Old 7th January 2005, 00:04   #1  |  Link
Cyberia
Cyberia's Avatar
DGMPGDec Development List
This is the list of requested fixes and enhancements for DGMPGDec. It's the wish list of features and fixes. Please feel free to add/correct to this list by posting to this thread.
This list is not prioritized or ordered in any way. Some of these may require extensive work, others may be easy changes. This is NOT intended to be a "to do" list for any one developer. Developers are invited to assign items to themselves for development. Please inform neuron2 if you with to do that, in order to avoid duplication of effort.
Fixes
1) DGMPGDec needs to support no-I-frame streams.
2) Stopping a preview with a field structure clip can result in
display of fields from different pictures. This only affects
display in DGIndex after hitting stop, and does not affect video
output.
DGIndex Enhancements
1) Auto detect and set Field Operation
        a) can be overridden/changed
2) Multiangle support
3) Unicode character support
4) Some kind of free-space check before saving projects
5) Produce audio files with no delay necessary.
        a) Also, tool for audio sync/PTS debugging
        b) Proper correction for AV sync loss due to
           video or audio losses due to stream errors.
6) (GUI) Frame accuracy. Individual frame stepping (both directions).
7) (GUI) Allow multiple simultaneous selection ranges to be set. Cutting.
8) (GUI) Audio Identification
        a) Audio track selector reports valid tracks and some info
           (types, bitrate, freq, length, language, etc)
           AC3(5.1) 448Kbps 48Khz  849s En
           AC3(2.0) 192Kbps 44Khz  243s Sp
           DTS      768Kbps 48Khz 1843s Gr
9) (GUI) Audio playback
10) (GUI) Clipping option needs better granularity
11) (GUI) Save clipping settings if clipping is checked when ending the program
    Cyberia's comment: Not sure if this is a good idea at all.  Don't
    save the setting, but don't clear it when you load a new vob. If you
    save the clipping value, users will  forget about it (especially
    command-line users) and bad things will happen.  Better
    to preserve the current setting while the program is open and
    allow the user to load multiple files without resetting the value.
12) (GUI) Enhanced Color/Luma controls
        a) Possibly like AVIUTL or....
        b) Invoke the AviSynth filters Tweak and Levels
13) (CLI) option to specify the process priority
14) (CLI) Add a commandline option to specify a range of "VOB Cell IDs" to
index. [mg262]
15) Process multiple audio streams at once for transport streams
(as is currently done for program streams).
DGDecode Enhancements
1) Rationalize parameter definitions and functionality
        a) See this thread: http://forum.doom9.org/showthread.php?s=&threadid=76625
2) Automatic D2V file generation
3) Allow "Info" to be used in AviSynth for conditional filtering
Cyberia is offline   Reply With Quote
Old 7th January 2005, 00:22   #2  |  Link
Cyberia
Cyberia's Avatar
I am reposting this thread now that it seems some development has resumed on DGMPDec. The original thread can be found here.
I believe these items have been resolved by the latest fixes from Tritical:
Fixes
1) Upsampling based on progressive/interlaced picture indication
[AbsoluteDestiny]
2) Set ipp parameter automatically according to current frame type
4) Show clip TFF versus BFF in info dialog.
Please confirm these and ill remove them from the list. Also, thanks for the new coding!
Old 8th January 2005, 01:14   #3  |  Link
Cyberia
Cyberia's Avatar
Well, sorry everyone. The list originally posted was a bit out of date. I have updated it with the current issues, so please go over it again.
Old 12th January 2005, 14:52   #4  |  Link
Originally posted by Cyberia
Please confirm these and I'll remove them from the list.
Please don't remove them until they make it into my full releases. Otherwise, I may forget about them.
I am reviewing tritical's changes right now with a view to incorporating them.
Old 24th January 2005, 17:59   #5  |  Link
Cyberia
Cyberia's Avatar
The list has been updated as of 1/24/05 to reflect the changes made with DGMPGDec 1.1.0.
Old 19th April 2005, 04:25   #6  |  Link
Updated the list.
Old 29th April 2005, 23:54   #7  |  Link
iNFO-DVD
Author of avi.NET rip.NET
iNFO-DVD's Avatar
The "[ ]" in CLI
Just a little request if possible.....
Are the [ and ] (around filenames) in the CLI of DGIndex there for just parsing???? I mean, any reason why they are "[ ]" or was that just what was chosen originally?
The reason I ask is because if I use DGIndex CLI I can now not have the "[" or "]" symbol in my path, which is a bit of a pain as I use them quite a lot.
Any chance you could change the symbol to something that you can't legally have in a path so it will never be an issue with anyone again?
