Old 18th March 2021, 01:33   #41  |  Link
Neiromaster
Neiromaster
If it is between xvid and x264, AV1 or VP9 are already better.
This is a different, completely rewritten codec.
Several new inventions have been added
It does not currently support B frames.
But this is planned to be added in the near future.
If you compare it in zerrolatensy mode, then it is better than 264, close to 265 and better AV1 in realtime modes. Similar in level to VP9 with B frames, but has a number of unique things.
And yes, this is a realtime codec that plays in a different area than AV1
Neiromaster is offline   Reply With Quote
Old 18th March 2021, 06:52   #42  |  Link
Neiromaster
Neiromaster
About x264 and SIF
Park Joy at 8 Mbit.
https://disk.yandex.ru/d/9_oLybuBktSSVQ
Encoding String
ConsoleEnc.exe "park_joy_1080p.y4m" --viz_dist=64 -o park_joy_1920x1080_test.avi
x264 Veryslow Zerolatency crf 30
https://disk.yandex.ru/i/5u3ZJRFI-P5Ubw
You can see everything yourself
Old 7th April 2021, 21:09   #43  |  Link
Gravitator
Hello!
v2.05.0
Encoding is completed without starting the second pass.
C:\>ffmpeg -i z:\space_6s.mkv -f yuv4mpegpipe - | sif1_enc.exe --avi_outp --comp_mode=vbr_all_p --vbr_stat_f=z:\sif_stat.sta --out_bitrt=1200 -o z:\test.avi -
Are there any plans to make friends your decoder with the MPC-BE player?
Win10x64, Xeon E5450, GTX 750 2GB, DDR3 8GB.
Gravitator is offline   Reply With Quote
Old 9th April 2021, 06:27   #44  |  Link
Neiromaster
Neiromaster
An interface that uses standard threads does not allow you to rewind the thread to the beginning of the file. Therefore, when you use it, you cannot specify multiple passes with a single key.
Use multiple program launches
C:\>ffmpeg -i z:\space_6s.mkv -f yuv4mpegpipe - | sif1_enc.exe --avi_outp --comp_mode=vbr_1_p --first_pass_mode=medium --vbr_stat_f=z:\sif_stat.sta --viz_dist=45 -o z:\test.avi
C:\>ffmpeg -i z:\space_6s.mkv -f yuv4mpegpipe - | sif1_enc.exe --avi_outp --comp_mode=vbr_2_p --first_pass_mode=medium --vbr_stat_f=z:\sif_stat.sta --out_bitrt=1200 -o z:\test.avi
Setting the VD value on the first pass affects the quality obtained on the second pass.
The DirectShow decoder uses a 10 bit p010 format, which causes a number of problems with programs that do not understand it.
Some problems with this were fixed and the DirectShow decoder was updated without increasing the version number.
On the other hand, native support for decoding the format in FFMPEG, VLC is needed.
To do this, need to open the decoder code under the GPL or BSD license.
I am not the sole owner of SIF Codec LLC and such a solution requires coordination of different interests. This is a goal in the near future.
Old 8th May 2021, 15:57   #45  |  Link
Gravitator
Waiting for b-frames.
Old 11th May 2021, 00:50   #46  |  Link
benwaggoner
For videoconferencing, B-frames aren't used. So a codec doesn't need them to be interesting or valuable.
I can see a future codec combining generalized B-frames with off-screen references into something that doesn't really have B-frames per se, with everything only forward-referenced...
Ben Waggoner
My Compression Book
Old 13th December 2021, 20:38   #47  |  Link
Gravitator
Здравствуйте!
At what stage of development are you?
