Old 5th October 2022, 17:00   #541  |  Link
kedautinh12
I was tried removed all logo from this video. I think this very good but can you suggest if this can better, VX? (If had other way). Thanks
example: https://drive.google.com/file/d/19xu...ew?usp=sharing
Applied Scripts: https://drive.google.com/file/d/1E4Z...ew?usp=sharing
Scripts:
LWLibavVideoSource("C:\Users\ADMIN\Downloads\Gen Hoshino - Kigeki [1440x1080i MPEG2 M-ON! HD].ts", fpsnum=24000, fpsden=1001)
a0=trim(0,49)
b0=trim(50,5488).InpaintDelogo(mask="C:\mask5.bmp", Automask=0, aMix=0, Loc="50,40,-1186,-910", Mode="Inpaint")
c0=trim(5489,5563)
a0++b0++c0
a1=trim(0,53)
b1=trim(54,119).InpaintDelogo(mask="C:\mask1.bmp", Automask=0, aMix=0, Loc="60,880,-1094,-50", Mode="Inpaint", Analyze=3)
c1=trim(120,5477).InpaintDelogo(mask="C:\mask1.bmp", Automask=0, aMix=0, Loc="60,880,-1094,-50", Mode="Deblend")
d1=trim(5478,5491).InpaintDelogo(mask="C:\mask1.bmp", Automask=0, aMix=0, Loc="60,880,-1094,-50", Mode="Inpaint", Analyze=3)
e1=trim(5492,5563)
a1++b1++c1++d1++e1
a2=trim(0,25)
b2=trim(26,37).InpaintDelogo( mask="C:\mask2.bmp", Automask=0, aMix=0, Loc="1292,908,-60,-50", Mode="Inpaint", Analyze=3)
c2=trim(38,5526).InpaintDelogo( mask="C:\mask2.bmp", Automask=0, aMix=0, Loc="1292,908,-60,-50", Mode="Deblend")
d2=trim(5527,5538).InpaintDelogo( mask="C:\mask2.bmp", Automask=0, aMix=0, Loc="1292,908,-60,-50", Mode="Inpaint", Analyze=3)
e2=trim(5539,5563)
a2++b2++c2++d2++e2
propSet("_FieldBased",0)
deep_resize(1920,1080)
Old 5th October 2022, 20:02   #542  |  Link
Reel.Deel
Video without logo: https://www.youtube.com/watch?v=D_Oyplmhhv0
v1 = DGSource("Gen Hoshino - Kigeki [1440x1080i MPEG2 M-ON! HD].dgi").TFM().Tdecimate().Trim(3,0).Spline36Resize(1920,1080)
v2 = DGSource("Gen Hoshino  Comedy.dgi")
msk = v1.ExtractY().Trim(5460,5460).mt_binarize(24).mt_expand().mt_expand().mt_expand().mt_expand().mt_expand()
mt_merge(v1, v2, msk, luma=true)
Result: https://imgsli.com/MTI4ODcw
The mask can be improved, should be really easy to draw it yourself.
Old 5th October 2022, 21:36   #543  |  Link
Dogway
@kedautinh12: For live video opaque delogo is not very good, I think in this case InpaintDelogo just does a passthrough to AVSInpaint which is spatial only. I tried to improve it with temporal compensation, it does improve a little but needs more work.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 6th October 2022, 04:17   #544  |  Link
kedautinh12
Hi, any suggestions scripts for temporal compensation?? Thanks
Old 6th October 2022, 05:22   #545  |  Link
johnmeyer
Mcompensate, from MVTools2:
http://avisynth.org.ru/mvtools/mvtools2.html#functions
Old 6th October 2022, 13:52   #546  |  Link
kedautinh12
sr for noob answer, why msk use trim(5460,5460) and why use many mt_expand()??
Old 7th October 2022, 06:10   #547  |  Link
Reel.Deel
Trim(5460,5460) because that frame is all black with just the logo and text, perfect for creating a mask. mt_expand() is used to grow the mask outward. The text on the bottom left has a black outline and since frame #5460 is all black there no way to get the outline. Like I said, the mask can be improved but it took me just a few minutes to do that and the result was very good.
Old 7th October 2022, 06:20   #548  |  Link
kedautinh12
Ok, thanks. Got it
Old 8th October 2022, 02:58   #549  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
# Version 3.00 :  Fixed: A frame selection scan result wasn't saved properly when "Automask=1" and "Inpaint" mode,
#                        now the deblending masks generation is up to twice faster in this scenario.
#                 New feature: Easy use of the ebmp masks on other videos, you can input them directly with "Mask" parameter.
#                              Ebmp format is changed, the masks from older versions are not compatible.
#                 New feature: Twice faster subtitles extraction with auto intermediate file.
#                              It's activated by negative "Extract" values.
#                              Requirements: LSMASH, TWriteAVI, x264vfw.
#                              New params: "ReExtract", "FourCC".
#                 New feature: Adjustable subs detection window, useful if video has non-middle subs alignment.
#                              New params: "DetWinPercW", "DetWinPercH", "DetWinHoPos".
#                              With "Show=12" you can see the subs detection window and correlation coefficient [CorrTh/Corr].
