#22141 | Link | |
#22142 | Link |
Hello, i have purchased a BD (gladiator) but it doesnt have my language and i want to replace an external audio track keeping video quality bit to bit, and menu... i could get the BD context to my PC. Can i add a new auido track with this programme while keeping everything intact? what are the settings?
#22143 | Link | |
@jdobbs - looks like the issue is either the Video encode to alternative file formats or in rebuild stage? |
#22144 | Link | |
![]() Join Date: Oct 2001
1. Set BD-RB to BD-50 output. That will prevent reencoding. 2. Start the job. 3. When the audio/video extraction is complete, stop the job. 4. In the working folder, replace one of the audio streams with the stream you want to use. Note: The type of audio (ac3, dts, etc) must match the original, and the sample rate must be the same. 5. Continue the job. When it rebuilds it will use your audio.
jdobbs.softworks@gmail.com |
#22146 | Link |
Senior Member
The way to fix the audio sync if it is the correct length, but has the wrong start time, would be to set the proper audio delay (positive or negative) in tsmuxer. The delay would have to be manually determined.
I've done this before for the movie only mode. Reauthor in tsmuxer with the delay set and then import into BD-RB. Last edited by Video Dude; 19th January 2015 at 18:34. |
#22148 | Link | |
I have used no avail to Interto change audio audio Latino Spanish My intention is to only change the primary audio of the movie Castilian Spanish case observing the audio menus, extras and Maxima quality Excuse my language translator Use Code:
---------------------- [01/19/15] BD Rebuilder v0.50.02 [20:40:19] Source: DOLPHIN_TALE - Input BD size: 41,00 GB - Approximate total content: [02:05:28.103] - Target BD size: 46,26 GB - Windows Version: 6.1 [7601] - Quality: Good (Very Fast), ABR - MVC 3D Output Mode enabled - Decoding/Frame serving: FRIMDecode - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [20:40:19] PHASE ONE, Encoding - [20:40:19] Processing: VID_00010 (1 of 5) - [20:40:19] Extracting A/V streams [VID_00010] - [20:40:24] Reencoding video [VID_00010] - [20:40:24] Keeping original video (no reencode) - [20:40:25] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:40:25] Multiplexing M2TS - [20:40:30] Scanning for 3D CLPI info... - [20:40:35] Processing: VID_00017 (2 of 5) - [20:40:35] Extracting A/V streams [VID_00017] - [20:40:42] Reencoding video [VID_00017] - [20:40:42] Keeping original video (no reencode) - [20:40:42] Processing audio tracks - [20:40:42] Multiplexing M2TS - [20:40:47] Scanning for 3D CLPI info... - [20:40:54] Processing: VID_00134 (3 of 5) - [20:40:54] Extracting A/V streams [VID_00134] - [20:41:01] Reencoding video [VID_00134] - [20:41:01] Keeping original video (no reencode) - [20:41:01] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:41:01] Multiplexing M2TS - [20:41:06] Scanning for 3D CLPI info... - [20:41:14] Processing: VID_00138 (4 of 5) - [20:41:14] Extracting A/V streams [VID_00138] - [20:44:53] Reencoding video [VID_00138] - [20:44:53] Keeping original video (no reencode) - [20:44:53] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (fra): Keeping original audio - Track 4355 (fra): Keeping original audio - Track 4356 (deu): Keeping original audio - Track 4357 (ita): Keeping original audio - Track 4358 (spa): Keeping original audio - Track 4359 (por): Keeping original audio - Track 4360 (jpn): Keeping original audio - [20:44:54] Multiplexing M2TS - [20:50:44] Scanning for 3D CLPI info... - [20:56:34] Processing: VID_00139 (5 of 5) - [20:56:34] Extracting A/V streams [VID_00139] - [20:59:12] Reencoding video [VID_00139] - [20:59:12] Keeping original video (no reencode) - [20:59:12] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (fra): Keeping original audio - Track 4355 (fra): Keeping original audio - Track 4356 (deu): Keeping original audio - Track 4357 (ita): Keeping original audio - Track 4358 (spa): Keeping original audio - Track 4359 (por): Keeping original audio - Track 4360 (jpn): Keeping original audio - [20:59:12] Multiplexing M2TS - [21:01:35] Scanning for 3D CLPI info... [21:07:07]PHASE ONE complete [21:07:07]PHASE TWO - Rebuild Started - [21:07:07] Converting SSIF file references - [21:07:25] Rebuilding BD-3D file Structure [21:07:28] - Encode and Rebuild complete [21:07:28] Writing BD structure to ISO file - ImgBurn completed successfully [21:14:02] JOB: DOLPHIN_TALE finished. |
#22149 | Link |
It works for anything... I notice your log doesn't show a point at which you stopped and restarted. So that means you couldn't have possibly followed the instructions I listed.
