Old 19th August 2016, 16:50   #14501  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
show me content of Blu-Ray_structure_info.txt and Blu-Ray_title1_info.txt
Old 20th August 2016, 04:12   #14502  |  Link
Grayfox
eac3to v3.31
command line: "I:\RipBot264v1.19.3\Tools\eac3to\eac3to.exe"  "E:\" -log="I:\Temp\RipBot264temp\job2\Blu-Ray_structure_info.txt"
1) 00001.mpls, 00001.m2ts+00002.m2ts, 2:23:11
   - Chapters, 16 chapters
   - h264/AVC, 1080p24 /1.001 (16:9)
   - RAW/PCM, English, multi-channel, 48kHz
   - AC3, English, multi-channel, 48kHz
   - DTS, French, multi-channel, 48kHz
   - AC3, French, multi-channel, 48kHz
   - DTS, Spanish, multi-channel, 48kHz
   - AC3, Spanish, multi-channel, 48kHz
2) 00020.mpls, 00021.m2ts, 0:51:49
   - Chapters, 43 chapters
   - h264/AVC, 1080i60 /1.001 (16:9)
   - AC3, French, stereo, 48kHz
   - AC3, Spanish, stereo, 48kHz
Blu-Ray_title1_info
eac3to v3.31
command line: "I:\RipBot264v1.19.3\Tools\eac3to\eac3to.exe"  "E:\" 1) -log="I:\Temp\RipBot264temp\job2\Blu-Ray_title1_info.txt"
The program type (4352) changes from video to audio.  <ERROR>
The format of the source file could not be detected.  <ERROR>
File Type: txt Blu-Ray_structure_info.txt (796 Bytes, 32 views)
File Type: txt Blu-Ray_title1_info.txt (349 Bytes, 25 views)
Grayfox is offline   Reply With Quote
Old 21st August 2016, 12:43   #14503  |  Link
fatpizza
Originally Posted by FuzzyNutz View Post
I'm getting the error "avs2avi.exe has stopped working" with VC-1 sources.
I've uninstalled and reinstalled ffdshow, AviSynth and Haali Media Splitter with a reboot in between and reinstalled Ripbot264.
ffdshow video decoder is set to wmv9 for VC-1.
I'm running Windows 10 Pro 64bit with Windows Media Player 12.
Can anyone help? Thanks.
I always have those issues with VC1 unless I set the decoder to intel quicksync in ffdshow. Solves all my problems.
fatpizza is offline   Reply With Quote
Old 21st August 2016, 13:04   #14504  |  Link
wraith
Error: The file 'D:\Temp\RipBot264temp\video.265' could not be opened for reading: op
Hi All. Noob to Ripbot, trying to take advantage of the Distributed Encoding feature.
So far I’ve been unable to get an encode to continue past the window with the text at the bottom declaring “Please Wait… Copying tools to shared folder…” Shortly after this window appears, it drops back to the main window. The last line in the log file says:
Error: The file 'D:\Temp\RipBot264temp\video.265' could not be opened for reading: open file error.
I’ve searched the forum and google and have come across a couple posts that raise the same issue with the video.264 file. Taking into account the RipBot264 Distributed Encoding Tutorial and the few posts I’ve found, I’ve:
• Setup RipBot264 to run as Administrator
• Set the necessary flags in RipBot264.ini
• Set Temp to D:\TEMP [only folder designation that seems to work]
• Shared the D:\TEMP\RIPBOT264TEMP directory and confirmed can be accessed from other Server computers on the same network
Despite the above, I still get the error.
Greatly appreciate any assistance on resolving this
OS: Windows 7 SP1 64-bit
NETWORK: Windows
HARDWARE: Intel i7-950; 6.0Gb RAM
SOFTWARE: RipBot v1.19.4; AVISynth v2.6.0.6; FFDShow v1.3.4532.0; Haali Media Splitter v1.13.138.14; Java v8 Update 101
wraith is offline   Reply With Quote
Old 21st August 2016, 17:53   #14505  |  Link
FuzzyNutz
How? My VC-1 decoder choices for ffdshow are 'libavcodec' or 'wmv9'.
FuzzyNutz is offline   Reply With Quote
Old 21st August 2016, 18:40   #14506  |  Link
Atak_Snajpera
Record your desktop with fraps or similar software and upload on youtube or somewhere. This will help me to understand what is happening on your pc.
Old 21st August 2016, 18:43   #14507  |  Link
Atak_Snajpera
eac3to v3.31
Blu-Ray_title1_info
eac3to v3.31
Are you sure that your movie has been correctly decrypted? Can you play that playlist 00001 in MPC-HC?
Can you also show me mediainfo reports of 00001.m2ts and 00002.m2ts ?