#                 New: "Turbo=-1", it activates an inpainting preset more suitable for UHD - HD resolutions.
#                 New: "IntSpd=4", similar as above.
#                 Basemask change: Background should be less than full white, logo - full white.
#                 Swapped "Turbo" 1 & 3.
#                 Removed "rSize" parameter.
#                 Reworked "Show=2", alternative to "Show=1" for positive Analyze.
#                 New feature: Various parameters to manipulate the deblending masks from positive analyze [for the experts only]:
#                              "YAlphaTweak", "UAlphaTweak", "VAlphaTweak",
#                              "YAlphaSolidIns", "UAlphaSolidIns", "VAlphaSolidIns",
#                              "YAlphaSolidOuts", "UAlphaSolidOuts", "VAlphaSolidOuts",
#                              "YColorSolid", "UColorSolid", "VColorSolid",
#                              "YColorSolidOuts", "UColorSolidOuts", "VColorSolidOuts",
#                              "YColorSolidIns", "UColorSolidIns", "VColorSolidIns",
#                              "YOffsetIns", "YOffsetOuts", "UVOffsetIns", "UVOffsetOuts", "ShiftMasksVe", "ShiftMasksHo",
#                              "YAlphaExternal", "WholeDeblend", "TriggerDynamic", "DumpMasks".
#                 Various other tweaks.
#                 Avisynth+ v3.7.2 or later is required.
Have fun.
I would be interested in your compensation script if it improves anything.
VoodooFX is offline   Reply With Quote
Old 8th October 2022, 04:27   #550  |  Link
kedautinh12
Lol, many new parameters to remember
Old 8th October 2022, 12:44   #551  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Originally Posted by Zetti View Post
Thank you very much.
I will test the temp script and im happy to see that i came with something you can use to get the script better for everyone.
Now you can adjust detection position with DetWinHoPos and use Show=12 for preview.
InpaintDelogo(Loc="60,566,-120,-30", Show=12, DynLocUp=2, DynMask=4, DynTune=170, DynMask4H=150, KillBlobs=-7, KillNoise=5, DetWinHoPos=0.8)
Comparison of Extract=1 vs Extract=-1 vs ReExtract=1 [read help about how to setup negative Extract]:
InpaintDelogo(Loc="60,566,-120,-30", Show=4, DynLocUp=2, DynMask=4, DynTune=170, DynMask4H=150, KillBlobs=-7, KillNoise=5,
\  Extract=1, ImgDir="D:\Subs", ImgInflate=1, CorrTh=0.7, DetWinHoPos=0.8)
\  Extract=-1, ImgDir="D:\Subs", ImgInflate=1, CorrTh=0.7, DetWinHoPos=0.8)
\  Extract=-1, ReExtract=1, ImgDir="D:\Subs", ImgInflate=1, CorrTh=0.7, DetWinHoPos=0.8)
Test.mkv file: https://drive.google.com/file/d/1Wi-...ew?usp=sharing
Old 8th October 2022, 12:59   #552  |  Link
Zetti
Thank you i will look into it.
Zetti is offline   Reply With Quote
Old 8th October 2022, 14:08   #553  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
There at the manual's bottom is filter() with all parameters and defaults, I copy/paste from there sometimes.
Anyway, "for the experts only", so you don't need to know them.
Btw, I think that v3 crossed some threshold, because avs v3.7.1 just ignores InpaintDelogo filter like it's commented out.
Originally Posted by katzenjoghurt View Post
Still looking forward to it.
(Not so much on trying to figure out what they do exactly... but some means to tweak deblending... mhh... looks super-delicous.)
Here is a good sample to practice on hard to delogo video -> https://www.youtube.com/watch?v=hSXo5EMY-vA
There is a good quality 2K VP9 stream [not 1080p!], not all download tools can see that 2K stream [use 4KVideoDownloader].
Logo:
Delogo:
Old 8th October 2022, 14:16   #554  |  Link
kedautinh12
Btw, can new parameters fix my problem??
https://forum.doom9.org/showthread.p...72#post1975972
Old 8th October 2022, 15:54   #555  |  Link
kedautinh12
I meet new problem with circle logo
can anyone had suggest when use with InpaintDelogo??
https://imgur.com/gallery/9G8g3Bv
Source: https://drive.google.com/file/d/1tes...ew?usp=sharing
Scripts:
ex_bob(nnedi3=true).SelectEven()
trim(38,6996)
InpaintDelogo(mask="C:\mask2.bmp", Automask=1, aMix=-10, Loc="84,44,-1260,-910", Mode="Inpaint")
Old 8th October 2022, 16:20   #556  |  Link
kedautinh12
same error with left-bottom
https://imgur.com/gallery/HrQ3Vvg
Script:
trim(224,6871)
InpaintDelogo(mask="C:\mask1.bmp", Automask=1, aMix=-50, Loc="78,916,-1180,-48", Mode="Inpaint")
Old 8th October 2022, 18:20   #557  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
What error? I see expected result of what you are doing.
Logo has shadow, so you are inpainting that shadow over letters.
Old 8th October 2022, 19:06   #558  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Split logo at the left and delogo separately.
To delogo at the right you can use ebmp from another video: https://drive.google.com/drive/folde...Vl?usp=sharing
Old 9th October 2022, 01:26   #559  |  Link
kedautinh12
But how i can erase that remain of black color??
Old 9th October 2022, 01:28   #560  |  Link
kedautinh12
And can you have other ways to delogo with circle logo??
delogo, hardsubs, ocr, remove, watermark
