#18141 | Link |
For me, file searched on second phase exists during the encoding process and it seems to be renamed after encoding finish...
And an other thing, all .stats files are auto deleted but the last .stats file isn't deleted. And this file is encoded but original .264 is also present in the directory and the size of original .264 is lower than .264 encoded... Last edited by Nico8583; 7th November 2013 at 18:37. |
#18142 | Link |
![]() Join Date: Oct 2001
The 3D discussion had pulled the thread way off topic -- so I've moved it to a thread of its own.
jdobbs.softworks@gmail.com Last edited by jdobbs; 8th November 2013 at 18:57. |
#18143 | Link |
@Darth_Emma and others
I found the cause of the "file not found" error during rebuild and have fixed it for the next release.
jdobbs.softworks@gmail.com |
#18144 | Link |
Failed to reencode audio, aborted
I met with the following problem in BD-RB:
---------------------- [11.08.13] BD Rebuilder v0.44.17 (beta) [18:20:40] Source: JACK_THE_GIANT_SLAYER_00100 - Input BD size: 27,09 GB - Approximate total content: [01:54:08.883] - Target BD size: 7,32 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Quality: Good (Very Fast), Two Pass - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [18:20:40] PHASE ONE, Encoding - [18:20:40] Processing: VID_00085 (1 of 1) - [18:20:40] Extracting A/V streams [VID_00085] - [18:29:38] Reencoding video [VID_00085] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 164*209 frames - Bitrate: 6*769 Kbs - [18:29:38] Reencoding: VID_00085, Pass 1 of 2 - [18:54:11] Reencoding: VID_00085, Pass 2 of 2 - [19:18:57] Video Encode complete - [19:18:57] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - [19:18:57] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - [19:18:57] ReencodeAudio() 00070 1801 [19:20:14] - Failed to reencode audio, aborted I do not really understand because I marked the following options in the setup window which can affect on audio reencoding: - Do not convert DTS to AC3; - Do not reencode AC3; - Keep HD Audio for BD25; The other two options were unmarked. Please advise. |
#18145 | Link |
I have made a new test (but I have seen you have found the bug). I have choose 47 GB output (instead of 25GB) and I have launch backup with same settings. All is working (it's logical, there is no encode) but strange result is final ISO file fit into a BD25 without reencode
#18146 | Link | |
I'm guessing the source is DTS and you're outputting to AVCHD. In that case the flags don't matter, because AVCHD doesn't accept DTS (it isn't part of the AVCHD standard). You might try unclicking "Strict AVCHD" in SETUP.
jdobbs.softworks@gmail.com Last edited by jdobbs; 8th November 2013 at 20:53. |
#18147 | Link | |
#18149 | Link |
choosing which VID to encode problem
I would like to know what is the basis of choosing between the VIDS to reencode when switching from one output option to the other in case of full backup mode? BD-rebuilder chooses by itself specific VIDS to reencode based on the given capacity on which to store. The VIDS which are not going to be reencoded will remain intact (supposed to be). I would just like to know the process "behind the curtain". I am asking it because it seems to me that it doesn't really depend on the size of the VIDS, there must be something else, too I think. For example if I switch the target size from BD-5 to BD-25 a lot of big sized VIDS are going to be left intact, but some with similar or even smaller sizes are about to be reencoded. Please advise.
#18150 | Link | |
#18151 | Link |
Ok, but it is still not clear, sorry. I have a VID with the size of 465 Mbyte for example, and I am in the output mode of BD-5, the program "wants" to reencode it, but if I simply switch to BD-25 mode the program ends up with the VID not located in the list anymore to be reencoded. It is not a menu and the size is above 100Mbyte, so there must be some other determining factor skipped.
#18152 | Link |
BD Rebuilder v0.45.03 (beta)
I have updated the first post of this thread with a link to the most recent release of BD-RB (v0.45.03). Note: This release has a LOT of changes and new code related to the way importing and Quick-Play reauthoring works. I ask that beta testers please concentrate on these features and post any issues you find. One other note - remember that an import or Quick-Play reauthored disc that only has one item does NOT create a menu, so it will be very much like a movie-only disc. At least two playlists have to match the import criteria (minimum threshold) to be included and invoke the need for a menu.
