#20341 | Link | ||
And as for "preprocessed" sources, this is a discussion of the import feature, which accepts MKV files, so it sort of has to include preprocessed sources in this case, since you can't get an MKV without processing a source to make it. And I wasn't reporting a bug, just trying to find more details about an issue some one else reported, in an effort to clarify the issue.Quote:
#20342 | Link |
You cannot discuss downloaded material unless you specifically show for each instance that it is in the public domain. Strikes will follow if you do not abide by this. Is it clear? If not, please follow up in PM to me and not in this thread. Thank you.
#20343 | Link |
Hi everyone, my name's Diego. I have used bdrebuilder many times, but with the last upgrade, I have some problems....
I have two pc, with Windows 7. In the first pc, when I try to convert a bluray 50 to 25 gb, after a few minutes the pc shutdow. This appen with a movie of 2002, Rookie from Disney. In the second pc, when I try to do the same ( rebuild from 50 to 25 ) all goes ok, but at the end, the size is 14 gb, and the movie freeze after 20 minutes. I've ripped with anydvdhd, and burnt on 50 gb it works... Any ideas? Thanks. P.S. the log show no error ...
#20344 | Link |
![]() Join Date: Oct 2001
Go to the first page of this thread and install exactly as outlined with exactly the links provided. If you follow that sequence BD-RB will work every time.
jdobbs.softworks@gmail.com |
#20345 | Link |
Hi Diego,
First, do what JD suggested above. But keep in mind that it could still be a bad rip. BD players are designed to throw out data errors and keep going. BD-Rebuilder is not. A bad rip can sneak through, without causing an error message during ripping, and then cause unpredictable results later on. So if re-loading the helper apps doesn't solve the problem, then try cleaning the disc and ripping again. |
#20347 | Link |
Thanks to everyone,I'have reinstalled all, as the first page and the file readme. said, but still the problem remains.
I've made a try with another disk, machete kills. Made new rip. The original copy burnt on br rewritable works ( it is about 27 gb ) but, the resize made to fit it in br 25, is 17 gb, and the movie freeze in the first 20 minutes.... Here the process : LABEL=MACHETE_KILLS_BD VERSION=v0.47.06 (beta) SOURCE_SIZE=28830789738 SOURCE_VIDEO_SIZE=28796123136 TARGET_SIZE=24641536000 REDUCTION=.8545202172454 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=eng;ita; KEEP_HD_AUDIO=0 SUBS_TO_KEEP=all BACKUP_MODE=0 MOVIEONLY_TYPE=0 USE_LAVF=0 INSTANCES=1 DGDECNV=0 DGDECIM=0 FRIMSOURCE=0 SSIF_MODE=0 QUICK=0 ENCODE_STEP=0 COMPLETED=7 REBUILD_COMPLETE=1 [00004] AUDIO=11 PGS=10 APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=19590818113 RATE=22009 SPLITS=1 NSTART=27000000 NEND=318352934 NSIZE=13953964032 FLINK=0 MLINK=0 [00005] AUDIO=1 PGS=1 APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=591473901 RATE=18179 SPLITS=1 NSTART=27000000 NEND=37713202 NSIZE=576651264 FLINK=0 MLINK=0 [00006] AUDIO=1 PGS=1 APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=587714778 RATE=18172 SPLITS=1 NSTART=27000000 NEND=37645635 NSIZE=580958208 FLINK=0 MLINK=0 [00007] AUDIO=1 PGS=1 APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=291746820 RATE=18562 SPLITS=1 NSTART=27000000 NEND=32178298 NSIZE=288024576 FLINK=0 MLINK=0 [00008] AUDIO=1 PGS=1 APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=324339889 RATE=18487 SPLITS=1 NSTART=27000000 NEND=32777021 NSIZE=330252288 FLINK=0 MLINK=0 [00009] AUDIO=1 PGS=1 APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=237764549 RATE=18770 SPLITS=1 NSTART=27000000 NEND=31172293 NSIZE=233533440 FLINK=0 MLINK=0 [00010] AUDIO=1 PGS=1 APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=2983011348 RATE=17912 SPLITS=1 NSTART=27000000 NEND=81872317 NSIZE=2456303616 FLINK=0 MLINK=0 the target was 24 gb , but at end process it is 17....