Illegal folder/file names are:
Hope you can oblige.......
iNFO-DVD is offline   Reply With Quote
Old 4th May 2005, 22:15   #8  |  Link
Cyberia
Cyberia's Avatar
Re: The "[ ]" in CLI
Your only option would be to use the -BF([filelist]) option. I just tested it with [ ] in filenames and it does work fine.
You should also post questions like these in a new thread. I understand your confusion, but this is not a feature request thread.
Cyberia
Old 15th May 2005, 02:58   #9  |  Link
Added a bug regarding multiple instances of DGVfapi. Well, I didn't add the bug, I added the notice of its existence.
Old 3rd June 2005, 23:50   #10  |  Link
Zetto
Is there anyway to include the demuxed sound file name somewhere in the template.avs? I mean like substituting videofile name with the generated d2v, is it possible to introduce something similar for audio file? Thanks for the great work
Zetto is offline   Reply With Quote
Old 4th June 2005, 19:22   #11  |  Link
Xesdeeni
How about adding DxVA support to DGMPEGDecode? That should allow much faster conversions, especially for HD material.
Also, is there any advantage to using the flags in the MPEG stream to help Decomb? I.e. would the decomb process (Telcide/Decimate) be any faster if rolled into DGIndex/DGMPEGDecode?
Xesdeeni
Xesdeeni is offline   Reply With Quote
Old 4th June 2005, 21:29   #12  |  Link
Pookie
Have you guys considered transport stream repair capability, ala Mpeg2Repair http://users.adelphia.net/~mwilczyn/mpeg2repair/ ? Not so much to fix the file, but rather to fix the errors before A/V demux and .d2v creation. I know it is a bit out of the scope of what DGmpgdec was designed to do, but hell, thought I'd ask.
Pookie is offline   Reply With Quote
Old 4th June 2005, 23:29   #13  |  Link
Originally Posted by Pookie
Have you guys considered transport stream repair capability.
Yes, I've considered it. It's possible but probably not before I personally start capturing transport streams.
Old 5th June 2005, 02:39   #14  |  Link
Pookie
Thanks for your consideration, Donald. If you want a couple of DVDs worth of transport stream samples (laden with errors) for testing purposes, just say the word.
Old 10th June 2005, 03:19   #15  |  Link
dvgeek
Small Feature Request
Great Tool Neuron2 !
New feature for demuxing is very useful - and I have a request here - when this option is selected, could it generate a d2v file that points to the demuxed m2v file instead of the original file (tp / mpg) ?
Thanks again.
dvgeek is offline   Reply With Quote
Old 13th June 2005, 16:24   #16  |  Link
Xesdeeni
The LinkPlayer2 is capable of playing ATSC TS and DiVX HD content from a DVD. But ATSC content can fill a single-layer DVD*R with as little as 30 minutes of video. So I'm converting some ATSC HD content to DiVX HD to shrink it, and for possible playback with a LinkPlayer2 or similar device.
On my Athlon XP 2400+, I can't play back the HD stream via DGMPEGDec faster than 15-20 fps. But it can play back at a full 60 fps using only 35% of the CPU with the FusionHDTV software decoder using DxVA (it can't quite handle 60 fps with 100% use without DxVA).
Is there any way we can help with decoder optimizations? Is it possible to add DxVA to the decoder?
Xesdeeni
Old 3rd July 2005, 21:49   #17  |  Link
mg262
Clouded
mg262's Avatar
Request: CLI selection of VOB Cell ID
Would you consider adding a commandline option to specify a range of "VOB Cell IDs" to index?
I tend to rip the episodic DVDs I'm working on as .ISOs (to keep the originals safe), and in order to frameserve I have to (mount and) re-rip each episode as a separate VOB. Commandline selection of VOB Cell ID ranges would allow frameserving directly from the mounted .ISOs, saving a lot of hard disk space and substantially reducing the number of files that need to be managed.
Thanks very much!
M.
mg262 is offline   Reply With Quote
Old 4th July 2005, 04:59   #18  |  Link
I don't see DGIndex as a player. The play is there only for finding cut points and getting preview information. Therefore, optimized playback appears superfluous, especially without audio.
Old 4th July 2005, 05:01   #19  |  Link
That's not easy because all the indexing is done on the stream parsed as demuxing occurs, and that is not the M2V stream. It would require a lot of changes. You'll have to just index the M2V.
Old 4th July 2005, 05:02   #20  |  Link
Originally Posted by mg262
Would you consider adding a commandline option to specify a range of "VOB Cell IDs" to index?.
Yes, I'll consider it for 1.5.0.
