16th March 2021, 16:50 | #121 | Link | |||
Posts: n/a
20th March 2021, 23:47 | #123 | Link |
Posts: n/a
Cool. I don't need fft3d, so no worries there.
Hey, there's some good stuff in this repo, which I didn't know about until recently. It's nice not to have to build some plugins from source, and closer to the way that we're meant to do things on Linux. Thanks! EDIT: The instructions here for building ffmpeg worked fine on Debian. I installed avisynthplus-yuuki-dev in addition to avisynthplus-yuuki. Last edited by Richard1485; 21st March 2021 at 20:23. |
26th May 2021, 00:55 | #124 | Link |
Plushie
You can specify an architecture for a specific repository in your sources.list file - in this case, by using
deb [arch=amd64] http://yuuki-deb.x86.men buster main
Still watching stuff on a 16:9 720p60 TV |
26th May 2021, 01:31 | #125 | Link | |
¹requires mounting /proc, which OpenBSD (and possibly others) don't have. Anything that uses libavformat, so long as it's FFmpeg 4.3 or higher and was configured with --enable-avisynth. If the ffmpeg supplied by the distro doesn't use that configuration flag, you'll have to build it yourself or use a third-party repo. |
7th September 2023, 18:05 | #126 | Link |
cannot get .avs test script to run
I've run into a wall with getting AviSynth+ running on my Fedora 38 box. I believe I compiled AviSynth+ & and ffmpeg properly, but get the error below when trying to run the test.avs script. Could this be a codec issue? Not sure where to go...any point in the right direction would go most appreciated!
test.avs: Code:
$ cat test.avs Version() Code:
$ ./ffplay test.avs ffplay version N-111974-gfd9bafc85e Copyright (c) 2003-2023 the FFmpeg developers built with gcc 13 (GCC) configuration: --prefix=/home/junkyardcat/ffmpeg_build --enable-gpl --enable-version3 --disable-doc --disable-debug --enable-pic --enable-avisynth libavutil 58. 19.100 / 58. 19.100 libavcodec 60. 26.100 / 60. 26.100 libavformat 60. 11.100 / 60. 11.100 libavdevice 60. 2.101 / 60. 2.101 libavfilter 9. 11.100 / 9. 11.100 libswscale 7. 3.100 / 7. 3.100 libswresample 4. 11.100 / 4. 11.100 libpostproc 57. 2.100 / 57. 2.100 test.avs: Unknown error occurred 0KB vq= 0KB sq= 0B f=0/0 warning: queue 0x3cfab10 destroyed while proxies still attached: wl_callback@40 still attached wl_surface@38 still attached Code:
$ /home/junkyardcat/ffmpeg_build/bin/ffmpeg -formats | grep avisynth ffmpeg version N-111974-gfd9bafc85e Copyright (c) 2000-2023 the FFmpeg developers built with gcc 13 (GCC) configuration: --prefix=/home/junkyardcat/ffmpeg_build --enable-gpl --enable-version3 --disable-doc --disable-debug --enable-pic --enable-avisynth libavutil 58. 19.100 / 58. 19.100 libavcodec 60. 26.100 / 60. 26.100 libavformat 60. 11.100 / 60. 11.100 libavdevice 60. 2.101 / 60. 2.101 libavfilter 9. 11.100 / 9. 11.100 libswscale 7. 3.100 / 7. 3.100 libswresample 4. 11.100 / 4. 11.100 libpostproc 57. 2.100 / 57. 2.100 D avisynth AviSynth script |
15th September 2023, 03:13 | #127 | Link |
I really do need to revamp the POSIX page in the docs. But I went ahead and spun up a fresh Fedora 38 VM to confirm my suspicions, and I'm pretty much 100% certain that your issue is with LD_LIBRARY_PATH (that is, unless you did something weird, like try to build AviSynth+ as a static library).
