#19941 | Link |
![]() Join Date: Oct 2001
Hmm... I'll have to play with that and see if something weird is going on.
jdobbs.softworks@gmail.com |
#19942 | Link |
My tests only included the software decoding/encoding of the Intel library. My processor doesn't support Quick-Sync. But, I personally wouldn't consider moving away from X264 for anything but MVC encodes unless there was an overwhelming increase in encoding speed.
jdobbs.softworks@gmail.com Last edited by jdobbs; 5th April 2014 at 15:47. |
#19943 | Link | |
#19944 | Link | |
regards |
#19945 | Link |
One question and I apologize in advance if this is not the correct thread.
I have a Blu-ray that has both the 2D and 3D version of a movie (The Nut Job), and I would like to compress to a BD-25 but leaving the 3D version out, just keep the movie-only 2D in the compression. Is there an easy way to do this? Or is there a way to identify the correct playlist for the 2D version? Thanks for your help, |
#19946 | Link | |
Another thing you can do is open program and go under setting and choose option "Process 3D video sources as 2D for backup" which basically set above flag on it's own.
If you fail to plan; you plan to fail, would you not agree? Think about it. |
#19947 | Link |
Not likely, but possible I guess.
#19948 | Link | ||
#19951 | Link |
In that case, if you are using anydvd there is an option simulate 3d output. Make sure that is turned before you rip or feed to BD-RB. Although it may cause problem in some, best is to check. Basically it modify in such a way that disc doesn't check for 3D player/display capability and will play without any problem.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 5th April 2014 at 19:16. |
#19952 | Link |
I'll have to run a test on that one and see what I find.
#19953 | Link |
I am afraid the region 1 disc may be different from my region 2 disc, so don't waste your time and money on what I believe is (hopefully) an exceptional case.
The disk works with the default stars backdrop, so thanks for having fixed the former Quick-Play backup issue. This seems to be solved now. Last edited by Sharc; 5th April 2014 at 23:45. |
#19954 | Link | |
The disc you did may be an odd one. Normally in BD each individual line of subtitle text has a flag indicating whether is should be forced. BD-RB pulls those out into a subtitle file of its own. During conversion the flag is examined and applied to the DVD subtitle. I'm thinking that maybe the disc you are attempting may have done it in a nonstandard way -- and simply turned the subtitle stream ON rather than asserting the "forced" flag. If so, there's no much I can do for that one. But... I'll test it today and make sure the forced subtitles are following through to the DVD.
#19955 | Link |
---------------------- [04/05/14] BD Rebuilder v0.46.14 (beta) [19:04:11] Source: THE_ODD_LIFE_OF_TIMOTHY_GREEN - Input BD size: 39.99 GB - Approximate total content: [02:27:53.489] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [19:04:33] PHASE ONE, Encoding - [19:04:33] Processing: VID_00800 (1 of 20) - [19:04:33] Extracting A/V streams [VID_00800] - [19:45:04] Reencoding video [VID_00800] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 150,504 frames - Bitrate: 20,301 Kbs - [19:45:05] Reencoding: VID_00800, Pass 1 of 1 - [20:31:57] Video Encode complete - [20:31:57] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:31:57] Multiplexing M2TS - [20:41:47] Processing: VID_00875 (2 of 20) - [20:41:48] Extracting A/V streams [VID_00875] - [20:42:39] Reencoding video [VID_00875] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,992 frames - Bitrate: 18,696 Kbs - [20:42:39] Reencoding: VID_00875, Pass 1 of 1 - [20:45:06] Video Encode complete - [20:45:06] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:45:06] Multiplexing M2TS - [20:45:23] Processing: VID_00876 (3 of 20) - [20:45:23] Extracting A/V streams [VID_00876] - [20:48:43] Reencoding video [VID_00876] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 13,310 frames - Bitrate: 18,506 Kbs - [20:48:43] Reencoding: VID_00876, Pass 1 of 1 - [20:59:28] Video Encode complete - [20:59:28] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:59:28] Multiplexing M2TS - [21:00:52] Processing: VID_00877 (4 of 20) - [21:00:52] Extracting A/V streams [VID_00877] - [21:04:33] Reencoding video [VID_00877] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 14,689 frames - Bitrate: 18,509 Kbs - [21:04:34] Reencoding: VID_00877, Pass 1 of 1 - [21:16:50] Video Encode complete - [21:16:50] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:16:50] Multiplexing M2TS - [21:18:45] Processing: VID_00878 (5 of 20) - [21:18:45] Extracting A/V streams [VID_00878] - [21:18:51] Reencoding video [VID_00878] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 168 frames - Bitrate: 6,674 Kbs - [21:18:51] Reencoding: VID_00878, Pass 1 of 1 - [21:18:56] Video Encode complete - [21:18:56] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:18:56] Multiplexing M2TS - [21:19:00] Processing: VID_00879 (6 of 20) - [21:19:00] Extracting A/V streams [VID_00879] - [21:19:20] Reencoding video [VID_00879] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 954 frames - Bitrate: 18,736 Kbs - [21:19:21] Reencoding: VID_00879, Pass 1 of 1 - [21:20:13] Video Encode complete - [21:20:13] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:20:13] Multiplexing M2TS - [21:20:21] Processing: VID_00880 (7 of 20) - [21:20:21] Extracting A/V streams [VID_00880] - [21:20:27] Reencoding video [VID_00880] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 168 frames - Bitrate: 6,674 Kbs - [21:20:27] Reencoding: VID_00880, Pass 1 of 1 - [21:20:30] Video Encode complete - [21:20:30] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:20:31] Multiplexing M2TS - [21:20:35] Processing: VID_00881 (8 of 20) - [21:20:35] Extracting A/V streams [VID_00881] - [21:20:59] Reencoding video [VID_00881] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,145 frames - Bitrate: 18,634 Kbs - [21:20:59] Reencoding: VID_00881, Pass 1 of 1 - [21:21:58] Video Encode complete - [21:21:58] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:21:58] Multiplexing M2TS - [21:22:08] Processing: VID_00882 (9 of 20) - [21:22:08] Extracting A/V streams [VID_00882] - [21:22:13] Reencoding video [VID_00882] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 168 frames - Bitrate: 6,674 Kbs - [21:22:13] Reencoding: VID_00882, Pass 1 of 1 - [21:22:17] Video Encode complete - [21:22:17] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:22:17] Multiplexing M2TS - [21:22:21] Processing: VID_00883 (10 of 20) - [21:22:21] Extracting A/V streams [VID_00883] - [21:22:51] Reencoding video [VID_00883] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,583 frames - Bitrate: 18,665 Kbs - [21:22:51] Reencoding: VID_00883, Pass 1 of 1 - [21:24:17] Video Encode complete - [21:24:17] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:24:17] Multiplexing M2TS - [21:24:28] Processing: VID_00884 (11 of 20) - [21:24:28] Extracting A/V streams [VID_00884] - [21:24:34] Reencoding video [VID_00884] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 168 frames - Bitrate: 6,674 Kbs - [21:24:34] Reencoding: VID_00884, Pass 1 of 1 - [21:24:37] Video Encode complete - [21:24:37] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:24:37] Multiplexing M2TS - [21:24:42] Processing: VID_00885 (12 of 20) - [21:24:42] Extracting A/V streams [VID_00885] - [21:25:00] Reencoding video [VID_00885] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 790 frames - Bitrate: 18,676 Kbs - [21:25:00] Reencoding: VID_00885, Pass 1 of 1 - [21:25:41] Video Encode complete - [21:25:41] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:25:41] Multiplexing M2TS - [21:25:48] Processing: VID_00886 (13 of 20) - [21:25:48] Extracting A/V streams [VID_00886] - [21:25:54] Reencoding video [VID_00886] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 168 frames - Bitrate: 6,674 Kbs - [21:25:55] Reencoding: VID_00886, Pass 1 of 1 - [21:25:58] Video Encode complete - [21:25:58] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:25:58] Multiplexing M2TS - [21:26:02] Processing: VID_00887 (14 of 20) - [21:26:02] Extracting A/V streams [VID_00887] - [21:27:43] Reencoding video [VID_00887] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 6,749 frames - Bitrate: 18,632 Kbs - [21:27:43] Reencoding: VID_00887, Pass 1 of 1 - [21:31:36] Video Encode complete - [21:31:36] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:31:37] Multiplexing M2TS - [21:32:04] Processing: VID_00888 (15 of 20) - [21:32:04] Extracting A/V streams [VID_00888] - [21:32:23] Reencoding video [VID_00888] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,537 frames - Bitrate: 9,583 Kbs - [21:32:23] Reencoding: VID_00888, Pass 1 of 1 - [21:33:20] Video Encode complete - [21:33:20] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:33:20] Multiplexing M2TS - [21:33:28] Processing: VID_00890 (16 of 20) - [21:33:28] Extracting A/V streams [VID_00890] - [21:33:55] Reencoding video [VID_00890] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,668 frames - Bitrate: 10,215 Kbs - [21:33:56] Reencoding: VID_00890, Pass 1 of 1 - Encode failed. Aborting. - BD-Rebuilder v0.46.14 (beta) - Windows Version: 6.1 [7601] - Working Path Free Space: 721.63GB - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: 1.9.42.1, Ok - FFDSHOW: 4504, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - AnyDVD settings check: Ok. - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [21:33:58] - Failed video encode, aborted Last edited by jdobbs; 7th April 2014 at 13:43. |
#19957 | Link | |
If its any help, as you may recall I had the same issue with Thor 2 bluray to bluray movie only. The forced sub was not turned on by default as it was on the original. |
#19958 | Link |
My thanks to you.
#19959 | Link |
BD Rebuilder v0.47.04 (beta)
I have updated the first post of this thread with a link to the latest version of BD-RB (v0.47.04). Changes for this release:
- Implemented 3D Full Backup Mode. Note that BD-RB converts 3D method so that the SSIF folder is no longer required -- the method is 100% compliant with the BD standard. (v0.47.03) - Due to the changes in the way 3D is handled, BD-RB no longer outputs to ISO by default on movie-only 3D encodes. It can be enabled by using the OUTPUT_3D_ISO hidden option. Note: This option only applies to movie-only 3D encodes. (v0.47.03) - Made in-mux (single M2TS) 3D multiplexing mode the default on full-backup 3D. This can be changed back with the hidden option FORCE_INMUX_3D=0. - Modified 3D movie-only mode so it also now uses the in-mux structure for BD-3D output. - Corrected a error that might rarely occur on 3D sources with reencoded audio tracks that have sample rates higher than 48Khz. - Corrected an error that could might cause, under very rare circumstances, movie-only encodes of 29.97fps sources to either fail during muxing or create sync issues. - Corrected an error in the INSPECT report in which MP4BOX is incorrectly reported as missing. - Added FRIMSource as an option for decoding and frame-serving in the SETUP dialog. This may be particularly useful for those who can use Intel hardware mode for decoding. Note: Enabling CRF prediction automatically disabled FRIMSource decoding. - Corrected an issue with correct updating of the programinfo table when keeping HD audio on BD-3D full-backups. - Corrected an error in which blanking a 3D source would result in an error indicating a "missing file" during rebuild. - Corrected an error in which enabling LAVF and CRF modes simultaneously would cause an error during the prediction phase. - Other minor corrections and cosmetic fixes.
jdobbs.softworks@gmail.com Last edited by jdobbs; 7th April 2014 at 16:05. |
| Display Modes | |
