Old 18th February 2022, 02:31   #21  |  Link
real.finder
Originally Posted by Ceppo View Post
AvspMod does it wrong, for some reason it calls 3 times the first frame. I use x264 preset very fast. You can still use AvspMod if you edit the file, just delete the duplicates at the beginning since it says 3 times frame 0. You might also want to look at the last frame in the txt file.
Thanks for the sample.
yes with x264 it only one "0 0"
but "cycle at frame ..." errors still there!
See My Avisynth Stuff
Old 18th February 2022, 17:36   #22  |  Link
Ceppo
I updated the ReadMe and fixed the CDecimate2 bug in the v1.0.3 you can find above. Now it should work correctly.
The point of CDecimate is to get the correct decimate. There is no metric to do it right. The only way is to get a 00000, 11000, 01100, 00110, 00011, 10001 pattern every 5 frames. If in the txt file is not so, it will give you an error. I'm working on a way to reduce and minimalize the amount of required editing in the txt file. If you have a live action you often get the right pattern since everything is moving (so you have to edit only the critical parts). On anime, due the duplicates, this doesn't happen so there is a lot of editing to do.
Ceppo is offline   Reply With Quote
Old 19th February 2022, 19:39   #23  |  Link
real.finder
so if someone work with anime he/she will need so much time edit the file!
isn't better to add an option to just ignore these cases for peoples that dont have time and patient to edit thousands of lines?
also gispos said this about avspmod problem
In my opinion, the error is due to a non-existent option of the plugins. "After initializing, don't write the same frame multiple times"
It would be easy to integrate this option into the plugins!
Programs that display frames or need to initialize other variables when creating the clip must call get_frame multiple times at the beginning.
For example, if the matrix is read, get_frame must be called first. And with each call the plugin writes the frame number.
and I agree with him, since tivtc and others don't have this problem
Old 19th February 2022, 22:01   #24  |  Link
Ceppo
I understand your concern and you are right. I'm working on it to reduce to the minimum the editing by increasing accuracy. I will also make the option to ignore the error and try some heuristic way to handle those cases.
Thanks a lot for the feedback, I will follow the advice!
EDIT
Also, now I'm working on a new field matching mode, and I'm getting good results.
EDIT 2
I need only to implement the write only thing and write the ReadMe file for the new functions.
Here a preview: 60i VFR
WIth this Script:
CTelecineNew(bob=true,inputTxt=true)
CPostProcessing(isbob=true)
CDecimateNew(isBob=true,error=false)
The release will be in the day.
Old 20th February 2022, 17:21   #25  |  Link
Ceppo
Updated to v1.0.4, feedback is much appreciated.
EDIT
fix'd
Old 20th February 2022, 19:28   #26  |  Link
real.finder
thanks
with this
#~ CTelecineNew(bob=true,write=true) #1st pass
CPostProcessing(isbob=true,edeint2=qtgmc)
I got this
Old 21st February 2022, 16:40   #27  |  Link
Ceppo
Sorry, I was in a hurry and I didn't update CTools.avsi.
https://www.mediafire.com/file/tqrbk...%2529.zip/file
Old 21st February 2022, 16:58   #28  |  Link
real.finder
it work now but with https://xfl.jp/E5n90r I got same frame in all clip with this
Old 21st February 2022, 17:18   #29  |  Link
Ceppo
Test
CPostProcessing(isbob=true)#QTGMC() is the default
Aside missing the fade. It looks everything all right to me.
I can't recreate the problem
EDIT:
Maybe your CTelecine file is empty??? After the pass you have to close AVSPmod since I didn't yet included a close() function.
Old 21st February 2022, 17:54   #30  |  Link
real.finder
Test
EDIT:
it's not empty, do I need 3 passes in this case?
Old 21st February 2022, 17:58   #31  |  Link
Ceppo
No. There must some kind of other bug.
You are using 64bit or 32bit version? Just to track the problem.
Old 21st February 2022, 17:59   #32  |  Link
real.finder
64bit
Old 21st February 2022, 18:05   #33  |  Link
Ceppo
Do you have some people online to make them try on that source? I need to understand if it's a stack related problem.
Old 21st February 2022, 18:12   #34  |  Link
real.finder
I didn't get what you mean but I note in every experience some frames show randomly, like in avspmod if I hit f5 in some frame it will change to another
removing CDecimateNew(isBob=true,error=false) line will fix it but this not what we want
Old 21st February 2022, 18:23   #35  |  Link
Ceppo
Ok, just curios remove inputTxt=true from CTelecine and try again. Also if you could please tell me how much RAM you have.
Old 21st February 2022, 18:32   #36  |  Link
real.finder
it's same
it's rdp server with 64 gb ram
32bit seems ok
Old 21st February 2022, 18:41   #37  |  Link
Ceppo
So it's a 64bit issue. I will make some changes to reduce the stack, since is the only lead I have at the moment. Hope to release it for tomorrow.
Old 21st February 2022, 23:27   #38  |  Link
Ceppo
Updated. It was a 30min modification.
v1.0.5
- Reduced stack in CTelecineNew and CDecimateNew
- Now CTelecineNew closes automatically the txt file on last frame.
- Speed improvement.
Hope it works now.
Old 22nd February 2022, 00:43   #39  |  Link
real.finder
thanks, seems work fine, but there are something
"# timestamp format v1" should be "# timecode format v1"
and with
D2VSource("Hybrid_30p_+_24i_+60i_+_ifade.d2v")
i=last
bob=stgmc(useEdiExt=2,EdiExt=sanimebob(useBWDIF=true, FastNnediHBD=true),Sharpness=0,tr2=2,ESearchP=true, Refinemotion=true, fastma=true)
#~ CTelecineNew(bob=true,write=true,thr60i=0.1)
CTelecineNew(bob=true,thr60i=0.1)
CPostProcessing(0.1,0.9,isbob=true,edeint=i.CPostProcessingMask(bob=bob,nt=4),edeint2=bob)
it still got some random frames replaced with last frame even in 32bit!
Old 22nd February 2022, 02:28   #40  |  Link
Ceppo
thr60i in CTelecineNew and thr2 in CPostProcessing must have the same value. Try this way.
If still does that, tomorrow I will look into it (same clip I guess). Also, you are supposed to bob after CTelecineNew.
Last version of mkvtoolnix doesn't accept that.
