Old 12th December 2021, 11:46   #7081  |  Link
Suggest untick "Always use the included avisynth", and separate install of Avisynth+,
X64 MeGUI requires x64 Avisynth and x64 plugins.
you'll also need the newer Avs+ avisynth wrapper.
https://forum.doom9.org/showthread.p...15#post1956915
Put your avsi in your system installed plugins, directory
Old 12th December 2021, 12:25   #7082  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by pooksahib View Post
The error is "There is no function named xxx".
That not help at all, please zip and attach the log file (see in MeGUI64/logs).
Let me put the question this way: Does MeGUI allow you to add your own avsi file (containing functions) to it's own version of avisynth?
Only if you have the same plugins 64 bits versions than in your 32 bits versions and you have correctly instaled the 2 Avs versions.
It is not a MeGUI problem it is related with your Avs instalation.
Old 13th December 2021, 14:00   #7083  |  Link
tebasuna51
tebasuna51's Avatar
@kedautinh12 off topic post moved to eac3to-wrapper in audio subforum
Old 13th December 2021, 20:47   #7084  |  Link
pooksahib
Hi. I've just started using MeGUI 64-bit/avisynth+ 64-bit. It's worked fine on a couple of mp4 videos.
I've just tried to load up an mpg clip (of a type that works fine with my x86 MeGUI) and after the index process has completed, the preview is telling me that the video is twice it's actual duration. There's a green frame after every actual frame. The MeGUI log is attached. Hopefully, someone can identify the problem. Many thanks.
Last edited by tebasuna51; 14th December 2021 at 15:04. Reason: Problem solved, attachement not needed
pooksahib is offline   Reply With Quote
Old 14th December 2021, 03:58   #7085  |  Link
Pooky,
Methinks there were problems on earlier non-official x64 DGDecode.dll from DGMPGDec package,
DG posted official one here:- http://rationalqm.us/dgmpgdec/dgmpgdec.html
Also, DGIndexNV now free [238] :- http://rationalqm.us/dgdecnv/binaries/
Old 14th December 2021, 05:55   #7086  |  Link
pooksahib
That works. Great stuff, StainlessS, many thanks.
Old 25th December 2021, 01:43   #7087  |  Link
kedautinh12
DGDecNV_238 (updated 22-01-10)
Changelog:
http://rationalqm.us/board/viewtopic...=463&start=300
Old 17th January 2022, 17:41   #7088  |  Link
videoh
Useful n00b
Originally Posted by kedautinh12 View Post
Build 239 was released this morning.
http://rationalqm.us/board/viewtopic.php?p=15215#p15215
Old 19th January 2022, 21:33   #7089  |  Link
Octo-puss
What happened to Zathor? Is MeGUI abandoned?
I haven't been here for a long time.
Octo-puss is offline   Reply With Quote
Old 19th January 2022, 21:52   #7090  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Looks like abandoned atm, Zathor doesn't have time for it anymore I guess.
VoodooFX is offline   Reply With Quote
Old 21st January 2022, 04:38   #7091  |  Link
kedautinh12
Need someone continue development it
Old 27th January 2022, 00:25   #7092  |  Link
kedautinh12
DGDecNV 239 (02/02/22)
--Simple workaround for the "not licensed for this machine" error until fixed in MeGUI
----https://forum.doom9.org/showthread.php?p=1958970#post1958970
-------https://sourceforge.net/p/megui/feature-requests/672/
FFmpeg-Builds-Win32 v5.0
https://github.com/sudo-nautilus/FFm...Win32/releases
FFmpeg-Builds-Win64 v5.0
https://github.com/BtbN/FFmpeg-Builds/releases
MKVToolNix v64.0.0
https://mkvtoolnix.download/windows/releases
MP4Box v1.1.0-DEV-rev1663-g881c6a94a
https://www.mediafire.com/file/x2ktr...GCC112.7z/file
Opus-tools v0.2-27-gb982c4c (using libopus 1.3.1-101-g66d060c7)
https://www.mediafire.com/file/u737m...GCC112.7z/file
x264 0.164.3085 0bb85e8
https://www.mediafire.com/file/638kf...GCC112.7z/file
Old 24th February 2022, 12:30   #7093  |  Link
kedautinh12
FLAC v1.3.4
https://www.mediafire.com/file/m84pj...GCC112.7z/file
x265 v3.5+35-287466181
https://www.mediafire.com/file/257hl...GCC112.7z/file
x265 Note : The commit value is wrong due to something upstream at MulticoreWare. I recall that something like this have happen earlier also.
Old 12th March 2022, 23:13   #7094  |  Link
disklib
Preview window not showing entire image
The AVS Script Creator preview window seems to be cropping the right side of the image frame.
I experienced this when I upgraded to MeGUI 2928 and DGIndex 2005+. I went down a rabbit hole trying to get the Index to work (fake license file/manual upgrade/enable NV version/etc) so my recollection of all the steps I took is a mess, but I can say I experienced the problem once I upgraded beyond MeGUI 2924 + DGIndex 2002. I just restored back to those versions and the crop preview is now correct.
The crop was about 6 pixels from the right edge, which in my case happened to correspond to the black pixels on that edge of the frame. When I encoded that the black pixels were included in the mp4. I confirmed the crop spinner was set to 0 in the Script Creator window. If I'm remembering correctly I think I tried clicking the right spinner up a few times (0 to 2 to 4 pixels) and surprisingly noticed no change to the preview image on that edge.
disklib is offline   Reply With Quote
Old 15th March 2022, 20:53   #7095  |  Link
Morku
Look at this beauty! The master returned <3
Morku is offline   Reply With Quote
Old 16th March 2022, 13:17   #7096  |  Link
kedautinh12
he just update that he was commited so long
Old 17th March 2022, 11:51   #7097  |  Link
Glarioo
Thank you very much for the update!
Glarioo is offline   Reply With Quote
Old 19th March 2022, 08:44   #7098  |  Link
Penecho
Does anyone else have an issue with muxing? It is throwing an error here (no matter if it is done automatically after encoding or manually by me via the tools --> muxer --> mp4 muxer)
[Error] Process exits with error: 0xC0000094 STATUS_INTEGER_DIVIDE_BY_ZERO (-1073741676)
And in the corresponding Folder there is a 0 byte file _libgpac_13980_0000021528ffa7b0_855_24584_0000021528ffa790
The line that it tries to execute: [Information] [19.03.2022 08:34:41] Job command line: "xxx\MeGUI_2153_x86\tools\mp4box\mp4box.exe" -add "myvideo.264#trackID=1:fps=23.976ar=1:1:name=" -add "myaudio.mp4#trackID=1:lang=eng:name=" -tmp "Folder" -new "file-muxed.mp4"
Edit: It is working with the exact command line when I download GPAC and start it out of C:\Program Files\GPAC\mp4box.exe... So I assume there are some files missing in the mp4box megui dir?
Penecho is offline   Reply With Quote
Old 19th March 2022, 11:48   #7099  |  Link
tebasuna51
tebasuna51's Avatar
I can confirm the bug with last MP4Box-2.1-DEV-rev15 update.
The same than Barough show in their last post (the text show rev18 but when download it is the rev15)
Old 19th March 2022, 12:38   #7100  |  Link
Barough
Barough's Avatar
I'll upload a new compile and make it available here during the weekend
Sent from my SM-S908B via Tapatalk
Do NOT re-post any of my Mediafire links. Download & re-host the content(s) if you want to share it somewhere else.
