10th February 2021, 22:04 | #3901 | Link |
Acid fr0g
How I wish to have full batch support for DGDecNV instead of being bond to non frame accurate indexers. For one movie I can manually feed DGI and manually remux the streams. I am currently converting some dozens of episode clips and I am tied up to default ffmsindex to keep on having the batch feature available.
@turment on Telegram |
10th February 2021, 22:29 | #3902 | Link |
You can create a small bat file for that. I indexed/demuxed 26 episodes with my bat in one go, easy peasy.
10th February 2021, 22:41 | #3903 | Link |
The batch mode of staxrip would also work.
11th February 2021, 13:41 | #3904 | Link |
Acid fr0g
Look what happens if I use DGIndexNV as preprocessor:
------------------------- System Environment ------------------------- StaxRip : 2.1.8.0 Windows : Windows 10 Enterprise 2004 Language : Italian (Italy) CPU : Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz GPU : NVIDIA GeForce GTX 1060 3GB Resolution : 1920 x 1080 DPI : 96 Code Page : 1252 ----------------------- Media Info Source File ----------------------- F:\In\test\06 Hitagi end 6.mkv General Complete name : F:\In\test\06 Hitagi end 6.mkv Format : Matroska Format version : Version 4 File size : 1.55 GiB Duration : 26 min 26 s Overall bit rate : 8 382 kb/s Encoded date : UTC 2020-09-15 16:33:07 Writing application : mkvmerge v50.0.0.18 ('Awakenings') 64-bit Writing library : libebml v1.4.0 + libmatroska v1.6.2 Attachments : IwaMinPro-Lt-Madoka.ttf / IwaOMinPro-Bd-Fate.ttf / LHF_Scriptana.ttf / Montara-Gothic_0.otf / Reswysokr.otf / arial.ttf / CenturyOldStyle-Light Bold.ttf Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L4@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 26 min 26 s Bit rate : 8 142 kb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.164 Stream size : 1.50 GiB (97%) Writing library : x265 3.1.1:[Linux][GCC 9.1.0][64 bit] 10bit Language : Japanese Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 26 min 26 s Bit rate mode : Constant Bit rate : 224 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 42.4 MiB (3%) Language : Japanese Service kind : Complete Main Default : Yes Forced : No Text ID : 3 Format : ASS Codec ID : S_TEXT/ASS Codec ID/Info : Advanced Sub Station Alpha Duration : 26 min 23 s Bit rate : 398 b/s Count of elements : 951 Compression mode : Lossless Stream size : 76.9 KiB (0%) Language : Italian Default : Yes Forced : No Menu 00 : 00:00.000 : it:Prologo 00 : 01:20.998 : it:Opening 00 : 02:51.046 : it:Episodio 00 : 25:40.039 : it:Anteprima ----------------------- DGIndexNV: Index, Demux ----------------------- D:\Eseguibili\Media\DGDecNV\DGIndexNV.exe -i "F:\In\test\06 Hitagi end 6.mkv" -o "F:\In\test\06 Hitagi end 6_temp\06 Hitagi end 6.dgi" -a -h Project 20 33 42 75 80 100 Start: 13:35:23 End: 13:35:28 Duration: 00:00:04 Code:
Summary of path: F:\In\test Created: 11/02/2021 13:41:08 F:\In\test\06 Hitagi end 6_temp F:\In\test\06 Hitagi end 6_temp\06 Hitagi end 6.dgi F:\In\test\06 Hitagi end 6_temp\06 Hitagi end 6.log F:\In\test\06 Hitagi end 6_temp\06 Hitagi end 6.dgi_chapters.xml F:\In\test\06 Hitagi end 6_temp\06 Hitagi end 6_new.avs F:\In\test\06 Hitagi end 6_temp\06 Hitagi end 6_new_source.avs F:\In\test\06 Hitagi end 6_temp\06 Hitagi end 6_new_staxrip.log F:\In\test\06 Hitagi end 6_temp\06 Hitagi end 6_track2_jpn_DELAY 0ms.ac3 F:\In\test\06 Hitagi end 6_temp\06 Hitagi end 6_track3_ita.ass F:\In\test\06 Hitagi end 6.mkv F:\In\test\arial.ttf F:\In\test\CenturyOldStyle-Light Bold.ttf F:\In\test\IwaMinPro-Lt-Madoka.ttf F:\In\test\IwaOMinPro-Bd-Fate.ttf F:\In\test\LHF_Scriptana.ttf F:\In\test\Montara-Gothic_0.otf F:\In\test\Reswysokr.otf
11th February 2021, 14:29 | #3905 | Link |
App Digger
Seems like DGIndexNV.exe does not extract attachments to the temp subfolder - where the dgi file is - in CLI.
(All the jobs are done in the subfolder.) Look. All the others except the attachments are in the subfolder. It's something you have to ask the DGDecNV developer, not here. It's not StaxRip but DGIndexNV.exe that does the extraction. It's clear in the log. Seems like you didn't try it on CMD like I recommended... Last edited by JKyle; 11th February 2021 at 14:40. |
13th February 2021, 13:39 | #3909 | Link |
2.1.8.0 users can take StaxRip.exe from the Beta cloud folders and auto update nvenc.
