#62 | Link | |
#64 | Link |
Just a quick question so I can experiment, what's the easiest way to grab a portion of the dolby audio track from an HD-DVD.
I use avisynth to grab a certain number of frames with the Trim() command (using VdubMod to view) but how to get the audio from the same frames?? |
#65 | Link |
Hey Now!
you using nero vision to create your avchd disks atak? Does the transcoding degrade the quality much if the source is about the same size (ie m2ts file is 4 gig. and you target a dvd-5)?
#66 | Link | |
#67 | Link |
New beta version of tsMuxer with "Dolby True HD" support available. I have only one small clip with True HD, so I don't sure that this version work stable.
#73 | Link |
x264 Tester
@roman:
please have a look at this stream, it's from german HDTV and won't mux correctly into TS: http://www.megaupload.com/de/?d=O262L4JJ it's more or less the same issue ultratoto had on the previous page: http://forum.doom9.org/showthread.ph...49#post1092649 it's only seekable with 1.1.5 and the streams are not synchronous. |
#74 | Link |
Roman, tsMuxeR doesn't detect some DTS streams. If you convert TrueHD to DTS with EAC3TO, then try to open it with tsMuxeR, it says cant detect file. Here is a DTS sample (DTS, 5.1 channels, 0:01:07, 24 bits, 1536kbit/s, 48khz), I hope it helps fixing it.
300.dts |
#76 | Link | |
Once the file is processed by DelayCut, tsMuxeR will accept it. People say this is caused by surcode v1.0.21 and v1.0.23/v1.0.29 don't have this problem. |
#78 | Link |
First I would like to say thanks for this great tool! It has a great potential! I tried the latest beta version, with the true HD support, but it seems now that detecting others sound tracks in EVO is broken. I tried with the transformers HDDVD and I couldn't see the audio tracks anymore. It worked before with version 1.2 @puppydg68 How do you stream your .ts with tversity? For some reason, since I reinstalled my PC and installed the latest tversity, all my .ts (I'm sure they were working before) reported "Data Corrupted" on my PS3. The only way I found to make something work was to mux them in m2ts and rename them to .mpg bb1b |
#79 | Link |
Guys I must be dreaming!!
I have on my HDD a demux of the Top Gun HD-DVD (which I own but want to sell my xbox HD-DVD drive as I'm broke) (Video.mpv which is AVC 29.976fps h.264 and audio.ac3 which I made from eac3to from the DD+ file) are you telling me I can now mux these two files into something which will work on the PS3? |
#80 | Link |
Super tool!!!
1. Seems that the detection of filetypes under vista (32bit sp1) is a little bit fishy.. I ended up 5 or 6 instances of the program after adding 1 file and nuthing happened... Then i tried again since the screen didnt pause the window that was active.. 2. Is there a slight possebility to make a PS3 profile which would imply various checks for the target-bitstream, like level 4.1, if .ts, and no .ac3 track = failure or a notification and so on.. PS! Anyone know of a more stable upnp server than tiversity ? It crashes all the time on my XP.. best regards TEB |
| Tags |
| tsmuxer |
| Display Modes | |