#20349 | Link |
@ Diego; RE: I've made a try with another disk, machete kills.
You are not showing your BD Rebuilder log and did you run the inspect to see if everything is installed correctly. Plus you don't say what player you're using to play back the final rebuilt BD. It seems like maybe it has something to do with cinavia since this is an infected disk and it's also stopping at 20 min. Just sayin', maybe it's a player problem if you are using a up to date software player or a BD player that's mfg. after Feb 2012. |
#20350 | Link |
chapter + freez !!
possible Bug 101!!
have made an bd50 → bd25 from the movie AvP Extended edition and during playback the movie freezes at every chapter for an few secs and continue's with playback on stand alone player !! tested in software player (TMT 6) the image freezes and stay's frozen !! This is happening with the Extended selection .., when selecting Theatral (original) everything play's fine both on stand alone and software player !! Have tried an Movie only backup, and it seems to play fine BUT!! The movie only wos the original (cutted) version and not the extedended version !! Thats another thing i like to know, how to choose the extended version when doing an "movie only" backup !! Original Rip seems unaffected and play fine !! BD-rebuilder 0.47.6 Every utility up to date (check) regards, |
#20352 | Link |
Here you are ..
[Status] LABEL=ALIEN_VS_PREDATOR VERSION=v0.47.06 (beta) SOURCE_SIZE=33037341058 SOURCE_VIDEO_SIZE=28601321472 TARGET_SIZE=24641536000 REDUCTION=.706453945975213 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=dum;dut;eng;kor;nld; KEEP_HD_AUDIO=-1 SUBS_TO_KEEP=all BACKUP_MODE=0 MOVIEONLY_TYPE=0 USE_LAVF=0 INSTANCES=1 DGDECNV=0 DGDECIM=0 FRIMSOURCE=-1 SSIF_MODE=0 QUICK=1 ENCODE_STEP=0 COMPLETED=28 REBUILD_COMPLETE=1 [00060] AUDIO=1 PGS=1111 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=186639 SPLITS=1 NSTART=27000000 NEND=27011261 NSIZE=67584 FLINK=0 MLINK=0 [00029] AUDIO=10000 PGS=1101010000000000000 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=52966861 RATE=18955 SPLITS=1 NSTART=27000000 NEND=27724473 NSIZE=49274880 FLINK=-1 MLINK=0 [00017] AUDIO=10000 PGS=1101010000000000000 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=57899569 RATE=17095 SPLITS=1 NSTART=27000000 NEND=27893392 NSIZE=55357440 FLINK=-1 MLINK=0 [00036] AUDIO=10000 PGS=1101010000000000000 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=64814732 RATE=17307 SPLITS=1 NSTART=27000000 NEND=27977852 NSIZE=60936192 FLINK=-1 MLINK=0 [00058] AUDIO=1 PGS=1111 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=85199591 SPLITS=1 NSTART=27000000 NEND=29451198 NSIZE=74913792 FLINK=0 MLINK=0 [00006] AUDIO=10000 PGS=1101010000000000000 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=91421155 RATE=16448 SPLITS=1 NSTART=27000000 NEND=28383257 NSIZE=85241856 FLINK=-1 MLINK=0 [00011] AUDIO=10000 PGS=1101010000000000000 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=95813223 RATE=17121 SPLITS=1 NSTART=27000000 NEND=28388887 NSIZE=88903680 FLINK=-1 MLINK=0 [00020] AUDIO=10000 PGS=1101010000000000000 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=127341963 RATE=17547 SPLITS=1 NSTART=27000000 NEND=28809307 NSIZE=115402752 FLINK=-1 MLINK=0 [00003] AUDIO=10000 PGS=1101010000000000000 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=142889355 RATE=19556 SPLITS=1 NSTART=27000000 NEND=28989487 NSIZE=137232384 FLINK=-1 MLINK=0 [00032] AUDIO=10000 PGS=1101010000000000000 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=185725102 RATE=17851 SPLITS=1 