Go Back   Doom9's Forum > Capturing and Editing Video > NLE - Non Linear Editing
Old 16th May 2018, 09:58   #1  |  Link
LigH
LigH's Avatar
BlackMagic DaVinci Resolve: Last free version for Win7?
Current versions of DaVinci Resolve (14/15) appear to be incompatible with Windows 7 now, they use an API which requires at least Windows 8.1 or even 10 (with the result that "the procedure entry point DeleteCriticalSection could not be located in the dynamic link library api-ms-win-core-synch-l1-2-0.dll" under Windows 7, while this entry point exists in api-ms-win-core-synch-l1-1-0.dll).
An older version of Resolve may still work under Windows 7. But is there any known archive for them? The BlackMagic website offers only the latest free edition.
_
P.S.:
Let's try the VideoHelp Software archive... (just got reminded: a forum login is required to download from here)
New German Gleitz board
Old 16th May 2018, 10:29   #2  |  Link
smok3
brontosaurusrex
smok3's Avatar
Yeah, really a shame that they fail to mention that, I lost a lot of time trying to make it work, now the old version won't install properly either...
I do have 'DaVinci_Resolve_14.3_Windows.zip 2018-Feb-02 11:12:23 642.4M' on my disk, so let me know if you need that. edit: You have a link on your pm.
certain other member
smok3 is offline   Reply With Quote
Old 16th May 2018, 10:53   #3  |  Link
LigH
LigH's Avatar
No, thank you, as I said, v14.x may not be compatible to Win7 anymore, and VideoHelp has still a few v12.x, that will be tested.
Old 16th May 2018, 13:43   #4  |  Link
Google 'old version davinci resolve'
ie
https://www.google.com/search?client....0.eUoh62hkW5Q
first on list give link to this:- https://forum.blackmagicdesign.com/v...p?f=21&t=63752
which seems to answer your problem, (have not checked myself).
EDIT:
All Resolve installers are available in the Support section, just select the Resolve Product Family and scroll down (have no idea why nobody seems to think of that, but this question keeps coming up over and over :roll: ).
You can go back all the way to Resolve 10!
Old 16th May 2018, 14:06   #5  |  Link
LigH
LigH's Avatar
I will consider this after version 12.5.6 from the VideoHelp archive has been tested by the person who wants to use it (not me).
Old 16th May 2018, 14:15   #6  |  Link
smok3
brontosaurusrex
smok3's Avatar
14.3 was working fine on my win7 irc.
Old 16th May 2018, 14:34   #7  |  Link
LigH
LigH's Avatar
Then one would have to find the reason why your api-ms-win-core-synch-l1-2-0.dll was functionally equal to current ones built for Win10, possibly due to installing most recent MSVC or .NET runtimes.
Version 12.5.6 doesn't run stable on the PC it was installed to, doesn't recognize CUDA on a GeForce 9800, and crashes soon after the first dialogs, I was just told ... but that happens in a distance from me.
Old 16th May 2018, 22:48   #8  |  Link
In one of the (slightly) older Libre Office things, I get some message (maybe in Events, not sure where) that
the Office prog dont work on my system[XP32], however, I dont seem to have noticed any other problems.
Message came from some "api-ms-win-core-synch ... " style message.
Dont know if of any pertinence.
EDIT: Maybe was just testing if some sys option existed, dont know.
Old 17th May 2018, 07:33   #9  |  Link
LigH
LigH's Avatar
In one of the forums, a requirement of OpenCL 1.2 / CUDA 3.0 and 2 GB VRAM was reported; so v14 won't work with a GeForce 9800 anyway. Maybe some much older version...
Old 18th May 2018, 16:14   #10  |  Link
hajj_3
anyone reason why you can't use a different program or a new windows version?
Old 18th May 2018, 17:49   #11  |  Link
LigH
LigH's Avatar
I am not the user.
And yes, until a whole new PC gets affordable, the user I asked for may try other software; but he already learned about DaVinci's features, and wants to use them, so he knows he will need a new PC.
Old 18th May 2018, 17:49   #12  |  Link
If that was addressing me, then is because I dont want to.
(although I do use Win10 on a 10.1 inch tablet/laptop [not quite as bad as I expected it to be,
although updates are annoying and major updates keep breaking Auto Rotate, requiring a registry hack]).
Old 16th July 2019, 00:16   #13  |  Link
gispos
Old thread, but for information.
