#19981 | Link |
[Status]
LABEL=LLUVIA_DOS VERSION=v0.47.04 (beta) SOURCE_SIZE=24836591616 SOURCE_VIDEO_SIZE=24836591616 TARGET_SIZE=49666850816 REDUCTION=1.99974503683525 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=0 SUBS_TO_KEEP=all BACKUP_MODE=1 MOVIEONLY_TYPE=0 USE_LAVF=0 INSTANCES=1 DGDECNV=0 FRIMSOURCE=0 SSIF_MODE=-1 QUICK=0 ENCODE_STEP=0 COMPLETED=1 REBUILD_COMPLETE=1 [00000] USE_ORIGINAL=1 AUDIO=1 PGS=1010 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=49666850816 NSIZE=0 FLINK=0 MLINK=0 04/09/14] BD Rebuilder v0.47.04 (beta) [22:19:28] Source: LLUVIA_DOS_00000 - Input BD size: 23,13 GB - Approximate total content: [01:34:50.684] - Target BD size: 46,26 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Quality: Good (Very Fast), ABR - MVC 3D Output Mode enabled - Decoding/Frame serving: FRIMDecode - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [22:19:28] PHASE ONE, Encoding - [22:19:28] Processing: VID_00000 (1 of 1) - [22:19:28] Extracting A/V streams [VID_00000] - [22:32:00] Reencoding video [VID_00000] - [22:32:01] Keeping original video (no reencode) - [22:32:01] Processing audio tracks - Track 4352 (spa): Keeping original audio [22:32:01]PHASE ONE complete [22:32:01]PHASE TWO - Rebuild Started - [22:32:01] Rebuilding BD-3D file Structure [22:52:34] - Encode and Rebuild complete [22:52:34] JOB: LLUVIA_DOS finished. - [22:58:25] BuildTreeList() 35602 2702 |
#19982 | Link | |
![]() Join Date: Oct 2001
AVATAR 3D is one of the test discs I am using, and it plays correctly in 3D after reencoding, even on PDVD11, on my system.
jdobbs.softworks@gmail.com Last edited by jdobbs; 10th April 2014 at 14:42. |
#19983 | Link |
@montana72
The error you are getting is really weird. It is saying there is a problem when it is trying to build the display list. That shouldn't even be happening except when the program is loading or you are selecting a new source. That makes me think the computer had a major system problem at that point.
jdobbs.softworks@gmail.com |
#19984 | Link | |
Mr
#19985 | Link |
It has to in order to legally call itself a BD-3D player. Support for that format is required as a part of the BD standard. There are also numerous commercial discs out there (AVATAR is an example) that use it, albeit usually for smaller playlists. Give me more information and lets see if there is something that needs correcting. There's a lot of new code that was created for 3D support.
jdobbs.softworks@gmail.com Last edited by jdobbs; 11th April 2014 at 14:48. |
#19986 | Link | |
Mr
Some of the titles I tried are: Alice in Wonderland GI Joe - Retaliation Avatar Journey to the Center of the Earth The stream folder in all of these originals include an SSIF subfolder. Unless you have a Dune 3D player, I'm not sure how you would figure out what is happening (or, for that matter, even if you did have one unless you had the firmware source to work with). Last edited by jdobbs; 11th April 2014 at 14:48. |
#19987 | Link |
idk what to do :/
- AVISYNTH Version: 2.5.8.0, not recommended version - HAALI Splitter: Ok - FFDSHOW: 4530, not recommended version - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - BD-RB vUNKNOWN, not current scratching my head on this one. i have uninstalled bd and the other three programs many times over. i have been using this software for years now and have never encountered this problem. |
#19988 | Link |
I think these newer network media players with 3D playback don't actually carry a Bluray-license or logo. They have some 3D capabilities (MVC support listed in the specs). Probably as a consequence of that the ones I've researched (Mede8er, Himedia) don't support Java menus (only "Lite"-menus without Java). That's why I'm holding off on buying one.
#19989 | Link | |
Mr
#19990 | Link | |
jdobbs.softworks@gmail.com Last edited by jdobbs; 11th April 2014 at 15:41. |
#19991 | Link |
I'm sorry. But the software is called "BD" Rebuilder after all. Have you tried playing the M2TS file by itself?
#19992 | Link |
yes i was using inspect.. i did not realize it was part of the program itself now. the reason i posted that is because when i export an mkv and then rencode it back to bluray format the audio is not sync with the film.
#19993 | Link |
Hmmm... I'll try a couple of movies and see if I get the same results. Has it happened on more than one?
