Old 13th August 2018, 14:03   #6281  |  Link
Barough
Barough's Avatar
New x264
x264 0.157.2932 303c484 (32-bit GCC 7.3.0 / 64-bit GCC 8.2.0 8/10/12bit Multilib Windows Binaries)
Old 13th August 2018, 14:20   #6282  |  Link
LigH
LigH's Avatar
Indeed; you too, Baroughtus.
New German Gleitz board
Old 13th August 2018, 14:26   #6283  |  Link
Barough
Barough's Avatar
Sent from my SM-G965F via Tapatalk
Do NOT re-post any of my Mediafire links. Download & re-host the content(s) if you want to share it somewhere else.
Old 14th August 2018, 05:22   #6284  |  Link
imsrk48
imsrk48's Avatar
HD Stream Extractor Not Getting .ts in Extraction Process then how can i Pre-Clean .TS??
Originally Posted by Zathor View Post
Have you tried the suggestions found here?
https://forum.doom9.org/showthread.p...78#post1845778
In any case I need more details = your log file.
Sent from my P4 using Tapatalk
imsrk48 is offline   Reply With Quote
Old 20th August 2018, 13:34   #6285  |  Link
laurentje
Megui 64 bits hangs when coding small files
Situation:
Megui 64 bit (2872 Development Server-portable version) on Windows10.
I want to make a MKV from an image sequence. Only 10" total length.
On the main input tab, I introduce the name of the avs-file in the field "AviSynth Script".
It's this:
LoadPlugin("C:\programs\megui64\tools\avs\plugins\ImageSeq.dll")
ImageSource("C:\tmp\video\the_end\1920x1080fps50\%04d.png", 1, 500, 50)
ConvertToYV12(matrix="REC709")
In the field "Video Output" I changed the name of the output-file; field "Encoder settings": a preset crf 17 level4.2.
No audio. So I click on "Queue" in the "Video encoding frame".
I went to the "Queue tab" and I see now 2 jobs listed: x264-job + mux-job.
Click on "start". All goes well till nearly the end of the 1st job, no reaction of Megui. In windows I look in the log file it is this: see attachement "...10a.txt" and I see also at the last line "Job completed"... but Megui still hangs. With file manager I see also that the mkv is created and the .264-file deleted.
With Taskmanager I stopped Megui. Then I look into the log file: see attachment "...10b.txt". See the time jump in the log from 37:25 to 43:52 at the start of job2: the mux-job the moment I stopped Megui with Task manager.
When I restart Megui I see job 2 is waiting of execution.
I have tested Megui64b with other clips and the risk of hanging is about 14". So if my clip-length is longer than 14", I'ill use 32bit: with that version (2836) I have no problems with short clips.
My question is now: experience of others with Megui 64b and short clips?
laurentje is offline   Reply With Quote
Old 26th August 2018, 14:32   #6286  |  Link
Zetti
MKVToolNix v26.0.0 is released.
Zetti is offline   Reply With Quote
Old 27th August 2018, 14:04   #6287  |  Link
ryszardzonk
encoding using x265 regardless of encoder settings (even with defaults) does not work and fails right after recreating of lwi index file. Audio encoding on this file as well as encoding video with x264 works without any problems so no idea why would it complain about opening input file for x265.
