#22 | Link |
SVT-AV1 2 pass still doesn't work properly with a higher target bitrate. I set -tbr for 10 mbps and the resulting encode is only 4-5 mbps.
Both -rc 2 (4.6 mbps) and -rc 3 (3.8 mbps). Last edited by quietvoid; 9th November 2019 at 17:16. |
#24 | Link |
Derek Prestegard IRL
![]() Join Date: Nov 2003
I get some really bad dealbreaker artifacts at high bitrates using fast presets though. For example, my smoke test at QP 30 with enc-mode 8 through 5 has really bad glitches in certain parts of the frame. These should not be happening at 12 Mbps
![]() They clear up at enc-mode 4 https://imgur.com/a/46Oeofq Last edited by Blue_MiSfit; 10th November 2019 at 03:37. |
#25 | Link | |||
Trimmed 500 frames of a BT.709 1080p 8-bit SDR clip, ran these two lines: Quote:
#26 | Link |
Maybe some weird edge case with y4m input? I've been doing my tests with raw yuv.
Try this exact 2 pass command (my documentation PR just got merged )https://github.com/OpenVisualCloud/S...-command-lines |
#27 | Link |
2 pass will only work for me if I specify the number of frames to encode (-n). Otherwise 1st pass works fine but 2nd pass freezes at first frame. But I've noticed I've had the following error several times : "Error in freed returnVal 0"
#28 | Link | ||
![]() I've tried again with the example CLI and it behaves the same. I'll just give up, I don't think it's implemented properly yet. I had asked 4 months ago on another site and got this response: Quote:
#30 | Link |
Yes, using -q does change the bitrate. It's only -tbr not reaching the target bitrate.
The sample isn't special, I've tried with 24 frames scenes, 500 frames of one scene and multiple samples. I'm sure I could reproduce it with Tears of Steel but I'll wait for a couple PRs to be merged first (including the kbps one )-tbr has never worked for me, 2 pass still hasn't changed that. Last edited by quietvoid; 13th November 2019 at 22:54. |
#31 | Link |
Ryzen 3950X is very fast on SVT-AV1, no doubt about it, it's even faster than latest HEDT from Intel Core i9-10980XE which has 2 more cores, BUT Threadripper's devastating performance is simply out of this world.
It's three times faster than previous Threadripper 32C and two times faster than latest Intel 18C
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all Last edited by NikosD; 25th November 2019 at 18:34. |
#33 | Link |
Artem S. Tashkinov
SVT-AV1 0.75 is out with a long list of changes.
I've compared it to x265 at a similar bitrate and x265 came up on top - a lot more details were generally preserved and SVT-AV1 output is kinda blurry/too smooth. Code:
ffmpeg -i source.mkv -vf fps=30 -an -c:a copy -c:v libx265 -preset veryslow \ -x265-params keyint=600:min-keyint=30:bframes=16:crf=20:no-sao=1 265.mkv ffmpeg -hide_banner -loglevel panic -nostats -i source.mkv -nostdin -f rawvideo -pix_fmt yuv420p - \ | ./SvtAv1EncApp -i stdin -w 1280 -h 720 -n 25038 -b out.av1 -enc-mode 1 -q 24 -rc 0 -intra-period 250 Maybe there are flags to retain details better but I didn't find them. enc-mode 0 is even slower and basically impossible to use. Last edited by birdie; 26th November 2019 at 12:06. |
#35 | Link |
I'm actually more shocked to see a performance graph that actually uses an FPS metric than anything. I got frustrated and stopped looking at such charts because they always had useless, or obscure metrics that involve extra math to find out what the performance is; and that's on top of them not even telling you the encode settings or other critical information
Someone should ask Toms what the hell "1080p encoder mode 4 to AV1 encode" even means and if they speak english. |
#36 | Link | |
Version 0.8.0, still getting final bitrates way off of the target I set.
#37 | Link |
Running Linux, tested by Phoronix.
https://i.postimg.cc/nL6c7W9H/svt-av1-39xx-9900.png
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
#38 | Link |
Angel of Night
![]() Join Date: Nov 2004
SVT-AV1 0.8.1 has been released. Mostly a bugfix release, plus 10-bit palette support for screen coding.
#39 | Link |
Does anyone know how the SVT-AV1 Gui does 2pass?
2 times the same speed or first pass at speed 8? |
#40 | Link | |
Angel of Night
| Thread Tools | |
| Display Modes | |