NSTART=27000000 NEND=29723345 NSIZE=177432576 FLINK=-1 MLINK=0 [00055] AUDIO=1 PGS=1111 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=212896955 SPLITS=1 NSTART=27000000 NEND=33180549 NSIZE=246773760 FLINK=0 MLINK=0 [00057] AUDIO=1 PGS=1111 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=238410821 SPLITS=1 NSTART=27000000 NEND=33505248 NSIZE=237656064 FLINK=0 MLINK=0 [00056] AUDIO=1 PGS=1111 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=254603401 SPLITS=1 NSTART=27000000 NEND=33595338 NSIZE=264554496 FLINK=0 MLINK=0 [00026] AUDIO=10000 PGS=1101010000000000000 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=256013604 RATE=18897 SPLITS=1 NSTART=27000000 NEND=30400897 NSIZE=237441024 FLINK=-1 MLINK=0 [00002] AUDIO=10000 PGS=1101010000000000000 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=342696884 RATE=19257 SPLITS=1 NSTART=27000000 NEND=31579575 NSIZE=312330240 FLINK=-1 MLINK=0 [00023] AUDIO=10000 PGS=1101010000000000000 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=358216958 RATE=18763 SPLITS=1 NSTART=27000000 NEND=32097592 NSIZE=340531200 FLINK=-1 MLINK=0 [00005] AUDIO=10000 PGS=1101010000000000000 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=365493535 RATE=19059 SPLITS=1 NSTART=27000000 NEND=31928673 NSIZE=340525056 FLINK=-1 MLINK=0 [00000] AUDIO=10000 PGS=1101010000000000000 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=376161317 RATE=14330 SPLITS=1 NSTART=27000000 NEND=33394513 NSIZE=345704448 FLINK=-1 MLINK=0 [00016] AUDIO=10000 PGS=1101010000000000000 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=402543757 RATE=18338 SPLITS=1 NSTART=27000000 NEND=32628748 NSIZE=371349504 FLINK=-1 MLINK=0 [00031] AUDIO=10000 PGS=1101010000000000000 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=495354082 RATE=20057 SPLITS=1 NSTART=27000000 NEND=33394513 NSIZE=457402368 FLINK=-1 MLINK=0 [00022] AUDIO=10000 PGS=1101010000000000000 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=498431807 RATE=21213 SPLITS=1 NSTART=27000000 NEND=33129873 NSIZE=462778368 FLINK=-1 MLINK=0 [00013] AUDIO=10000 PGS=1101010000000000000 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=542523943 RATE=19941 SPLITS=1 NSTART=27000000 NEND=34043912 NSIZE=501086208 FLINK=-1 MLINK=0 [00025] AUDIO=10000 PGS=1101010000000000000 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=732986883 RATE=19896 SPLITS=1 NSTART=27000000 NEND=36611477 NSIZE=680939520 FLINK=-1 MLINK=0 [00028] AUDIO=10000 PGS=1101010000000000000 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=943184213 RATE=20582 SPLITS=1 NSTART=27000000 NEND=38944432 NSIZE=883716096 FLINK=-1 MLINK=0 [00019] AUDIO=10000 PGS=1101010000000000000 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1519098073 RATE=19905 SPLITS=1 NSTART=27000000 NEND=47213943 NSIZE=1419454464 FLINK=-1 MLINK=0 [00034] AUDIO=10000 PGS=1101010000000000000 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=2175867473 RATE=20233 SPLITS=1 NSTART=27000000 NEND=55367088 NSIZE=2037233664 FLINK=-1 MLINK=0 [00008] AUDIO=10000 PGS=1101010000000000000 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=4956041765 RATE=20269 SPLITS=1 NSTART=27000000 NEND=91735295 NSIZE=4638959616 FLINK=-1 MLINK=0 [00038] AUDIO=10000 PGS=1101010000000000000 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=5582317182 RATE=19410 SPLITS=1 NSTART=27000000 NEND=102756305 NSIZE=5269487616 FLINK=0 MLINK=0 |
#20354 | Link |
Here i thought the longest/movie log should be the most complete/detailed file and thus the most helpfull log to help you ppl sorting this out ..