Fedora installs user-compiled things to /usr/local by default (like most distros do), and shared libraries in that situation go into /usr/local/lib64. /usr/local/bin is on the PATH, but /usr/local/lib64 is not on LD_LIBRARY_PATH. /usr/lib64 is on LD_LIBRARY_PATH, so if you install directly into /usr it'll work. Since there aren't any Fedora-specific instructions in that guide in the docs, here's what you'd ideally be looking at: Dependencies: Code:
sudo dnf install git ninja-build DevIL g++ DevIL-devel cmake Code:
git clone https://github.com/AviSynth/AviSynthPlus.git cd AviSynthPlus mkdir avisynth-build cd avisynth-build cmake ../ -G Ninja -DCMAKE_INSTALL_PREFIX=/usr ninja sudo ninja install avs2yuv: Code:
git clone https://github.com/DJATOM/avs2yuv.git cd avs2yuv mkdir build cd build cmake ../ -G Ninja -DCMAKE_INSTALL_PREFIX=$HOME/.local ninja ninja install Code:
echo 'Version(pixel_type="YUV420P8")'>test.avs Code:
avs2yuv test.avs -o - | ffplay - Code:
sudo dnf install nasm git clone git://source.ffmpeg.org/ffmpeg.git cd ffmpeg mkdir ffmpeg-build cd ffmpeg-build ../configure --prefix=$HOME/.local --progs-suffix=-avs --enable-gpl --enable-version3 --disable-debug --disable-doc --enable-pic --enable-avisynth <other configuration options if you want> make -j$(nproc) make install Example of the above FFmpeg-avs trying and failing to find AviSynth+ in /usr/local/lib64 (under LXDE): Code:
[qyot27@fedora ~]$ ffmpeg-avs -i test.avs ffmpeg version N-112081-gc1b6235d41 Copyright (c) 2000-2023 the FFmpeg developers built with gcc 13 (GCC) configuration: --prefix=/home/qyot27/.local --progs-suffix=-avs --enable-gpl --enable-version3 --disable-debug --disable-doc --enable-pic --enable-avisynth libavutil 58. 24.100 / 58. 24.100 libavcodec 60. 26.100 / 60. 26.100 libavformat 60. 12.101 / 60. 12.101 libavdevice 60. 2.101 / 60. 2.101 libavfilter 9. 11.100 / 9. 11.100 libswscale 7. 3.100 / 7. 3.100 libswresample 4. 11.100 / 4. 11.100 libpostproc 57. 2.100 / 57. 2.100 [in#0 @ 0x30363c0] Error opening input: Unknown error occurred Error opening input file test.avs. Error opening input files: Unknown error occurred [qyot27@fedora ~]$ Code:
[qyot27@fedora ~]$ LD_LIBRARY_PATH=/usr/local/lib64 ffmpeg-avs -i test.avs ffmpeg version N-112081-gc1b6235d41 Copyright (c) 2000-2023 the FFmpeg developers built with gcc 13 (GCC) configuration: --prefix=/home/qyot27/.local --progs-suffix=-avs --enable-gpl --enable-version3 --disable-debug --disable-doc --enable-pic --enable-avisynth libavutil 58. 24.100 / 58. 24.100 libavcodec 60. 26.100 / 60. 26.100 libavformat 60. 12.101 / 60. 12.101 libavdevice 60. 2.101 / 60. 2.101 libavfilter 9. 11.100 / 9. 11.100 libswscale 7. 3.100 / 7. 3.100 libswresample 4. 11.100 / 4. 11.100 libpostproc 57. 2.100 / 57. 2.100 Input #0, avisynth, from 'test.avs': Duration: 00:00:10.00, start: 0.000000, bitrate: 0 kb/s Stream #0:0: Video: rawvideo (I420 / 0x30323449), yuv420p(tv, smpte170m/unknown/unknown), 480x106, 24 fps, 24 tbr, 24 tbn At least one output file must be specified [qyot27@fedora ~]$ What this means is that you have several different options: A) Install AviSynth+ to /usr, so that the library and its symlinks get put in /usr/lib64. This is the most straightforward to make sure that avs2yuv, ffmpeg, etc. can always see it. B) Use LD_LIBRARY_PATH= to add /usr/local/lib64 (or ~/.local/lib64, if you also install AviSynth+ to $HOME/.local) to the search path when you run avs2yuv or ffmpeg-avs. Alias them in .bashrc if you don't want to keep remembering to override LD_LIBRARY_PATH. C) Unconditionally add /usr/local/lib64 (and/or ~/.local/lib64) to LD_LIBRARY_PATH in .bashrc. May or may not be a good idea.
AviSynth+ native Linux/macOS/BSD support | AviSynth+ utilities and plugins for non-Windows and non-x86(-64) Last edited by qyot27; 16th September 2023 at 23:40. |
16th September 2023, 22:57 | #128 | Link | |||
Thank you so much for the response. This is super helpful. I have a poor understanding of how libraries are shared with local vs system installs, but your explanation helps explain some of that.