SetMemoryMax(2048)
Import("C:\Software\Megui\tools\setmtmode.avsi")
LoadPlugin("C:\Software\Megui\tools\lsmash\LSMASHSource.dll")
LWLibavVideoSource("E:\kodowanie\20180826 2104 - TVP 2 HD - Wieden dla Kiepury.ts.lwi")
AudioDub(last, LWLibavAudioSource("E:\kodowanie\20180826 2104 - TVP 2 HD - Wieden dla Kiepury.ts.lwi", stream_index=1, av_sync=true))
Load_Stdcall_Plugin("C:\Software\Megui\tools\avisynth_plugin\yadifmod2.dll")
yadifmod2(order=-1)
crop(2, 2, -2, -2)
Spline16Resize(720,400) # Spline16 (Neutral)
Import("C:\Software\Megui\tools\denoise-min.avs")
Trim(7698, 82090)
Prefetch(8)
[Error] Log
-[Information] Versions
--[Information] MeGUI: 2872 x64
--[Information] Update Check: Disabled
--[Information] System Information
---[Information] Operating System: Windows 10 Pro 1803 x64 (10.0.17134.228)
---[Information] .NET Framework: 4.0 (4.0.0.0)
---[Information] .NET Framework: 4.7 (4.7.03056)
---[Information] Redistributables
----[Information] No redistributables found
---[Information] DPI: 100% (96/96)
---[Information] Monitor 1
----[Information] Resolution: 1280x960
----[Information] Primary Screen: True
--[Information] Component Information
---[Information] Haali Media Splitter: 1.13.138.14 (14-04-2013)
---[Information] Haali DSS2: (14-04-2013)
---[Information] ICSharpCode.SharpZipLib: 0.85.5.452 (07-08-2008)
---[Information] MediaInfo: 18.05.0.0 (08-05-2018)
---[Information] SevenZipSharp: 0.64.3890.29348 (02-01-2011)
---[Information] 7z: 9.20 (18-11-2010)
--[Information] AviSynth Information
---[Information] AviSynth Wrapper
----[Information] Version: 1.0.2847.0
----[Information] Date: 06-05-2018
----[Information] Interface: 3
----[Information] AviSynth Status: ignored as portable build is forced
---[Information] AviSynth portable
----[Information] File Version: 0.1
----[Information] File Date: 02-07-2018
----[Information] File Name: AviSynth+ 0.1 (r2728, MT, x86_64)
----[Information] File Path: c:\software\megui\avisynth.dll
----[Information] AviSynth Version: AviSynth+ 0.1 (r2728, MT, x86_64)
----[Information] AviSynth+: true
----[Information] AviSynth MT: true
----[Information] AviSynth Status: active
-[Information] Update detection
--[Information] [27.08.2018 14:55:43] Automatic update is disabled
--[Information] [27.08.2018 14:55:43] Using cached update config and server: http://megui.tmebi.de/test/
--[Information] [27.08.2018 14:55:43] No package requires an update
--[Information] [27.08.2018 14:55:44] redist files copied: 2017_x64
-[Error] Log for job1 (video, 20180826 2104 - TVP 2 HD - Wieden dla Kiepury.avs -> 20180826 2104 - TVP 2 HD - Wieden dla Kiepury.hevc)
--[Information] [27.08.2018 14:56:07] Started handling job
--[Information] [27.08.2018 14:56:07] Preprocessing
--[Information] [27.08.2018 14:56:07] AviSynth input script
---[NoImage] SetMemoryMax(2048)
---[NoImage] Import("C:\Software\Megui\tools\setmtmode.avsi")
---[NoImage] LoadPlugin("C:\Software\Megui\tools\lsmash\LSMASHSource.dll")
---[NoImage] LWLibavVideoSource("E:\kodowanie\20180826 2104 - TVP 2 HD - Wieden dla Kiepury.ts.lwi")
---[NoImage] #
---[NoImage] AudioDub(last, LWLibavAudioSource("E:\kodowanie\20180826 2104 - TVP 2 HD - Wieden dla Kiepury.ts.lwi", stream_index=1, av_sync=true))
---[NoImage] Load_Stdcall_Plugin("C:\Software\Megui\tools\avisynth_plugin\yadifmod2.dll")
---[NoImage] yadifmod2(order=-1)
---[NoImage] crop(2, 2, -2, -2)
---[NoImage] Spline16Resize(720,400) # Spline16 (Neutral)
---[NoImage] Import("C:\Software\Megui\tools\denoise-min.avs")