i guess i wos wrong!! ↓ this is the rebuilder ini file, now you have both ! Happy hunting.. Code:
---------------------- [05/26/14] BD Rebuilder v0.47.06 (beta) [23:45:27] Source: ALIEN_VS_PREDATOR - Input BD size: 30,77 GB - Approximate total content: [02:06:39.424] - Target BD size: 22,95 GB - Windows Version: 6.1 [7601] - Quality: High Quality (Default), Two Pass - SHUTDOWN at completion enabled - Decoding/Frame serving: FRIMSource - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [23:45:27] PHASE ONE, Encoding - [23:45:27] Processing: VID_00060 (1 of 28) - [23:45:27] Extracting A/V streams [VID_00060] - [23:45:33] Reencoding video [VID_00060] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 6 frames - [23:45:33] Reencoding: VID_00060, Pass 1 of 1 - [23:45:35] Video Encode complete - [23:45:35] Processing audio tracks - Track 4352 (eng): Keeping original audio - [23:45:35] Multiplexing M2TS - [23:45:38] Processing: VID_00029 (2 of 28) - [23:45:38] Extracting A/V streams [VID_00029] - [23:45:44] Reencoding video [VID_00029] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 386 frames - Bitrate: 18.955 Kbs - [23:45:44] Reencoding: VID_00029, Pass 1 of 2 - [23:45:49] Reencoding: VID_00029, Pass 2 of 2 - [23:46:07] Video Encode complete - [23:46:07] Processing audio tracks - Track 4352 (eng): Keeping original audio - [23:46:07] Multiplexing M2TS - [23:46:11] Processing: VID_00017 (3 of 28) - [23:46:11] Extracting A/V streams [VID_00017] - [23:46:16] Reencoding video [VID_00017] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 476 frames - Bitrate: 17.095 Kbs - [23:46:16] Reencoding: VID_00017, Pass 1 of 2 - [23:46:23] Reencoding: VID_00017, Pass 2 of 2 - [23:46:44] Video Encode complete - [23:46:44] Processing audio tracks - Track 4352 (eng): Keeping original audio - [23:46:44] Multiplexing M2TS - [23:46:48] Processing: VID_00036 (4 of 28) - [23:46:48] Extracting A/V streams [VID_00036] - [23:46:53] Reencoding video [VID_00036] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 521 frames - Bitrate: 17.307 Kbs - [23:46:53] Reencoding: VID_00036, Pass 1 of 2 - [23:47:00] Reencoding: VID_00036, Pass 2 of 2 - [23:47:21] Video Encode complete - [23:47:21] Processing audio tracks - Track 4352 (eng): Keeping original audio - [23:47:21] Multiplexing M2TS - [23:47:26] Processing: VID_00058 (5 of 28) - [23:47:26] Extracting A/V streams [VID_00058] - [23:47:31] Reencoding video [VID_00058] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 1.306 frames - [23:47:31] Reencoding: VID_00058, Pass 1 of 1 - [23:47:43] Video Encode complete - [23:47:43] Processing audio tracks - Track 4352 (eng): Keeping original audio - [23:47:43] Multiplexing M2TS - [23:47:50] Processing: VID_00006 (6 of 28) - [23:47:50] Extracting A/V streams [VID_00006] - [23:47:55] Reencoding video [VID_00006] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 737 frames - Bitrate: 16.448 Kbs - [23:47:55] Reencoding: VID_00006, Pass 1 of 2 - [23:48:06] Reencoding: VID_00006, Pass 2 of 2 - [23:48:36] Video Encode complete - [23:48:36] Processing audio tracks - Track 4352 (eng): Keeping original audio - [23:48:36] Multiplexing M2TS - [23:48:41] Processing: VID_00011 (7 of 28) - [23:48:41] Extracting A/V streams [VID_00011] - [23:48:46] Reencoding video [VID_00011] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 740 frames - Bitrate: 17.121 Kbs - [23:48:46] Reencoding: VID_00011, Pass 1 of 2 - [23:48:57] Reencoding: VID_00011, Pass 2 of 2 - [23:49:30] Video Encode complete - [23:49:30] Processing audio tracks - Track 4352 (eng): Keeping original audio - [23:49:30] Multiplexing