23rd March 2010, 14:14 | #281 | Link |
Coder
This disc is really a mess, it's a miracle it can work at all.
Invalid commands, missing buttons, meaningless code, etc. I try to handle all of this abnormal thing and make my code fool-proof... The fix coming soon. |
23rd March 2010, 15:47 | #282 | Link |
Coder
New version v0.24b1
The fix is available.
For your better understanding I'm trying to explain now what happen in the Menu page. When you first press the Start button the program checks all the buttons and decides which one can be displayed ('valid'). The process: 1. check the BOGs 1.1 if a BOG has a default valid button value which is not $ffff then this button (if exists) in this BOG is valid 2. display all the valid buttons 3. find the 'selected' button 3.1 if the page has a default selected button (<$ffff) then bingo 3.2 if not, check all the valid buttons and if its auto action flag is Yes then run the commands of this button (usually there is a SetButtonPage command which set the 'selected' button) 4. display the selected button 5. if the selected button's auto action flag is Yes then run its commands If everything went fine you can see the page now. The navigation buttons do the following: U: If there is a selected button and this selected button's 'upper' field has a value which is not the same as the buttons own id then this will be the new 'selected' button D: If there is a selected button and this selected button's 'lower' field has a value which is not the same as the buttons own id then this will be the new 'selected' button L: If there is a selected button and this selected button's 'left' field has a value which is not the same as the buttons own id then this will be the new 'selected' button R: If there is a selected button and this selected button's 'right' field has a value which is not the same as the buttons own id then this will be the new 'selected' button If you press the 'Sel' button then the selected button's commands will run If no selected button or the selected button has the same button id in these fields then you cannot navigate crl2007: In your example I can use the audio settings if I preset the PSR1, PSR2, PSR4, GPR1001, GPR1002 in the right time, but it's too difficult to explain all the things you have to do You can find another disc which is properly authored. 'Unfortunately' I've tested BDedit with Ice Age II which is a perfect work there is no even one unnecessary command, you have to preset the PSR1 value for the audio menu or the PSR5 for the chapter menu and everything work well without any trace. (Sorry for my English) Last edited by Pelican9; 23rd March 2010 at 16:05. |
23rd March 2010, 17:13 | #283 | Link |
Still an access violation error. This disc starts to annoy me. As I told you, I can give you access through Teamviewer to see everything this disc has to "offer". I'm not such a computer geek, but even I can see that there are some invalid commands.
23rd March 2010, 17:45 | #284 | Link | |
Coder
What title is this anyway? My internet access is very limited (D:20kB/s, U:2kB/s) so I can't use that Teamviewer option but thanks. |
23rd March 2010, 18:22 | #285 | Link |
Programmer (or just 教务长)
I often get access_violation errors with BDedit. 100% of the cases I get such errors it turns out to be mpls/clpi/bdmv which is either broken (I brake it ) or does not conform the standards. That's been since the 1st version, so I would not worry about such things
Dean |
25th March 2010, 23:19 | #290 | Link |
Coder
New version v0.25b
Changes for v0.25
- View/Edit/Save sound.bdmv (Delete/Play sound, Save/Load sound to/from .wav file) - Delete, View, Load, Save ExtensionData() from/to sound.bdmv - Menu page view can play button sound on selected and activated states - Double click on s.sound or a.sound fields of Button table plays the selected sound |
26th March 2010, 19:10 | #291 | Link |
NY Frame of Mind
@pelican, I just upgraded tp v25 and every rime I start the program, it says "unregistered" and defaults to the "donation" tab and has a short countdown until the main screen appears.
How to "register" or bypass that startup? Thanks
"Talk to me Goose" |
26th March 2010, 19:21 | #292 | Link | |
Link.
26th March 2010, 22:05 | #296 | Link |
Coder
New version v0.26b
There is a new snapshot on my site.
Changes for v0.26 - Save program list (MovieObject commands) - One-click version update - Internet access has rewritten to a separate thread - One Effect tab instead of InEffects and OutEffects - Bug fixes (including transparency and cropping issues) dean: You support BDedit like your own software... Last edited by Pelican9; 31st March 2010 at 16:37. |
31st March 2010, 16:36 | #297 | Link |
Coder
New version v0.27b
Changes for v0.27
- Insert/Delete object updates the Title's object_id references - Save program in binary format (MovieObject commands) - Edit fields of PlayItems - IN time value change can update OUT time value, SubPlayItem IN/OUT time values and PlayListMark mark time values - Edit fields of SubPlayItem - Edit fields of Button commands - Reset registers can fill up the PSRs with 'real' values (instead of standard initial values) - New Commands Table (invalid and forbidden opcodes with different colors) - Bug fixes Done. Last edited by Pelican9; 31st March 2010 at 16:44. |
1st April 2010, 05:17 | #299 | Link |
NY Frame of Mind
I'm having trouble with what should be a simple task. I want to remove the FBI warning.
From the op : Code:
For example you want to remove the FBI warning before the main movie. Play the m2ts files, to find the unwanted clip (the warning, PG, etc.). If you found click to Find. It will give you a list of the Items using this clip. Switch to the PLAYLIST tab, select the listed PlayList and Click the Find button here. It will give you a list, which movie object's command plays this PlayList. Switch to the BDMV tab, select the listed object and command and press Shift-N. It will change the command to NOP (do nothing). Follow these steps until you delete all occurrences. However, clicking the "find" button doesn't give any further info re which movie object's commands apply so I don't know what to do on the BDMV tab to change a command . Find button results : Code:
00003.m2ts found in: 00003.mpls , PlayItem 000 PlayList 00018 found in:
1st April 2010, 13:18 | #300 | Link | |
Coder
Is it right? Switch to the PLAYLIST tab select the 00003.mpls and click to Find. |
bd menu, bdedit, blu-ray |