---[NoImage] Trim(7698, 82090)
---[NoImage] Prefetch(8)
--[Information] [27.08.2018 14:56:12] resolution: 720x400
--[Information] [27.08.2018 14:56:12] frame rate: 75070/3003
--[Information] [27.08.2018 14:56:12] frames: 74393
--[Information] [27.08.2018 14:56:12] length: 00:49:35.918
--[Information] [27.08.2018 14:56:12] aspect ratio: 9:5 (1.800)
--[Information] [27.08.2018 14:56:12] color space: I420
--[Information] [27.08.2018 14:56:13] Job command line: "cmd.exe" /c ""C:\Software\Megui\tools\ffmpeg\ffmpeg.exe" -loglevel level+error -i "E:\kodowanie\20180826 2104 - TVP 2 HD - Wieden dla Kiepury.avs" -strict -1 -f yuv4mpegpipe - | "C:\Software\Megui\tools\x265\x64\x265.exe" --sar 1:1 --output "E:\kodowanie\20180826 2104 - TVP 2 HD - Wieden dla Kiepury.hevc" --frames 74393 --y4m -"
--[Information] [27.08.2018 14:56:13] Process started
--[Information] [27.08.2018 14:56:13] Standard output stream
--[Error] [27.08.2018 14:56:13] Standard error stream
---[Error] [27.08.2018 14:56:20] x265 [error]: unable to open input file <->
--[Error] [27.08.2018 14:56:20] Process exits with error: 1
--[Information] [27.08.2018 14:56:20] Job completed
ryszardzonk is offline   Reply With Quote
Old 27th August 2018, 14:12   #6288  |  Link
LigH
LigH's Avatar
Sounds like this x265 build is unable to open a pipe as input when the input file name is "-"?
Old 27th August 2018, 16:51   #6289  |  Link
ryszardzonk
@LigH Anything can be done about it? I tried several different builds from https://builds.x265.eu/ with same result. Maybe it is MeGUI that feeds x265 wrong file location?
Old 27th August 2018, 18:38   #6290  |  Link
LigH
LigH's Avatar
There is no file location if x265 gets the video stream piped from ffmpeg. It only exists in the RAM (more or less).
Why don't you rely on the x265 shipped with MeGUI? Is there any reason to take it from any other distributor?
__
If you are able, try to execute the whole job command line inside "cmd.exe" /c "..." (what matches ...) in a separate command window. In your case:
Ahhh - wait, that may not work so easily. It won't have MeGUI's AviSynth environment.
Old 27th August 2018, 23:14   #6291  |  Link
ryszardzonk
I dodn't have any other x265 than that shipped by MeGUI. It actually worked just fine as I encoded about 200 videos using it, but I did not encode anything for several months. I updated MeGUI wth Ctrl+U and whoopsie something went south.
Old 28th August 2018, 10:53   #6292  |  Link
tebasuna51
tebasuna51's Avatar
The command line sintax work fine here.
Maybe the problem is in ffmpeg side than crash with this .avs and don't send the appropiate STDOUT to x265.
If previously work fine...
The last MeGUI change was ffmpeg to version 4.0.2, try recover the previous version from:
C:\Software\Megui\update_cache\_obsolete_ffmpeg-4.0-64.7z
BTW in your script there are a non-MeGUI standard avs call:
we can't know what happen with that.
When use that script to encode video (to be sended to x264/x265) please comment the AudioDub line:
#AudioDub(...)
Old 28th August 2018, 12:43   #6293  |  Link
ryszardzonk
To my suprise it is not downgrade of x265 not ffmpeg that helped, but changing MeGUI core to version 2855 (the previous one I had). Latest x265 with latest ffmpeg encodes now just fine.
As for AudioDub(...) it never really was the problem for thousands of encodes I did this way, although I realize for video part it is not required. It is simply faster that way to load one avs in main window as it would than show in both video and audio section.
