19th August 2011, 23:30 | #4882 | Link |
When I installed LAV Filters via installer, I can't complete Windows Experience Index testing anymore.
It fails at Windows Media Decoding optimization or whatever called in english. This doesn't happen with zip version of LAV Filters x86/x64. LAV Filters 0.32, Windows7 x64 |
19th August 2011, 23:43 | #4883 | Link | |
_
With MS decoder, I have some problems: even if it needs less CPU, the video in not always synchronized with audio (and subtitles), there is a delay after some time, or after seeking; and I don't have this problem with ffmpeg (madVR, ffdshow or LAV). Like I never have problem with ffmpeg, I stay with it. And it seems I don't have any interlaced videos (I don't have DVD). Last edited by pirlouy; 19th August 2011 at 23:52. |
19th August 2011, 23:45 | #4884 | Link | |
Also, speaking of that, how good is ffdshow at detecting when to use deinterlacing? Also, what is wrong with the intel vc-1 decoder? I understand the problems with ffmpeg's, but i would think intel's would be fine. Heh, I was using divx h264 on one of my computers too, though now I am using lav video. It hasn't been updated for such a long time, I wonder if ffmpeg has more or less caught up to it in terms of performance. Last edited by mindbomb; 20th August 2011 at 00:00. |
19th August 2011, 23:50 | #4885 | Link | |
_
20th August 2011, 00:01 | #4886 | Link | |
In short: I now have even lower power consumption than DXVA when playing back SD video using this tool. There are three power consumption modes for my GPU: P12, low power for 2DDXVA automatically kicks the GPU into P8 power consumption, so EVR-CP/DXVA uses 100W. With this tool, MadVR/CUVID can run in the P12 state with SD videos, dropping consumption to 92W. (and P8 with HD, at 103W) So I have effectively halved my power consumption when playing back SD video from 180W this morning to 92W now! |
20th August 2011, 01:10 | #4888 | Link |
Sorry for the noob question, but I'm new to LAV and have a quick question about audio. I can't get DTS-HD MA bitstreamed with the LAV decoder with Daum. I have to use it's built-in decoder. Is there a setting I need to enable or disable?
Win 7/64 GT-430 Daum PotPlayer 1.5.29332 (x86) LAV 0.32 |
20th August 2011, 02:47 | #4890 | Link | |
@nevcairiel: Does this build of LAV Video include the swscale levels bug fix?
Forget about my old .3dlut stuff, just use mpv if you want accurate color management Last edited by nand chan; 20th August 2011 at 02:49. |
20th August 2011, 07:05 | #4892 | Link | |
Fantasy Codecs writer
20th August 2011, 08:04 | #4894 | Link | |
Firefox User
but according http://forum.doom9.org/showthread.php?t=113362 , it is not in spec anymore. AviSynth and VirtualDub will output raw YUV444p video in AVI with FourCC YV24. for packed YUV 4:4:4, there is an alternative, IYU2. http://www.fourcc.org/yuv.php#IYU2 Last edited by roytam1; 20th August 2011 at 08:26. |
20th August 2011, 08:23 | #4895 | Link | |
Did some testing with an EVO from "Heroes, S1E1" MediaInfo reports it as: Code:
Video ID : 253 (0xFD)-85 (0x55) Format : VC-1 Format profile : AP@L3 Duration : 53mn 17s Bit rate : 18.6 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Scan order : 2:3 Pulldown Compression mode : Lossy Bits/(Pixel*Frame) : 0.374 Stream size : 6.92 GiB (91%) The same file when remuxed to M2TS plays at 23.976 and while it does not have the presentation glitches it too does not look very good with panning and will stutter on these scenes badly. Samples: Original EVO: http://www.megaupload.com/?d=BOC0RSXW Remuxed M2TS: http://www.megaupload.com/?d=H5USKBUW Last edited by jmone; 20th August 2011 at 11:35. |
20th August 2011, 08:43 | #4896 | Link | |
Hero's S1 is the only HD-DVD I haven't replaced, but they work fine with the LAV combo.
Windows 11 Pro, CPU: Ryzen 9 5900X, GPU: GeForce RTX 3090 /w 512.95, Audio: HDMI to Yamaha RX-A3060 (5.1) |
20th August 2011, 09:09 | #4897 | Link | |
What bug fix?
20th August 2011, 10:37 | #4899 | Link |
AVCHD playlist support
does the LAV splitter allow to use the AVCHD playlist files in same way as for BluRay discs? I don't only mean the playback of the single *.MTS files, but also to use the playlist (*.MPL) The AVCHD structure is nearly identical to BD, but uses short file extensions (3 chars), means: *.bdmv -> .BDM ; *.m2ts -> *.MTS The main issue with such playlists is, they contain file references to *.m2ts, although the real filenames are *.MTS (see also http://en.wikipedia.org/wiki/File:AV..._structure.svg). When you try to open the playlist with the LAV splitter it fails, because the referenced files are not found. Could the splitter be extended to support the short file extensions as kind of "fallback" source when reading the stream files? Thank you Morpheus_xx |
20th August 2011, 13:32 | #4900 | Link |
@nevcairiel
Does lavvideo support subtitles in wmp12? I tried some mkv files but no subtitles. I see in wmp12 that lavvideo and lavaudio are used for decoding but no subtitles. I use the standard settings for lavsplitter and I even tried to put eng in the preffered languafes field. |
