • Pin 14 : Reserved (N.C. on device)
  • Pin 15 : SCL , . . . . . . . . • Pin 16 : SDA
  • Pin 17 : DDC/CEC Ground , • Pin 18 : +5V Power
  • Pin 19 : Hot Plug Detect
- Tareek
Old 6th February 2006, 07:27   #38  |  Link
tareek
DVI connector :
Digital Visual Interface .
DVI-D : digital . DVI-A : analog . DVI-I : digital and analog .
DVI-DL indicates dual link DVI .
uses TMDS, DDC, LVDS, LDI signals .
           DVI-I : Dual Link : 24 + 5
  /        _   _   _   _   _   _   _   _  \
 |  _   _ |_| |_| |_| |_| |_| |_| |_| |_|  |
 | |_| |_|                                 |
 |  _____  _   _   _   _   _   _   _   _   |
 | |_____||_| |_| |_| |_| |_| |_| |_| |_|  |
 |  _   _                                  |
 | |_| |_| _   _   _   _   _   _   _   _   |
  \       |_| |_| |_| |_| |_| |_| |_| |_| /
   \_____________________________________/
 |        08  07  06  05  04  03  02  01   |
 | c2  c1                                  |
 |   c5   16  15  14  13  12  11  10  09   |
 | c4  c3                                  |
  \       24  23  22  21  20  19  18  17  /
  • Pin 1 : TMDS Data 2- : Digital red - (Link 1) , • Pin 2 : TMDS Data 2+ : Digital red + (Link 1) ,
  • Pin 3 : TMDS Data 2/4 shield , • Pin 4 : TMDS Data 4− : Digital green − (Link 2) ,
  • Pin 5 : TMDS Data 4+ : Digital green + (Link 2) , • Pin 6 : DDC clock ,
  • Pin 7 : DDC data , • Pin 8 : Analog Vertical Sync ,
  • Pin 9 : TMDS Data 1− : Digital green − (Link 1) , • Pin 10 : TMDS Data 1+ : Digital green + (Link 1) ,
  • Pin 11 : TMDS Data 1/3 shield , • Pin 12 : TMDS Data 3− : Digital blue − (Link 2) ,
  • Pin 13 : TMDS Data 3+ Digital blue + (Link 2) , • Pin 14 : +5V Power for monitor when in standby ,
  • Pin 15 : Ground Return for pin 14 and analog sync , • Pin 16 : Hot Plug Detect ,
  • Pin 17 : TMDS data 0− : Digital blue − (Link 1) and digital sync ,
  • Pin 18 : TMDS data 0+ : Digital blue + (Link 1) and digital sync ,
  • Pin 19 : TMDS data 0/5 shield , • Pin 20 : TMDS data 5− : Digital red − (Link 2) ,
  • Pin 21 : TMDS data 5+ : Digital red + (Link 2) , • Pin 22 : TMDS clock shield ,
  • Pin 23 : TMDS clock+ : Digital clock + (Links 1 and 2) ,
  • Pin 24 : TMDS clock− : Digital clock − (Links 1 and 2) ,
  • Pin C1 : Analog Red , • Pin C2 : Analog Green , • Pin C3 : Analog Blue ,
  • Pin C4 : Analog Horizontal Sync , • Pin C5 : Analog Ground Return for R, G and B signals
RGB (analog) bandwidth : 400 MHz at −3 dB .
most often used/found in FP-LCD TV, digital projectors, video/graphics card .
- Tareek
Old 6th February 2006, 07:28   #39  |  Link
tareek
Digital TV other part
- Tareek
Old 6th February 2006, 17:59   #40  |  Link
DVD_GR
I deleted my post which was between your guide!
nice work tareek!!
DVD_GR is offline   Reply With Quote