M2TS - [23:49:34] Processing: VID_00020 (8 of 28) - [23:49:34] Extracting A/V streams [VID_00020] - [23:49:40] Reencoding video [VID_00020] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 964 frames - Bitrate: 17.547 Kbs - [23:49:40] Reencoding: VID_00020, Pass 1 of 2 - [23:49:53] Reencoding: VID_00020, Pass 2 of 2 - [23:50:35] Video Encode complete - [23:50:35] Processing audio tracks - Track 4352 (eng): Keeping original audio - [23:50:35] Multiplexing M2TS - [23:50:40] Processing: VID_00003 (9 of 28) - [23:50:40] Extracting A/V streams [VID_00003] - [23:50:47] Reencoding video [VID_00003] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 1.060 frames - Bitrate: 19.556 Kbs - [23:50:47] Reencoding: VID_00003, Pass 1 of 2 - [23:51:01] Reencoding: VID_00003, Pass 2 of 2 - [23:51:45] Video Encode complete - [23:51:45] Processing audio tracks - Track 4352 (eng): Keeping original audio - [23:51:45] Multiplexing M2TS - [23:51:50] Processing: VID_00032 (10 of 28) - [23:51:50] Extracting A/V streams [VID_00032] - [23:51:57] Reencoding video [VID_00032] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 1.451 frames - Bitrate: 17.851 Kbs - [23:51:57] Reencoding: VID_00032, Pass 1 of 2 - [23:52:16] Reencoding: VID_00032, Pass 2 of 2 - [23:53:15] Video Encode complete - [23:53:15] Processing audio tracks - Track 4352 (eng): Keeping original audio - [23:53:15] Multiplexing M2TS - [23:53:20] Processing: VID_00055 (11 of 28) - [23:53:20] Extracting A/V streams [VID_00055] - [23:53:29] Reencoding video [VID_00055] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 3.293 frames - [23:53:29] Reencoding: VID_00055, Pass 1 of 1 - [23:53:58] Video Encode complete - [23:53:58] Processing audio tracks - Track 4352 (eng): Keeping original audio - [23:53:58] Multiplexing M2TS - [23:54:04] Processing: VID_00057 (12 of 28) - [23:54:04] Extracting A/V streams [VID_00057] - [23:54:11] Reencoding video [VID_00057] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 3.466 frames - [23:54:12] Reencoding: VID_00057, Pass 1 of 1 - [23:54:42] Video Encode complete - [23:54:42] Processing audio tracks - Track 4352 (eng): Keeping original audio - [23:54:42] Multiplexing M2TS - [23:54:48] Processing: VID_00056 (13 of 28) - [23:54:48] Extracting A/V streams [VID_00056] - [23:54:56] Reencoding video [VID_00056] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 3.514 frames - [23:54:56] Reencoding: VID_00056, Pass 1 of 1 - [23:55:28] Video Encode complete - [23:55:28] Processing audio tracks - Track 4352 (eng): Keeping original audio - [23:55:28] Multiplexing M2TS - [23:55:34] Processing: VID_00026 (14 of 28) - [23:55:34] Extracting A/V streams [VID_00026] - [23:55:41] Reencoding video [VID_00026] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 1.812 frames - Bitrate: 18.897 Kbs - [23:55:41] Reencoding: VID_00026, Pass 1 of 2 - [23:56:05] Reencoding: VID_00026, Pass 2 of 2 - [23:57:25] Video Encode complete - [23:57:25] Processing audio tracks - Track 4352 (eng): Keeping original audio - [23:57:25] Multiplexing M2TS - [23:57:31] Processing: VID_00002 (15 of 28) - [23:57:31] Extracting A/V streams [VID_00002] - [23:57:40] Reencoding video [VID_00002] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 2.440 frames - Bitrate: 19.257 Kbs - [23:57:40] Reencoding: VID_00002, Pass 1 of 2 - [23:58:10] Reencoding: VID_00002, Pass 2 of 2 - [23:59:50] Video Encode complete - [23:59:50] Processing audio tracks - Track 4352 (eng): Keeping original audio - [23:59:50] Multiplexing M2TS - [23:59:56] Processing: VID_00023 (16 of 28) - [23:59:56] Extracting A/V streams [VID_00023] - [00:00:05] Reencoding video [VID_00023] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 2.716 frames - Bitrate: 18.763 Kbs - [00:00:05] Reencoding: VID_00023, Pass 1 of 2 - [00:00:38] Reencoding: VID_00023, Pass 2 of 2 - [00:02:41] Video Encode complete - [00:02:41] Processing audio tracks - Track 4352 (eng): Keeping original audio - [00:02:41] Multiplexing M2TS - [00:02:48] Processing: VID_00005 (17 of 28) - [00:02:48] Extracting A/V streams [VID_00005] - [00:02:57] Reencoding video [VID_00005] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 2.626 frames - Bitrate: 19.059 Kbs - [00:02:57] Reencoding: VID_00005, Pass 1 of 2 - [00:03:30] Reencoding: VID_00005, Pass 2 of 2 - [00:05:23] Video Encode complete - [00:05:23] Processing audio tracks - Track 4352 (eng): Keeping original audio - [00:05:23] Multiplexing M2TS - [00:05:30] Processing: VID_00000 (18 of 28) - [00:05:30] Extracting A/V streams [VID_00000] - [00:05:39] Reencoding video [VID_00000] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 3.407 frames - Bitrate: 14.330 Kbs - [00:05:39] Reencoding: VID_00000, Pass 1 of 2 - [00:06:19] Reencoding: VID_00000, Pass 2 of 2 - [00:08:18] Video Encode complete - [00:08:18] Processing audio tracks - Track 4352 (eng): Keeping original audio - [00:08:18] Multiplexing M2TS - [00:08:26] Processing: VID_00016 (19 of 28) - [00:08:26] Extracting A/V streams [VID_00016] - [00:08:35] Reencoding video [VID_00016] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 2.999 frames - Bitrate: 18.338 Kbs - [00:08:35] Reencoding: VID_00016, Pass 1 of 2 - [00:09:13] Reencoding: VID_00016, Pass 2 of 2 - [00:11:32] Video Encode complete - [00:11:32] Processing audio tracks - Track 4352 (eng): Keeping original audio - [00:11:32] Multiplexing M2TS - [00:11:40] Processing: VID_00031 (20 of 28) - [00:11:40] Extracting A/V streams [VID_00031] - [00:11:50] Reencoding video [VID_00031] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 3.407 frames - Bitrate: 20.057 Kbs - [00:11:50] Reencoding: VID_00031, Pass 1 of 2 - [00:12:35] Reencoding: VID_00031, Pass 2 of 2 - [00:15:25] Video Encode complete - [00:15:25] Processing audio tracks - Track 4352 (eng): Keeping original audio - [00:15:25] Multiplexing M2TS - [00:15:33] Processing: VID_00022 (21 of 28) - [00:15:33] Extracting A/V streams [VID_00022] - [00:15:43] Reencoding video [VID_00022] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 3.266 frames - Bitrate: 21.213 Kbs - [00:15:43] Reencoding: VID_00022, Pass 1 of 2 - [00:16:29] Reencoding: VID_00022, Pass 2 of 2 - [00:19:19] Video Encode complete - [00:19:19] Processing audio tracks - Track 4352 (eng): Keeping original audio - [00:19:19] Multiplexing M2TS - [00:19:27] Processing: VID_00013 (22 of 28) - [00:19:27] Extracting A/V streams [VID_00013] - [00:19:37] Reencoding video [VID_00013] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 3.753 frames - Bitrate: 19.941 Kbs - [00:19:37] Reencoding: VID_00013, Pass 1 of 2 - [00:20:28] Reencoding: VID_00013, Pass 2 of 2 - [00:23:34] Video Encode complete - [00:23:34] Processing audio tracks - Track 4352 (eng): Keeping original audio - [00:23:34] Multiplexing M2TS - [00:23:42] Processing: VID_00025 (23 of 28) - [00:23:42] Extracting A/V streams [VID_00025] - [00:23:55] Reencoding video [VID_00025] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 5.121 frames - Bitrate: 19.896 Kbs - [00:23:55] Reencoding: VID_00025, Pass 1 of 2 - [00:25:03] Reencoding: VID_00025, Pass 2 of 2 - [00:29:17] Video Encode complete - [00:29:17] Processing audio tracks - Track 4352 (eng): Keeping original