Go Back   Doom9's Forum > Capturing and Editing Video > NLE - Non Linear Editing
Old 17th November 2023, 00:40   #1  |  Link
ClubM
Pixelation transition without antialiasing
Hi everyone,
i'm looking for some advice to help me achieve this pixelation transition used in the 90s super mario bros 3 cartoon intro.
https://www.youtube.com/watch?v=iJLTLNqPy-M
I would like to remake the effect as close as possible.
The original art underneath the blocky effect probably looks similar to this:
But i wonder how the go from that to this:
It looks like the are zooming, stretching and squashing the footage slightly underneath.
But i can't wrap my head around how the averaged out the image into clean squares that still sorta represent the art.
Without making it look blurry / antialiased.
I was playing around with the Mosaic Blur filter in Davinci Resolve but my attempts don't look quite right.
Appreciate any tips or advice.
ClubM is offline   Reply With Quote
Old 17th November 2023, 02:57   #2  |  Link
poisondeathray
Animate a downscale (using something other than nearest neighbor) , upscale using nearest neighbor (this preservers the blockiness) . You can animate width and height asymetrically if you wanted to squash or stretch it
Old 17th November 2023, 12:27   #3  |  Link
ClubM
Thanks for the tip poisondeathray.
This helped tremendously with my restoration. Thank you so much!