I compiled and built everything to your instructions with the exception of the below, had to change --enable-version to --enable-version3. Quote:
[junkyardcat@fedora ~]$ ffmpeg-avs -i test.avs ffmpeg version N-112103-gb5c07a368b Copyright (c) 2000-2023 the FFmpeg developers built with gcc 13 (GCC) configuration: --prefix=/home/junkyardcat/.local --progs-suffix=-avs --enable-gpl --enable-version3 --disable-debug --disable-doc --enable-pic --enable-avisynth libavutil 58. 24.100 / 58. 24.100 libavcodec 60. 26.100 / 60. 26.100 libavformat 60. 12.101 / 60. 12.101 libavdevice 60. 2.101 / 60. 2.101 libavfilter 9. 11.100 / 9. 11.100 libswscale 7. 3.100 / 7. 3.100 libswresample 4. 11.100 / 4. 11.100 libpostproc 57. 2.100 / 57. 2.100 Input #0, avisynth, from 'test.avs': Duration: 00:00:10.00, start: 0.000000, bitrate: 0 kb/s Stream #0:0: Video: rawvideo (I420 / 0x30323449), yuv420p(tv, smpte170m/unknown/unknown), 480x106, 24 fps, 24 tbr, 24 tbn At least one output file must be specified [junkyardcat@fedora ~]$ LD_LIBRARY_PATH=/usr/local/lib64 ffmpeg-avs -i test.avs ffmpeg version N-112103-gb5c07a368b Copyright (c) 2000-2023 the FFmpeg developers built with gcc 13 (GCC) configuration: --prefix=/home/junkyardcat/.local --progs-suffix=-avs --enable-gpl --enable-version3 --disable-debug --disable-doc --enable-pic --enable-avisynth libavutil 58. 24.100 / 58. 24.100 libavcodec 60. 26.100 / 60. 26.100 libavformat 60. 12.101 / 60. 12.101 libavdevice 60. 2.101 / 60. 2.101 libavfilter 9. 11.100 / 9. 11.100 libswscale 7. 3.100 / 7. 3.100 libswresample 4. 11.100 / 4. 11.100 libpostproc 57. 2.100 / 57. 2.100 Input #0, avisynth, from 'test.avs': Duration: 00:00:10.00, start: 0.000000, bitrate: 0 kb/s Stream #0:0: Video: rawvideo (I420 / 0x30323449), yuv420p(tv, smpte170m/unknown/unknown), 480x106, 24 fps, 24 tbr, 24 tbn At least one output file must be specified Quote:
16th September 2023, 23:59 | #129 | Link | ||||
But this also means you now have two copies of AviSynth+ installed, so I'd recommend going into /usr/local and deleting the pertinent files there (the three libavisynth.so* files in /usr/local/lib64, the 'avisynth' directory in /usr/local/lib64, and the 'avisynth' directory in /usr/local/include). Quote:
Basically, Option A: Install AviSynth+ to /usr Result: avs2yuv and FFmpeg with --enable-avisynth will *just work*. Option B: Install AviSynth+ to /usr/local (the default behavior) or literally anywhere else on the system Result: you need to use LD_LIBRARY_PATH when invoking avs2yuv or ffmpeg-avs so they can see where libavisynth.so is located. The aliasing would be adding a line to .bashrc so that when you use 'avs2yuv' or 'ffmpeg-avs', the bash profile automatically adds the correct LD_LIBRARY_PATH value to the front of the command. Option C: same as option B, but instead of aliasing anything, you would just add more search paths to LD_LIBRARY_PATH, so that every program looks in those areas, not just avs2yuv or ffmpeg-avs. If you planned to write shell scripts that would be working with encoding from AviSynth scripts, aliased functions don't work; you either have to add LD_LIBRARY_PATH values in the shell script, or rely on the values already having been added by the environment.
AviSynth+ native Linux/macOS/BSD support | AviSynth+ utilities and plugins for non-Windows and non-x86(-64) Last edited by qyot27; 17th September 2023 at 00:02. |
21st September 2023, 19:20 | #130 | Link |
Hello, just compiled AVISynth+ (+ffmpeg, +mpv) on linux, examples with
«Version»/«ColorBars» works OK. But I cannot find working source filter for media files, looks like on Linux we have no internal AVISource. Code:
avisynth: Script error: There is no function named 'AVISource' And how (without AVISource ) we should open "avs" scripts from AVISynth scripts? Last edited by belonesox; 21st September 2023 at 23:04. |
21st September 2023, 23:12 | #131 | Link | |
FFMS2 (both the C++ and C plugin) and LSMASHSource (https://github.com/HomeOfAviSynthPlu.../L-SMASH-Works) are both able to be used with AviSynth+ on Linux. AVISource (and its sister functions OpenDMLSource, AVIFileSource, and WAVSource) and DirectShowSource are both tied to Windows-specific media frameworks, so they'll only work on Windows - or in AVISource's case if you've set up the codecs correctly, Wine.
23rd September 2023, 12:28 | #132 | Link |
Thank you very much!