I realized long time ago that setting denoise separately for each video or even having different avisynth profile for each video type is a bit error prone. Al my profiles have script that loads minimal denoise chain and if I need I simply change min to med/high/higher/highest. So my Import("C:\Software\Megui\tools\denoise-min.avs") actually loads file starting
LoadPlugin("C:\Software\Megui\tools\avisynth_extra\TTempSmooth\TTempSmooth.dll")
ttempsmooth()
LoadPlugin("C:\Software\Megui\tools\avisynth_extra\RgTools\RgTools.dll")
RemoveGrain(mode=1)
Old 28th August 2018, 16:21   #6294  |  Link
LouieChuckyMerry
LouieChuckyMerry's Avatar
I'm still using version 2855--I turned off automatic updates and manually update everything but the MeGUI core--because this is the last version before Zathor made the switch from avs4x26x to ffmpeg, which somehow wreaked havoc on my MeGUI setup. I never could figure out exactly why but it's OK because I'm plenty happy with the quality of my encodes regardless .
P.S.--Actually, the above makes me wonder, since x264 Encoder r2932 was recently released: how would I update the x264 encoder in version 2855, ie, what does MeGUI version 2855 use to encode 10 bit x264 video? More simply, which .exe in the "Tools" folder would I need to update? Thanks for any help.
LouieChuckyMerry is offline   Reply With Quote
Old 30th August 2018, 12:46   #6295  |  Link
hello_hello
Running an Xvid first pass results in an error (as opposed to an automated 2 pass). When the output selected is something other than RAWASP the following happens. Also, it's not possible to change the output location unless the encoder is configured for running something other than a first pass. I don't know if that's expected behavior.
Two jobs are added to the queue, implying an output video will be written and then remuxed by ffmpeg, but the second job fails as the output file doesn't exist.
--[Information] [30/08/18 9:34:48 PM] resolution: 640x480
--[Information] [30/08/18 9:34:48 PM] frame rate: 30000/1001
--[Information] [30/08/18 9:34:48 PM] frames: 1000
--[Information] [30/08/18 9:34:48 PM] length: 00:00:33.367
--[Information] [30/08/18 9:34:48 PM] aspect ratio: 4:3 (1.333)
--[Information] [30/08/18 9:34:48 PM] color space: YV12
--[Information] [30/08/18 9:34:48 PM] Job command line: "C:\Program Files\MeGUI\tools\xvid_encraw\xvid_encraw.exe" -i "D:\video.avs" -pass1 "D:\video.stats" -par 1
--[Information] [30/08/18 9:34:48 PM] Process started
--[Information] [30/08/18 9:34:48 PM] Standard output stream
---[Information] [30/08/18 9:34:51 PM] xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert
---[Information] [30/08/18 9:35:02 PM] Tot: enctime(ms) =5295.00, length(bytes) = 12638363
---[Information] [30/08/18 9:35:02 PM] Avg: enctime(ms) = 5.29, fps = 188.86, length(bytes) = 12638
---[Information] [30/08/18 9:35:02 PM] I frames: 6 frames, size = 33532/ 201192, quants = 2 / 2.00 / 2
---[Information] [30/08/18 9:35:02 PM] P frames: 406 frames, size = 24219/9833016, quants = 2 / 2.00 / 2
---[Information] [30/08/18 9:35:02 PM] B frames: 588 frames, size = 4428/2604155, quants = 4 / 4.00 / 4
--[Information] [30/08/18 9:34:48 PM] Standard error stream
---[Information] [30/08/18 9:35:02 PM] Trying to retrieve width and height from input header
---[Information] [30/08/18 9:35:02 PM] xvidcore build version: xvid-1.3.5
---[Information] [30/08/18 9:35:02 PM] Bitstream version: 1.3.5
---[Information] [30/08/18 9:35:02 PM] Detected CPU flags: ASM MMX MMXEXT SSE SSE2 SSE3 SSE41 TSC
---[Information] [30/08/18 9:35:02 PM] Detected 4 cpus, using 4 threads.
--[Information] [30/08/18 9:35:02 PM] Postprocessing
--[Information] [30/08/18 9:35:02 PM] Job completed
-[Error] Log for job2 (mux, video.m4v -> video.mkv)
--[Information] [30/08/18 9:35:02 PM] Started handling job
--[Information] [30/08/18 9:35:02 PM] Preprocessing
--[Error] [30/08/18 9:35:02 PM] Error starting job
---[Error] [30/08/18 9:35:02 PM] Exception message: Calling setup of processor failed with error 'Required file 'D:\video.m4v' is missing.'
