11th May 2006, 01:40 | #882 | Link | |
Mr. Sandman
11th May 2006, 11:34 | #888 | Link | |
Pain and suffering
2136
Microsoft (R) Visual C# 2005 Compiler version 8.00.50727.42 for Microsoft (R) Windows (R) 2005 Framework version 2.0.50727 Copyright (C) Microsoft Corporation 2001-2005. All rights reserved. AviSynthWindow.cs(1556,10): warning CS1030: #warning: 'This is just quickfix, please check it!' Calculator.cs(28,10): warning CS1030: #warning: 'Calculator should be aware of mux providing, etc.' d2vReader.cs(46,10): warning CS1030: #warning: 'Why load the video here? This means that we can't apply force film unless the video unless it is playable in AviSynth' ProfilePorter.cs(210,10): warning CS1030: #warning: 'We are generating a list of failed attempts, but we aren't doing anything with it (below).' VideoUtil.cs(959,10): warning CS1030: #warning: 'This should be rearranged to work better' mkvMuxWindow.cs(861,18): error CS0103: The name 'MUXTYPE' does not exist in the current context mkvMuxWindow.cs(878,23): error CS1501: No overload for method 'generateMkvmergeCommandline' takes '3' arguments CommandLineGenerator.cs(1147,24): (Location of symbol related to previous error) Microsoft (R) Visual C# 2005 Compiler version 8.00.50727.42 for Microsoft (R) Windows (R) 2005 Framework version 2.0.50727 Copyright (C) Microsoft Corporation 2001-2005. All rights reserved. Seems like you didn't really use the latest 2136 source where this was fixed, where only the version number was wrong. Please fix the problem and stick with SVN, automation is key for lazy people!! |
11th May 2006, 12:40 | #889 | Link | |
Hi, I am getting this error and it seems to be a MeGUI bug.
My AVS script: Code:
# Set DAR in encoder to 37 : 20. The following line is for automatic signalling global MeGUI_darx = 37 global MeGUI_dary = 20 DGDecode_mpeg2source("H:\dvd\z.d2v",info=3) ColorMatrix(hints=true) #Not doing anything because the source is progressive crop( 10, 10, -6, -6) #resize Undot() # Minimal Noise Code:
Generating jobs. Desired size: 1234173952 bytes No audio encoding. Calculating desired video bitrate directly. Setting video bitrate for the video jobs to 0 kbit/s Setting desired size of video to 1231512576 bytes Starting job job1-1 at 00:18:12 Job is a video job. encoder commandline: --pass 1 --bitrate 0 --stats "H:\dvd\z.stats" --bframes 3 --b-pyramid --direct auto --filter -2,-1 --subme 1 --analyse none --me dia --sar 1073:880 --cqmfile "D:\x264\eqm_avc_hr.cfg" --progress --no-psnr --output NUL "H:\dvd\z.avs" successfully started encoding Processing ended at 02:20:13 ---------------------------------------------------------------------------------------------------------- Log for job job1-1 avis [info]: 704x464 @ 23.98 fps (166996 frames) x264 [info]: using SAR=1073/880 x264 [info]: using cpu capabilities MMX MMXEXT SSE 3DNow! x264 [info]: slice I:825 Avg QP:47.96 size: 3920 x264 [info]: slice P:58907 Avg QP:51.00 size: 503 x264 [info]: slice B:107264 Avg QP:51.00 size: 87 x264 [info]: mb I I16..4: 95.4% 0.0% 4.6% x264 [info]: mb P I16..4: 6.5% 0.0% 0.0% P16..4: 2.9% 0.0% 0.0% 0.0% 0.0% skip:90.6% x264 [info]: mb B I16..4: 0.3% 0.0% 0.0% B16..8: 0.9% 0.0% 0.0% direct: 0.2% skip:98.6% x264 [info]: final ratefactor: 258.67 x264 [info]: direct mvs spatial:94.2% temporal:5.8% x264 [info]: kb/s:48.5 Actual bitrate after encoding without container overhead: 48.68 ---------------------------------------------------------------------------------------------------------- job job1-1 has been processed. This job is linked to the next job: job1-2 Starting job job1-2 at 02:20:14 Job is a video job. encoder commandline: --pass 2 --bitrate 0 --stats "H:\dvd\z.stats" --ref 16 --mixed-refs --no-fast-pskip --bframes 3 --b-pyramid --b-rdo --bime --weightb --direct auto --filter -2,-1 --subme 7 --trellis 2 --analyse all --8x8dct --me umh --sar 1073:880 --cqmfile "D:\x264\eqm_avc_hr.cfg" --progress --no-psnr --output "H:\dvd\z.mkv" "H:\dvd\z.avs" successfully started encoding Processing ended at 02:20:25 ---------------------------------------------------------------------------------------------------------- Log for job job1-2 avis [info]: 704x464 @ 23.98 fps (166996 frames) x264 [info]: using SAR=1073/880 x264 [error]: requested bitrate is too low. estimated minimum is 7 kbps x264_encoder_open failed ---------------------------------------------------------------------------------------------------------- I followed the same steps that I always use: D2V Creator, AviSynth Script Creator, Autoencode -> Filesize (in this case 1177MB, which predicts an Average Bitrate of 1415 kbit/s). Any hints? Thanks in advance. |
11th May 2006, 13:04 | #891 | Link |
Thanks! Now a stupid question, I was installing MeGUI with Sharktooth's x264-Std_r***. It was working with x264-Std_r512 and I got this problem with x264-Std_r520 and x264-Std_r522.
I don't have x264-Std_r512 anymore. Where can I download MeGUI 0.2.3.2130? I looked at sourceforge but the latest version seems to be 0.2.3.2116. Thanks. |
11th May 2006, 13:34 | #892 | Link |
I got it! http://chronocrossdev.com/apps/megui/. 0.2.3.2132 solved the problem. Thanks.
11th May 2006, 14:48 | #893 | Link | |
Then it should compile fine. I've reported here: http://forum.doom9.org/showthread.ph...078#post826078 Last edited by leowai; 11th May 2006 at 14:50. |
12th May 2006, 05:57 | #895 | Link |
Lost His Beer
just finished complieing svn downloaded code, works fine.. Thanks =)
- I spoke too soon, I added a avs script, went to change the same information, framerate to 29, then change it to mp4, then change the file size from 700 to 20 and clicked OKAY.. same problem Last edited by Deep_Eyes; 12th May 2006 at 06:09. |
12th May 2006, 06:34 | #896 | Link |
Lost His Beer
2136 SVN download Complie
Microsoft (R) Visual C# 2005 Compiler version 8.00.50727.42 for Microsoft (R) Windows (R) 2005 Framework version 2.0.50727 Copyright (C) Microsoft Corporation 2001-2005. All rights reserved. AviSynthWindow.cs(1556,10): warning CS1030: #warning: 'This is just quickfix, please check it!' Calculator.cs(28,10): warning CS1030: #warning: 'Calculator should be aware of mux providing, etc.' d2vReader.cs(46,10): warning CS1030: #warning: 'Why load the video here? This means that we can't apply force film unless the video unless it is playable in AviSynth' ProfilePorter.cs(210,10): warning CS1030: #warning: 'We are generating a list of failed attempts, but we aren't doing anything with it (below).' VideoUtil.cs(959,10): warning CS1030: #warning: 'This should be rearranged to work better' Microsoft (R) Visual C# 2005 Compiler version 8.00.50727.42 for Microsoft (R) Windows (R) 2005 Framework version 2.0.50727 Copyright (C) Microsoft Corporation 2001-2005. All rights reserved. |
12th May 2006, 13:10 | #897 | Link |
Mr. Sandman
The problem is in the still incomplete Vorbis support.
13th May 2006, 02:22 | #898 | Link |
Bitrate calculator bugs are to be expected, because they still use the same code from before the refactor. I have put a warning message when using it, because it still needs a reworking.
I've fixed the AutoEncode bitrate calculation bug (bitrate wasn't set). I should have fixed all the other bugs mentioned here as well, except for the mencoder huffy commandlines (I haven't set it up for testing, and it can wait a bit, because it doesn't actually cause a crash). |