Changes for this release: Code:
- Made major changes to how the Quick-Play reauthoring mechanism works. Implemented an interactive menu to the reauthored output. Now you can browse and select from multiple titles on Quick-Play reauthored discs. This feature applies also to all imported titles (DVD, Videofile, and BD). This feature is especially useful for combining and reencoding multiple BD or DVD series discs into a single BD-25 or BD-50. It is also nice for creating a disc backup that comes up-and-running without annoying leader and sales information. - Added significant new editing capabilities associated with Quick-Play menu items. The features include a dialog for viewing and/or modifying title information for imports and Quick-Play reauthored discs. - Improved the algorithm for finding duplicate playlists during import of multiple BDs via Quick-Play reauthoring. - Changed the MP4BOX temporary folder setting to use the specified working folder rather than the system default. - Made a correction to the code related to the hidden option FORCED_SUB_LANG. The option wasn't working as designed in v0.44.17. Also modified it so you can add more than one language separated using a semicolon. The languages are prioritized as entered from left to right. - Added a new hidden option REMOVE_IMPORT. If set, BD-RB will remove the folder used for import after the reencoding is successfully completed. As with any auto-removal feature you should be very careful in its use. - Added a multiple BD import feature. Similar to the DVD import function, if multiple BDs are grouped together under a single selected source folder, BD-RB gives you the option of importing them as one (combining with the Quick-Play reauthoring format). Please note that the output to the IMPORT folder can be very large (equal to all the combined source BD folders). - Improved the algorithm for determining title playback order during IMPORT of DVDs or BDs. - Added BD-50 as a selectable target size in the OUTPUT OPTIONS menu. This should be of particular use when creating collections via the IMPORT functions. - Removed DVD_IMPORT_THRESHOLD from the hidden options. It was renamed to IMPORT_THRESHOLD, now applies to both DVD imports and BD imports, and is set via dialong. - Added new option MENU_AUTO_BACKGROUND. This setting is currently experimental to some degree. When set to "1" (the default) it will tell BD-RB to attempt to find and utilize a menu background & audio track from the source disc when doing an import or Quick-Play encode. Set via dialog. - Made "zlib" compression the default for MKV output to better comply with the Matroska standard. Also added a new hidden option "USE_ZLIB" that is documented in the HIDDENOPTS.TXT file. Setting this option to "0" disables zlib compression (for the few players that may not support it). - Corrected an issue in which an out-of-place secondary audio stream could cause the PIDs to be incorrectly updated in the MPLS file during a full backup. - Corrected an error in which LPCM sources in DVDs were not being imported. - Added code that will shorten the amount of time used to scan sources on movie-only backups -- especially in situations where the number of M2TS files is large. - Fixed an error that could result in failed rebuild due to missing .264 file on certain multipart sources being encoded in movie-only mode. - Updated the included version of X264.EXE to the latest release (r2377). - Updated the included version of X264-64.EXE to the latest release (r2377). - Other minor corrections and cosmetic fixes.
jdobbs.softworks@gmail.com Last edited by jdobbs; 9th November 2013 at 21:57. |
#18153 | Link |
I just noticed there is a bug I caused recently in the BD import function that results in "Runtime Error 9, Subscript out of Range" -- ugghhh... after two weeks of testing I cause an error in the last couple of changes.
Anyway, I'll find it, fix it, and post another version in the next hour or so. [Edit] Ok, it's fixed and has been uploaded -- the first post has also been updated. I've also fixed it so any attempts to download v0.45.02 from the jdobbs site will actually get v0.45.03 as well.
jdobbs.softworks@gmail.com Last edited by jdobbs; 9th November 2013 at 22:10. |
#18154 | Link | |
#18155 | Link | |
I appreciate your support.
#18156 | Link | |
MKV vbv buffer/maxrate settings
I can't find it the hidden options. Last edited by Glarioo; 10th November 2013 at 00:35. |
#18160 | Link |
Testing multi-disc import in Quick-Play mode right now, and there's one thing I sorely miss: the option of forcing a subtitle track on, as in Movie-only mode. Discs have two English sub tracks on them, with different contents, and I'm guessing FORCED_SUB_LANG option is unable to decide which one to force on.
| Display Modes | |
