#1 | Link |
QTGMC shenanigans
Hey everyone,
I'm completely stumped by a persistent QTGMC error and I've exhausted every troubleshooting step I can think of. I'm hoping someone here might have an idea what's going on. My goal is to deinterlace a 1080i TS file, do some filtering, and then use AutoOverlay to combine it with a filtered 720p MKV. The problem is that the script fails immediately with an "Invalid arguments to function 'QTGMC'" error. The most confusing part is that a preview generated in Hybrid, using the exact same plugins and settings, works perfectly fine. The error only happens when I try to run the .avs script externally through my system-wide AviSynth+ installation (latest version) and VirtualDub2 (64-bit). Here's everything I've tried so far: - The error happens even with the simplest possible call. This line fails with the same error: `main = temp.QTGMC(Preset="Placebo")` - I've confirmed I'm using a 64-bit host (VirtualDub2) with the 64-bit plugins from the Hybrid folder. - I've installed the complete Visual C++ Redistributable Runtimes (All-in-One) and restarted. - I tried forcing the input colorspace immediately after loading the source, using `ConvertToYV12(interlaced=true)`. - I even replaced Hybrid's `QTGMC.avsi` with the latest official version from avisynth.nl. Nothing has changed the result. Here is the full script I'm trying to run. Any ideas would be greatly appreciated. Code:
LoadPlugin("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\LoadDll.dll")
LoadPlugin("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\flash3kyuu_deband.dll")
LoadPlugin("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\aWarpSharpMT.dll")
LoadPlugin("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\VariableBlur.dll")
LoadPlugin("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\Deblock.dll")
LoadPlugin("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\DctFilter.dll")
LoadCPlugin("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\yadif.dll")
LoadPlugin("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\TDeint.dll")
LoadPlugin("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\FFT3DFilter.dll")
LoadPlugin("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\eedi3.dll")
LoadPlugin("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\EEDI2.dll")
LoadDLL("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\libfftw3f-3.dll")
LoadPlugin("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\D2VSource.dll")
LoadPlugin("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\TIVTC.dll")
LoadPlugin("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\dfttest.dll")
LoadPlugin("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\AddGrainC.dll")
LoadPlugin("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\nnedi3.dll")
LoadPlugin("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\neo-fft3d.dll")
LoadPlugin("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\mvtools2.dll")
LoadPlugin("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\masktools2.dll")
LoadPlugin("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\RgTools.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins64+\AvsFilterNet.dll")
LoadNetPlugin("C:\Program Files (x86)\AviSynth+\plugins64+\AutoOverlay_netautoload.dll")
Import("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\mtmodes.avsi")
Import("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\BalanceBorders.avsi")
Import("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\GrainFactory3mod.avsi")
Import("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\LSFmod.avsi")
Import("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\ExTools.avsi")
Import("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\Deblock_QED_MT2.avsi")
Import("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\SMDegrain.avsi")
Import("C:\Program Files\Hybrid\64bit\Avisynth\avisynthPlugins\Zs_RF_Shared.avsi")
Import("C:\Program Files (x86)\AviSynth+\plugins64+\QTGMC.avsi")
1080i = LWLibavVideoSource("C:\Users\jopro\Downloads\bt projekte\vid_1029837442356038.ts")
720p = LWLibavVideoSource("C:\Users\jopro\Downloads\bt projekte\Spring.Subway.2002.720p.HDTV.x264-NGB.mkv")
mask = ImageSource("C:\Users\jopro\Downloads\bt projekte\ts_logo_mask.bmp")
#colorspace conv
temp = 1080i.ConvertToYV12(interlaced=true).Crop(0,2,0,0).AssumeTFF()
#1080i sauce
main = temp.QTGMC(Preset="Placebo", InputType=0, TR2=3, SourceMatch=3, Lossless=2, MatchPreset="Slower", MatchPreset2="Slower", EZKeepGrain=4.00, NoisePreset="Slower", ediThreads=2).SelectEven()
ref = main.QTGMC(preset="Very Slow", ediThreads=2, FPSDivisor=2, PrevGlobals="Replace")
filtered_1080i = main.TFM(mode=5,slow=2,clip2=ref)
\ .BalanceBorders(4,4,4,4)
\ .Deblock_QED(quant1=55,quant2=45,aOff1=5,bOff1=5,aOff2=5,bOff2=5,uv=1)
\ .LSFmod()
\ .Spline36Resize(1280,720)
#720p source
OverlayEngine.
filtered_720p = 720p.ConvertToYV12()
\ .InpaintDelogo(Loc="64,40,202,104", "C:\Users\jopro\Downloads\bt projekte\logo_mask.bmp", Automask=0, Mode="Both", Analyze=1, IntSpd=4, InterpM=-1, iTune=-5)
\ .LSFmod()
#merge
engine = OverlayEngine(filtered_1080i, filtered_720p)
engine.OverlayRender(filtered_1080i, filtered_720p, preset="FullFrame", overlayMask=mask)
Prefetch(3)
return last
#3 | Link |
Yep. QTGMC inside of Hybrid works which makes this all the more puzzling. I generated the lines for both qtgmc and tfm in hybrid so the syntax should be right. I also tried calling the qtgmc plugin in the hybrid installation folder in the script in virtualdub with the same result.
#4 | Link | |
![]() Join Date: Oct 2001
Since you didn't share what versions of QTGMC you are using, you might want to look at the script code yourself. |
#5 | Link | |
I don't think that the issue is that there have been any changes to QTGMC, because when I call QTGMC inside the Hybrid installation folder, I still get the same error. |
#8 | Link |
Still, to avoid collisions with automatically loaded dlls, I would recommend to keep 'ClearAutoloadDirs()'.
Also in your case: Code:
ref = main.QTGMC(preset="Very Slow", ediThreads=2, FPSDivisor=2, PrevGlobals="Reuse") But maybe first start with a simple script like: Code:
ClearAutoloadDirs()
SetFilterMTMode("DEFAULT_MT_MODE", MT_MULTI_INSTANCE)
LoadPlugin("F:\Hybrid\64bit\Avisynth\avisynthPlugins\LSMASHSource.dll")
LoadPlugin("F:\Hybrid\64bit\Avisynth\avisynthPlugins\nnedi3.dll")
LoadPlugin("F:\Hybrid\64bit\Avisynth\avisynthPlugins\mvtools2.dll")
LoadPlugin("F:\Hybrid\64bit\Avisynth\avisynthPlugins\masktools2.dll")
LoadPlugin("F:\Hybrid\64bit\Avisynth\avisynthPlugins\RgTools.dll")
Import("F:\Hybrid\64bit\Avisynth\avisynthPlugins\mtmodes.avsi")
Import("F:\Hybrid\64bit\Avisynth\avisynthPlugins\Zs_RF_Shared.avsi")
Import("F:\Hybrid\64bit\Avisynth\avisynthPlugins\QTGMC.avsi")
AssumeBFF()
QTGMC(Preset="Fast", ediThreads=2)
PreFetch(3)
return last
It that already fails, post the complete error message. |
| Display Modes | |