audio - [00:29:17] Multiplexing M2TS - [00:29:27] Processing: VID_00028 (24 of 28) - [00:29:27] Extracting A/V streams [VID_00028] - [00:29:42] Reencoding video [VID_00028] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 6.364 frames - Bitrate: 20.582 Kbs - [00:29:42] Reencoding: VID_00028, Pass 1 of 2 - [00:31:06] Reencoding: VID_00028, Pass 2 of 2 - [00:36:19] Video Encode complete - [00:36:19] Processing audio tracks - Track 4352 (eng): Keeping original audio - [00:36:19] Multiplexing M2TS - [00:36:31] Processing: VID_00019 (25 of 28) - [00:36:31] Extracting A/V streams [VID_00019] - [00:36:50] Reencoding video [VID_00019] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 10.770 frames - Bitrate: 19.905 Kbs - [00:36:50] Reencoding: VID_00019, Pass 1 of 2 - [00:39:09] Reencoding: VID_00019, Pass 2 of 2 - [00:47:57] Video Encode complete - [00:47:57] Processing audio tracks - Track 4352 (eng): Keeping original audio - [00:47:57] Multiplexing M2TS - [00:48:13] Processing: VID_00034 (26 of 28) - [00:48:13] Extracting A/V streams [VID_00034] - [00:48:38] Reencoding video [VID_00034] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 15.114 frames - Bitrate: 20.233 Kbs - [00:48:38] Reencoding: VID_00034, Pass 1 of 2 - [00:51:58] Reencoding: VID_00034, Pass 2 of 2 - [01:04:21] Video Encode complete - [01:04:21] Processing audio tracks - Track 4352 (eng): Keeping original audio - [01:04:21] Multiplexing M2TS - [01:04:44] Processing: VID_00008 (27 of 28) - [01:04:44] Extracting A/V streams [VID_00008] - [01:05:32] Reencoding video [VID_00008] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 34.491 frames - Bitrate: 20.269 Kbs - [01:05:32] Reencoding: VID_00008, Pass 1 of 2 - [01:12:55] Reencoding: VID_00008, Pass 2 of 2 - [01:40:54] Video Encode complete - [01:40:55] Processing audio tracks - Track 4352 (eng): Keeping original audio - [01:40:55] Multiplexing M2TS - [01:41:39] Processing: VID_00038 (28 of 28) - [01:41:39] Extracting A/V streams [VID_00038] - [01:42:33] Reencoding video [VID_00038] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 40.363 frames - Bitrate: 19.410 Kbs - [01:42:33] Reencoding: VID_00038, Pass 1 of 2 - [01:50:29] Reencoding: VID_00038, Pass 2 of 2 - [02:15:51] Video Encode complete - [02:15:51] Processing audio tracks - Track 4352 (eng): Keeping original audio - [02:15:51] Multiplexing M2TS [02:16:43]PHASE ONE complete [02:16:43]PHASE TWO - Rebuild Started - [02:16:43] Rebuilding BD file Structure [02:17:15] - Encode and Rebuild complete - WORKFILES folder removed. - Computer SHUTDOWN initiated. Last edited by kabster; 27th May 2014 at 20:58. |
#20355 | Link |
@ kabster; RE Decoding/Frame serving: FRIMSource
Alien Vs. Predator isn't a 3D movie, why are you using FRIMSource to encode. Perhaps you would have a better outcome if you just use the regular encoder instead. I thought jdobbs had disabled FRIM except for 3D MVC encodes. hope this helps, worknstiff |
#20357 | Link |
First i want to say, that i have used different settings for decoding. i.e: default, x264 → (fyi, using x264 as frame server helped allot to fix A/V lip sync), and lastly Frimsource .. its no use this time to get arround this latest issue !!
@chevron, as i have wrote earlier, every tool, codec, decoder etc is marked OK during the test .. |
#20358 | Link |
@kabster: that may exactly be the problem. You not supposed to use the latest versions out there! Only the ones specified in the first post. How are we and jdobbs supposed to help you if you refuse to most the required info?
Verstuurd vanaf mijn Nexus 7 met Tapatalk |
| Display Modes | |