Old 21st August 2016, 23:19   #14508  |  Link
FuzzyNutz
VC-1 Encoding Resolved
I reinstalled ffdshow using a modified version that allowed me to pick Intel's QuickSync for VC-1 decoding and I enabled my CPU's integrated graphics via BIOS configuration. VC-1 encoding is now working. Thank you, fatpizza.
It seems each time I open Ripbot264, the ffdshow encoder for VC-1 changes back to 'wmv9'. I have to change it to QuickSync after opening Ripbot264 when dealing with VC-1.
Old 22nd August 2016, 00:13   #14509  |  Link
fatpizza
I have to do it every time I reboot which is annoying. But at least it works.
Old 22nd August 2016, 00:37   #14510  |  Link
FuzzyNutz
Thanks again.
Old 22nd August 2016, 10:49   #14511  |  Link
Grayfox
Movie plays fine when decrypted when double clicking on index.bdmv or double clicking on 00001.m2ts , I decrypted it it twice just in case.
00001.m2ts media info
General
Complete name               : E:\BDMV\STREAM\00001.m2ts
CompleteName_Last           : E:\BDMV\STREAM\00050.m2ts
Format                      : BDAV
Format/Info                 : Blu-ray Video
File size                   : 40.8 GiB
Duration                    : 3 s 968 ms
Overall bit rate mode       : Variable
Overall bit rate            : 88.3 Gb/s
Maximum Overall bit rate    : 48.0 Mb/s
Video
Menu ID                     : 1 (0x1)
Format                      : AVC
Format/Info                 : Advanced Video Codec
Format profile              : High@L4.1
Format settings, CABAC      : Yes
Format settings, ReFrames   : 3 frames
Codec ID                    : 27
Duration                    : 4 s 4 ms
Bit rate                    : 84.8 Gb/s
Width                       : 1 920 pixels
Height                      : 1 080 pixels
Display aspect ratio        : 16:9
Frame rate                  : 23.976 (24000/1001) FPS
Color space                 : YUV
Chroma subsampling          : 4:2:0
Bit depth                   : 8 bits
Scan type                   : Progressive
Bits/(Pixel*Frame)          : 1704.834
Stream size                 : 39.5 GiB (97%)
Audio #1
Menu ID                     : 1 (0x1)
Format                      : PCM
Format settings, Endianness : Big
Format settings, Sign       : Signed
Muxing mode                 : Blu-ray
Codec ID                    : 128
Bit rate mode               : Constant
Bit rate                    : 4 608 kb/s
Channel(s)                  : 6 channels
Channel positions           : Front: L C R, Side: L R, LFE
Sampling rate               : 48.0 kHz
Bit depth                   : 16 bits
Delay relative to video     : -1 ms
Stream size                 : 2.18 MiB (0%)
Audio #2
Menu ID                     : 1 (0x1)
Format                      : AC-3
Format/Info                 : Audio Coding 3
Mode extension              : CM (complete main)
Codec ID                    : 129
Bit rate                    : 640 kb/s
Frame rate                  : 31.250 FPS (1536 spf)
Compression mode            : Lossy
Delay relative to video     : -9 ms
Stream size                 : 310 KiB (0%)
Audio #3
Menu ID                     : 1 (0x1)
Format                      : DTS
Format/Info                 : Digital Theater Systems
Format profile              : ES Matrix / Core
Mode                        : 16
Codec ID                    : 130
Bit rate                    : 1 509 kb/s
Channel(s)                  : 7 channels / 6 channels
Channel positions           : Front: L C R, Side: L R, Back: C, LFE / Front: L C R, Side: L R, LFE
Frame rate                  : 93.750 FPS (512 spf)
Bit depth                   : 24 bits
Stream size                 : 731 KiB (0%)
Audio #4
Menu ID                     : 1 (0x1)
Format                      : AC-3
Codec ID                    : 129
Bit rate                    : 640 kb/s
Audio #5
Menu ID                     : 1 (0x1)
Format                      : DTS
Mode                        : 16
Codec ID                    : 130
Bit depth                   : 24 bits
Audio #6
Menu ID                     : 1 (0x1)
Format                      : AC-3
Codec ID                    : 129
Bit rate                    : 640 kb/s
Text #1
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Text #2
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Text #3
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Delay relative to video     : 8 s 342 ms
Text #4
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Text #5
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Text #6
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Text #7
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Text #8
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Delay relative to video     : 9 s 801 ms
Text #9
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Text #10
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Text #11
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Text #12
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Text #13
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Text #14
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Text #15
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Old 22nd August 2016, 10:50   #14512  |  Link
Grayfox
Hit the 16,000 char limit so split post into 2.
