14th May 2019, 14:53 | #1 | Link |
Filter suggestion for avisynth/VirtualDub2 of source with "fata morgana"
Got a sample clip:
https://anonfile.com/C7Ffyar1n7/Filter_Movement_mp4 of landscape in "movement" that appears from hot air I think.. sort of "Fata Morgana".. (above is not the source, it is encoded in x264 8bit, which is also my target encode) would love to get some ideas on what kind of builtin filter (VirtualDub2), or avisynth script can be used to "process" this and reduce file size a bit yet maintain quality. Thanks for any possible tips. Source material is: Code:
Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 (mp42/avc1/CAEP) File size : 2.34 GiB Duration : 5 min 40 s Overall bit rate : 59.0 Mb/s Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L5.1 Format settings : CABAC / 2 Ref Frames Format settings, CABAC : Yes Format settings, RefFrames : 2 frames Format settings, GOP : M=3, N=24 Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 5 min 40 s Bit rate : 58.9 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 50.000 FPS Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.568 Stream size : 2.33 GiB (100%) Language : English Color range : Full Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Codec configuration box : avcC |
14th May 2019, 18:14 | #2 | Link |
Getting warning about a deceptive site from your link, I aint gonna download it.
14th May 2019, 18:30 | #3 | Link |
I just dl'd it, no problem, no complaints.
Groucho's Avisynth Stuff |
14th May 2019, 19:16 | #4 | Link |
Warning from fireFox 66.xx, Settings : Security : Deceptive Content and Dangerous Software Protection
(via some Google service about deceptive content). Might just have been because of the AnonFile.com name. Although I was a little sceptical myself about a 1920x1080@50.0FPS of duration 5:xx minutes (which is what source file seemed to be) and with output file size of about 3.5 MB. EDIT: Firefox "Learn About" page on the Deceptive content stuff:- https://support.mozilla.org/en-US/kb...urce=inproduct
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 14th May 2019 at 19:22. |
14th May 2019, 19:31 | #5 | Link |
*Stainless*, original source is:
File size : 2.34 GiB I clipped just a short segment and encoded it down to 3.5MB, just to give you an idea of the "movement" or "flickers" that appear in the sky/wires.. any idea on which filter/avisynth script would handle it best? |
14th May 2019, 20:00 | #6 | Link |
I went back to have another go, downloaded the named file (which turned out to be an html file, could not find real file name embeded in the html),
went back again for yet another go, and the constant refreshing of page made me shy off from download. I guess that I'm just not as courageous as the brave yet grouchy one. Stormy, suggest that you use another file host in future, that one is just a little too scarey. [I tend to get alarmed whenever anything unusual happens, eg when you try leave site and it will not let you until you click "Are you sure ?", "Leave Page" button, I tend to pull plug on connection and force kill the browser just to avoid pressing the button that it seems desperate for me to press. Paranoia rules OK].
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 14th May 2019 at 20:21. |
14th May 2019, 21:19 | #7 | Link |
I am under WinXP and using good old Opera 12 with a custom hosts file from winhelp2002.mvps.org/hosts.htm.
The only annoyance with this site is that after the first click on the file I get redirected (opening a new tab) to some advertising site. Clicking on the file for a second time downloads it without any issues. So I believe this is a little too much paranoia... |
14th May 2019, 21:39 | #8 | Link |
I made a copy of the video here, for those reluctant: http://savedonthe.net/download/2427/..._Movement.html
15th May 2019, 05:09 | #9 | Link |
Thanks Mariush
so sorry, I run no-script (firefox addon), and so all these noisy things do not really appear, anyways, I can also upload the original SOURCE, not the encoded, but it's pretty much the same video, just much much larger.. the question is there any "encoding" scheme that can "cope" with such almost "watery" or "vapory" movement in the sky Thanks... |
15th May 2019, 09:33 | #10 | Link |
Just saw Neat Video post and they claim to deal with "heat haze". https://blog.neatvideo.com/post/nv5-overview
No idea if this is available from plugin.
VirtualDub2 |
15th May 2019, 09:36 | #11 | Link |
I overcame my cowardice and bravely downloaded, thanx Mariush.
