18th October 2016, 08:49 | #4001 | Link |
Soul Seeker
18th October 2016, 12:40 | #4002 | Link |
&Siso
Thanks. Fixed in r2073. PS: I think the problem is incorrect work of swr_set_matrix() if the SwrContext was never initialized. I created the ticket #5897.
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource Last edited by v0lt; 18th October 2016 at 13:03. |
18th October 2016, 14:58 | #4003 | Link | |
Soul Seeker
18th October 2016, 17:57 | #4004 | Link |
Tried the latest stable and nightly (MPC-BE.1.5.0.2065.x64) builds too with or without madVR, but x265/HEVC DXVA doesn't want to work with the internal video decoders, i get funny green and only green image/video on my RX480.
Software decoder is working fine, LAV Video Decoder's DXVA also working fine with HEVC. Using the lastest 16.10.1 WHQL driver on Win10. |
18th October 2016, 23:29 | #4005 | Link |
Developers don't have RX4xx video adapters and can't test.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
20th October 2016, 14:23 | #4007 | Link |
120 .
21st October 2016, 15:34 | #4008 | Link |
updated german translation based on r2089:
https://drive.google.com/file/d/0B4y...ew?usp=sharing |
21st October 2016, 18:49 | #4009 | Link |
Can I have a request for you? I hope I won't offend any of the devs here by asking this :
can you make the key IDs (under Player -> Keys) identical to what MPC-HC has for the following keys (if you don't use the current one anywhere): - "Subtitle Delay -" from 1010 to 24000 - "Subtitle Delay +" from 1011 to 24001 - "After Playback settings" (some IDs are there but for the wrong command) The reason behind this, as I mentioned here, I use a remote app for Android (that I had painfully modded for MPC-HC around a year ago). The rest of the features of that app is working fine with MPC-BE as well. (If you don't know it, give it a try!) Thanks for considering this!
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
22nd October 2016, 08:13 | #4010 | Link |
@chros
Try this build - https://yadi.sk/d/K9hk8yr0xMZUC
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
22nd October 2016, 10:19 | #4011 | Link | |
Only 2 After playback entries aren't good: - "Do nothing" : from 918 to 948 - "Play next file in the folder" : from 1078 to 947 Cheers
22nd October 2016, 11:30 | #4012 | Link |
@chros
Please try a second build. Link is the same.
22nd October 2016, 13:13 | #4013 | Link |
Thank You, guys! Now it's perfect.
There's 1 more thing, but feel free to say no to this (since I don't use this feature, for now): there's an another option in MPC-HC called "After Playback: Turn off the monitor" that has the ID of 918. Thanks for your amazing support!
22nd October 2016, 14:03 | #4014 | Link |
Done in r2093.
I doubt about the "After Playback: Turn off the monitor". I find it hard to understand why it is needed. Random movement of the mouse and the monitor works again.
25th October 2016, 10:24 | #4015 | Link | |
Thanks! It's working fine with b2100.
But as I mentioned above, it's not an important feature for me, it's just about for the sake of completeness.
25th October 2016, 11:40 | #4017 | Link | |
Soul Seeker
28th October 2016, 05:41 | #4019 | Link |
cosmic entity
hy there,
i just upgraded from version: 1.4.2, and now one of my external filters isnt working anymore..i tried every possible configuration now and it doesnt work.. Going back to 1.4.2 and its working again.. Using this Filter: clauts.ax (Cyberlink Time-Stretch Filter) this is how it looks like with V 1.4.2: the thing is, if i set it up the exact same way with the newer versions and play the video it DOESNT show up under FILTER and i cant select it.. i have no clue why that is.. greetz |
28th October 2016, 06:45 | #4020 | Link |
"BetA13
Please tell CLSID of Cyberlink Time-Stretch Filter (see PinInfo).