I use Davinci Resolve 16 on a Win7 PC
How is that possible? With a Sandbox (Sandboxie)
When installing, the sandbox denies Resolve's driver installation, leaving only the native features of Resolve.
Disadvantage: I think I can only open mp4 videos. It can not save h265 videos, even the h264 format is not fully usable when encoding.
Anyway, I just save DNxHR or ChineForm in the mov container and then convert that to h264 later.
But everything else works perfectly, graphics card is recognized and thus full CUDA or OpenCL support.
Live and let live
gispos is offline   Reply With Quote
Old 30th December 2019, 05:24   #14  |  Link
tyee
I also use Sandboxie and Win7 and have always wanted to try DaVinci but never tried because of all the posts mentioning problems. Now I'm tempted. Any special Sandboxie settings you used?
tyee is offline   Reply With Quote
Old 29th July 2020, 20:58   #15  |  Link
DRbackagain!
Just wanted to update this. I, too, am a Win7 user and also found that DaVinci Resolve became "broken" on my system after v.14.2. But I found this thread (some years later) and was enthused to try it. I grabbed the most recent Resolve (16.2.3) and Sandboxie (now released as freewqre) and gave it a go. First, I tried installing Resolve using SandBoxie. That didn't even allowed Resolve to finish installing. Wiped that clean and tried again, this time installing Resolve and then using Sandboxie to run it. That didn't work either. So I got rid of both.
Then, not wanting to give up, did more searching and came across this YouTube video - "How to run DaVinci Resolve on Windows 7 and 8? The procedure entry point DeleteCrytical... error" (https://www.youtube.com/watch?v=uX9Sjyw2-Jg). A few users had other problems (too weak hardware, too old video drivers and/or .DLL files), but for most it worked ... me included!
It's so simple. Just install Resolve. You must be online while doing this to allow Resolve to grab additional parts from Blackmagic Design. After installation, when you run it, you'll get an error message "Resolve.exe Entry Point Not Found -- The procedure enty point DeleteCriticalSection could not be located in the dynamic link library api-ms-win-core-syngh-l1-2-0.dll" and it will not run. The YouTube video tells you to find "opencl.dll" in the Resolve folder and rename it to "openncl.dll" (adding another "n" so the program will not find it). Run Resolve again and this time it will run (no error messages). That's it! Then it works!
The Blackmagic Design programmers really need a flogging for not fixing such a nonsensical code error, which prevents untold numbers of potential users from getting hooked on their software. Then again it is buggy software -- meaning you can't do anything you want. You must "learn" what it can do, and do only that. Anything else produces wrong results, or it crashes. (For "free" we can't complain too loudly, I guess.) *rolleyes*
DRbackagain! is offline   Reply With Quote
Old 29th July 2020, 21:03   #16  |  Link
Cary Knoop
Cary Knoop
Cary Knoop's Avatar
This is a self-created problem. Why still running windows 7, a version that is officially end-of-life?
It was released 11 years ago for crying out loud.
DaVinci Resolve is professional software, run it with the latest stable version of the OS.
This is surreal why would they want to support a past end-of-life platform?
The mistake is on people who get stuck in the past.
Cary Knoop is offline   Reply With Quote
Old 30th July 2020, 02:30   #17  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Yeah IMO it's entirely unreasonable to expect a vendor like BlackMagic Design to support Windows 7 for something like a modern NLE. Do you expect them to support XP still?
Professional content creation should be happening on modern, supported systems - if nothing else for security reasons. Bleeding edge Windows 10 release? No. The latest known stable and widely released version? Yes.
Feel free to keep using the old version, but you're on your own. You really can't fault BMD for deprecating support for such an old OS. It costs money to support old OSs due to QA requirements and probably a lot of crufty code to maintain. They decided it was no longer worth spending those resources, and that was a good decision.
Old 30th July 2020, 09:16   #18  |  Link
LigH
LigH's Avatar
@Cary Knoop:
Apropos "stuck in the past" ... this thread was started in 2018. In the meantime, the relevant person was able to spare enough money to afford a new PC. No more reason for blaming the poor.
Old 13th September 2020, 08:48   #19  |  Link
Ghitulescu
Ghitulescu's Avatar
The only real threat to an OS comes from internet.
The good old practice required that such systems, used for professional work, NEVER be in contact with internet (or infected media).
Born in the USB (not USA)
