7th May 2015, 17:34 | #61 | Link | |
If the script works with VDub64, x264_64, AVSMeter64, I'd say your problem is not the plugin.
Groucho's Avisynth Stuff |
8th May 2015, 08:23 | #63 | Link |
Just because a bug does not surface doesn't mean that the bug does not exist, the only thing that it sure at this point is that the bug exists, it can be in the avs plugin, it can be in the avs core, it can be in the client interop layer, it can be even in the CLR. I tested 15 plugins and only nnedi3, DGMPGDec and DGDecNV have a problem, chances are good we will find it, wherever it is.
8th May 2015, 09:34 | #64 | Link | |
When you search the forum, you'll find that there are all sorts of problems with the 64 Bit version of DGDecode.dll, missing IDCT modes, "green" frames, ...
8th May 2015, 11:04 | #66 | Link |
Useful n00b
The 64-bit version of DGMPGDec's DGDecode is not made by Graft and is known to be buggy, as Groucho2004 pointed out. There are no known issues with 64-bit DGDecNV, so please demonstrate one if you can. Graft is always keen to fix issues in his code.
None of Graft's tools contain any "pointers pointing into managed space". Last edited by videoh; 8th May 2015 at 11:16. |
8th May 2015, 11:19 | #67 | Link | ||
The fact also that's it's not crashing with opt=1 means that it's crashing only when using the ASM part code, meaning that something broke the register presevation rules. If it was a bug in the ASM like a loop going too far or something like that, issue would have poped up earlier and on any system (i think). This is why within a week or two, i'll take a long time to properly check that the ASM code is not breaking the x64 register preservation rules, according the standard fastcall_ calling procedures. I'll also check code itself, but this is the only thing i think for now. stax76 You've asked benchmarks : Code:
[General info] Log file created with: AVSMeter 2.0.1 (x64) Avisynth version: AviSynth+ 0.1 (r1576, x64) (2.6.0.5) Avisynth DLL location: C:\Windows\System32\AviSynth.dll [Clip info] Number of frames: 4077 Length (hh:mm:ss.ms): 00:02:50.045 Frame width: 960 Frame height: 720 Framerate: 23.976 (24000/1001) Colorspace: YV12 Audio channels: n/a Audio bits/sample: n/a Audio sample rate: n/a Audio samples: n/a [Runtime info] Frames processed: 4077 (0 - 4076) FPS (min | max | average): 17.08 | 99.95 | 55.80 Memory usage (phys | virt): 93 | 91 MB Thread count: 37 CPU usage (average): 38% Time (elapsed): 00:01:13.060 [Script] SetMemoryMax(64) AVISource("Ken - 101.avi",False,"YV12").SetPlanarLegacyAlignment(True) nnedi3_rpow2(rfactor=2,cshift="Spline36Resize",fwidth=960,fheight=720,nsize=0,nns=3,qual=2) Code:
[General info] Log file created with: AVSMeter 2.0.1 (x64) Avisynth version: AviSynth+ 0.1 (r1576, x64) (2.6.0.5) Avisynth DLL location: C:\Windows\System32\AviSynth.dll [Clip info] Number of frames: 4077 Length (hh:mm:ss.ms): 00:02:50.045 Frame width: 960 Frame height: 720 Framerate: 23.976 (24000/1001) Colorspace: YV12 Audio channels: n/a Audio bits/sample: n/a Audio sample rate: n/a Audio samples: n/a [Runtime info] Frames processed: 1903 (0 - 1902) FPS (min | max | average): 15.32 | 36.55 | 26.79 Memory usage (phys | virt): 92 | 91 MB Thread count: 37 CPU usage (average): 74% Time (elapsed): 00:01:11.047 [Script] SetMemoryMax(64) AVISource("Ken - 101.avi",False,"YV12").SetPlanarLegacyAlignment(True) nnedi3_rpow2(rfactor=2,cshift="Spline36Resize",fwidth=960,fheight=720,nsize=0,nns=3,qual=2,opt=1) |
8th May 2015, 21:16 | #68 | Link | |
Angel of Night
9th May 2015, 08:17 | #70 | Link | |
unsigned int
jpsdr: I noticed this while perusing your ASM: https://github.com/jpsdr/NNEDI3/blob..._x64.asm#L1414 I don't know if that function is even used when it crashes, since stax76 hasn't provided the parameters passed to nnedi3...
Buy me a "coffee" and/or hire me to write code! |
9th May 2015, 09:42 | #71 | Link |
Good !!! And I don't know if it's related or the cause (there a good chance), but it's clearly a miss from my part wich need to be corrected.
Even with stax76 parameters, i don't know if i can say if this function is called or not. I'll try to make a new build as soon as i can. |
9th May 2015, 16:51 | #74 | Link |
Optimizations have to be turned off for debug builds.
9th May 2015, 16:58 | #75 | Link |
Thanks, I turned off optimizations and replaced
this line: #include "afxres.h" with: #include "WinResrc.h" #define IDC_STATIC -1 I thought MFC is included with Community Edition? The build succeeds now but why doesn't it output any DLLs? |
10th May 2015, 01:03 | #76 | Link |
It's always breaking as access violation in this line:
https://github.com/jpsdr/NNEDI3/blob...edi3.cpp#L1258 There is however something in my code because I just noticed it only happens in the preview dialog and it loads in the crop dialog fine, I didn't expect that. I don't remember I do threading or something special. At least we have some hints now. edit: crop dialog does not use any other filters than the source I was forgetting Last edited by stax76; 10th May 2015 at 01:14. |
10th May 2015, 01:49 | #77 | Link | |
10th May 2015, 10:14 | #79 | Link |
Picture information is interesting. If registers value are correct, RAX & RCX at 0, crash is expected. But issue is that RAX shouldn't be at 0, it's the source pointer. As this crash occur during the y loop, is the crash occuring at the first occurence of the loop, or after several ?