Unfortunately still cannot get working sample of MPV + AVS + FFMS2. Here test files to reproduce («Download all files» button on right top corner). ./mpv-avisynth-colorbars-ok.sh — Show MPV with AVS ColorBars, OK. ./mpv-avisynth-ffms-not-ok.sh — MPV did not showing without any errors in log ''' … [ 0.136][d][demux] Trying demuxer: lavf (force-level: unsafe) [ 0.145][d][file] resize stream to 131072 bytes, drop 0 bytes [ 0.145][v][lavf] Found 'avisynth' at score=50 size=181. [ 0.158][d][osc] osc_init [ 0.158][d][cplayer] Run command: change-list, flags=64, args=[name="shared-script-properties", operation="append", value="osc-margins=0.000000,0.000000,0.000000,0.000000"] [ 0.158][v][cplayer] Set property: shared-script-properties -> 1 [ 10.831][d][cplayer] Run command: quit, flags=73, args=[code="4"] ''' Does anyone have an idea what is wrong? Last edited by belonesox; 23rd September 2023 at 12:43. |
23rd September 2023, 23:01 | #133 | Link |
FFMS2 doesn't install to any of the autoload directories* by default. You need to either symlink or copy it there, or use LoadPlugin (or AddAutoloadDir, but I wouldn't do that for locations like /usr/local/lib) in the script. I have seen some plugins hook their buildsystems' install function to put the plugin in the system autoload directory, but it's not universal, and in some cases, there is no buildsystem install function, requiring the user to just copy/move the plugin to the right directory.
*On *nix, there are three locations searched for plugins to autoload: $(prefix)/$(libdir)/avisynth, $HOME/.avisynth, and $HOME/.local/lib/avisynth (which can also be overridden when configuring the core). The latter two aren't created automatically, so if you'd rather use one of those, you'll have to create them. $(prefix)/$(libdir)/avisynth is created by the normal install process to hold the core plugins (TimeStretch, Shibatch, ImageSeq, and ConvertStacked). |
24th September 2023, 09:00 | #134 | Link | |
LoadPlugin("libffms2.so") FFVideoSource("test.avi") Last edited by belonesox; 24th September 2023 at 09:05. |
24th September 2023, 23:41 | #136 | Link |
commit ef243ab40b8d4b6d18874c6cef0da1a2f55a6a45 Code:
CPPFLAGS=-I/usr/local/include/avisynth LDFLAGS=-L/usr/local/lib ./configure --enable-avisynth CPPFLAGS=-I/usr/local/include/avisynth LDFLAGS=-L/usr/local/lib make Last edited by belonesox; 24th September 2023 at 23:44. |
25th September 2023, 00:05 | #137 | Link |
The FFmpeg you built - did you build it as shared or as static? And if there are two installs of FFmpeg on the system (one in /usr, and your locally-built one in /usr/local), which one is FFMS2 actually linking against?
25th September 2023, 01:05 | #138 | Link | |
ffmpeg-libs-5.1.3-3.fc37.x86_64 ffmpeg-5.1.3-3.fc37.x86_64 ffmpeg-devel-5.1.3-3.fc37.x86_64 Code:
rpm -ql ffmpeg-devel … /usr/lib64/libavcodec.so /usr/lib64/libavdevice.so /usr/lib64/libavfilter.so /usr/lib64/libavformat.so /usr/lib64/libavutil.so /usr/lib64/libpostproc.so /usr/lib64/libswresample.so /usr/lib64/libswscale.so … Yes, I also build local version of ffmpeg Code:
commit 9b454fdaef413edfc8e0473569462271a64c59fb ./configure --prefix=$HOME/ffmpeg_build --enable-gpl --enable-version3 --disable-doc --disable-debug --enable-pic --enable-avisynth --enable-ffplay |
25th September 2023, 20:06 | #139 | Link |
So it's *just* your built mpv that has the problem? Did you install all of its dependencies before trying to build it?
sudo dnf builddep mpv |
26th September 2023, 16:30 | #140 | Link | |
May be.
But «my MPV» works OK with «mpv-avisynth-colorbars-ok.sh» and somehow failed with «mpv-avisynth-ffms-not-ok.sh». Looks like my mpv understand AVISynth, but definitely not calling «FFVideoSource» (because .ffindex not generated). But I have not idea how to effectively troubleshoot it without errors in MPV log. Quote:
use-libplacebo-custom v4.208.0 use-mpv-custom v0.35.1 (commit 140ec21c89d671d392877a7f3b91d67e7d7b9239 ) use-ffmpeg-master (commit fa20f5cd9e131f22da06ef57bf5aedd87ff51a90) «mpv-avisynth-ffms-not-ok.sh»? If so, tell me please what version/commit of MPV, and how you built it (version of ffmpeg, avisynth to link with). Last edited by belonesox; 26th September 2023 at 16:37. |
