11th March 2003, 14:57 | #62 | Link |
Retired
A new CCE SP 2.67.00.09 trial is out and here is EclCCE v1.2 supporting it. I also made an enhancement in that EclCCE can now be used also for earlier CCE versions (2.50, 2.62, 2.64) to add the command line support. See Readme for more information.
Enjoy! |
25th March 2003, 12:54 | #66 | Link |
Retired
New release v1.3 is out. It has a very nice new bitrate tweaking feature, letting you limit the bitrate at the end of the video from a certain point, so for example CCE no longer wastes precious bitrate on end credits. You can now also modify the VBR bias prior to the encode when no VAF file exists yet.
27th March 2003, 16:47 | #67 | Link |
Retired
I've uploaded v1.3a. Fixed a minor issue. Here is the change log:
27/03/2003 v1.3a - Fixed: Bitrate tweaking feature didn't take effect when encoding was started by clicking the "Encode Now" button in Encode Settings dialog. |
28th March 2003, 04:39 | #68 | Link |
jdgljlfljg
In regards to the bitrate tweaking feature, it seems to be good in theory but flawed in practice (through no fault of your own).
Correct me if I'm wrong, but what happens is that the vaf is created with the bitrate allocation information according to the average bitrate you input. Then the bitrate tweaking feature creates an upper limit on the max bitrate value from the time you specify until the end. The bitrate allocation for the non-credits part of the film is unchanged, so you simply end up with a smaller file and lower quality credits. So in order to get a fullsized video stream you need to input an inflated average bitrate to begin with. The formula for adjusted (i.e. inflated) average bitrate would be: =space for video on disc - post-tweak credit size ---------------------------------------------------------------- space for video on disc - pre-tweak credit size X pre-adjusted average bitrate Now there are 3 problems with this: 1.There is an assumption that the additional bitrate will be allocated to the 2 parts of the film (credits and non-credits) in the same proportion as the pre-adjusted bitrate. If it allocated more to the actual film part then the video stream will be oversized. 2. Post-tweak credit size calculation is imperfect. It equals the length of credits (which you know) multiplied by post-adjustment average bitrate for credits (which you don't know but with a low max bitrate of say 2000 kbps you can assume that the credits will be basically CBR 2000 kbps). So no biggie there if max bitrate is low. 3. The pre-tweak credit size is impossible to calculate without running an encode of the whole film. That's a bit of a problem. Maybe I'm this is all wrong, but anyway the point I am trying to make is that unfortunately it's hard to make full use of the bitrate tweak. |
28th March 2003, 09:35 | #69 | Link | |
Retired
Anyway, you can easily verify for your self. Encode a small test clip (like 30 seconds or so) at around 4000 kbps average, go into Advanced VBR settings and adjust the second half of the clip to have a max. bitrate of 1000 kbps. Watch the bitrate graph for the first half go up. |
29th March 2003, 06:00 | #70 | Link |
jdgljlfljg
I actually did run a couple of tests before posting. Basically I just ran the output of a 7 min sample through bitrate viewer to see if the average bitrate of the file matched up to what it should. But it didn't.
I think the problem was the nature of the test I used...in particular marking the credits point too early in the file. Because when I just redid the test with a later credits point, the average bitrate was correct. And having fiddled with the bitrate allocation settings before (just in testing, I've never actually used robshot - no need as I keep the bitrate high) I should have known better. Sometimes it's great to be wrong |
6th April 2003, 10:17 | #72 | Link |
First, thanks again for the tool. It works great as can be seen by the large amount of support it has gained. I wanted to suggest a feature. Would it be possible to set the CCE CPU priority in the eclcce.ini file? Previously I had my shortcut set CCE to 'low' on launch, but now that I use EclCCE I don't know if that is possible. I finally decided to post this after forgetting to manually set the priority for the tenth time.
7th April 2003, 17:20 | #75 | Link |
Ecl File
I am using CCE 2.66.01.07 in conjuction with DVD2SVCD 1.1.3b2, Avisynth 2.08 and EclCCE 1.3a on XP Home. I have set the encoder tab to eclcce.exe and opened the eclcce file once to create the inf file required. But am still recieving this message. Unable to find cce window. Error 126 the specified module could not be found With CCE telling me that it can't Save ecl file. Any Input would be appreciated. |
8th April 2003, 23:48 | #80 | Link |
Never exits
I've tried to use EclCCe with CCE 2.66 and DVD2SVCD, but CCE never exits after it's done encoding. It encodes just fine, but even after I try to close it manually, it doesn't return to DVD2SVCD. Do you have any ideas? Thanks!
