23rd November 2006, 04:26 | #101 | Link |
AC3 Decoder
Hi all,
I m doing AC3 Decoder code development. In that i got doubt, that how to transform LFE samples into time domain. since we are using 256 and 512 blocklength transform. Here we will get 7 LFE samples after mantissa decoding. and i am in confusion that whether we should mixup with FullBandwidth channel. please Let me know the solution...... |
23rd November 2006, 21:55 | #102 | Link |
Just a Member
Sorry I have no idea, but DGindex is open source and is able to decode ac3. You can take a look to the sources.
http://neuron2.net/dgmpgdec/ Good luck!. jsoto
Web sites with my tools http://download.videohelp.com/jsoto http://jsoto.posunplugged.com/ |
5th January 2007, 15:00 | #104 | Link |
Stupid question time
I have a .AC3 file with -128ms delay, created in DGIndex, but the delay is not recognised in delaycut. In which box do I put the -128, and what boxes do I need to check? I am assuming I enter '-128' in the 'Start' box under 'Delay', and that I have to check 'Original Length', but is this correct? Thank you for any answers |
5th January 2007, 15:48 | #105 | Link |
A negative delay means cut the stream, then you need check 'Cut file' and put
Start: 128 End: you need calculate Num of Frames x Frame length (ms) You can't obtain always the exact cut without reencode because DelayCut can only cut a exact number of frames i. e. a Frame length multiple. With 48 KHz the Frame length is 32 ms then cutting 4 frames the cut is exact. |
5th January 2007, 15:50 | #106 | Link |
Just a Member
delaycut recognizes the delay in the file name only in CLI mode
You have to write -128 in start (msec) box. You can check or not "original length". Because your're fixing a negative delay, some frames from the beginning of the file will be dropped (you can see it in "target file info". Checking "original length", the same number of frames (silences) will be added at the end of the file. EDIT: Didn't see tebasuna51 answer (I was replying). Yes, using cut is other way in negative delays, but I prefer to use the delay area, (it is more clear to me, and can be also used with positive delays) jsoto
Web sites with my tools http://download.videohelp.com/jsoto http://jsoto.posunplugged.com/ Last edited by jsoto; 5th January 2007 at 16:07. |
10th May 2007, 06:35 | #108 | Link |
@jsoto
Do you have any plans to include Dolby Digital Plus (EC3, DD+) cutting support?
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake? Curly: Burned at the stake! Moe: Why? Curly: A hot steak is always better than a cold chop. |
11th September 2007, 20:59 | #109 | Link |
I've just updated delaycut to v1.3.0.0 with full E-AC3 support. Here's the download with "delaycut.exe" and the full source code:
http://madshi.net/delaycut.rar Of course jsoto is greatly welcome to take the changes over into his code base. And many thanks to him for his extremely useful tool. |
12th September 2007, 22:04 | #110 | Link | |
12th September 2007, 22:19 | #111 | Link | |
Just a Member
jsoto
17th October 2007, 00:07 | #112 | Link | |
17th October 2007, 00:29 | #113 | Link | |
Ok? |
17th October 2007, 00:44 | #114 | Link |
Yes but that sort of means it's removing the first frames and "pulling the rest of the audio to the beginning" doesn't it? So if the audio already has a negative delay, which I'm assuming means it comes before the video, then putting a negative value in the start box would make it come even more before the video, doing twice the damage. Won't it?
17th October 2007, 02:28 | #115 | Link |
@janger
A sample. A gunshot image occurs at frame 5 and the gunshot sound at frame 7, 80 ms later (if 25 fps). You need start to play the sound 80 ms before than video to synchronize audio and video. DGIndex inform a delay needed of -80 ms. To obtain the sync you can also cut the first 80 ms and play audio and video at same time. |
17th October 2007, 04:34 | #116 | Link |
tebasuna, are you saying that the values as reported by vobedit, DGindex etc, are the correction values, and not the actual delay?
What I mean is, in your example the audio has a delay (delay means "occur after") of 80ms, but you say DGIndex gives the negative of that, -80ms. This is where I'm getting confused. I always thought the values these programs reported was how much the audio was delayed compared to the video, not the amount needed for correcting it. |
17th October 2007, 11:53 | #117 | Link | |
If you load in BeLight-BeSweet a file from DGIndex: VTS_01_6 T01 2_0ch 192Kbps DELAY -112ms.ac3 automatically the Delay box is filled with -112 ms, and the first 112 ms are cut. |
20th November 2008, 11:41 | #119 | Link | |
You need fix the track with DelayCut: 1) Open your sample se7ensplit.ac3 and PROCESS the file. 2) You have a log like this: "Time 00:00:01.120; Frame#= 36. Some basic parameters changed between Frame #1 and this frame" That means: the first 35 frames are 2.0 but at frame 36 you have other parameters. 3) Put -1120 at 'Delay -> Start' and PROCESS one more time. The first 35 frames are deleted. 4) Open se7ensplit_fixed.ac3 in DelayCut, now you have the first frame 5.1. Now you can add a 'Delay -> Start' 1120 to compensate the deleted frames in order to maintain the sync. In your sample the rest of frames are 5.1 but in the full track maybe there are more 2.0 frames (commercials adv.). You need fix the full track. @To developers. This is a very common issue, maybe we can add to Delaycut the option to manage the "Some basic parameters changed.." frames like CRC errors: Ignore, Silence or Skip (we can't Fix, then if Fix is selected the frames must be Silenced).
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 20th November 2008 at 11:52. |
20th November 2008, 16:34 | #120 | Link |
@jsoto, madshi
I think we need manage the frames with 'basic parameters changed' like wrong frames or with bad CRC. Now these frames are 'Ignored' with the result of invalid streams. With the changes we can obtain valid streams with 'Silence' or 'Skip' options (preserving or not the sync): Code:
--- delayac3.cpp Thu Nov 20 14:53:02 2008 +++ delayac3_mod.cpp Thu Nov 20 14:49:02 2008 @@ -1519,17 +1519,14 @@ fscodn != fileinfo->fscod || bsmodn != fileinfo->bsmod || acmodn != fileinfo->acmod) { - fileinfo->fscod=fscodn; - fileinfo->frmsizecod= iFrmsizecodn; - fileinfo->bsmod=bsmodn; - fileinfo->acmod= acmodn; - nuerrors++; csAux.Format (_T("Time %s; Frame#= %I64d. Some basic parameters changed between Frame #%I64d and this frame"), csTime, i64+1, fileinfo->i64frameinfo); printlog(csAux); - fileinfo->i64frameinfo=i64+1; - } + bCRCError=true; + if (m_iCrc==CRC_SKIP) f_writeframe=WF_SKIP; + else if ((m_iCrc==CRC_SILENCE) || (m_iCrc==CRC_FIX)) f_writeframe=WF_SILENCE; + } else { // CRC calculation and fixing. @@ -1582,6 +1579,7 @@ } else if (m_iCrc==CRC_SKIP) f_writeframe=WF_SKIP; else if (m_iCrc==CRC_SILENCE) f_writeframe=WF_SILENCE; + } } } - Preserve the initial parameters from first frame (fileinfo->). - Like framelength can vary we make bCRCError=true to force search new header inside the wrong frame. - Ignore, Skip or Silence like CRC error (f_writeframe). - We don't need CRC calculation in wrong frame (else).