So basically 'Heat Haze'. [I'de never heard the term Fata Morgana, looked Heat Haze up and it got me to Wikipedia Mirage:- https://en.wikipedia.org/wiki/Mirage]. I would not have any idea how to simulate heat haze. Regarding the wikipedia Mirage link, Fata Morgana paragraph, "atmospheric duct" hilited popup, I think I once experienced that myself. Back in 1981, I was stayng at a guest house in Bedfordshire countryside, about 5 of us were watching an Italian movie on analogue TV. Due to weird atmosperic conditions, we could not pick up UK TV, only a single Italian TV station (maybe due to 'atmospheric ducting' which probably acts similar to microwave WaveGuide used in Radar and microwave communications). the Italian movie of course had no subtitles (as it was broadcast for Italians, not Brits), so we asked the Swiss girl with us to translate (she spoke Swiss German, Italian, French and English), and we all sat there transfixed as she translated for a good 10 minutes, at which point she realised that nobody was watching the movie, we were all fixed upon her. I said something like, "Enough of the French, how about giving it to us in English". Some additional quite strange linguistic ducting had occurred. EDIT: Maybe some kind of +/- random number generation per pixel (vertical I think), and then run some kind of 'centered moving average' (to keep results coherent), would also need some kind of 'centered moving average' horizontally and temporally too. When all numbers crunched, then get pixel from Y coord +/- random sourced result. Not really sure, but something like above (maybe). EDIT from later post: Oh crap, I thought you wanted to synthesize Heat Haze, my bad.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 15th May 2019 at 10:41. |
15th May 2019, 10:27 | #12 | Link |
Oh, wait a sec.. Is that "shekh"? the developer of VD2 telling us to purchase a software package to encode.. hmm.. should we be worried ??
Thanks for the link, it mentioned "in-camera noise reduction", not sure I can find anything on that, it really appears to move, even to naked eye, so not sure camera is at fault here.. The term "Heat haze" is exactly right.. hopefully someone has some experience with encoding such content; almost looks like water/movement fuzzy shifting Stainless, I think you posted sober this time around (at least BEFORE the EDIT), nice story, and with a happy "ending", did anyone end up marrying the girl |
15th May 2019, 10:37 | #13 | Link | |
I think I may try play with daft edit idea, but might take some time before I get around to it. Tracking particals in meteorology, or as water goes over a waterfall (or even out of a tap/faucet) is an incredibly intractable problem, this is no easier probably (hence daft random number thing). EDIT: Oh crap, I thought you wanted to synthesize Heat Haze, my bad.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 15th May 2019 at 10:40. |
15th May 2019, 10:37 | #14 | Link |
I wouldn't do anything apart from some light de-noising. Just tried with "KNLMeansCL(d = 1, a = 2, h = 2.0, s = 2)" and the bitrate went from 5500 to 3000 @CRF18. At 1080p, this is already a very low bitrate.
If you want more comprehensive advice, upload a piece cut directly from the source.
Groucho's Avisynth Stuff Last edited by Groucho2004; 15th May 2019 at 10:41. |
15th May 2019, 14:20 | #15 | Link |
It was funny to see the term "heat haze" in 2 unrelated places in one day, I thought it won't hurt to link
VirtualDub2 |
15th May 2019, 14:41 | #16 | Link |
Groucho,
Sorry, wasn't thinking, naively thought answer is easy here is part of original clip: https://anonfile.com/G30bHardn8/Heat_Haze_Original_mp4 roughly 46MB, not too bad... The idea is that the reencode would not be apparent to human eye, or add artifacts that are not in the original already... Stainless, here's your second chance no worries, your company is enough sometimes Stormy. |
15th May 2019, 14:43 | #17 | Link | |
yeah, certainly funny chance to see such a rare phrase appear in two places |
15th May 2019, 15:04 | #18 | Link | |
At CRF 16 I highly doubt that you will see a difference between the original and the re-encoded file. At CRF 18, the encoded file has 5.5 Mbps (9.3% of the original). So, how much reduction do you have in mind?
15th May 2019, 15:14 | #19 | Link |
thanks so much, i went up to CRF17, but fear to go higher, yeah, 10% is great, was wondering which filter/syntax to use for 'denoising' for this particular clip given the "movement", did not find anything in the provided filters for VirtualDub2 (with noise in the name).. do u still recommend: "KNLMeansCL(d = 1, a = 2, h = 2.0, s = 2)" for this clip? I can give it a try on the full source and see...
15th May 2019, 15:50 | #20 | Link | |
Another option: Code:
function MCD(clip video, int "threshold") { last = video threshold = default(threshold, 200) bs = (width() > 960) ? 16 : 8 sc = MSuper(pel = 2, sharp = 1, hpad = 16, vpad = 16) backward_vector = MAnalyse(sc, isb = true, delta = 1, blksize = bs, overlap = bs / 2, sadx264 = 4) forward_vector = MAnalyse(sc, isb = false, delta = 1, blksize = bs, overlap = bs / 2, sadx264 = 4) backward_vector = MRecalculate(sc, backward_vector, blksize = bs / 2, overlap = bs / 4, thSAD = 100) forward_vector = MRecalculate(sc, forward_vector , blksize = bs / 2, overlap = bs / 4, thSAD = 100) MDegrain1(sc, backward_vector, forward_vector, thSAD = threshold) return last } Also, watch out for banding if you use a de-noiser. I usually stick with 'less is more' and use filters (particularly de-noisers) as little as possible.
