8th February 2010, 20:05 | #4281 | Link | |
8th February 2010, 20:28 | #4282 | Link |
Programmer (or just 教务长)
Yep... it is what makes multiAVCHD a lovely application... There are a lot of such things hidden in multiAVCHD when using the labels 'default' or 'auto'
*** Sadly there are not so many test-reports of 730RC build, but in one of the next days I'll publish it as official. I'll try to add a 'resume' function for the PLAY button but either way I'll upload it as new major version (probably not 3.1). Dean |
8th February 2010, 20:31 | #4283 | Link | |
When you speak about AVCHD, you should speak about the MultiAVCHD format -we all know that the "real" AVCHD is very restrictive ; no subtitles, no Dts, ...-, because this can cause misunderstandings in our discussion. I know of course that the "real" AVCHD format supports neither HD audio nor even simple Dts audio, but as I don't have any problem with Dts, I believed that HD formats would be read without problem. My Panasonic player is probably the cause of the problem. Last edited by Music Fan; 8th February 2010 at 20:33. |
8th February 2010, 20:38 | #4284 | Link |
When I say "AVCHD" I refer to "AVCHD standard". What multiAVCHD produces may sometimes be not compliant to the standard (when using subtitles or DTS or HD audio), but it is up to the user - it is that I made multiAVCHD relaxed. I can always make it strict and I'll avoid bug reports which are not really bugs.
8th February 2010, 20:51 | #4285 | Link | |
Am I the first to report problem with True HD exported in AVCHD mode ? Just to know if I'm unlucky. Last edited by Music Fan; 8th February 2010 at 20:54. |
8th February 2010, 22:28 | #4286 | Link | |
Audio and subtitles track selection work fine. N.B : With standalone players (like SONY or PIONEER tested in this case) nagivation into differents menu pages are not so quickly like a PS3. Is not a but to Multiavchd. For sample, The delay time to acces at setup menu page is 2sec after button validation on SONY player BDP-s350 For this test, I've made a project with one title and without "title menu" creation. But during playback menu the "tittle list" according button is always displayed (only the button), but acces return to title menu ? |
8th February 2010, 22:36 | #4287 | Link |
There is the same 2 seconds delay in NERO... I'll see if I can fix it (TMT and PS3 act differently... In fact ALL players - software/hardware do weird things and it makes my work a nightmare)
About your question about 'title menu' - I can't understand you. User has four options: * MAIN/TOP menu * No MAIN/TOP menu * MAIN/TOP menu + TITLE LIST menu * No MAIN/TOP menu and NO TITLE LIST menu If you don't create MAIN/TOP menu but you have [x] Add title-list menu option enabled, then you'll get the TITLE-LIST menu acting as a MAIN/TOP menu. What are you trying to accomplish? *** I re-read your post... I'll check about the "TITLE LIST" label... I did it for "SETUP" and "CHAPTERS" but I think there is no check about the "TITLE LIST" label when no "TITLE LIST" menu is created. Last edited by deank; 8th February 2010 at 22:39. |
8th February 2010, 22:46 | #4288 | Link | |
For more precision : With only 3 labels created "play" / "setup" / "chapter" navigation left/right into "play" and "setup" works fine but if you go to right between "setup" you selected blank button (correpsonding to title list i think) without label; same result if go to up between "setup". other button work fine. I hope that is more clearly than my previous post |
8th February 2010, 22:52 | #4290 | Link | |
What is it that you can't see in the menu preview, which causes you to re-do the compilations? |
8th February 2010, 23:21 | #4291 | Link | |
Edit: Just had an example of this. Made a TV compilation and forgot that the TV episodes had logos in the corner. This ended up over my text on the menu. A quick preview would have shown me this. Last edited by rendez2k; 8th February 2010 at 23:41. |
8th February 2010, 23:46 | #4292 | Link |
I know that a full-featured menu preview would be a nice touch but it will double (if not triple/4ple) the things I need to follow in multiAVCHD. Even at the current stage, menu preview and menu generation are two completely different procedures. 1st depends directly on the input media (files) and 2nd depends on the final mux/compilation.
There is no (easy) way to program what you ask for. It is a setback, but it will cost efforts which can be directed in other directions/features. Dean |
8th February 2010, 23:48 | #4293 | Link | |
8th February 2010, 23:53 | #4294 | Link |
All coordinates are applied to the preview. Probably you didn't enable [x] Apply button position settings option in MENU/Misc. Please take time to examine all the options I gave you.
The coordinate values are default for XMB menu and are not applied unless you tick the box I mentioned. The LABELS and the [x] hide options are applied when you change them, but not the coordinates (it is designed to work that way in case the user plays with the settings without paying attention what he is doing). Last edited by deank; 8th February 2010 at 23:58. |
9th February 2010, 00:36 | #4296 | Link |
Few requests when you'll work for one title authoring :
- A option to make totaly transparent the square background for the audio and chapter menu page. With this option, we can use a custom (static image) background. - A main menu with only PLAY SETUP and CHATPER button access with horizontal or vertical navigation (like as discusssion in previous post) That all, but only when you can have time for work on it - a option for use custom backoground (static or video with audio) for audio menu and chapter menu |
9th February 2010, 00:45 | #4297 | Link |
How would you know what you select with fully transparent selection box?
*** As I said, the [more] button in TITLE PROPERTIES will let you do whatever you want with all the pages (main/subtitle/chapters). I was hoping for more feedback to proceed further, but as I said I'll do it anyway. Dean *** p.s. I'm always amazed by the menu pages you create and they inspire me to add features in multiAVCHD, so if you can - please illustrate what you expect as a final result. It helps me a lot. I'm a good programmer and a bad designer as most of you already noticed. |
9th February 2010, 02:43 | #4298 | Link | |
You are great programmer and don't have a good aid with my english You're right, it's more easy with illustration. Tomorow, I'll create sample menus for illustrate Thank for your comprehension. |
9th February 2010, 12:32 | #4299 | Link |
Hello,
See sample for explain a custom presentation for audio and chapter menu pages (without the square background) For audio menu, can you provide same option as chapter menu page for "coordinate values" ? And additional question about the graphic type of button : With this new version, you've change the original button "arrow" by square and if I remember ours previuos posts, you said that you don't any solution for muxing (or create) IGS in m2ts to customize the button (like a frame arround chapter picture for example). It is right ? How can you create the actually button ? You use a ready m2ts create by other software (like NERO vision) ? in this case, if I'll provide you m2ts with other graphic buttons (like as frame for chapter) all ready muxed, that can help you ? If I right about this point, tell me characteritics you need. |
9th February 2010, 12:37 | #4300 | Link |
You have the option for X/Y of the audio/subtitle setup in MENU/General (default 640, 530).
The "RESUME" function of the PLAY button is ready. It is activated if user quits the movie from the POP-UP menu with "TITLE MENU" button. Then one can change the options in SETUP and resume the playback from the last chapter played. |
