Old 1st November 2019, 21:29   #1  |  Link
crabshank
Manual_WP (C plugin - x64 only)
https://github.com/crabshank/Avisynth-filters
This filter allows you to fix the white balance of media by changing the white point of it using the appropriate Bradford transform and transfer functions for 11 (I could easily add more) colour spaces:
"mode" parameter:
0 (Default) - sRGB
1 - Rec. 601 NTSC
2 - Rec. 601 PAL
3 - Rec. 709
4 - Rec. 2020
5 - DCI-P3
6 - Display P3
7 - Orginal NTSC (47 CFR 73.682 - TV transmission standards)
8 - Rec. 601 D93 (Use for Japanese media)
9 - Rec. 709 D93 (Some Japanese media may use this)
10 - DCI-P3 (D60/ACES)
It allows you to enter the xy value directly or, much more easily, enter the RGB values (0-255/0-65535) that you wish to turn grey. It also allows you to enter a target white point for the final output ("dst_x" and "dst_y" - D65 is the default).
I also have a hlsl version of this for greater speed but the input is only RGB32.
crabshank is offline   Reply With Quote
Old 2nd November 2019, 00:39   #2  |  Link
qyot27
qyot27's Avatar
Pull request submitted. 64-bit only required making sure the build system could do it (I used CMake, because why not?), there were no actual code changes required. Encompasses both plugins, not just WhitePoint.
qyot27 is online now   Reply With Quote
Old 2nd November 2019, 01:45   #3  |  Link
crabshank
Thanks a lot, main thing now will be to compile yours (to .dlls) in Code::Blocks if possible.
Old 2nd November 2019, 11:21   #4  |  Link
Groucho2004
Originally Posted by crabshank View Post
I would like to make this x64 and speed it up, so if anyone can help, it would be much appreciated.
As for speeding it up - The bottleneck is most likely the nested loops that access array elements of type double in "functions_c.h". You could probably speed this up considerably by using compiler intrinsics.
Groucho's Avisynth Stuff
Old 14th July 2020, 20:39   #5  |  Link
crabshank
Major updates, see first post.
color correction, white balance, white point