#19995 | Link | |
It's interesting that it wouldn't play. The in-mux M2TS is exactly the same thing as a .ssif file. What version of BD-RB did you use to create it?
#19996 | Link | |
Mr
Here are the INI and INF files for the build: Is there something there I should change? .INI Code:
[Options] DTSX_ENABLE=1 MODE=0 ENCODE_QUALITY=3 AUTO_QUALITY=0 TARGET_SIZE=23500 PRIORITY_CLASS=1 AUDIO_TO_KEEP=all SUBS_TO_KEEP=all SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 DEINTERLACE=1 SD_TO_1080=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=0 AC3_192=0 KEEP_HD_AUDIO=1 AVCHD=1 REMOVE_WORKFILES=1 MOVIE_ONLY_LOOP=0 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 USE_LAVF=0 IVTC_PULLDOWN=1 ASSUME_DVD_PAL=0 UNMASK_CHAPTER=1 COMPLETION_BEEP=0 AUDIO_TRACK_LIMIT=0 VERSION=0.47.0.4 CUSTOM_TARGET_SIZE=12000 RESIZE_1440=0 DGDECNV=0 OUTPUT_3D=1 SUBTITLE_TRACK_LIMIT=0 ENABLE_TEST=1 ENABLE_BLANKING=0 MULTIPROCESS=1 MOVIEONLY_TYPE=10 ALTCRF=20 ALT_TARGET=1024 ALTMETHOD=0 ALTAUTOCROP=0 MKV_CHAPTERS=1 MKV_MUXSUPS=1 FORCE_NOENCODE=0 RESIZE_720=0 NEROAAC=0 IGNORE_3D=0 FRIMSOURCE=1 OUTPUT_SBS=0 SUPTITLE=0 [Paths] WORKING_PATH=F:\BD_REBUILDER WORKFILES\ SOURCE_PATH=X:\ DirectShowMVCSource=D:\Utilities\BD_Rebuilder\Tools\stereoplayer.exe\DirectShowMVCSource.dll Code:
[Status] LABEL=ALICE_IN_WONDERLAND3D VERSION=v0.47.04 (beta) SOURCE_SIZE=44661672883 SOURCE_VIDEO_SIZE=42371119104 TARGET_SIZE=24641536000 REDUCTION=.527505118902795 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=all KEEP_HD_AUDIO=-1 SUBS_TO_KEEP=all BACKUP_MODE=0 MOVIEONLY_TYPE=0 USE_LAVF=0 INSTANCES=4 DGDECNV=0 FRIMSOURCE=-1 SSIF_MODE=-1 QUICK=0 ENCODE_STEP=0 COMPLETED=3 REBUILD_COMPLETE=1 [00008] AUDIO=1 PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=94154043 RATE=20556 NSTART=27000000 NEND=28482731 NSIZE=84019200 FLINK=0 MLINK=0 [00115] AUDIO=1111111 PGS=11111111111111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=12166480964 RATE=17417 NSTART=27000000 NEND=184385353 NSIZE=11518476288 FLINK=-1 MLINK=0 [00117] AUDIO=1111111 PGS=11111111111111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=10090347215 RATE=16387 NSTART=27000000 NEND=162784398 NSIZE=9556285440 FLINK=0 MLINK=0 |
#19997 | Link | |
Mr
I have a movie-only of this I created on 4/6 that seems to play fine. I downloaded 47.03 on 3/29 and 47.04 on 4/7 so I am presuming I created it with 47.03. Unfortunately, I'm not sure what the INI and INF files contained for that build. Update: Just re-ran movie-only with 47.03 and it works ok. So it would appear that it is something that changed from 47.03 to 47.04 that is responsible. Last edited by dfsooner; 11th April 2014 at 19:05. |
#19998 | Link |
yes it, has done it on more than one. not sure when it started doing it.. it was fine last week. i don't if its a glitch in my system or what. i going to tackle it later today.. if you get the same results let me know. i have had issues in the past when it would resize the picture incorrectly.. but i fixed it by uninstalling everything and starting over from scratch.. and that using worked all the time
#19999 | Link | |
If you set FORCE_INMUX_3D=0 in the INI you should get the same output you would have gotten from v0.47.03 (an out-of-mux build).
jdobbs.softworks@gmail.com Last edited by jdobbs; 11th April 2014 at 21:45. |
#20000 | Link |
i got everything working correctly again
no more audio out of sync issues with the mkv imports. all i did was uninstall all the programs including bd-rebuilder and started over from scratch. i believe ffdshow was the problem. i am straight now thanks for your help jdobbs.
| Thread Tools | |
| Display Modes | |
