Old 20th May 2018, 17:48   #5361  |  Link
nevcairiel
If the file does not expose a range, then none is reported. Limited Range should always be assumed to be the default by the renderer in such a case.
nevcairiel is online now   Reply With Quote
Old 20th May 2018, 18:27   #5362  |  Link
v0lt
@nevcairiel
Yes, but we got a more correct result if the decoder reports the nominal range. I do not remember the exact reason why we did this (maybe it was the effect of the settings of the video driver, it sometimes does not work as expected by the user).
I will not deny that the EVR-CP in this case may not work correctly. But the solution to this problem is not obvious, and other negative effects may appear.
v0lt is offline   Reply With Quote
Old 21st May 2018, 17:00   #5363  |  Link
beter
Update for translation of Chinese (Traditional/Simplified) and Dutch
https://www.sendspace.com/file/b3wsda
beter is offline   Reply With Quote
Old 22nd May 2018, 17:52   #5364  |  Link
v0lt
@Klaus1189
Thanks. Updated in r3647.
@beter
Thanks. Updated in r3650.
Old 23rd May 2018, 08:19   #5365  |  Link
ryrynz
ryrynz's Avatar
With the improvements made to the mpc audio renderer I've switched from sanear. Aleksoid, have you compared them at all? Look at the code or found any benefits with either over the other?
Old 24th May 2018, 04:14   #5366  |  Link
v0lt
MPC-BE 1.5.2 (build 3656) beta with a digital signature was released. (SF.net)
Old 24th May 2018, 18:50   #5367  |  Link
bozek
When I was installing that version I received two error dialogs (with OK button only). 'Runtime Error' and 'Out of Space (.)' error
bozek is offline   Reply With Quote
Old 24th May 2018, 19:13   #5368  |  Link
Klaus1189
No problem on my computer with Windows 10 Pro 1709 64-bit and MPC-BE 1.5.2 (build 3656) beta x64 build from SF.net.
What OS do you use? Not only (for example) "Windows 10", please complete like "Windows 10 Pro 1803 64-bit"
Can you upload a screenshot on google drive or similar and post link here, do not attach the file here, other users won't see the pictures.
Old 24th May 2018, 19:14   #5369  |  Link
v0lt
@bozek
I can not confirm (MPC-BE 1.5.2 (build 3656) beta x64, Win7sp1).
Please make a screenshot of these errors.
Old 24th May 2018, 23:21   #5370  |  Link
bozek
I should've stated that the installation was completed so those error dialogs were probably irrelevant. During the second installation I only received one of them.
Old 25th May 2018, 12:10   #5371  |  Link
Klaus1189
1.) Do have another computer you can run MPC-BE 1.5.2 (build 3656) beta x64 build installer from SF.net?
2.) On the computer with this error dialog: Uninstall MPC-BE completely, then reboot and run installer again. -> what happens?
3.) Did you "install" (run installer) a previous version just like that or unzipped you the portable version of the older one?
Old 25th May 2018, 16:00   #5372  |  Link
v0lt
@bozek
Run the installer this way.
MPC-BE.1.5.2.3656.x64.exe /LOG=mpcbe_install.log
And upload somewhere the resulting log file.
Old 25th May 2018, 18:32   #5373  |  Link
bozek
https://pastebin.com/YeSLbzvK
When I tried to install the x86 on another computer I got the second error dialog as well.
Old 25th May 2018, 19:30   #5374  |  Link
v0lt
@bozek
I think the problem is related to the need to reboot due to the unavailability to remove MPCBEShellExt64.dll.
Old 25th May 2018, 19:57   #5375  |  Link
bozek
I don't think it is. Here is another attempt after uninstallation and reboot.
https://pastebin.com/FzgYHYKr
Like I said, the installation is completed everytime and the program works just fine so it's probably a wild goose chase.
Old 26th May 2018, 05:04   #5376  |  Link
v0lt
@bozek
Ok. Now I think the problem is in the PinToTaskbar function. It uses cscript.exe and this can be a problem.
Try to disable the "Pin to Taskbar" option during installation.
Old 26th May 2018, 06:47   #5377  |  Link
beter
MPC-BE freezes when playing this video with corrupted DVB subtitles.
In the sample below, the DVB subpicture at 00:00:10 is badly received due to signal problem, but MPC-HC 1.7.11 can show it without crashing. Meanwhile MPC-BE cannot show the subtitle, starts eating CPU resources and freezes/crashes after seeking.
https://www.sendspace.com/file/gzcfe4
The corrupted subpicture:
Old 26th May 2018, 09:16   #5378  |  Link
v0lt
@beter
I fixed the freeze in r3672.
Old 26th May 2018, 15:49   #5379  |  Link
bozek
Originally Posted by v0lt View Post
@bozek
Nah, that's not it either. When I install, then on the page 'select additional tasks' I leave everything unchecked.
Old 26th May 2018, 18:04   #5380  |  Link
v0lt
bozek
Hmm. Please make a log with v1.5.2.3670 or newer - https://yadi.sk/d/UPpCf3tx3SciJK
