Thread Tools Display Modes
Old 30th July 2008, 15:07   #1  |  Link
elguaxo
elguaxo's Avatar
x264's SAR or MKV's DAR?
If I encode with x264 to MKV and use a custom SAR is it really stored in the AVC stream or is MKV's DAR used instead?
I did an anamorphic encode via MeGUI which resulted in a weird AR (it's a documented bug of the MeGUI version I'm currently using). I wanted to fix it via MKVToolnix remuxing and setting the correct DAR. Then I thought something weird might happen if the stream has one SAR and the container is specifying a different AR via DAR. But if I extract the rawstream out of the MKV with weird AR and open it via DGAVCIndex I get: SAR: Unspecified. So I wonder if the AR was stored just at the container level.
elguaxo is offline   Reply With Quote
Old 30th July 2008, 15:17   #2  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
in the avc stream.
mkvmerge removes the AR from the stream and places it into the container.
Old 30th July 2008, 15:20   #3  |  Link
martino
masktools2 (ab)user
martino's Avatar
Does it really remove it? I was in the through that it is kept, so even after doing AVC (w/ --sar) -> MKV/MP4 -> AVC -> MKV/MP4 the correct AR would be still kept since it's present in the AVC stream... Or is my memory going bad. :/
martino is offline   Reply With Quote
Old 30th July 2008, 15:21   #4  |  Link
elguaxo
elguaxo's Avatar
that solves the mystery! thanks.
Old 30th July 2008, 15:32   #5  |  Link
buzzqw
HDConvertToX author
or you can use the --engage keep_bitstream_ar_info in mkvmerge
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 30th July 2008, 15:35   #6  |  Link
elguaxo
elguaxo's Avatar
good to know. thanks buzzqw!
Old 30th July 2008, 15:42   #7  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
it removes the AR from the bitstream and places it in the container, how many times i have to repeat that?
you can do as buzzqw sugested to change the default behaviour
Old 30th July 2008, 15:50   #8  |  Link
martino
masktools2 (ab)user
martino's Avatar
Ugh calm down... I was merely saying something, nothing more... :V
Old 30th July 2008, 15:53   #9  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
k, np. sorry. however search before posting. that info is already available in other threads too.
Old 31st July 2008, 00:34   #10  |  Link
Brother John
(schein)heilig
Brother John's Avatar
The removal doesn’t happen for all input types, though, as mosu explained some time ago in the German forum. I’m sure about raw AVC input and I think it was MP4 as well, but not other formats.
Brother John
When lost in BeSweet's options, have a look at the Commandline Reference.
DVD nach MPEG-4 klappt nicht? Verzweifelt? Auf zum Encodingwissen!
Brother John is offline   Reply With Quote
dar, mkv, sar, x264
Thread Tools