00002.m2ts media info
General
Complete name               : E:\BDMV\STREAM\00002.m2ts
Format                      : BDAV
File size                   : 8.93 GiB
Overall bit rate            : 19.3 Gb/s
Video
Menu ID                     : 1 (0x1)
Format                      : AVC
Format settings, ReFrames   : 2 frames
Codec ID                    : 27
Duration                    : 4 s 54 ms
Bit rate                    : 18.6 Gb/s
Color space                 : YUV
Bit depth                   : 8 bits
Bits/(Pixel*Frame)          : 373.426
Stream size                 : 8.74 GiB (98%)
Audio #1
Menu ID                     : 1 (0x1)
Format                      : AC-3
Codec ID                    : 129
Bit rate                    : 640 kb/s
Audio #2
Menu ID                     : 1 (0x1)
Format                      : AC-3
Codec ID                    : 129
Bit rate                    : 640 kb/s
Audio #3
Menu ID                     : 1 (0x1)
Format                      : AC-3
Codec ID                    : 129
Bit rate                    : 640 kb/s
Audio #4
Menu ID                     : 1 (0x1)
Format                      : AC-3
Codec ID                    : 129
Bit rate                    : 640 kb/s
Audio #5
Menu ID                     : 1 (0x1)
Format                      : AC-3
Codec ID                    : 129
Bit rate                    : 640 kb/s
Audio #6
Menu ID                     : 1 (0x1)
Format                      : AC-3
Codec ID                    : 129
Bit rate                    : 640 kb/s
Text #1
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Text #2
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Text #3
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Text #4
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Text #5
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Text #6
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Text #7
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Text #8
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Text #9
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Text #10
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Text #11
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Text #12
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Text #13
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Text #14
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Text #15
Menu ID                     : 1 (0x1)
Format                      : PGS
Codec ID                    : 144
Old 22nd August 2016, 13:16   #14513  |  Link
Atak_Snajpera
@Grafox
This is what I suspected.
Audio 1 in first file is PCM while in second file is AC-3.
I'm afraid you will have to manually separate those streams in some Eac3toGUI or in MKVToolnix.
Old 22nd August 2016, 14:08   #14514  |  Link
wraith
Hi. I've saved a couple videos [due to Fraps 30sec limitation] to here: https://1drv.ms/f/s!Aszu1bOAzXDajgMAgzV9w6eDDWjK.
The first video is the initial setup [copy video to temp directory etc]. The second video is copy the shared files etc. It "crashes out" just after the video stops
NETWORK: Windows
Old 22nd August 2016, 16:49   #14515  |  Link
Atak_Snajpera
Do not press manually ON button. (I'm even surprised that you are actually able to do that because on my machine it is impossible). Encoding client will connect with specified servers automatically.
Old 23rd August 2016, 00:02   #14516  |  Link
wraith
Noted
FYI - the error occurs regardless whether I manually click the 'ON' button or not
NETWORK: Windows
Old 23rd August 2016, 13:40   #14517  |  Link
Atak_Snajpera
Noted
Use this version of EncodingClient.exe and show me error message in EncodingClient_crash_message.txt
Old 24th August 2016, 13:19   #14518  |  Link
wraith
Downloaded the above file into the RipBot directory. The program continues to crashes out. No EncodingClient_crash_message.txt can be found in either the job1 folder or the Ripbot folder. Should I be looking somewhere else?
If it helps, the contents of job1_log.txt follows:
D:\>"D:\Ripbot\EncodingClient.exe" "D:\Temp\RipBot264temp\job1\job1_EncodingClient.meta"
D:\>"D:\Ripbot\tools\mkvtoolnix\mkvmerge.exe" -o "D:\Trial.mkv" --compression 0:none --title "Trial" --default-duration 0:24000/1001fps  "D:\Temp\RipBot264temp\video.265" --compression 0:none --language 0:eng --sync 0:0 "D:\Temp\RipBot264temp\job1\1_audio_English.ac3"  --chapters "D:\Temp\RipBot264temp\job1\chapters.txt"
mkvmerge v9.3.1 ('Mask Machine') 32bit
Elapsed Time: 00h:00m:30s
Incidentally, the first file I tried was a small 2Gb H265 video. I ripped a small 300Mb+ file using MakeMKV and tried that. Still the same issue.
NETWORK: Windows
Old 25th August 2016, 18:26   #14519  |  Link
stasi
Hey Atak.
Drag and Drop into RipBot window would be nice. Any plans for that?
stasi is offline   Reply With Quote
Old 25th August 2016, 23:04   #14520  |  Link
wraith
Hi Atak,
Tried the EncodingClient provided. Still crashed and no .txt file was created. Not that I could find in the job1 or Ripbot folder.
I created a more detailed reply but this has not made it to the forum, for some reason. I can only assume it's been flagged for review [I tried to re-create the post, via copy and paste, and I was informed it was a duplicate]
NETWORK: Windows
