#101 | Link |
Testeur de codecs
You can change priority to "high" at each encoding time or change the priority in register:
https://www.youtube.com/watch?v=8FN8HcLa87A
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 |
#102 | Link |
|-----------------------------------------------------------------|-------------------------------------------------- | CPU | AMD Ryzen 5 5600X 6-Core Processor |-----------------------------------------------------------------|-------------------------------------------------- | H264 - x264 - 1080p - HDR - Multipart encoding - 1611 frames | 134.768 s |-----------------------------------------------------------------|-------------------------------------------------- | H265 - x265 - 1080p - HDR - Multipart encoding - 1611 frames | 168.442 s |-----------------------------------------------------------------|-------------------------------------------------- | AV1 - SVT-AV1 - 1080p - HDR - Multipart encoding - 1611 frames | 197.742 s |-----------------------------------------------------------------|-------------------------------------------------- | H266 - VVEnc - 1080p - HDR - Multipart encoding - 1611 frames | 318.505 s |-----------------------------------------------------------------|-------------------------------------------------- | Overall - 1080p - HDR - ABR Ladder encoding - 1611 frames | 826.828 s |-----------------------------------------------------------------|-------------------------------------------------- Stock cooler, ASUS Prime X570-Pro , 2x8GB DDR4-2400 ECC, Win 8.1 |
#106 | Link |
|-----------------------------------------------------------------|-------------------------------------------------- | CPU | Ryzen Threadripper 9970X 32-Cores |-----------------------------------------------------------------|-------------------------------------------------- | H264 - x264 - 1080p - HDR - Multipart encoding - 1611 frames | 17.892 s |-----------------------------------------------------------------|-------------------------------------------------- | H265 - x265 - 1080p - HDR - Multipart encoding - 1611 frames | 23.863 s |-----------------------------------------------------------------|-------------------------------------------------- | AV1 - SVT-AV1 - 1080p - HDR - Multipart encoding - 1611 frames | 27.758 s |-----------------------------------------------------------------|-------------------------------------------------- | H266 - VVEnc - 1080p - HDR - Multipart encoding - 1611 frames | 55.586 s |-----------------------------------------------------------------|-------------------------------------------------- | Overall - 1080p - HDR - ABR Ladder encoding - 1611 frames | 167.228 s |-----------------------------------------------------------------|--------------------------------------------------
My github... |
#107 | Link |
And faster than my AMD Ryzen Threadripper PRO 7975WX 32-Cores, as should be expected. There is nevertheless around 20%, not bad, but not worth spending again around 5000$...
My github. |
#108 | Link | |
Testeur de codecs
![]() Really impressive result for this 9970X .... simply 2 times more powerful than the previous 3970x. My Advanced Benchmark v.2 is simply the only benchmark in area that is currently able to show the real encoding power with such Threadripper CPUs. And this will be particularly the case with the next generation of Intel's next-gen "Nova Lake-S" CPUs, which will have up to 52 cores.
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 Last edited by Sagittaire; 16th September 2025 at 22:07. |
#109 | Link |
Testeur de codecs
Nobody to bench the Intel 285K ... ???
I'am really curious to see result versus 14900K and 9950X ...
#111 | Link |
Given that Ryzen does much better in Linux, would be nice to get comparative results..
for instance, Phoronix tests for 9950x - https://www.phoronix.com/review/wind...-ubuntu-2510/6 |
#113 | Link | |
![]() Join Date: Jan 2006
https://www.phoronix.com/review/wind...-ubuntu-2510/4 |
#114 | Link | |
#115 | Link |
IFP is enabled. For better performance, AlfUnitSize is adjusted to the CTUSize. Using IFP at low number of threads (<12) does not provide more speedup, consider disabling IFP. run.sh: line 82: warning: command substitution: ignored null byte in input |-----------------------------------------------------------------|-------------------------------------------------- | CPU | Intel(R) Core(TM) i7-14700KF |-----------------------------------------------------------------|-------------------------------------------------- | H264 - x264 - 1080p - HDR - Multipart encoding - 1611 frames | 50.279 s |-----------------------------------------------------------------|-------------------------------------------------- | H265 - x265 - 1080p - HDR - Multipart encoding - 1611 frames | 61.127 s |-----------------------------------------------------------------|-------------------------------------------------- | AV1 - SVT-AV1 - 1080p - HDR - Multipart encoding - 1611 frames | 68.972 s |-----------------------------------------------------------------|-------------------------------------------------- | H266 - VVEnc - 1080p - HDR - Multipart encoding - 1611 frames | 119.728 s |-----------------------------------------------------------------|-------------------------------------------------- | Overall - 1080p - HDR - ABR Ladder encoding - 1611 frames | 336.502 s |-----------------------------------------------------------------|-------------------------------------------------- |
#116 | Link | |
Testeur de codecs
The result should be closer to a 14900K with only 4 fewer ECore.
#118 | Link |
Testeur de codecs
14900K at stock frequencies produce these result:
|-----------------------------------------------------------------|-------------------------------------------------- | CPU | Core i9-14900K |-----------------------------------------------------------------|-------------------------------------------------- | H264 - x264 - 1080p - HDR - Multipart encoding - 1611 frames | 33.965 s |-----------------------------------------------------------------|-------------------------------------------------- | H265 - x265 - 1080p - HDR - Multipart encoding - 1611 frames | 43.507 s |-----------------------------------------------------------------|-------------------------------------------------- | AV1 - SVT-AV1 - 1080p - HDR - Multipart encoding - 1611 frames | 51.432 s |-----------------------------------------------------------------|-------------------------------------------------- | H266 - VVEnc - 1080p - HDR - Multipart encoding - 1611 frames | 86.797 s |-----------------------------------------------------------------|-------------------------------------------------- | Overall - 1080p - HDR - ABR Ladder encoding - 1611 frames | 241.588 s |-----------------------------------------------------------------|-------------------------------------------------- Are you sure that your 14700KF is at stock frequencies? You must don't use another application during bench for best result.
#119 | Link | |
yes, everything is stock. No over or underclocking afaik!
Windows 11, beta run Quote:
#120 | Link |
Another Ryzen to the chart, my first buy.
|-----------------------------------------------------------------|-------------------------------------------------- | CPU | Ryzen 5 8645HS w/ Radeon 760M Graphics |-----------------------------------------------------------------|-------------------------------------------------- | H264 - x264 - 1080p - HDR - Multipart encoding - 1611 frames | 131.440 s |-----------------------------------------------------------------|-------------------------------------------------- | H265 - x265 - 1080p - HDR - Multipart encoding - 1611 frames | 143.743 s |-----------------------------------------------------------------|-------------------------------------------------- | AV1 - SVT-AV1 - 1080p - HDR - Multipart encoding - 1611 frames | 173.557 s |-----------------------------------------------------------------|-------------------------------------------------- | H266 - VVEnc - 1080p - HDR - Multipart encoding - 1611 frames | 253.541 s |-----------------------------------------------------------------|-------------------------------------------------- | Overall - 1080p - HDR - ABR Ladder encoding - 1611 frames | 669.482 s |-----------------------------------------------------------------|-------------------------------------------------- |
| Tags |
| av1, benchmark, codec comparison, x264, x265 |
| Thread Tools | |
| Display Modes | |
