Old 19th March 2024, 16:36   #1  |  Link
groucho86
Help making eedi3m aarch64 compatible
Hoping someone is able to find a way to make eedi3m work on M1/M2/M3 Macs:
https://github.com/HomeOfVapourSynth...ourSynth-EEDI3
The plugin uses x86-specific optimization via vectorclass, causing compilation to fail on aarch64.
sse2neon sounds like an option (albeit sub-optimal. cf: https://github.com/vapoursynth/vapoursynth/issues/516 )
groucho86 is offline   Reply With Quote
Old 19th March 2024, 17:58   #2  |  Link
Julek
Julek's Avatar
I'm currently rewriting the plugin in Zig, so it will be possible to do a native aarch64 build.
But as I'm also changing the way processing is done (horizontal enlargement by default) to avoid temporary copies and gain a little performance, it's taking me a while to figure out what needs to be changed.
CPU: AMD 3700X | GPU: RTX 3070Ti | RAM: 32GB 3200MHz
GitHub
Julek is offline   Reply With Quote
Old 21st March 2024, 22:36   #3  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
Bit of an aside, but are you willing and able to test plugins on Mac aarch64, groucho?
Similar to Julek, Iím also developing plugins in Zig, but I donít have a Mac M1/2/3 to test things on.
Old 22nd March 2024, 04:09   #4  |  Link
groucho86
Yes I have an M2. Limited free time/availability but happy to help the community as much as possible.
eedi3m arm aarch64 mac