Main Menu > Apps > Manage > NVEnc > Tools > Auto Update 2.1.8.1 Beta - aomenc options rearranged (Dendraspis) - aomenc supports chunk encoding (Dendraspis, [#368]) - aomenc gets decoder and pipe settings (Dendraspis, [#497]) - aomenc default value for --kf-max-dist changed to 120 (Dendraspis, 44vince44, [#506]) - aomenc default value for --kf-min-dist changed to 120 (Dendraspis, 44vince44, [#506]) - aomenc sets --verbose by default (Dendraspis, 44vince44, [#506]) - Fix frame rates for AviSynth functions (44vince44) - Replace Rapair16 with Dither_Repair16 for AVS (44vince44) - Fix AvsResize website address and VS ConvertFormat command (JJKylee) - aomenc 2-pass stats file extension change to '.fpf' (Dendraspis) - Fix aomenc --webm parameter (Dendraspis) - Force mkvmerge to write fps in case of aomenc not using IVF container (Dendraspis) - Fix shortcut editor key default causing an issue when m is typed (stax76, [#505]) - x265 UI option for '--progress-readframes' on DJATOM builds (Dendraspis) - nvenc 5.28 (Windows 10 long path and AviSynth Unicode support)
13th February 2021, 16:06 | #3911 | Link |
App Digger
Side note:
If you just overwrote StaxRip.exe(2.1.8.1 Beta) and still see the Menu Editor pop up whenever you type 'm' in Code Editor, don't forget to delete the shortcut 'M' assigned to Edit Menu... in the Code Editor right-click menu. |
13th February 2021, 17:10 | #3912 | Link | |
what you see is what you get, now you see a float and get num,den. But what can I do if 44vince44 prefers it. Code:
[Frame Rate] AssumeFPS = AssumeFPS($select:msg:Select a frame rate;23.976|24000, 1001;24;25;29.970|30000, 1001;30;50;59.940|60000, 1001;60;120;144;240$) AssumeFPS Source File = AssumeFPS(%media_info_video:FrameRate%) ChangeFPS = ChangeFPS($select:msg:Select a frame rate;23.976|24000, 1001;24;25;29.970|30000, 1001;30;50;59.940|60000, 1001;60;120;144;240$) ConvertFPS = ConvertFPS($select:msg:Select a frame rate;23.976|24000, 1001;24;25;29.970|30000, 1001;30;50;59.940|60000, 1001;60;120;144;240$) InterFrame = InterFrame(preset="Medium", tuning="$select:msg:Select the Tuning Preset;Animation;Film;Smooth;Weak$", newNum=$enter_text:Enter the NewNum Value.$, newDen=$enter_text:Enter the NewDen Value$, cores=$enter_text:Enter the Number of Cores You want to use$, overrideAlgo=$select:msg:Which Algorithm Do you want to Use?;Strong Predictions|2;Intelligent|13;Smoothest|23$, GPU=$select:msg:Enable GPU Feature?;True;False$)
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 13th February 2021 at 17:17. |
13th February 2021, 20:28 | #3913 | Link | |
@Atlantis, it's only about proposing the correct standard values for fps ONLY WHEN USING FILTERS AssumeFPS, ChangeFPS and ConvertFPS. If you use those filters, you'll see how it is set now.
E.g: If you select AssumeFPS -> choose 23.976 then this will create the filter AssumeFPS(24000,1001). Also some frequencies have been added. And finally, ChangeFPS was added (it wasn't there before). @Stax76: Quote:
Old captions were 24000/1001, value (24000,1001) Then Dendraspis changed the captions AND THE VALUES to 23.976. So I kept 23.976 caption because Dendraspis likes it, but we changed the VALUES back to 24000,1001 in order to respect the standards. Initially, I only wanted to add filter ChangeFPS. According to Dendraspis, the caption 23.976 is better for newbies. I tend to agree, as long as the real value used is 24000/1001. Last edited by 44vince44; 13th February 2021 at 20:37. |
14th February 2021, 12:29 | #3916 | Link |
@44vince44
Ah OK, showing both would also be possible: 23.976 (24000/1001) But it's fine either way.
15th February 2021, 00:30 | #3917 | Link |
Guys,
When converting audio to AAC how do you increase the dialogue (midrage). I plan to use qaac and fdkaac. I find it annoying ac3 dts atmos and other sound technologies have very subtle dialogue. Increasing the volume would also increase the other channels Thanks
Asus ProArt Z790 - 13th Gen Intel i9 - RTX 3080 - DDR5 64GB Predator - LG OLED C9 - Yamaha A3030 - Windows 11 x64 - PotPlayerr - Lav - MadVR |
15th February 2021, 13:33 | #3918 | Link |
Acid fr0g
Usually dialogue is on C channel. Try to use FFMpeg with FDKAAC support and play with channel volume or gain or mixing. My suggestion, however, is not to touch it and adjust player mixer to enhance C channel.
17th February 2021, 22:11 | #3919 | Link |
App Digger
rigaya released QSVEnc 4.13 today with the following important updates:
In order to avoid the exit code: 1 error like this, maybe we need to update StaxRip to write the AVS script in UTF-8 for QSVEnc encoding. (Or... is it already there? ) |
18th February 2021, 10:59 | #3920 | Link |