#22150 | Link | |
I'll try to spell out the steps very easily so you can hopefully translate and understand. I DO speak a little Spanish, but not nearly enough for this Also, I do not know exactly how to start/stop BDRB properly as JD is saying, so I'm going to give you an alternate suggestion if that is okay. This suggestion will ONLY keep the video track and your Spanish track, but will NOT keep any of the menus or extras.1. Run BDRB with your movie 2. As SOON as it finishes extracting the A/V tracks and starts rebuilding the structure, STOP BDRB. 3. Go to the WORKFILES folder. 4. In it you will see the video file that ends I think with .264. 5. Open TSMuxer and import that video file. 6. Using TSMuxer import the Spanish audio file that you want. 7. Use TSMuxer then to build a new BDMV (Blu-ray) folder with the video file and the new Spanish file (if you want also to include any of the other languages too, add those audio files) 8. At this point, if you ONLY want the video track and the Spanish and/or other audio tracks and that is all, then you are done and you can burn the resulting BDMV folder to disc if you want. 9. Or, if you want to compress the size from that point, import the newly made BDMV (Blu-ray) folder into BDMV and set it to output whatever size you want. The only thing is as was said before. IF the audio and video are NOT in sync, then at # 7 above you will manually have to adjust the delay or time difference using TSMuxer BEFORE you input the result into BDRB. Now, what JD was saying is that IF you can stop BDRB at I guess the right moment (I'm honestly not quite sure how to do that) then he is saying that you CAN simply put the new Spanish audio track right into the WORKFILES folder and I GUESS just somehow have BDRB continue rebuilding it. But, I don't know quite how to do that exactly ![]() But, using TSMuxer, then at least you can have a chance to check the A/V sync and adjust if first. Also, using TSMuxer, you can use ANY legal audio format file for your Spanish track instead of HAVING to match the one that is already in BDRB (I think...) I HOPE that helps somehow... |
#22151 | Link |
And Lathe jdobbs through.
Just pause the operation and replace the audio I need. Tomorrow proves again with your advice. Gracias a jdobbs y Lathe. Solo pause la operación y sustituir el audio que necesito. Mañana probare de nuevo con vuestros consejo |
#22152 | Link | |
jdobbs, firstly, thank you for ur suggestion, i will certainly give it a try, but i just did not understand what u meant by "but it's not built-in"
You mean it wont keep the menu? Quote:
#22153 | Link |
No. I mean BD-RB doesn't do it automatically as a built-in function -- you have to manually do it by stopping, replacing the file, and restarting.
#22154 | Link |
3d compilations
Impossible to make 3d compilations (when quick reauthored, I get only 2d version of my 3d sources in compilation...) ? Also, is it possible to reduce time lap (maybe 4 seconds) between parts of the compilation when reading, as if you were reading a dual layer disk (I don't care about menu: just want to put 2 disk movie into 1 reauthored disk)? Thanks for your help ! |
#22155 | Link |
BD Rebuilder v0.50.03
I have updated the first post of this thread with a link to the most recent update to BD-RB (v0.50.03). Changes for this release:
- Improved prediction of audio size when auto ALTERNATE audio bitrate an a target size is selected. - Added a new audio option to the SETUP dialog that enables use of a special type of Dynamic Range Compression. This option will improve some audio tracks where quieter sounds, like conversations, can be lost due to playback volume adjustments needed for louder sounds. - Added a new hidden option AUDIO_DRC_FACTOR which sets a factor for amount of Dynamic Range Compression. See HIDDENOPTS.TXT - Corrected an issue with automatic ALTERNATE audio bitrate settings when a target size has been selected (resulting in "Audio is too large for target" dialog). - Corrected an issue in which restarting from an aborted encode while forced subtitles are enabled might result in the subtitles not being displayed by default. This would also apply to ALTERNATE encodes using SupTitle. - Corrected an issue in which forced subtitles in multipart movie-only titles did not work properly. - Added a hidden option MPEG2_DIRECTSHOW. If set to "1" it will disable DGDECODE.DLL as the decoder for MPEG-2 via AVISYNTH (when in Directshow mode) and use DirectshowSource() instead. The default is "0" (OFF). It is not recommended to change the default except as required for very special circumstances. - Corrected a problem in which it is possible, under certain circumstances that a segment of a multipart movie-only encode might get flagged to keep intact while other parts are encoded. - Updated the included version of X265.EXE to a newer release (01/08/2015). - Other minor corrections and cosmetic fixes.
#22157 | Link | |
THANK YOU!!! |
#22158 | Link |
- Added a hidden option MPEG2_DIRECTSHOW. If set to "1" it will disable DGDECODE.DLL as the decoder for MPEG-2 via AVISYNTH (when in Directshow mode) and use DirectshowSource() instead. The default is "0" (OFF). It is not recommended to change the default except as required for very special circumstances. ------------------------- @ jdobbs many thanks for that! ![]() I will retry dgdecode when I update from Win 7 to Win 10. I don´t know why dgdecode dont work correctly on my current Win 7 system!? rergards andref4 |
#22159 | Link |
Sweeeet.... I Laughed a lot.
Ch3vr0n, NO disrespected intended in this reply. Just enjoyed the playfulness.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! |
| Display Modes | |