---[Error] [30/08/18 9:35:02 PM] Stacktrace: at MeGUI.core.gui.JobWorker.startEncoding(TaggedJob job)
---[Error] [30/08/18 9:35:02 PM] Inner exception: null
Old 31st August 2018, 20:59   #6296  |  Link
Zetti
MediaInfo v18.08 is released.
Old 4th September 2018, 16:06   #6297  |  Link
Zetti
xy-VSFilter / XySubFilter v3.1.0.801 is released by pinterf
https://forum.doom9.org/showthread.p...00#post1850600
https://github.com/pinterf/xy-VSFilt.../tag/3.1.0.801
Old 7th September 2018, 09:44   #6298  |  Link
LigH
LigH's Avatar
When DirectShowSource is enabled, opening anything except AVIs (which displays a choice with 3 buttons, the rightmost is "AviSource") makes MeGUI crash in module StackHash_2264 for me.
Both VirtualDub2 in 32 and 64 bit can open the default DSS script via AviSynth+ MT r2728 and LAV Filters 0.72, so I would doubt the reason for the crash is in my DirectShow installation.
Preliminary log file only. During closing of MeGUI the well formed log file will be written.
--[Information] MeGUI: 2872 x86
--[Information] Update Check: development update server
-[Information] Operating System: Windows 7 Professional x64 SP1 (6.1.65536.7601)
-[Information] .NET Framework: 4.7 (4.7.03062)
-[Information] Microsoft Visual C++ 2008 x86:  9.0.21022
-[Information] Microsoft Visual C++ 2010 x64:  10.0.40219
-[Information] Microsoft Visual C++ 2010 x86:  10.0.40219
-[Information] Microsoft Visual C++ 2012 x64:  11.0.61030
-[Information] Microsoft Visual C++ 2012 x86:  11.0.61030
-[Information] Microsoft Visual C++ 2013 x64:  12.0.40660
-[Information] Microsoft Visual C++ 2013 x86:  12.0.40660
-[Information] Microsoft Visual C++ 2017 x64:  14.14.26405
-[Information] Microsoft Visual C++ 2017 x86:  14.14.26405
-[Information] Resolution: 1920x1200
-[Information] Haali Media Splitter: not installed
-[Information] Haali DSS2: not installed
--[Information] [07.09.2018 10:33:33] Using cached update config and server: http://megui.org/auto/
-[Information] File Name: AviSynth+ 0.1 (r2728, MT, i386)
-[Information] File Path: c:\windows\system32\avisynth.dll
-[Information] AviSynth Version: AviSynth+ 0.1 (r2728, MT, i386)
--[Information] [07.09.2018 10:33:33] No package requires an update
-[Information] MediaInfoWrapper
-[Information] [07.09.2018 10:33:50] File: H:\Video\Test\example.ts
--[Information] sessions open: 1, id: 392232
-[Information] [07.09.2018 10:33:51] File: H:\Video\Test\example.ts
--[Information] sessions open: 0, id: 392232, close: True
-[Information] AviSynthWrapper
-[Information] [07.09.2018 10:33:51] Script: DirectShowSource("H:\Video\Test\example.ts", audio=false)
--[Information] sessions open: 1, id: 99936
Right before the crash, I believe to spot a small dialog flashing, possibly the size of the input choice.
Old 8th September 2018, 14:06   #6299  |  Link
thecrowler
MediaInfo.dll (x64) v18.08 causes an unhandled error
#Bug - MediaInfo.dll (x64) v18.08 causes an unhandled error in HD Stream Extractor (MeGUI 2872 x64).
Everything works fine with the old 18.05 MediaInfo.dll x64 (using "obsolete_mediainfo-18.05-64.7z" from "update_cache" folder).
thecrowler is offline   Reply With Quote
Old 8th September 2018, 17:42   #6300  |  Link
tuanden0
Sorry for dumb question but why meGUI using ffmpeg to pipe instead of avs4x26x?
tuanden0 is offline   Reply With Quote
